Manjaro hanging at random
Greetings,
Recently, I have been experiencing issues with my computer hanging at random to the point where the SysRq keys do not work. For example, today my computer has locked up twice: when I opened a .mp4 file, and when I was playing the steam game Hacknet. I fear for my filesystem and the inconveniences that may come with my computer locking up at random. I’ve had to chroot into my computer twice so far due to my computer locking up during an update, and I’ve only been using Manjaro since October.
Here’s an inxi dump:
  Kernel: 6.1.26-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 12.2.1
    root=UUID=206c8d41-a472-47ba-b70d-5a64b7e9c848 rw quiet
    udev.log_priority=3
  Desktop: KDE Plasma v: 5.27.4 tk: Qt v: 5.15.9 wm: kwin_wayland vt: 2
  Type: Desktop System: Dell product: OptiPlex 3010 v: 01
    serial: <superuser required> Chassis: type: 6 serial: <superuser required>
  Mobo: Dell model: 042P49 v: A01 serial: <superuser required> BIOS: Dell
    v: A09 date: 01/31/2013
  System RAM: available: 15.59 GiB used: 3.06 GiB (19.6%)
  RAM Report: permissions: Unable to run dmidecode. Root privileges
    required.
  Info: model: Intel Core i5-3470 bits: 64 type: MCP arch: Ivy Bridge
    gen: core 3 level: v2 built: 2012-15 process: Intel 22nm family: 6
    model-id: 0x3A (58) stepping: 9 microcode: 0x21
  Topology: cpus: 1x cores: 4 smt: <unsupported> cache: L1: 256 KiB
    desc: d-4x32 KiB; i-4x32 KiB L2: 1024 KiB desc: 4x256 KiB L3: 6 MiB
    desc: 1x6 MiB
  Speed (MHz): avg: 2010 high: 2464 min/max: 1600/3200 scaling:
    driver: intel_cpufreq governor: schedutil cores: 1: 2307 2: 1674 3: 2464
    4: 1597 bogomips: 25549
  Flags: acpi aes aperfmperf apic arat arch_perfmon avx bts clflush cmov
    constant_tsc cpuid cpuid_fault cx16 cx8 de ds_cpl dtes64 dtherm dts epb
    ept erms est f16c flexpriority flush_l1d fpu fsgsbase fxsr ht ibpb ibrs
    lahf_lm lm mca mce md_clear mmx monitor msr mtrr nonstop_tsc nopl nx pae
    pat pbe pcid pclmulqdq pdcm pebs pge pln pni popcnt pse pse36 pti pts
    rdrand rdtscp rep_good sep smep smx ss ssbd sse sse2 sse4_1 sse4_2 ssse3
    stibp syscall tm tm2 tpr_shadow tsc tsc_deadline_timer vme vmx vnmi vpid
    x2apic xsave xsaveopt xtopology xtpr
    disabled
    STIBP: disabled, RSB filling, PBRSB-eIBRS: Not affected
  Type: srbds status: Vulnerable: No microcode
  Device-1: AMD Ellesmere [Radeon RX 470/480/570/570X/580/580X/590]
    vendor: PC Partner / Sapphire driver: amdgpu v: kernel arch: GCN-4
    code: Arctic Islands process: GF 14nm built: 2016-20 pcie: gen: 3
    speed: 8 GT/s lanes: 16 ports: active: DP-2 empty: DP-1, DVI-D-1,
    HDMI-A-1, HDMI-A-2 bus-ID: 01:00.0 chip-ID: 1002:67df class-ID: 0300
    temp: 45.0 C
  Display: wayland server: X.org v: 1.21.1.8 with: Xwayland v: 23.1.1
    compositor: kwin_wayland driver: X: loaded: amdgpu
    unloaded: modesetting,vesa alternate: fbdev dri: radeonsi gpu: amdgpu
    display-ID: 0
  Monitor-1: DP-2 model: Viewteck GFV24C built: 2019 res: 1920x1080 dpi: 92
    gamma: 1.2 size: 530x280mm (20.87x11.02") diag: 599mm (23.6") modes:
    max: 1920x1080 min: 720x400
  API: OpenGL v: 4.6 Mesa 23.0.3 renderer: AMD Radeon RX 470 Graphics
    (polaris10 LLVM 15.0.7 DRM 3.49 6.1.26-1-MANJARO) direct-render: Yes
    vendor: Dell driver: snd_hda_intel v: kernel bus-ID: 00:1b.0
    chip-ID: 8086:1c20 class-ID: 0403
  Device-2: AMD Ellesmere HDMI Audio [Radeon RX 470/480 / 570/580/590]
    vendor: PC Partner / Sapphire driver: snd_hda_intel v: kernel pcie: gen: 3
    speed: 8 GT/s lanes: 16 bus-ID: 01:00.1 chip-ID: 1002:aaf0 class-ID: 0403
  Device-3: C-Media TONOR TC-777 Audio Device
    driver: hid-generic,snd-usb-audio,usbhid type: USB rev: 1.1 speed: 12 Mb/s
    lanes: 1 mode: 1.1 bus-ID: 2-1.5:5 chip-ID: 0d8c:0134 class-ID: 0300
  API: ALSA v: k6.1.26-1-MANJARO status: kernel-api with: aoss
  Server-3: PipeWire v: 0.3.70 status: off with: pipewire-media-session
    status: active tools: pw-cli
  Server-4: PulseAudio v: 16.1 status: active with: pulseaudio-alsa
    type: plugin tools: pacat,pactl,pavucontrol
    vendor: Dell driver: r8169 v: kernel pcie: gen: 1 speed: 2.5 GT/s lanes: 1
    port: d000 bus-ID: 03:00.0 chip-ID: 10ec:8168 class-ID: 0200
  Device-1: Realtek Bluetooth Radio driver: btusb v: 0.8 type: USB rev: 1.1
    speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 2-1.4:4 chip-ID: 0bda:8771
  Supported mdraid levels: raid0
  Device-1: md126 maj-min: 9:126 type: mdraid level: raid-0 status: active
  Info: report: N/A blocks: 976224256 chunk-size: 64k
  Components: Online:
  0: sdb maj-min: 8:16 size: 931.51 GiB
  Device-2: md127 maj-min: 9:127 type: mdraid level: N/A status: inactive
  Info: report: N/A blocks: 538328 chunk-size: N/A
  Components: Online: N/A Spare:
  0: sdb maj-min: 8:16 size: 931.51 GiB state: S
  Local Storage: total: raw: 1.16 TiB usable: 252.35 GiB
    used: 695.18 GiB (275.5%)
  ID-1: /dev/sda maj-min: 8:0 vendor: PNY model: CS900 240GB SSD
    size: 223.57 GiB block-size: physical: 512 B logical: 512 B speed: 3.0 Gb/s
    tech: SSD serial: <filter> fw-rev: 0BB3 scheme: MBR
  ID-2: /dev/sdb maj-min: 8:16 vendor: Hitachi model: HUA722010CLA330
    size: 931.51 GiB block-size: physical: 512 B logical: 512 B speed: 3.0 Gb/s
    tech: HDD rpm: 7200 serial: <filter> fw-rev: A3EA
  ID-3: /dev/sdc maj-min: 8:32 model: N/A size: 29.3 GiB block-size:
    physical: 512 B logical: 512 B type: USB rev: 2.0 spd: 480 Mb/s lanes: 1
    mode: 2.0 tech: N/A serial: <filter> fw-rev: 2.00
  Optical-1: /dev/sr0 vendor: HL-DT-ST model: DVD+-RW GHA2N rev: A103
    dev-links: cdrom
  ID-1: / raw-size: 223.57 GiB size: 219 GiB (97.96%) used: 142.39 GiB (65.0%)
    fs: ext4 dev: /dev/sda1 maj-min: 8:1 label: N/A
    uuid: 206c8d41-a472-47ba-b70d-5a64b7e9c848
  ID-2: /mnt/7c1fa927-7b20-4c59-878a-9bc1bc64e298 raw-size: 931 GiB
    size: 915.31 GiB (98.32%) used: 552.79 GiB (60.4%) fs: ext4
    dev: /dev/md126p1 maj-min: 259:0 label: N/A
    uuid: 7c1fa927-7b20-4c59-878a-9bc1bc64e298
  Hub-1: 1-0:1 info: full speed or root hub ports: 2 rev: 2.0
  Hub-2: 1-1:2 info: Intel Integrated Rate Matching Hub ports: 4 rev: 2.0
    speed: 480 Mb/s (57.2 MiB/s) lanes: 1 mode: 2.0 chip-ID: 8087:0024
  Device-1: 1-1.2:3 info: USB OPTICAL MOUSE type: mouse
    driver: hid-generic,usbhid interfaces: 1 rev: 1.1
    chip-ID: 0000:0538 class-ID: 0301
  Hub-3: 2-0:1 info: full speed or root hub ports: 2 rev: 2.0
  Hub-4: 2-1:2 info: Intel Integrated Rate Matching Hub ports: 6 rev: 2.0
  Device-1: 2-1.3:3 info: USB Disk 2.0 type: mass storage
    driver: usb-storage interfaces: 1 rev: 2.0 speed: 480 Mb/s (57.2 MiB/s)
    lanes: 1 mode: 2.0 power: 100mA chip-ID: ffff:5678 class-ID: 0806
    serial: <filter>
  Device-2: 2-1.4:4 info: Realtek Bluetooth Radio type: bluetooth
    driver: btusb interfaces: 2 rev: 1.1 speed: 12 Mb/s (1.4 MiB/s) lanes: 1
    mode: 1.1 power: 500mA chip-ID: 0bda:8771 class-ID: e001 serial: <filter>
  Device-3: 2-1.5:5 info: C-Media TONOR TC-777 Audio Device type: audio,HID
    driver: hid-generic,snd-usb-audio,usbhid interfaces: 3 rev: 1.1
  Device-4: 2-1.6:6 info: China Resource Semico USB Keyboard
    type: keyboard,mouse driver: hid-generic,usbhid interfaces: 2 rev: 1.1
    speed: 1.5 Mb/s (183 KiB/s) lanes: 1 mode: 1.0 power: 500mA
    chip-ID: 1a2c:4b81 class-ID: 0301
  System Temperatures: cpu: 37.0 C mobo: N/A gpu: amdgpu temp: 46.0 C
  Fan Speeds (RPM): N/A gpu: amdgpu fan: 1780
  Processes: 259 Uptime: 3m wakeups: 0 Init: systemd v: 252 default: graphical
  tool: systemctl Compilers: gcc: 12.2.1 clang: 15.0.7 Packages: 2039
  pm: pacman pkgs: 2033 libs: 515 tools: pamac,yay pm: flatpak pkgs: 6
  Shell: Zsh v: 5.9 running-in: konsole inxi: 3.3.27
Any help would be greatly appreciated. Thanks.
