I remember your own ISO using manjaro-tools-iso-git
and iso-profile
I remember there is a Manjaro Wiki which tells how to build it but I cannot find it now.
I search for ‘ISO’ ‘iso-profile’ or ‘manjaro-tools-iso’ and find nothing
Thanks!
and iso-profile
Thanks!
It is important to use the same version of the tools for dependencies.
E.g. manjaro-tools-iso depends on manjaro-tools-yaml and manjaro-tools-base
To use the git version You will have to install the git versions of the other packages as well otherwise the result will be unpredicatable
So either
sudo pacman -Syu manjaro-tools-iso manjaro-tools-yaml manjaro-tools-base
Or
sudo pacman -Syu manjaro-tools-iso-git manjaro-tools-yaml-git manjaro-tools-base-git
To get the profiles use git
~$ git clone https://gitlab.manjaro.org/profiles-and-settings/iso-profiles manjaro-iso-profiles
Then copy the folder /etc/manjaro-tools to your home/.config
cp -r /etc/manjaro-tools /home/$USER/manjaro-tools
Set up a pointer to the iso-profile dir
echo "run_dir=/home/$USER/manjaro-iso-profiles" > /home/$USER/manjaro-tools/iso-profiles.conf
Modify you preferred profile in /home/$USER/manjaro-iso-profiles and build it
