By default, Gnome has 3-finger system-wide touch gestures. This does not make sense to me (and many others). It should be 4-fingers. This way, 3-finger gestures can be used within applications such as browsers.
However, whether installed via browser or manually: it is only installed for the current user. How can I install it globally for all users that might be created in the future?
Gnome Help isn’t very helpful for Manjaro as I cannot do step 4, that path does not exist: https://help.gnome.org/admin/system-admin-guide/stable/extensions-enable.html.en
Since Manjaro Gnome already includes several global Gnome extensions by default, how can I add 1 extension to that list and make sure this extension is also activated for future users?
Thanks so much!!
Now if only it would become default part of Manjaro Gnome… strangely X11 Gestures is still installed by default, even though it does not work on Wayland…
Hey, you asked for it to be in the AUR, not the Manjaro repos. Also having conflicting gesture extensions wouldn’t work out very well. Gestures work out of the box in a Wayland session. In Xorg, they do not.