Well … you dont have any SWAP.
When you reach the end of your RAM a hard lockup is expected.
And to start off thats pretty old.
In fact A01 is very likely the first and only BIOS this machine has ever seen. From back in 2013.
It also appears you have a much more recent BIOS update available.
(check yourself … this seems right to me)
https://www.dell.com/support/home/en-us/product-support/product/optiplex-3010/drivers
Also given the age of all the things … you likely want an older kernel series rather than chasing the new ones. Even dropping below 6 to 5.15 might be a good idea … if not further back.
If it helps you can reference this table for projected end-of-life dates:
https://kernel.org/category/releases.html
i just add, that you are on wayland, so switch to xorg and test with it
I require Wayland to emulate android on my machine, so even if I switched to Xorg, I’d still have to use Wayland for multiple hours.
Yeah… swap is something I overlooked. What should I add? 4096 megs?
Downgrading to 5.15 now…
A rule used to be ‘equal to RAM’ … though that is really only necessary if you want to use hibernation.
If you use something like systemd-swap it will just make some on the fly as needed.
If you want a set size … you might make use of a swapfile … that way you dont need to mess with partitions. Heres an example … (we will go with 8 gigs, edit as you like):
To start we will create the file at a proper place:
cd / && sudo dd if=/dev/zero of=/swapfile bs=1M count=8192 status=progress
Then we set it with correct permissions and enable swap:
sudo chmod 0600 /swapfile
sudo mkswap -U clear /swapfile
sudo swapon /swapfile
Swap should be working now … to have it mounted and working at boot the final step is edit /etc/fstab:
sudo nano /etc/fstab
And add the following line:
/swapfile none swap defaults,pri=-2 0 0
(save and exit … Ctrl+x with nano)
Thats it, reboot. You should have an active 8gb swapfile.
Status update: We’ve got a problem.
About 2 weeks ago, I attempted to install kernel module binder-linux because it was a dependency for Waydroid, the android emulator I’m using (see Waydroid - ArchWiki). Because of an issue, I wasn’t able to get it to work and installed linux-zen instead. Now, when I try booting into 5.15 from GRUB, (6.1 is still installed, don’t worry!) I get the following error message:
Also, @brahma, on Xorg, the main reason why I went to Wayland in the first place was because I broke my Xorg installation. Curious n00b me decided it would be a good idea to start an Xorg session whilst it was already running when I was warned not to by the output from xstart. When I ran sudo xstart after the warning, I broke something and now whenever I attempt to start Xorg from a tty something about the Xauthority files makes it not run. Yeah, I know, stupid mistake.
Also @cscs, just saying that for the count argument on the dd command you provided you typed in 81922 instead of what I presume should be 8192. It’s alright, just wouldn’t be good if you make a slip up on a dangerous command. I’ve still yet to run the commands though. Will get back to you on that.
Again, any help would be greatly appreciated. Thanks in advance.
Ah sorry and thanks.
Swap is working now. I set it to 8 gigs.
swapon -show
Filename                                Type            Size            Used            Priority
/mnt/7c1fa927-7b20-4c59-878a-9bc1bc64e298/swapfile file         8388604         0               -2
It just froze up again.
Pft….
in your home directory delete the .Xauthority file (or if you have more than one, delete them all), reboot and try login with xorg …
Well I’d be dammed, it worked! I removed the files and now, using a concise command I found online, we can now confirm that Xorg is fixed.
inxi -Gxx | grep compositor
    compositor: kwin_x11 driver: X: loaded: amdgpu
Nice. Thank you.
Just updated BIOS too.
now just test on xorg, so that we can rule out if its wayland related or not…
I’ll make a post (guess it’s this one) and edit it to include all crashes over the course of 3 days while using Xorg. If there’s a minimal amount, I’ll close this thread.
Crashes:
  1. Was using Weston to run Wayland in a container to use Waydroid. Journal logs are the following:
May 18 17:11:02 dylan-optiplex3010 kernel: ------------[ cut here ]------------
May 18 17:11:02 dylan-optiplex3010 kernel: list_add corruption. prev->next should be next (ffffffff8f6f6290), but was e28304eac00d51b6. (prev=ffffffffc04ad460).
May 18 17:11:02 dylan-optiplex3010 kernel: WARNING: CPU: 3 PID: 8875 at lib/list_debug.c:30 __list_add_valid+0x83/0xa0
May 18 17:11:02 dylan-optiplex3010 kernel: Modules linked in: sch_ingress af_key tcp_diag nfnetlink_log xfrm_interface xfrm6_tunnel tunnel4 udp_diag tunnel6 inet_diag cfg80211 veth overlay nft_masq nft_chain_nat nf_nat nf_conntrack nf_defrag_ipv6 nf_defrag_ipv4 bridge stp llc nf_tables libcrc32c nfnetlink snd_seq_dummy snd_seq rfcomm vmnet(OE) ppdev parport_pc parport vmw_vsock_vmci_transport vsock vmw_vmci vmmon(OE) qrtr cmac algif_hash algif_skcipher af_alg bnep intel_rapl_msr intel_rapl_common x86_pkg_temp_thermal intel_powerclamp coretemp kvm_intel kvm psmouse irqbypass serio_raw crct10dif_pclmul atkbd crc32_pclmul raid0 libps2 polyval_clmulni vivaldi_fmap polyval_generic mei_hdcp amdgpu dell_wmi mei_pxp gf128mul ghash_clmulni_intel i8042 sha512_ssse3 at24 dell_smbios serio dcdbas aesni_intel iTCO_wdt gpu_sched intel_pmc_bxt iTCO_vendor_support dell_wmi_descriptor sparse_keymap crypto_simd wmi_bmof snd_hda_codec_hdmi md_mod snd_hda_codec_conexant cryptd snd_hda_codec_generic rapl drm_buddy ledtrig_audio
May 18 17:11:02 dylan-optiplex3010 kernel:  intel_cstate r8169 btusb drm_ttm_helper btrtl snd_usb_audio snd_hda_intel btbcm ttm snd_intel_dspcfg btintel snd_intel_sdw_acpi snd_usbmidi_lib realtek btmtk snd_rawmidi snd_hda_codec mdio_devres drm_display_helper bluetooth snd_seq_device snd_hda_core mc snd_hwdep cec i2c_i801 libphy intel_uncore joydev snd_pcm mousedev ecdh_generic rfkill mei_me snd_timer snd soundcore i2c_smbus mei lpc_ich video mac_hid wmi uinput dm_multipath vboxnetflt(OE) vboxnetadp(OE) vboxdrv(OE) sg crypto_user ashmem_linux(OE) dm_mod fuse loop bpf_preload ip_tables x_tables ext4 crc32c_generic crc16 mbcache jbd2 sr_mod crc32c_intel cdrom usbhid
May 18 17:11:02 dylan-optiplex3010 kernel: Unloaded tainted modules: binder_linux(OE):4
May 18 17:11:02 dylan-optiplex3010 kernel: CPU: 3 PID: 8875 Comm: main Tainted: G        W  OE      6.1.26-1-MANJARO #1 e1c38db939b1e3efe75f91662b55a6291cec7a5e
May 18 17:11:02 dylan-optiplex3010 kernel: Hardware name: Dell Inc. OptiPlex 3010/042P49, BIOS A22 11/29/2018
May 18 17:11:02 dylan-optiplex3010 kernel: RIP: 0010:__list_add_valid+0x83/0xa0
