inxi -zv8 ✔
Kernel: 5.10.221-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 14.1.1
root=UUID=cf91cf20-ab16-4e38-abc6-4222c1cf2929 ro quiet apparmor=1
security=apparmor resume=UUID=a3fd6cf2-dd64-4f65-bc0b-81cd05ad3f2f
udev.log_priority=3
Desktop: KDE Plasma v: 6.0.5 tk: Qt v: N/A info: frameworks v: 6.3.0
Type: Desktop System: ASUS product: All Series v: N/A
serial: <superuser required>
Mobo: ASUSTeK model: SABERTOOTH Z97 MARK 1 v: Rev 1.xx
serial: <superuser required> part-nu: All uuid: <superuser required>
UEFI: American Megatrends v: 2702 date: 10/27/2015
System RAM: total: 16 GiB available: 15.57 GiB used: 7.77 GiB (49.9%)
Array-1: capacity: 32 GiB slots: 4 modules: 4 EC: None
Device-1: DIMM_A1 type: DDR3 detail: synchronous size: 4 GiB
speed: 1333 MT/s volts: curr: 1.65 min: 2 max: 2 width (bits): data: 64
total: 64 manufacturer: 1302 part-no: 1333EL Series serial: N/A
Device-2: DIMM_A2 type: DDR3 detail: synchronous size: 4 GiB
Device-3: DIMM_B1 type: DDR3 detail: synchronous size: 4 GiB
Device-4: DIMM_B2 type: DDR3 detail: synchronous size: 4 GiB
Info: model: Intel Core i7-4790 bits: 64 type: MT MCP arch: Haswell
gen: core 4 level: v3 note: check built: 2013-15 process: Intel 22nm
family: 6 model-id: 0x3C (60) stepping: 3 microcode: 0x28
L3: 8 MiB desc: 1x8 MiB
Speed (MHz): avg: 3837 high: 3923 min/max: 800/4000 scaling:
driver: intel_cpufreq governor: schedutil cores: 1: 3767 2: 3901 3: 3734
4: 3818 5: 3868 6: 3813 7: 3878 8: 3923 bogomips: 57616
Flags: abm acpi aes aperfmperf apic arat arch_perfmon avx avx2 bmi1 bmi2
bts clflush cmov constant_tsc cpuid cpuid_fault cx16 cx8 de ds_cpl dtes64
dtherm dts epb erms est f16c flush_l1d fma fpu fsgsbase fxsr ht ibpb ibrs
ida invpcid invpcid_single lahf_lm lm mca mce md_clear mmx monitor movbe
msr mtrr nonstop_tsc nopl nx pae pat pbe pcid pclmulqdq pdcm pdpe1gb pebs
pge pln pni popcnt pse pse36 pti pts rdrand rdtscp rep_good sdbg sep smep
smx ss ssbd sse sse2 sse4_1 sse4_2 ssse3 stibp syscall tm tm2 tsc
tsc_adjust tsc_deadline_timer vme x2apic xsave xsaveopt xtopology xtpr
Type: itlb_multihit status: KVM: VMX unsupported
prctl and seccomp
STIBP: conditional, RSB filling, PBRSB-eIBRS: Not affected
Device-1: NVIDIA GP106 [GeForce GTX 1060 6GB] vendor: Gigabyte
driver: nvidia v: 550.100 alternate: nouveau,nvidia_drm non-free: 545.xx+
status: current (as of 2024-06; EOL~2026-12-xx) arch: Pascal code: GP10x
process: TSMC 16nm built: 2016-2021 pcie: gen: 3 speed: 8 GT/s lanes: 16
bus-ID: 01:00.0 chip-ID: 10de:1c03 class-ID: 0300
Display: x11 server: X.Org v: 21.1.13 with: Xwayland v: 24.1.1
compositor: kwin_x11 driver: X: loaded: nvidia gpu: nvidia display-ID: :0
screens: 1
