hello
i installed Vmware from the AUR with git clone and makepkg -is.
i see in pamac that there’s an upgrade available;
is there something specific i should do,or doing it through pamac is ok?
i also have optimus-manager-qt i installed from the AUR,but i installed it through pamac and upgrade it from there.
is there a difference between installing an AUR package the way i did with Vmware vs doing it from pamac,or is it the same?
there were some instructions in the PKGBUILD about commenting or un-commenting some lines for extra functionalities which i did.
so if i do it in pamac then i have to do it again in the “build files”/PKGBUILD?
where should i add the groups=('modified') line in the PKGBUILD?
i saw i could also edit /etc/pacman.conf and add the name of the package to the IgnorePkg line.
Thank you
i ended up upgrading through pamac and editing the build files there.
i tried “git pull” first, but i got a warning or error about PKGBUILD and swap or commit(i don’t remember) and didn’t know what to do/choose.
