My goal is to always suspend-then-hibernate system-wide bc I don’t use this laptop often and don’t want it to run out of battery all the time.
I figured out a way to achieve this and wanted to share. Lmk if anyone thinks it’s a bad idea!
Approach 1: Overides the ExecStart value to suspend-then-hibernate
sudo mkdir /etc/systemd/system/systemd-suspend.service.d
print "[Service]\nExecStart=\nExecStart=/usr/lib/systemd/systemd-sleep suspend-then-hibernate" | sudo tee /etc/systemd/system/systemd-suspend.service.d/override.conf > /dev/null
sudo systemctl daemon-reload
Approach 2: symlink
ln -s /usr/lib/systemd/system/systemd-suspend-then-hibernate.service /etc/systemd/system/systemd-suspend.service
