I’m using a HiDPI screen and some apps (specifically bcrawl) don’t scale properly. QT_SCALE_FACTOR and GDK_SCALE don’t seem to work.
Hi there … I wrote a thing … which starting from a default setup should scale the things correctly for you:
(IE - please remove any augmentations before using)