Screen-1: 0 s-res: 4480x1440 s-dpi: 108 s-size: 1054x342mm (41.50x13.46")
s-diag: 1108mm (43.63")
Monitor-1: DP-1 pos: primary,right res: 1920x1080 hz: 60 dpi: 81
size: 600x340mm (23.62x13.39") diag: 690mm (27.15") modes: N/A
Monitor-2: HDMI-0 pos: left res: 2560x1440 dpi: 109
size: 597x336mm (23.5x13.23") diag: 685mm (26.97") modes: N/A
API: EGL v: 1.5 hw: drv: nvidia platforms: device: 0 drv: nvidia device: 2
drv: swrast gbm: drv: kms_swrast surfaceless: drv: nvidia x11: drv: nvidia
inactive: wayland,device-1
API: OpenGL v: 4.6.0 compat-v: 4.5 vendor: nvidia mesa v: 550.100
glx-v: 1.4 direct-render: yes renderer: NVIDIA GeForce GTX 1060
6GB/PCIe/SSE2 memory: 5.86 GiB
API: Vulkan v: 1.3.279 layers: 5 device: 0 type: discrete-gpu name: NVIDIA
GeForce GTX 1060 6GB driver: nvidia v: 550.100 device-ID: 10de:1c03
surfaces: xcb,xlib
Device-1: Intel 9 Series Family HD Audio vendor: ASUSTeK
driver: snd_hda_intel v: kernel bus-ID: 00:1b.0 chip-ID: 8086:8ca0
class-ID: 0403
Device-2: NVIDIA GP106 High Definition Audio vendor: Gigabyte
bus-ID: 01:00.1 chip-ID: 10de:10f1 class-ID: 0403
Device-3: Creative Labs EMU20k2 [Sound Blaster X-Fi Titanium Series]
driver: snd_ctxfi v: kernel pcie: gen: 1 speed: 2.5 GT/s lanes: 1
bus-ID: 05:00.0 chip-ID: 1102:000b class-ID: 0403
API: ALSA v: k5.10.221-1-MANJARO status: kernel-api with: aoss
Server-2: PipeWire v: 1.2.1 status: off with: pipewire-media-session
status: active tools: pw-cli
Server-3: PulseAudio v: 17.0 status: active with: 1: pulseaudio-alsa
type: plugin 2: pulseaudio-jack type: module tools: pacat,pactl
Device-1: Intel Ethernet I218-V vendor: ASUSTeK driver: e1000e v: kernel
port: f040 bus-ID: 00:19.0 chip-ID: 8086:15a1 class-ID: 0200
vendor: ASUSTeK AM1I-A driver: r8169 v: kernel pcie: gen: 1 speed: 2.5 GT/s
lanes: 1 port: d000 bus-ID: 06:00.0 chip-ID: 10ec:8168 class-ID: 0200
IF: enp6s0 state: down mac: <filter>
Device-3: Intel Wi-Fi 5 Wireless-AC 9x6x [Thunder Peak] driver: iwlwifi
v: kernel pcie: gen: 2 speed: 5 GT/s lanes: 1 bus-ID: 0a:00.0
chip-ID: 8086:2526 class-ID: 0280
IF: wlp10s0 state: up mac: <filter>
Device-1: Intel Wireless-AC 9260 Bluetooth Adapter driver: btusb v: 0.8
type: USB rev: 2.0 speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 3-8:2
chip-ID: 8087:0025 class-ID: e001
Report: rfkill ID: hci0 rfk-id: 1 state: down bt-service: enabled,running
Local Storage: total: 1.82 TiB used: 143.33 GiB (7.7%)
ID-1: /dev/sda maj-min: 8:0 vendor: Samsung model: SSD 860 EVO 500GB
tech: SSD serial: <filter> fw-rev: 1B6Q scheme: GPT
ID-2: /dev/sdb maj-min: 8:16 vendor: Seagate model: ST31000524AS
tech: HDD rpm: 7200 serial: <filter> fw-rev: JC45 scheme: MBR
ID-3: /dev/sdc maj-min: 8:32 vendor: Samsung model: SSD 870 EVO 500GB