May 18 17:11:02 dylan-optiplex3010 kernel: Code: eb e9 48 89 c1 48 c7 c7 c0 35 ef 8e e8 76 99 b1 ff 0f 0b eb d6 48 89 d1 48 89 c6 4c 89 c2 48 c7 c7 10 36 ef 8e e8 5d 99 b1 ff <0f> 0b eb bd 48 89 f2 48 89 c1 48 89 fe 48 c7 c7 60 36 ef 8e e8 44
May 18 17:11:02 dylan-optiplex3010 kernel: RSP: 0018:ffffb50249d9bdb8 EFLAGS: 00210286
May 18 17:11:02 dylan-optiplex3010 kernel: RAX: 0000000000000000 RBX: ffff9f6c73cfec30 RCX: 0000000000000027
May 18 17:11:02 dylan-optiplex3010 kernel: RDX: ffff9f6d4eda1668 RSI: 0000000000000001 RDI: ffff9f6d4eda1660
May 18 17:11:02 dylan-optiplex3010 kernel: RBP: ffffffffc04ad460 R08: 0000000000000000 R09: ffffb50249d9bc30
May 18 17:11:02 dylan-optiplex3010 kernel: R10: 0000000000000003 R11: ffffffff8f6c3248 R12: ffff9f6c73cfec50
May 18 17:11:02 dylan-optiplex3010 kernel: R13: ffffffff8f64b920 R14: ffffffff8db80820 R15: 00000000ffffffff
May 18 17:11:02 dylan-optiplex3010 kernel: FS:  00000000f7b02e00(0073) GS:ffff9f6d4ed80000(006b) knlGS:00000000f7d26480
May 18 17:11:02 dylan-optiplex3010 kernel: CS:  0010 DS: 002b ES: 002b CR0: 0000000080050033
May 18 17:11:02 dylan-optiplex3010 kernel: CR2: 00000000f6dcb2d0 CR3: 00000000bce8a006 CR4: 00000000001706e0
May 18 17:11:02 dylan-optiplex3010 kernel: Call Trace:
May 18 17:11:02 dylan-optiplex3010 kernel:  <TASK>
May 18 17:11:02 dylan-optiplex3010 kernel:  register_shrinker_prepared+0x39/0x70
May 18 17:11:02 dylan-optiplex3010 kernel:  sget_fc+0x1a0/0x330
May 18 17:11:02 dylan-optiplex3010 kernel:  ? shmem_put_link+0x30/0x30
May 18 17:11:02 dylan-optiplex3010 kernel:  get_tree_nodev+0x27/0xa0
May 18 17:11:02 dylan-optiplex3010 kernel:  ? bpf_lsm_capset+0x10/0x10
May 18 17:11:02 dylan-optiplex3010 kernel:  vfs_get_tree+0x29/0xc0
May 18 17:11:02 dylan-optiplex3010 kernel:  path_mount+0x46e/0xa90
May 18 17:11:02 dylan-optiplex3010 kernel:  __ia32_sys_mount+0x118/0x150
May 18 17:11:02 dylan-optiplex3010 kernel:  __do_fast_syscall_32+0x88/0xe0
May 18 17:11:02 dylan-optiplex3010 kernel:  do_fast_syscall_32+0x33/0x80
May 18 17:11:02 dylan-optiplex3010 kernel:  entry_SYSENTER_compat_after_hwframe+0x70/0x82
May 18 17:11:02 dylan-optiplex3010 kernel: RIP: 0023:0xf7e80549
May 18 17:11:02 dylan-optiplex3010 kernel: Code: 03 74 c0 01 10 05 03 74 b8 01 10 06 03 74 b4 01 10 07 03 74 b0 01 10 08 03 74 d8 01 00 00 00 00 00 51 52 55 89 e5 0f 34 cd 80 <5d> 5a 59 c3 cc 90 90 90 8d b4 26 00 00 00 00 8d b4 26 00 00 00 00
May 18 17:11:02 dylan-optiplex3010 kernel: RSP: 002b:00000000ffd625d4 EFLAGS: 00200286 ORIG_RAX: 0000000000000015
May 18 17:11:02 dylan-optiplex3010 kernel: RAX: ffffffffffffffda RBX: 00000000f68d1e44 RCX: 00000000f73385a0
May 18 17:11:02 dylan-optiplex3010 kernel: RDX: 00000000f68d1e44 RSI: 000000000000000e RDI: 00000000f68cafb7
May 18 17:11:02 dylan-optiplex3010 kernel: RBP: 00000000ffd62688 R08: 0000000000000000 R09: 0000000000000000
May 18 17:11:02 dylan-optiplex3010 kernel: R10: 0000000000000000 R11: 0000000000200286 R12: 0000000000000000
May 18 17:11:02 dylan-optiplex3010 kernel: R13: 0000000000000000 R14: 0000000000000000 R15: 0000000000000000
May 18 17:11:02 dylan-optiplex3010 kernel:  </TASK>
May 18 17:11:02 dylan-optiplex3010 kernel: ---[ end trace 0000000000000000 ]---
May 18 17:11:02 dylan-optiplex3010 kmix[1068]: org.kde.kmix: Could not get icon for "audio-card-pci"
May 18 17:11:02 dylan-optiplex3010 kmix[1068]: org.kde.kmix: Could not get icon for "audio-card-usb"
May 18 17:11:02 dylan-optiplex3010 kmix[1068]: org.kde.kmix: Could not get icon for "chromium-browser"
May 18 17:11:05 dylan-optiplex3010 kernel: general protection fault, probably for non-canonical address 0x9092b60f0fe28304: 0000 [#1] PREEMPT SMP PTI
May 18 17:11:05 dylan-optiplex3010 kernel: CPU: 3 PID: 60 Comm: kswapd0 Tainted: G        W  OE      6.1.26-1-MANJARO #1 e1c38db939b1e3efe75f91662b55a6291cec7a5e
May 18 17:11:05 dylan-optiplex3010 kernel: Hardware name: Dell Inc. OptiPlex 3010/042P49, BIOS A22 11/29/2018
May 18 17:11:05 dylan-optiplex3010 kernel: RIP: 0010:__x86_indirect_thunk_array+0x10/0x20
May 18 17:11:05 dylan-optiplex3010 kernel: Code: b9 cc cc cc cc cc cc cc cc cc cc cc cc cc cc cc cc cc cc cc cc cc cc cc cc cc e8 07 00 00 00 f3 90 0f ae e8 eb f9 48 89 04 24 <c3> cc cc cc cc 66 66 2e 0f 1f 84 00 00 00 00 00 e8 07 00 00 00 f3
May 18 17:11:05 dylan-optiplex3010 kernel: RSP: 0018:ffffb5024032fba0 EFLAGS: 00010282
May 18 17:11:05 dylan-optiplex3010 kernel: RAX: 9092b60f0fe28304 RBX: ffffb5024032fc30 RCX: 0000000000000000
May 18 17:11:05 dylan-optiplex3010 kernel: RDX: 000000000000000c RSI: ffffb5024032fc30 RDI: ffffffffc04ad440
May 18 17:11:05 dylan-optiplex3010 kernel: RBP: ffff9f6a40132000 R08: 0000000000000000 R09: 0000000000000002
May 18 17:11:05 dylan-optiplex3010 kernel: R10: 0000000000000002 R11: 0000000000000000 R12: 92b60f0fe2830c51
May 18 17:11:05 dylan-optiplex3010 kernel: R13: 000000000000000c R14: 000000000000000c R15: ffffffffc04ad440
May 18 17:11:05 dylan-optiplex3010 kernel: FS:  0000000000000000(0000) GS:ffff9f6d4ed80000(0000) knlGS:0000000000000000
May 18 17:11:05 dylan-optiplex3010 kernel: CS:  0010 DS: 0000 ES: 0000 CR0: 0000000080050033
May 18 17:11:05 dylan-optiplex3010 kernel: CR2: 00000000b6507fc0 CR3: 0000000350dac004 CR4: 00000000001706e0
May 18 17:11:05 dylan-optiplex3010 kernel: Call Trace:
May 18 17:11:05 dylan-optiplex3010 kernel:  <TASK>
May 18 17:11:05 dylan-optiplex3010 kernel:  ? do_shrink_slab+0x3a/0x2e0
May 18 17:11:05 dylan-optiplex3010 kernel:  ? VBoxHost_RTUuidToStr+0x210/0x2c0 [vboxdrv 68fee84976504c8167f0e5e9c605615892aa6121]
May 18 17:11:05 dylan-optiplex3010 kernel:  ? shrink_slab+0xaa/0x290
May 18 17:11:05 dylan-optiplex3010 kernel:  ? shrink_node+0x21c/0x710
May 18 17:11:05 dylan-optiplex3010 kernel:  ? balance_pgdat+0x309/0xa40
May 18 17:11:05 dylan-optiplex3010 kernel:  ? psi_task_switch+0xd6/0x230
May 18 17:11:05 dylan-optiplex3010 kernel:  ? __switch_to_asm+0x3e/0x60
May 18 17:11:05 dylan-optiplex3010 kernel:  ? kswapd+0x1f8/0x3b0
May 18 17:11:05 dylan-optiplex3010 kernel:  ? sugov_start+0x150/0x150
May 18 17:11:05 dylan-optiplex3010 kernel:  ? balance_pgdat+0xa40/0xa40
May 18 17:11:05 dylan-optiplex3010 kernel:  ? kthread+0xde/0x110
May 18 17:11:05 dylan-optiplex3010 kernel:  ? kthread_complete_and_exit+0x20/0x20
May 18 17:11:05 dylan-optiplex3010 kernel:  ? ret_from_fork+0x22/0x30
May 18 17:11:05 dylan-optiplex3010 kernel:  </TASK>
