How to add an UFW status icon to the panel
#1
With this recipe you can add an icon to your panel showing the state of UFW.
gufw_icon
Requisites , install yad and gufw
sudo pacman -S yad gufw
Then copy this bash script:
to some directory (example /home/$USER/Documents)
cd /home/${USER}/Documents
wget https://github.com/juanmafont/ufwIconbar/raw/master/gufw_icon.sh
then
chmod +x gufw_icon.sh
and goto settings->session and startup->application autostart->add
Description: Will show an icon on status bar with state of UFW
Command: /home/username/Documents/gufw_icon.sh
Note: above, substitute “username” with your username, to know your username open terminal and enter : echo $USER
Finally, logout and login again… you will see an new icon showing the state of your firewall (UFW)
Note: I’m using MOKA icon theme. The icon theme you use must have two icons named:
security-high and security-low
You can select the icon you prefer changing lines into script. See where is said “security-high” and “security-low” and replace it with your favourite icon (use full path is needed)
Note: If you click over the icon, gufw gui will be launch :wink:
Create KDE "program status" widget?
Open GUFW at startup without having to enter password?
yad: error while loading shared libraries
New to the forum, introduce yourself
#2
This should probably be in:
https://forum.manjaro.org/c/technical-issues-and-assistance/tutorials
#3
Yes, I try it, but I can create new tutorial, not enough rights… :wink:
Please, if anyone can move it to tutorials I would appreciate it.
SECOND: Can someone change the title topic to " How to add an UFW status icon to the panel bar"
Thanks.
#4
Renamed thread, almost as requested. :grinning:
closed #5
