I would like to know how to add in bootsplash with the manufacturer logo showing up. How to configure it with either the terminal, UEFI/BIOS, or both? Thanks.
Installing bootsplash-manager
from Add/Remove Software is the easiest way.
There are several themes available as well, search for bootsplash-theme
After the latest updates on the unstable branch, no longer works.