May 18 17:11:05 dylan-optiplex3010 kernel: Modules linked in: sch_ingress af_key tcp_diag nfnetlink_log xfrm_interface xfrm6_tunnel tunnel4 udp_diag tunnel6 inet_diag cfg80211 veth overlay nft_masq nft_chain_nat nf_nat nf_conntrack nf_defrag_ipv6 nf_defrag_ipv4 bridge stp llc nf_tables libcrc32c nfnetlink snd_seq_dummy snd_seq rfcomm vmnet(OE) ppdev parport_pc parport vmw_vsock_vmci_transport vsock vmw_vmci vmmon(OE) qrtr cmac algif_hash algif_skcipher af_alg bnep intel_rapl_msr intel_rapl_common x86_pkg_temp_thermal intel_powerclamp coretemp kvm_intel kvm psmouse irqbypass serio_raw crct10dif_pclmul atkbd crc32_pclmul raid0 libps2 polyval_clmulni vivaldi_fmap polyval_generic mei_hdcp amdgpu dell_wmi mei_pxp gf128mul ghash_clmulni_intel i8042 sha512_ssse3 at24 dell_smbios serio dcdbas aesni_intel iTCO_wdt gpu_sched intel_pmc_bxt iTCO_vendor_support dell_wmi_descriptor sparse_keymap crypto_simd wmi_bmof snd_hda_codec_hdmi md_mod snd_hda_codec_conexant cryptd snd_hda_codec_generic rapl drm_buddy ledtrig_audio
May 18 17:11:05 dylan-optiplex3010 kernel:  intel_cstate r8169 btusb drm_ttm_helper btrtl snd_usb_audio snd_hda_intel btbcm ttm snd_intel_dspcfg btintel snd_intel_sdw_acpi snd_usbmidi_lib realtek btmtk snd_rawmidi snd_hda_codec mdio_devres drm_display_helper bluetooth snd_seq_device snd_hda_core mc snd_hwdep cec i2c_i801 libphy intel_uncore joydev snd_pcm mousedev ecdh_generic rfkill mei_me snd_timer snd soundcore i2c_smbus mei lpc_ich video mac_hid wmi uinput dm_multipath vboxnetflt(OE) vboxnetadp(OE) vboxdrv(OE) sg crypto_user ashmem_linux(OE) dm_mod fuse loop bpf_preload ip_tables x_tables ext4 crc32c_generic crc16 mbcache jbd2 sr_mod crc32c_intel cdrom usbhid
May 18 17:11:05 dylan-optiplex3010 kernel: Unloaded tainted modules: binder_linux(OE):4
May 18 17:11:05 dylan-optiplex3010 kernel: ---[ end trace 0000000000000000 ]---
May 18 17:11:05 dylan-optiplex3010 kernel: general protection fault, probably for non-canonical address 0x9092b60f0fe28304: 0000 [#2] PREEMPT SMP PTI
May 18 17:11:05 dylan-optiplex3010 kernel: CPU: 0 PID: 8919 Comm: RenderThread Tainted: G      D W  OE      6.1.26-1-MANJARO #1 e1c38db939b1e3efe75f91662b55a6291cec7a5e
May 18 17:11:05 dylan-optiplex3010 kernel: RSP: 0000:ffffb5024a4738c0 EFLAGS: 00210282
May 18 17:11:05 dylan-optiplex3010 kernel: RAX: 9092b60f0fe28304 RBX: ffffb5024a473950 RCX: 0000000000000000
May 18 17:11:05 dylan-optiplex3010 kernel: RDX: 000000000000000c RSI: ffffb5024a473950 RDI: ffffffffc04ad440
May 18 17:11:05 dylan-optiplex3010 kernel: RBP: ffff9f6a40132000 R08: 0000000000000000 R09: 0000000000000004
May 18 17:11:05 dylan-optiplex3010 kernel: R10: 0000000000000002 R11: ffffb5024a4735e8 R12: 92b60f0fe2830c51
May 18 17:11:05 dylan-optiplex3010 kernel: FS:  00000000c3ace400(0073) GS:ffff9f6d4ec00000(006b) knlGS:00000000b9fe9480
May 18 17:11:05 dylan-optiplex3010 kernel: CS:  0010 DS: 002b ES: 002b CR0: 0000000080050033
May 18 17:11:05 dylan-optiplex3010 kernel: CR2: 00000000b4e19aa0 CR3: 00000000bce8a001 CR4: 00000000001706f0
May 18 17:11:05 dylan-optiplex3010 kernel:  ? do_try_to_free_pages+0xde/0x5a0
May 18 17:11:05 dylan-optiplex3010 kernel:  ? try_to_free_pages+0xe7/0x210
May 18 17:11:05 dylan-optiplex3010 kernel:  ? __alloc_pages_slowpath.constprop.0+0x34c/0xe10
May 18 17:11:05 dylan-optiplex3010 kernel:  ? xas_store+0x2e5/0x630
May 18 17:11:05 dylan-optiplex3010 kernel:  ? __filemap_add_folio+0x1c9/0x430
May 18 17:11:05 dylan-optiplex3010 kernel:  ? __alloc_pages+0x224/0x250
May 18 17:11:05 dylan-optiplex3010 kernel:  ? folio_alloc+0x1b/0x50
May 18 17:11:05 dylan-optiplex3010 kernel:  ? page_cache_ra_unbounded+0x94/0x180
May 18 17:11:05 dylan-optiplex3010 kernel:  ? filemap_fault+0x552/0x920
May 18 17:11:05 dylan-optiplex3010 kernel:  ? filemap_map_pages+0x154/0x6f0
May 18 17:11:05 dylan-optiplex3010 kernel:  ? __do_fault+0x33/0x110
May 18 17:11:05 dylan-optiplex3010 kernel:  ? do_fault+0x1b9/0x410
May 18 17:11:05 dylan-optiplex3010 kernel:  ? __handle_mm_fault+0x660/0xfa0
May 18 17:11:05 dylan-optiplex3010 kernel:  ? handle_mm_fault+0xdf/0x2d0
May 18 17:11:05 dylan-optiplex3010 kernel:  ? do_user_addr_fault+0x1be/0x6a0
May 18 17:11:05 dylan-optiplex3010 kernel:  ? exc_page_fault+0x74/0x170
May 18 17:11:05 dylan-optiplex3010 kernel:  ? asm_exc_page_fault+0x26/0x30
May 18 17:11:05 dylan-optiplex3010 kernel: general protection fault, probably for non-canonical address 0x9092b60f0fe28304: 0000 [#3] PREEMPT SMP PTI
May 18 17:11:05 dylan-optiplex3010 kernel: CPU: 3 PID: 1076 Comm: pulseaudio Tainted: G      D W  OE      6.1.26-1-MANJARO #1 e1c38db939b1e3efe75f91662b55a6291cec7a5e
May 18 17:11:05 dylan-optiplex3010 kernel: RSP: 0018:ffffb50242667638 EFLAGS: 00010282
May 18 17:11:05 dylan-optiplex3010 kernel: RAX: 9092b60f0fe28304 RBX: ffffb502426676c8 RCX: 0000000000000000
May 18 17:11:05 dylan-optiplex3010 kernel: RDX: 000000000000000c RSI: ffffb502426676c8 RDI: ffffffffc04ad440
May 18 17:11:05 dylan-optiplex3010 kernel: RBP: ffff9f6a40132000 R08: 0000000000000000 R09: 0000000000000006
May 18 17:11:05 dylan-optiplex3010 kernel: FS:  00007fc0daa5b840(0000) GS:ffff9f6d4ed80000(0000) knlGS:0000000000000000
May 18 17:11:05 dylan-optiplex3010 kernel: CR2: 000035b000ea6000 CR3: 0000000118db6004 CR4: 00000000001706e0
May 18 17:11:05 dylan-optiplex3010 kernel:  ? __get_free_pages+0x11/0x40
May 18 17:11:05 dylan-optiplex3010 kernel:  ? __pollwait+0x8d/0xe0
May 18 17:11:05 dylan-optiplex3010 kernel:  ? unix_poll+0x27/0x100
May 18 17:11:05 dylan-optiplex3010 kernel:  ? sock_poll+0x55/0xf0
May 18 17:11:05 dylan-optiplex3010 kernel:  ? do_sys_poll+0x2e4/0x610
May 18 17:11:05 dylan-optiplex3010 kernel:  ? poll_initwait+0x40/0x40
May 18 17:11:05 dylan-optiplex3010 kernel:  ? __pollwait+0xe0/0xe0
May 18 17:11:05 dylan-optiplex3010 kernel:  ? __x64_sys_ppoll+0xe2/0x170
May 18 17:11:05 dylan-optiplex3010 kernel:  ? do_syscall_64+0x5f/0x90
May 18 17:11:05 dylan-optiplex3010 kernel:  ? syscall_exit_to_user_mode+0x1b/0x40
May 18 17:11:05 dylan-optiplex3010 kernel:  ? do_syscall_64+0x6b/0x90
May 18 17:11:05 dylan-optiplex3010 kernel:  ? entry_SYSCALL_64_after_hwframe+0x63/0xcd
May 18 17:11:05 dylan-optiplex3010 kernel: BUG: unable to handle page fault for address: ffffb50242667c98
May 18 17:11:05 dylan-optiplex3010 kernel: #PF: supervisor read access in kernel mode
May 18 17:11:05 dylan-optiplex3010 kernel: #PF: error_code(0x0000) - not-present page
May 18 17:11:05 dylan-optiplex3010 kernel: Oops: 0000 [#4] PREEMPT SMP PTI
May 18 17:11:05 dylan-optiplex3010 kernel: CPU: 2 PID: 8882 Comm: threaded-ml Tainted: G      D W  OE      6.1.26-1-MANJARO #1 e1c38db939b1e3efe75f91662b55a6291cec7a5e
May 18 17:11:05 dylan-optiplex3010 kernel: RIP: 0010:__wake_up_common+0x4c/0x180
May 18 17:11:05 dylan-optiplex3010 kernel: Code: 24 0c 89 4c 24 08 4d 85 c9 74 0a 41 f6 01 04 0f 85 a3 00 00 00 48 8b 43 08 4c 8d 40 e8 48 83 c3 08 49 8d 40 18 48 39 c3 74 5b <49> 8b 40 18 31 ed 4c 8d 70 e8 45 8b 28 41 f6 c5 04 75 5f 49 8b 40
May 18 17:11:05 dylan-optiplex3010 kernel: RSP: 0018:ffffb5024b1abb08 EFLAGS: 00010087
