How to change color scheme on manjaro i3wm?
Can i change the color scheme in application such as manjaro-setting-manager and notification such as volume icon notification to another color scheme?
If it is possible, then how to change those color scheme?
Thanks.
Generally speaking you change the GTK theme - which would then reflect on the appearance of the mentioned apps.
But as the settings manager is a Qt application - you may have to adjust Kvantum theme settings - and maybe you need lxappearance to change gtk2 settings.
I am really - really not into tiling window manager so i3 is way out of my league - but I can tell you which files could possibly hold those configs
Not all systems has these files
  • ~/i3 (or ~/.config/i3)
  • ~/.gtkrc-2.0
  • ~/.config/gtk-3.0/settings.ini (gtk.css)
  • ~/.config/Kvantum/kvantum.kvconfig
  • ~/.config/qt5ct.conf
Then there is notifications which are configured using either command line arguments or separate config files
  • ~/.config/dunst/dunstrc
The same for rofi and dmenu and the list goes on and on …
Thanks, i’ll try to change those files and see if it works…
In addition to what @linux-aarhus already wrote, another config file to edit, especially for the appearance of the default terminal (urxvt) and terminal-based applications, is
  • ~/.Xresources
The section of the file to edit is this one (lines 17-55).
