How to add disk in steam? not showing my disk to "Add library folder"
how to add disk in steam? not showing my disk to “Add library folder”
You have to mount your disks preferably on boot (or at minimum before starting steam or else it will not work if the library is on an unmounted disk). Then in Steam Settings you add your library by browsing to the proper path (Settings → Downloads → Libraries)