May 18 17:11:05 dylan-optiplex3010 kernel: RAX: ffffb50242667c98 RBX: ffff9f6cfa54f788 RCX: 0000000000000010
May 18 17:11:05 dylan-optiplex3010 kernel: RDX: 0000000000000001 RSI: 0000000000000001 RDI: ffff9f6cfa54f780
May 18 17:11:05 dylan-optiplex3010 kernel: RBP: 0000000000000246 R08: ffffb50242667c80 R09: ffffb5024b1abb60
May 18 17:11:05 dylan-optiplex3010 kernel: R10: 0000000000000000 R11: ffffb5024b1abcc0 R12: ffffb5024b1abb60
May 18 17:11:05 dylan-optiplex3010 kernel: R13: 00000000000000c3 R14: 0000000000000010 R15: 00000000000000c3
May 18 17:11:05 dylan-optiplex3010 kernel: FS:  0000000000000000(0000) GS:ffff9f6d4ed00000(006b) knlGS:00000000f1d55480
May 18 17:11:05 dylan-optiplex3010 kernel: CR2: ffffb50242667c98 CR3: 0000000355ba4001 CR4: 00000000001706e0
May 18 17:11:05 dylan-optiplex3010 kernel:  __wake_up_common_lock+0x82/0xd0
May 18 17:11:05 dylan-optiplex3010 kernel:  sock_def_readable+0x40/0x80
May 18 17:11:05 dylan-optiplex3010 kernel:  unix_stream_sendmsg+0x194/0x6c0
May 18 17:11:05 dylan-optiplex3010 kernel:  sock_sendmsg+0x63/0x70
May 18 17:11:05 dylan-optiplex3010 kernel:  __sys_sendto+0x120/0x170
May 18 17:11:05 dylan-optiplex3010 kernel:  __ia32_compat_sys_socketcall+0x2ee/0x350
May 18 17:11:05 dylan-optiplex3010 kernel:  __do_fast_syscall_32+0x88/0xe0
May 18 17:11:05 dylan-optiplex3010 kernel:  ? __do_fast_syscall_32+0x94/0xe0
May 18 17:11:05 dylan-optiplex3010 kernel:  do_fast_syscall_32+0x33/0x80
May 18 17:11:05 dylan-optiplex3010 kernel:  entry_SYSENTER_compat_after_hwframe+0x70/0x82
May 18 17:11:05 dylan-optiplex3010 kernel: RIP: 0023:0xf7e58549
May 18 17:11:05 dylan-optiplex3010 kernel: Code: 03 74 c0 01 10 05 03 74 b8 01 10 06 03 74 b4 01 10 07 03 74 b0 01 10 08 03 74 d8 01 00 00 00 00 00 51 52 55 89 e5 0f 34 cd 80 <5d> 5a 59 c3 cc 90 90 90 8d b4 26 00 00 00 00 8d b4 26 00 00 00 00
May 18 17:11:05 dylan-optiplex3010 kernel: RSP: 002b:00000000f1d54e50 EFLAGS: 00000282 ORIG_RAX: 0000000000000066
May 18 17:11:05 dylan-optiplex3010 kernel: RAX: ffffffffffffffda RBX: 000000000000000b RCX: 00000000f1d54e70
May 18 17:11:05 dylan-optiplex3010 kernel: RDX: 00000000f7be5e4c RSI: 00000000f78b4780 RDI: 000000000000000e
May 18 17:11:05 dylan-optiplex3010 kernel: RBP: 00000000f1d54ea8 R08: 0000000000000000 R09: 0000000000000000
May 18 17:11:05 dylan-optiplex3010 kernel: R10: 0000000000000000 R11: 0000000000000282 R12: 0000000000000000
May 18 17:11:05 dylan-optiplex3010 kernel: R13: 0000000000000000 R14: 0000000000000000 R15: 0000000000000000
May 18 17:11:06 dylan-optiplex3010 kernel: BUG: unable to handle page fault for address: ffffb50242667d18
May 18 17:11:06 dylan-optiplex3010 kernel: #PF: supervisor read access in kernel mode
May 18 17:11:06 dylan-optiplex3010 kernel: #PF: error_code(0x0000) - not-present page
May 18 17:11:06 dylan-optiplex3010 kernel: Oops: 0000 [#5] PREEMPT SMP PTI
May 18 17:11:06 dylan-optiplex3010 kernel: CPU: 2 PID: 8656 Comm: threaded-ml Tainted: G      D W  OE      6.1.26-1-MANJARO #1 e1c38db939b1e3efe75f91662b55a6291cec7a5e
May 18 17:11:06 dylan-optiplex3010 kernel: Hardware name: Dell Inc. OptiPlex 3010/042P49, BIOS A22 11/29/2018
May 18 17:11:06 dylan-optiplex3010 kernel: RIP: 0010:__wake_up_common+0x4c/0x180
May 18 17:11:06 dylan-optiplex3010 kernel: Code: 24 0c 89 4c 24 08 4d 85 c9 74 0a 41 f6 01 04 0f 85 a3 00 00 00 48 8b 43 08 4c 8d 40 e8 48 83 c3 08 49 8d 40 18 48 39 c3 74 5b <49> 8b 40 18 31 ed 4c 8d 70 e8 45 8b 28 41 f6 c5 04 75 5f 49 8b 40
May 18 17:11:06 dylan-optiplex3010 kernel: RSP: 0018:ffffb5024b373d70 EFLAGS: 00010093
May 18 17:11:06 dylan-optiplex3010 kernel: RAX: ffffb50242667d18 RBX: ffff9f69fd991810 RCX: 0000000000000000
May 18 17:11:06 dylan-optiplex3010 kernel: RDX: 0000000000000001 RSI: 0000000000000003 RDI: ffff9f69fd991808
May 18 17:11:06 dylan-optiplex3010 kernel: RBP: ffff9f69fd991800 R08: ffffb50242667d00 R09: 0000000000000000
May 18 17:11:06 dylan-optiplex3010 kernel: R10: 0000000000000000 R11: 0000000000000001 R12: 0000000000000000
May 18 17:11:06 dylan-optiplex3010 kernel: R13: ffff9f69fd991810 R14: 0000000000000008 R15: 0000000000000001
May 18 17:11:06 dylan-optiplex3010 kernel: FS:  00007fb015ec66c0(0000) GS:ffff9f6d4ed00000(0000) knlGS:0000000000000000
May 18 17:11:06 dylan-optiplex3010 kernel: CS:  0010 DS: 0000 ES: 0000 CR0: 0000000080050033
May 18 17:11:06 dylan-optiplex3010 kernel: CR2: ffffb50242667d18 CR3: 00000001bc48a002 CR4: 00000000001706e0
May 18 17:11:06 dylan-optiplex3010 kernel: Call Trace:
May 18 17:11:06 dylan-optiplex3010 kernel:  <TASK>
May 18 17:11:06 dylan-optiplex3010 kernel:  eventfd_write+0x21e/0x320
May 18 17:11:06 dylan-optiplex3010 kernel:  ? wake_up_q+0x90/0x90
May 18 17:11:06 dylan-optiplex3010 kernel:  vfs_write+0xcb/0x3f0
May 18 17:11:06 dylan-optiplex3010 kernel:  ? __fget_light+0x9d/0x100
May 18 17:11:06 dylan-optiplex3010 kernel:  ksys_write+0x6f/0xf0
May 18 17:11:06 dylan-optiplex3010 kernel:  do_syscall_64+0x5f/0x90
May 18 17:11:06 dylan-optiplex3010 kernel:  ? exc_page_fault+0x74/0x170
May 18 17:11:06 dylan-optiplex3010 kernel:  entry_SYSCALL_64_after_hwframe+0x63/0xcd
May 18 17:11:06 dylan-optiplex3010 kernel: RIP: 0033:0x7fb032123a0f
May 18 17:11:06 dylan-optiplex3010 kernel: Code: 89 54 24 18 48 89 74 24 10 89 7c 24 08 e8 19 b6 f8 ff 48 8b 54 24 18 48 8b 74 24 10 41 89 c0 8b 7c 24 08 b8 01 00 00 00 0f 05 <48> 3d 00 f0 ff ff 77 31 44 89 c7 48 89 44 24 08 e8 6c b6 f8 ff 48
May 18 17:11:06 dylan-optiplex3010 kernel: RSP: 002b:00007fb015ec5530 EFLAGS: 00000293 ORIG_RAX: 0000000000000001
May 18 17:11:06 dylan-optiplex3010 kernel: RAX: ffffffffffffffda RBX: 000000000000002c RCX: 00007fb032123a0f
May 18 17:11:06 dylan-optiplex3010 kernel: RDX: 0000000000000008 RSI: 00007fb015ec55a0 RDI: 0000000000000023
May 18 17:11:06 dylan-optiplex3010 kernel: RBP: 0000000000000023 R08: 0000000000000000 R09: 00002dc4003a0840
May 18 17:11:06 dylan-optiplex3010 kernel: R10: 00007ffda81f3080 R11: 0000000000000293 R12: 00007fb015ec55a0
May 18 17:11:06 dylan-optiplex3010 kernel: R13: 0000000000000008 R14: 00002dc40035e4ec R15: 000000000000002c
May 18 17:11:06 dylan-optiplex3010 kernel:  </TASK>
May 18 17:11:06 dylan-optiplex3010 kernel: Modules linked in: sch_ingress af_key tcp_diag nfnetlink_log xfrm_interface xfrm6_tunnel tunnel4 udp_diag tunnel6 inet_diag cfg80211 veth overlay nft_masq nft_chain_nat nf_nat nf_conntrack nf_defrag_ipv6 nf_defrag_ipv4 bridge stp llc nf_tables libcrc32c nfnetlink snd_seq_dummy snd_seq rfcomm vmnet(OE) ppdev parport_pc parport vmw_vsock_vmci_transport vsock vmw_vmci vmmon(OE) qrtr cmac algif_hash algif_skcipher af_alg bnep intel_rapl_msr intel_rapl_common x86_pkg_temp_thermal intel_powerclamp coretemp kvm_intel kvm psmouse irqbypass serio_raw crct10dif_pclmul atkbd crc32_pclmul raid0 libps2 polyval_clmulni vivaldi_fmap polyval_generic mei_hdcp amdgpu dell_wmi mei_pxp gf128mul ghash_clmulni_intel i8042 sha512_ssse3 at24 dell_smbios serio dcdbas aesni_intel iTCO_wdt gpu_sched intel_pmc_bxt iTCO_vendor_support dell_wmi_descriptor sparse_keymap crypto_simd wmi_bmof snd_hda_codec_hdmi md_mod snd_hda_codec_conexant cryptd snd_hda_codec_generic rapl drm_buddy ledtrig_audio