ID-1: / raw-size: 448.33 GiB size: 440.22 GiB (98.19%)
used: 143.33 GiB (32.6%) fs: ext4 dev: /dev/sdc2 maj-min: 8:34 label: N/A
uuid: cf91cf20-ab16-4e38-abc6-4222c1cf2929
used: 312 KiB (0.1%) fs: vfat dev: /dev/sdc1 maj-min: 8:33 label: N/A
uuid: E177-9383
ID-1: swap-1 type: partition size: 17.14 GiB used: 0 KiB (0.0%)
priority: -2 dev: /dev/sdc3 maj-min: 8:35 label: N/A
uuid: a3fd6cf2-dd64-4f65-bc0b-81cd05ad3f2f
ID-1: /dev/sda1 maj-min: 8:1 size: 300 MiB fs: vfat label: N/A
uuid: 124B-1E93
ID-2: /dev/sda2 maj-min: 8:2 size: 16 MiB fs: <superuser required>
label: N/A uuid: N/A
ID-3: /dev/sda3 maj-min: 8:3 size: 465.45 GiB fs: ntfs label: N/A
uuid: 7A4605234604E1AD
ID-4: /dev/sdb1 maj-min: 8:17 size: 931.5 GiB fs: ext4 label: Spare_HDD
uuid: b20f320b-bf4a-4a20-a58f-a788a7e0ee62
Hub-1: 1-0:1 info: full speed or root hub ports: 2 rev: 2.0
Hub-2: 1-1:2 info: Intel ports: 6 rev: 2.0 speed: 480 Mb/s (57.2 MiB/s)
lanes: 1 mode: 2.0 chip-ID: 8087:8009 class-ID: 0900
Hub-3: 2-0:1 info: full speed or root hub ports: 2 rev: 2.0
Hub-4: 2-1:2 info: Intel Integrated Hub ports: 8 rev: 2.0
speed: 480 Mb/s (57.2 MiB/s) lanes: 1 mode: 2.0 chip-ID: 8087:8001
Hub-5: 3-0:1 info: hi-speed hub with single TT ports: 14 rev: 2.0
Device-1: 3-8:2 info: Intel Wireless-AC 9260 Bluetooth Adapter
type: bluetooth driver: btusb interfaces: 2 rev: 2.0
Hub-6: 3-9:9 info: Genesys Logic Hub ports: 4 rev: 2.1
Device-1: 3-9.3:10 info: KnoblesseOblige Freebird60 type: keyboard,HID
lanes: 1 mode: 1.1 power: 500mA chip-ID: adad:fb60 class-ID: 0300
Device-2: 3-9.4:11 info: Ploopy Trackball type: keyboard,HID
driver: hid-generic,usbhid interfaces: 3 rev: 1.1 speed: 12 Mb/s (1.4 MiB/s)
lanes: 1 mode: 1.1 power: 100mA chip-ID: 5043:5442 class-ID: 0300
Hub-7: 4-0:1 info: super-speed hub ports: 6 rev: 3.0
Hub-8: 4-5:4 info: Genesys Logic Hub ports: 4 rev: 3.2
speed: 5 Gb/s (596.0 MiB/s) lanes: 1 mode: 3.2 gen-1x1 chip-ID: 05e3:0626
Hub-9: 5-0:1 info: hi-speed hub with single TT ports: 2 rev: 2.0
Hub-10: 6-0:1 info: super-speed hub ports: 2 rev: 3.0
System Temperatures: cpu: 48.0 C mobo: N/A
Fan Speeds (rpm): N/A
Packages: 1897 pm: pacman pkgs: 1886 libs: 547 tools: pamac,yay pm: flatpak
pkgs: 11
1: https://ridgewireless.mm.fcix.net/manjaro/stable/$repo/$arch
2: https://opencolo.mm.fcix.net/manjaro/stable/$repo/$arch
3: https://ftp.halifax.rwth-aachen.de/manjaro/stable/$repo/$arch
4: https://ftp.lysator.liu.se/pub/manjaro/stable/$repo/$arch
5: https://mirror.yandex.ru/mirrors/manjaro/stable/$repo/$arch
6: https://mirror.bouwhuis.network/manjaro/stable/$repo/$arch
7: https://mirror.freedif.org/Manjaro/stable/$repo/$arch
8: http://mirror.is.co.za/mirrors/manjaro.org/stable/$repo/$arch
Processes:
CPU top: 5 of 276
1: cpu: 37.8% command: firefox pid: 2054 mem: 1895.4 MiB (11.8%)
2: cpu: 8.5% command: firefox pid: 8115 mem: 676.7 MiB (4.2%)
3: cpu: 7.0% command: firefox pid: 17104 mem: 205.8 MiB (1.2%)
4: cpu: 7.0% command: firefox pid: 17166 mem: 244.4 MiB (1.5%)
5: cpu: 4.2% command: kwin_x11 pid: 1477 mem: 198.3 MiB (1.2%)
Memory top: 5 of 276
1: mem: 1895.4 MiB (11.8%) command: firefox pid: 2054 cpu: 37.8%
2: mem: 1844.2 MiB (11.5%) command: pamac-manager pid: 3058 cpu: 0.3%
3: mem: 676.7 MiB (4.2%) command: firefox pid: 8115 cpu: 8.5%
4: mem: 528.3 MiB (3.3%) command: spectacle pid: 16055 cpu: 1.3%
5: mem: 460.2 MiB (2.8%) command: plasmashell pid: 1504 cpu: 0.4%
Processes: 276 Power: uptime: 2h 26m states: freeze,mem,disk suspend: deep
suspend, test_resume image: 6.22 GiB services: org_kde_powerdevil,upowerd
Init: systemd v: 256 default: graphical tool: systemctl
Compilers: clang: 18.1.8 gcc: 14.1.1 Shell: Zsh v: 5.9 default: Bash
v: 5.2.26 running-in: konsole inxi: 3.3.35
This is what your /etc/shells
should look like…
# Pathnames of valid login shells.
# See shells(5) for details.
/bin/sh
/bin/bash
/bin/rbash
/bin/zsh
/usr/bin/sh
/usr/bin/bash
/usr/bin/rbash
/usr/bin/zsh
/usr/bin/git-shell
/usr/bin/systemd-home-fallback-shell
If you do not use systemd-homed
, then it would be safe to remove /usr/bin/systemd-home-fallback-shell
In this case, you should safely be able to click the left-facing pointer to merge, delete the middle green one from the left (as it’s covered by merging the bottom (blue) one and to be honest I’d leave the top one alone. Then save the one on the left (no need to save anything in the .pacnew).
They are both missing /usr/bin/zsh
. Not a problem just yet because of the symlink from /bin
to /usr/bin
, but those symlinks may end up disappearing from:the specifications at some point in the future, and then zsh
users wouldn’t be able to log in anymore.
I see it in the left pane, which is why I suggested to leave those in.
Sorry, my eyes are acting up today — aura.
Mine have been since my late 40s, unfortunately … and it’s the same with most people I know around my age. Although it varies quite a bit. a few months ago, I could not use the laptop without glasses; now I can, mostly. (also the case with others I know, it’s a bit of a “hot topic”).
Totally off-topic, but I’m not using a laptop. This is a desktop computer with a 27" monitor in 1920x1080 resolution.
Anyway, I gave the OP the content of what their /etc/shells
should look like. It’s up to them now.
One glass is enough, isn’t it? … Unless you wanted a chaser.
I’m finishing off a nice “tinny” just now, so I think I’ll be OK until it’s safe to take the covers off (sunset?) …