May 18 17:11:06 dylan-optiplex3010 kernel:  intel_cstate r8169 btusb drm_ttm_helper btrtl snd_usb_audio snd_hda_intel btbcm ttm snd_intel_dspcfg btintel snd_intel_sdw_acpi snd_usbmidi_lib realtek btmtk snd_rawmidi snd_hda_codec mdio_devres drm_display_helper bluetooth snd_seq_device snd_hda_core mc snd_hwdep cec i2c_i801 libphy intel_uncore joydev snd_pcm mousedev ecdh_generic rfkill mei_me snd_timer snd soundcore i2c_smbus mei lpc_ich video mac_hid wmi uinput dm_multipath vboxnetflt(OE) vboxnetadp(OE) vboxdrv(OE) sg crypto_user ashmem_linux(OE) dm_mod fuse loop bpf_preload ip_tables x_tables ext4 crc32c_generic crc16 mbcache jbd2 sr_mod crc32c_intel cdrom usbhid
May 18 17:11:06 dylan-optiplex3010 kernel: Unloaded tainted modules: binder_linux(OE):4
May 18 17:11:06 dylan-optiplex3010 kernel: ---[ end trace 0000000000000000 ]---
May 18 17:11:06 dylan-optiplex3010 kernel: RIP: 0010:__x86_indirect_thunk_array+0x10/0x20
May 18 17:11:06 dylan-optiplex3010 kernel: Code: b9 cc cc cc cc cc cc cc cc cc cc cc cc cc cc cc cc cc cc cc cc cc cc cc cc cc e8 07 00 00 00 f3 90 0f ae e8 eb f9 48 89 04 24 <c3> cc cc cc cc 66 66 2e 0f 1f 84 00 00 00 00 00 e8 07 00 00 00 f3
May 18 17:11:06 dylan-optiplex3010 kernel: RSP: 0018:ffffb5024032fba0 EFLAGS: 00010282
May 18 17:11:06 dylan-optiplex3010 kernel: RAX: 9092b60f0fe28304 RBX: ffffb5024032fc30 RCX: 0000000000000000
May 18 17:11:06 dylan-optiplex3010 kernel: RDX: 000000000000000c RSI: ffffb5024032fc30 RDI: ffffffffc04ad440
May 18 17:11:06 dylan-optiplex3010 kernel: RBP: ffff9f6a40132000 R08: 0000000000000000 R09: 0000000000000002
May 18 17:11:06 dylan-optiplex3010 kernel: R10: 0000000000000002 R11: 0000000000000000 R12: 92b60f0fe2830c51
May 18 17:11:06 dylan-optiplex3010 kernel: R13: 000000000000000c R14: 000000000000000c R15: ffffffffc04ad440
May 18 17:11:08 dylan-optiplex3010 kernel: general protection fault, probably for non-canonical address 0x9092b60f0fe28304: 0000 [#6] PREEMPT SMP PTI
May 18 17:11:08 dylan-optiplex3010 kernel: CPU: 2 PID: 6662 Comm: weston-desktop- Tainted: G      D W  OE      6.1.26-1-MANJARO #1 e1c38db939b1e3efe75f91662b55a6291cec7a5e
May 18 17:11:08 dylan-optiplex3010 kernel: Hardware name: Dell Inc. OptiPlex 3010/042P49, BIOS A22 11/29/2018
May 18 17:11:08 dylan-optiplex3010 kernel: RIP: 0010:__x86_indirect_thunk_array+0x10/0x20
May 18 17:11:08 dylan-optiplex3010 kernel: Code: b9 cc cc cc cc cc cc cc cc cc cc cc cc cc cc cc cc cc cc cc cc cc cc cc cc cc e8 07 00 00 00 f3 90 0f ae e8 eb f9 48 89 04 24 <c3> cc cc cc cc 66 66 2e 0f 1f 84 00 00 00 00 00 e8 07 00 00 00 f3
May 18 17:11:08 dylan-optiplex3010 kernel: RSP: 0018:ffffb50243ac77d8 EFLAGS: 00010282
May 18 17:11:08 dylan-optiplex3010 kernel: RAX: 9092b60f0fe28304 RBX: ffffb50243ac7868 RCX: 0000000000000000
May 18 17:11:08 dylan-optiplex3010 kernel: RDX: 000000000000000c RSI: ffffb50243ac7868 RDI: ffffffffc04ad440
May 18 17:11:08 dylan-optiplex3010 kernel: RBP: ffff9f6a40132000 R08: 0000000000000000 R09: 0000000000000008
May 18 17:11:08 dylan-optiplex3010 kernel: R10: 0000000000000002 R11: 0000000000000000 R12: 92b60f0fe2830c51
May 18 17:11:08 dylan-optiplex3010 kernel: R13: 000000000000000c R14: 000000000000000c R15: ffffffffc04ad440
May 18 17:11:08 dylan-optiplex3010 kernel: FS:  00007fb3b56d7400(0000) GS:ffff9f6d4ed00000(0000) knlGS:0000000000000000
May 18 17:11:08 dylan-optiplex3010 kernel: CS:  0010 DS: 0000 ES: 0000 CR0: 0000000080050033
May 18 17:11:08 dylan-optiplex3010 kernel: CR2: 00007f3ba82d5000 CR3: 00000003a0870003 CR4: 00000000001706e0
May 18 17:11:08 dylan-optiplex3010 kernel: Call Trace:
May 18 17:11:08 dylan-optiplex3010 kernel:  <TASK>
May 18 17:11:08 dylan-optiplex3010 kernel:  ? do_shrink_slab+0x3a/0x2e0
May 18 17:11:08 dylan-optiplex3010 kernel:  ? VBoxHost_RTUuidToStr+0x210/0x2c0 [vboxdrv 68fee84976504c8167f0e5e9c605615892aa6121]
May 18 17:11:08 dylan-optiplex3010 kernel:  ? shrink_slab+0xaa/0x290
May 18 17:11:08 dylan-optiplex3010 kernel:  ? shrink_node+0x21c/0x710
May 18 17:11:08 dylan-optiplex3010 kernel:  ? do_try_to_free_pages+0xde/0x5a0
May 18 17:11:08 dylan-optiplex3010 kernel:  ? try_to_free_pages+0xe7/0x210
May 18 17:11:08 dylan-optiplex3010 kernel:  ? __alloc_pages_slowpath.constprop.0+0x34c/0xe10
May 18 17:11:08 dylan-optiplex3010 kernel:  ? memcg_alloc_slab_cgroups+0x3b/0x80
May 18 17:11:08 dylan-optiplex3010 kernel:  ? mod_objcg_state+0x19a/0x2c0
May 18 17:11:08 dylan-optiplex3010 kernel:  ? __alloc_pages+0x224/0x250
May 18 17:11:08 dylan-optiplex3010 kernel:  ? __folio_alloc+0x1b/0x50
May 18 17:11:08 dylan-optiplex3010 kernel:  ? refill_stock+0x1a/0x30
May 18 17:11:08 dylan-optiplex3010 kernel:  ? vma_alloc_folio+0xa0/0x360
May 18 17:11:08 dylan-optiplex3010 kernel:  ? shmem_alloc_folio+0x82/0xd0
May 18 17:11:08 dylan-optiplex3010 kernel:  ? shmem_alloc_and_acct_folio+0x7b/0x1a0
May 18 17:11:08 dylan-optiplex3010 kernel:  ? shmem_get_folio_gfp+0x1fe/0x7d0
May 18 17:11:08 dylan-optiplex3010 kernel:  ? wb_position_ratio+0x1e0/0x1e0
May 18 17:11:08 dylan-optiplex3010 kernel:  ? shmem_fallocate+0x3ce/0x560
May 18 17:11:08 dylan-optiplex3010 kernel:  ? alloc_empty_file+0x63/0xc0
May 18 17:11:08 dylan-optiplex3010 kernel:  ? vfs_fallocate+0x135/0x340
May 18 17:11:08 dylan-optiplex3010 kernel:  ? __x64_sys_fallocate+0x44/0x70
May 18 17:11:08 dylan-optiplex3010 kernel:  ? do_syscall_64+0x5f/0x90
May 18 17:11:08 dylan-optiplex3010 kernel:  ? syscall_exit_to_user_mode+0x1b/0x40
May 18 17:11:08 dylan-optiplex3010 kernel:  ? do_syscall_64+0x6b/0x90
May 18 17:11:08 dylan-optiplex3010 kernel:  ? switch_fpu_return+0x50/0xe0
May 18 17:11:08 dylan-optiplex3010 kernel:  ? exit_to_user_mode_prepare+0x132/0x1e0
May 18 17:11:08 dylan-optiplex3010 kernel:  ? entry_SYSCALL_64_after_hwframe+0x63/0xcd
May 18 17:11:08 dylan-optiplex3010 kernel:  </TASK>
May 18 17:11:08 dylan-optiplex3010 kernel: Modules linked in: sch_ingress af_key tcp_diag nfnetlink_log xfrm_interface xfrm6_tunnel tunnel4 udp_diag tunnel6 inet_diag cfg80211 veth overlay nft_masq nft_chain_nat nf_nat nf_conntrack nf_defrag_ipv6 nf_defrag_ipv4 bridge stp llc nf_tables libcrc32c nfnetlink snd_seq_dummy snd_seq rfcomm vmnet(OE) ppdev parport_pc parport vmw_vsock_vmci_transport vsock vmw_vmci vmmon(OE) qrtr cmac algif_hash algif_skcipher af_alg bnep intel_rapl_msr intel_rapl_common x86_pkg_temp_thermal intel_powerclamp coretemp kvm_intel kvm psmouse irqbypass serio_raw crct10dif_pclmul atkbd crc32_pclmul raid0 libps2 polyval_clmulni vivaldi_fmap polyval_generic mei_hdcp amdgpu dell_wmi mei_pxp gf128mul ghash_clmulni_intel i8042 sha512_ssse3 at24 dell_smbios serio dcdbas aesni_intel iTCO_wdt gpu_sched intel_pmc_bxt iTCO_vendor_support dell_wmi_descriptor sparse_keymap crypto_simd wmi_bmof snd_hda_codec_hdmi md_mod snd_hda_codec_conexant cryptd snd_hda_codec_generic rapl drm_buddy ledtrig_audio
May 18 17:11:08 dylan-optiplex3010 kernel:  intel_cstate r8169 btusb drm_ttm_helper btrtl snd_usb_audio snd_hda_intel btbcm ttm snd_intel_dspcfg btintel snd_intel_sdw_acpi snd_usbmidi_lib realtek btmtk snd_rawmidi snd_hda_codec mdio_devres drm_display_helper bluetooth snd_seq_device snd_hda_core mc snd_hwdep cec i2c_i801 libphy intel_uncore joydev snd_pcm mousedev ecdh_generic rfkill mei_me snd_timer snd soundcore i2c_smbus mei lpc_ich video mac_hid wmi uinput dm_multipath vboxnetflt(OE) vboxnetadp(OE) vboxdrv(OE) sg crypto_user ashmem_linux(OE) dm_mod fuse loop bpf_preload ip_tables x_tables ext4 crc32c_generic crc16 mbcache jbd2 sr_mod crc32c_intel cdrom usbhid
May 18 17:11:08 dylan-optiplex3010 kernel: Unloaded tainted modules: binder_linux(OE):4
May 18 17:11:08 dylan-optiplex3010 kernel: ---[ end trace 0000000000000000 ]---
May 18 17:11:08 dylan-optiplex3010 kernel: RSP: 0018:ffffb5024032fba0 EFLAGS: 00010282
May 18 17:11:08 dylan-optiplex3010 kernel: RAX: 9092b60f0fe28304 RBX: ffffb5024032fc30 RCX: 0000000000000000
May 18 17:11:08 dylan-optiplex3010 kernel: RDX: 000000000000000c RSI: ffffb5024032fc30 RDI: ffffffffc04ad440
May 18 17:11:08 dylan-optiplex3010 kernel: RBP: ffff9f6a40132000 R08: 0000000000000000 R09: 0000000000000002
May 18 17:11:08 dylan-optiplex3010 kernel: general protection fault, probably for non-canonical address 0x9092b60f0fe28304: 0000 [#7] PREEMPT SMP PTI
May 18 17:11:08 dylan-optiplex3010 kernel: CPU: 1 PID: 3169 Comm: firefox Tainted: G      D W  OE      6.1.26-1-MANJARO #1 e1c38db939b1e3efe75f91662b55a6291cec7a5e
May 18 17:11:08 dylan-optiplex3010 kernel: RSP: 0000:ffffb502430bb9b8 EFLAGS: 00010282
May 18 17:11:08 dylan-optiplex3010 kernel: RAX: 9092b60f0fe28304 RBX: ffffb502430bba48 RCX: 0000000000000000
May 18 17:11:08 dylan-optiplex3010 kernel: RDX: 000000000000000c RSI: ffffb502430bba48 RDI: ffffffffc04ad440
May 18 17:11:08 dylan-optiplex3010 kernel: FS:  00007f7ef543c480(0000) GS:ffff9f6d4ec80000(0000) knlGS:0000000000000000
May 18 17:11:08 dylan-optiplex3010 kernel: CR2: 00007f7ec5b6a000 CR3: 0000000270606001 CR4: 00000000001706e0
May 18 17:11:08 dylan-optiplex3010 kernel:  ? __handle_mm_fault+0x92f/0xfa0
May 18 17:11:08 dylan-optiplex3010 kernel:  ? handle_mm_fault+0xdf/0x2d0
May 18 17:11:08 dylan-optiplex3010 kernel:  ? do_user_addr_fault+0x1be/0x6a0
May 18 17:11:08 dylan-optiplex3010 kernel:  ? exc_page_fault+0x74/0x170
May 18 17:11:08 dylan-optiplex3010 kernel:  ? asm_exc_page_fault+0x26/0x30
May 18 17:11:09 dylan-optiplex3010 kernel: general protection fault, probably for non-canonical address 0x9092b60f0fe28304: 0000 [#8] PREEMPT SMP PTI
May 18 17:11:09 dylan-optiplex3010 kernel: CPU: 1 PID: 5406 Comm: kworker/u8:3 Tainted: G      D W  OE      6.1.26-1-MANJARO #1 e1c38db939b1e3efe75f91662b55a6291cec7a5e
May 18 17:11:09 dylan-optiplex3010 kernel: Hardware name: Dell Inc. OptiPlex 3010/042P49, BIOS A22 11/29/2018
May 18 17:11:09 dylan-optiplex3010 kernel: Workqueue: events_unbound commit_work
May 18 17:11:09 dylan-optiplex3010 kernel: RIP: 0010:__x86_indirect_thunk_array+0x10/0x20
May 18 17:11:09 dylan-optiplex3010 kernel: Code: b9 cc cc cc cc cc cc cc cc cc cc cc cc cc cc cc cc cc cc cc cc cc cc cc cc cc e8 07 00 00 00 f3 90 0f ae e8 eb f9 48 89 04 24 <c3> cc cc cc cc 66 66 2e 0f 1f 84 00 00 00 00 00 e8 07 00 00 00 f3
May 18 17:11:09 dylan-optiplex3010 kernel: RSP: 0018:ffffb502480f7560 EFLAGS: 00210282
May 18 17:11:09 dylan-optiplex3010 kernel: RAX: 9092b60f0fe28304 RBX: ffffb502480f75f0 RCX: 0000000000000000
May 18 17:11:09 dylan-optiplex3010 kernel: RDX: 000000000000000c RSI: ffffb502480f75f0 RDI: ffffffffc04ad440
May 18 17:11:09 dylan-optiplex3010 kernel: RBP: ffff9f6a40132000 R08: 0000000000000000 R09: 0000000000000008
May 18 17:11:09 dylan-optiplex3010 kernel: R10: 0000000000000002 R11: 0000000000000003 R12: 92b60f0fe2830c51
May 18 17:11:09 dylan-optiplex3010 kernel: R13: 000000000000000c R14: 000000000000000c R15: ffffffffc04ad440
May 18 17:11:09 dylan-optiplex3010 kernel: FS:  0000000000000000(0000) GS:ffff9f6d4ec80000(0000) knlGS:0000000000000000
May 18 17:11:09 dylan-optiplex3010 kernel: CS:  0010 DS: 0000 ES: 0000 CR0: 0000000080050033
May 18 17:11:09 dylan-optiplex3010 kernel: CR2: 00007f93c2c75000 CR3: 0000000350dac001 CR4: 00000000001706e0
May 18 17:11:09 dylan-optiplex3010 kernel: Call Trace:
May 18 17:11:09 dylan-optiplex3010 kernel:  <TASK>
May 18 17:11:09 dylan-optiplex3010 kernel:  ? do_shrink_slab+0x3a/0x2e0
May 18 17:11:09 dylan-optiplex3010 kernel:  ? VBoxHost_RTUuidToStr+0x210/0x2c0 [vboxdrv 68fee84976504c8167f0e5e9c605615892aa6121]
May 18 17:11:09 dylan-optiplex3010 kernel:  ? shrink_slab+0xaa/0x290
May 18 17:11:09 dylan-optiplex3010 kernel:  ? shrink_node+0x21c/0x710
May 18 17:11:09 dylan-optiplex3010 kernel:  ? do_try_to_free_pages+0xde/0x5a0
May 18 17:11:09 dylan-optiplex3010 kernel:  ? try_to_free_pages+0xe7/0x210
May 18 17:11:09 dylan-optiplex3010 kernel:  ? __alloc_pages_slowpath.constprop.0+0x34c/0xe10
May 18 17:11:09 dylan-optiplex3010 kernel:  ? __alloc_pages+0x224/0x250
May 18 17:11:09 dylan-optiplex3010 kernel:  ? __alloc_pages_bulk+0x462/0x7a0
May 18 17:11:09 dylan-optiplex3010 kernel:  ? __vmalloc_node_range+0xf0/0x7e0
May 18 17:11:09 dylan-optiplex3010 kernel:  ? __vmalloc_node_range+0x255/0x7e0
May 18 17:11:09 dylan-optiplex3010 kernel:  ? dc_create_state+0x22/0x60 [amdgpu 0480d40e88acad82771dcf83484cee747c9f72c9]
May 18 17:11:09 dylan-optiplex3010 kernel:  ? kvmalloc_node+0xa6/0xd0
May 18 17:11:09 dylan-optiplex3010 kernel:  ? amdgpu_dm_atomic_commit_tail+0x21ea/0x2a70 [amdgpu 0480d40e88acad82771dcf83484cee747c9f72c9]
May 18 17:11:09 dylan-optiplex3010 kernel:  ? check_preempt_curr+0x61/0x70
May 18 17:11:09 dylan-optiplex3010 kernel:  ? load_balance+0x7e3/0xea0
May 18 17:11:09 dylan-optiplex3010 kernel:  ? update_load_avg+0x7e/0x780
May 18 17:11:09 dylan-optiplex3010 kernel:  ? psi_group_change+0x15f/0x3a0
May 18 17:11:09 dylan-optiplex3010 kernel:  ? psi_task_switch+0xd6/0x230
May 18 17:11:09 dylan-optiplex3010 kernel:  ? wait_for_completion_timeout+0x13e/0x170
May 18 17:11:09 dylan-optiplex3010 kernel:  ? __switch_to_asm+0x3e/0x60
May 18 17:11:09 dylan-optiplex3010 kernel:  ? finish_task_switch.isra.0+0x90/0x2d0
  1. Left my computer alone for about 30 minutes, came back with a frozen computer.
May 18 19:09:06 dylan-optiplex3010 kernel: ---[ end trace 0000000000000000 ]---
May 18 19:09:27 dylan-optiplex3010 kernel: general protection fault, probably for non-canonical address 0x9092b60f0fe28304: 0000 [#1] PREEMPT SMP PTI
May 18 19:09:27 dylan-optiplex3010 kernel: CPU: 2 PID: 60 Comm: kswapd0 Tainted: G        W  OE      6.1.26-1-MANJARO #1 e1c38db939b1e3efe75f91662b55a6291cec7a5e
May 18 19:09:27 dylan-optiplex3010 kernel: Hardware name: Dell Inc. OptiPlex 3010/042P49, BIOS A22 11/29/2018
May 18 19:09:27 dylan-optiplex3010 kernel: RIP: 0010:__x86_indirect_thunk_array+0x10/0x20
May 18 19:09:27 dylan-optiplex3010 kernel: Code: b9 cc cc cc cc cc cc cc cc cc cc cc cc cc cc cc cc cc cc cc cc cc cc cc cc cc e8 07 00 00 00 f3 90 0f ae e8 eb f9 48 89 04 24 <c3> cc cc cc cc 66 66 2e 0f 1f 84 00 00 00 00 00 e8 07 00 00 00 f3
May 18 19:09:27 dylan-optiplex3010 kernel: RSP: 0000:ffffa0348032fba0 EFLAGS: 00010282
May 18 19:09:27 dylan-optiplex3010 kernel: RAX: 9092b60f0fe28304 RBX: ffffa0348032fc30 RCX: 0000000000000000
May 18 19:09:27 dylan-optiplex3010 kernel: RDX: 000000000000000c RSI: ffffa0348032fc30 RDI: ffffffffc057e440
May 18 19:09:27 dylan-optiplex3010 kernel: RBP: ffff8b7c00135000 R08: 0000000000000000 R09: 0000000000000002
May 18 19:09:27 dylan-optiplex3010 kernel: R10: 0000000000000002 R11: 0000000000000000 R12: 92b60f0fe2830c51
May 18 19:09:27 dylan-optiplex3010 kernel: R13: 000000000000000c R14: 000000000000000c R15: ffffffffc057e440
May 18 19:09:27 dylan-optiplex3010 kernel: FS:  0000000000000000(0000) GS:ffff8b7f0ed00000(0000) knlGS:0000000000000000
May 18 19:09:27 dylan-optiplex3010 kernel: CS:  0010 DS: 0000 ES: 0000 CR0: 0000000080050033
May 18 19:09:27 dylan-optiplex3010 kernel: CR2: 00000000bb268000 CR3: 00000002367cc005 CR4: 00000000001706e0
May 18 19:09:27 dylan-optiplex3010 kernel: Call Trace:
May 18 19:09:27 dylan-optiplex3010 kernel:  <TASK>
May 18 19:09:27 dylan-optiplex3010 kernel:  ? do_shrink_slab+0x3a/0x2e0
May 18 19:09:27 dylan-optiplex3010 kernel:  ? VBoxHost_RTUuidToStr+0x210/0x2c0 [vboxdrv 68fee84976504c8167f0e5e9c605615892aa6121]
May 18 19:09:27 dylan-optiplex3010 kernel:  ? shrink_slab+0xaa/0x290
May 18 19:09:27 dylan-optiplex3010 kernel:  ? shrink_node+0x21c/0x710
May 18 19:09:27 dylan-optiplex3010 kernel:  ? balance_pgdat+0x309/0xa40
May 18 19:09:27 dylan-optiplex3010 kernel:  ? psi_task_switch+0xd6/0x230
May 18 19:09:27 dylan-optiplex3010 kernel:  ? __switch_to_asm+0x3e/0x60
May 18 19:09:27 dylan-optiplex3010 kernel:  ? kswapd+0x1f8/0x3b0
May 18 19:09:27 dylan-optiplex3010 kernel:  ? sugov_start+0x150/0x150
May 18 19:09:27 dylan-optiplex3010 kernel:  ? balance_pgdat+0xa40/0xa40
May 18 19:09:27 dylan-optiplex3010 kernel:  ? kthread+0xde/0x110
May 18 19:09:27 dylan-optiplex3010 kernel:  ? kthread_complete_and_exit+0x20/0x20
May 18 19:09:27 dylan-optiplex3010 kernel:  ? ret_from_fork+0x22/0x30
May 18 19:09:27 dylan-optiplex3010 kernel:  </TASK>
May 18 19:09:27 dylan-optiplex3010 kernel: Modules linked in: snd_seq_dummy snd_seq rfcomm vmnet(OE) ppdev parport_pc parport vmw_vsock_vmci_transport vsock vmw_vmci qrtr vmmon(OE) cmac algif_hash algif_skcipher af_alg bnep intel_rapl_msr intel_rapl_common x86_pkg_temp_thermal intel_powerclamp coretemp kvm_intel raid0 kvm irqbypass crct10dif_pclmul amdgpu psmouse serio_raw atkbd libps2 vivaldi_fmap snd_hda_codec_conexant snd_hda_codec_generic snd_hda_codec_hdmi crc32_pclmul polyval_clmulni snd_hda_intel snd_intel_dspcfg btusb polyval_generic snd_intel_sdw_acpi gf128mul btrtl snd_hda_codec dell_wmi btbcm ghash_clmulni_intel btintel btmtk snd_usb_audio mei_hdcp sha512_ssse3 dell_smbios mei_pxp at24 i8042 snd_usbmidi_lib iTCO_wdt ledtrig_audio intel_pmc_bxt aesni_intel wmi_bmof sparse_keymap iTCO_vendor_support serio snd_rawmidi crypto_simd dell_wmi_descriptor dcdbas r8169 gpu_sched snd_seq_device bluetooth snd_hda_core cryptd rapl drm_buddy mc snd_hwdep drm_ttm_helper intel_cstate realtek mdio_devres ttm mei_me
May 18 19:09:27 dylan-optiplex3010 kernel:  ecdh_generic snd_pcm i2c_i801 intel_uncore i2c_smbus snd_timer drm_display_helper lpc_ich rfkill snd libphy mei cec soundcore md_mod video wmi joydev mousedev mac_hid uinput dm_multipath vboxnetflt(OE) vboxnetadp(OE) vboxdrv(OE) sg crypto_user ashmem_linux(OE) fuse dm_mod loop bpf_preload ip_tables x_tables ext4 crc32c_generic crc16 mbcache jbd2 crc32c_intel sr_mod cdrom usbhid
May 18 19:09:27 dylan-optiplex3010 kernel: Unloaded tainted modules: binder_linux(OE):4
May 18 19:09:27 dylan-optiplex3010 kernel: ---[ end trace 0000000000000000 ]---
May 18 19:09:27 dylan-optiplex3010 kernel: general protection fault, probably for non-canonical address 0x9092b60f0fe28304: 0000 [#2] PREEMPT SMP PTI
May 18 19:09:27 dylan-optiplex3010 kernel: CPU: 1 PID: 50 Comm: khugepaged Tainted: G      D W  OE      6.1.26-1-MANJARO #1 e1c38db939b1e3efe75f91662b55a6291cec7a5e
May 18 19:09:27 dylan-optiplex3010 kernel: RSP: 0000:ffffa034801d38b8 EFLAGS: 00010282
May 18 19:09:27 dylan-optiplex3010 kernel: RAX: 9092b60f0fe28304 RBX: ffffa034801d3948 RCX: 0000000000000000
May 18 19:09:27 dylan-optiplex3010 kernel: RDX: 000000000000000c RSI: ffffa034801d3948 RDI: ffffffffc057e440
May 18 19:09:27 dylan-optiplex3010 kernel: RBP: ffff8b7c00135000 R08: 0000000000000000 R09: 0000000000000004
May 18 19:09:27 dylan-optiplex3010 kernel: FS:  0000000000000000(0000) GS:ffff8b7f0ec80000(0000) knlGS:0000000000000000
May 18 19:09:27 dylan-optiplex3010 kernel: CR2: 00000000b82f1000 CR3: 00000002367cc005 CR4: 00000000001706e0
May 18 19:09:27 dylan-optiplex3010 kernel:  ? do_try_to_free_pages+0xde/0x5a0
May 18 19:09:27 dylan-optiplex3010 kernel:  ? try_to_free_pages+0xe7/0x210
May 18 19:09:27 dylan-optiplex3010 kernel:  ? __alloc_pages_slowpath.constprop.0+0x34c/0xe10
May 18 19:09:27 dylan-optiplex3010 kernel:  ? update_load_avg+0x7e/0x780
May 18 19:09:27 dylan-optiplex3010 kernel:  ? psi_task_switch+0x122/0x230
May 18 19:09:27 dylan-optiplex3010 kernel:  ? __alloc_pages+0x224/0x250
May 18 19:09:27 dylan-optiplex3010 kernel:  ? alloc_charge_hpage+0xd9/0x220
May 18 19:09:27 dylan-optiplex3010 kernel:  ? collapse_huge_page+0xb2/0x1490
May 18 19:09:27 dylan-optiplex3010 kernel:  ? schedule+0x5e/0xd0
May 18 19:09:27 dylan-optiplex3010 kernel:  ? schedule_timeout+0x11c/0x150
May 18 19:09:27 dylan-optiplex3010 kernel:  ? wait_for_completion+0x95/0x160
May 18 19:09:27 dylan-optiplex3010 kernel:  ? hpage_collapse_scan_pmd+0x5b2/0x820
May 18 19:09:27 dylan-optiplex3010 kernel:  ? khugepaged+0x500/0x970
May 18 19:09:27 dylan-optiplex3010 kernel:  ? collapse_pte_mapped_thp+0x5d0/0x5d0
May 18 19:09:27 dylan-optiplex3010 kernel: general protection fault, probably for non-canonical address 0x9092b60f0fe28304: 0000 [#3] PREEMPT SMP PTI
May 18 19:09:27 dylan-optiplex3010 kernel: CPU: 2 PID: 2391 Comm: webrtc_audio_mo Tainted: G      D W  OE      6.1.26-1-MANJARO #1 e1c38db939b1e3efe75f91662b55a6291cec7a5e
May 18 19:09:27 dylan-optiplex3010 kernel: RSP: 0000:ffffa03483a8f9b8 EFLAGS: 00010282
May 18 19:09:27 dylan-optiplex3010 kernel: RAX: 9092b60f0fe28304 RBX: ffffa03483a8fa48 RCX: 0000000000000000
May 18 19:09:27 dylan-optiplex3010 kernel: RDX: 000000000000000c RSI: ffffa03483a8fa48 RDI: ffffffffc057e440
May 18 19:09:27 dylan-optiplex3010 kernel: RBP: ffff8b7c00135000 R08: 0000000000000000 R09: 0000000000000006
May 18 19:09:27 dylan-optiplex3010 kernel: FS:  00007f071f7816c0(0000) GS:ffff8b7f0ed00000(0000) knlGS:0000000000000000
May 18 19:09:27 dylan-optiplex3010 kernel: CR2: 00002b5400c60000 CR3: 0000000206baa002 CR4: 00000000001706e0
May 18 19:09:27 dylan-optiplex3010 kernel:  ? __folio_alloc+0x1b/0x50
May 18 19:09:27 dylan-optiplex3010 kernel:  ? vma_alloc_folio+0xa0/0x360
May 18 19:09:27 dylan-optiplex3010 kernel:  ? __handle_mm_fault+0x92f/0xfa0
May 18 19:09:27 dylan-optiplex3010 kernel:  ? handle_mm_fault+0xdf/0x2d0
May 18 19:09:27 dylan-optiplex3010 kernel:  ? do_user_addr_fault+0x1be/0x6a0
May 18 19:09:27 dylan-optiplex3010 kernel:  ? exc_page_fault+0x74/0x170
May 18 19:09:27 dylan-optiplex3010 kernel:  ? asm_exc_page_fault+0x26/0x30
May 18 19:09:27 dylan-optiplex3010 kernel: general protection fault, probably for non-canonical address 0x9092b60f0fe28304: 0000 [#4] PREEMPT SMP PTI
May 18 19:09:27 dylan-optiplex3010 kernel: CPU: 3 PID: 6269 Comm: Render thread Tainted: G      D W  OE      6.1.26-1-MANJARO #1 e1c38db939b1e3efe75f91662b55a6291cec7a5e
May 18 19:09:27 dylan-optiplex3010 kernel: RSP: 0000:ffffa034835d79b8 EFLAGS: 00010282
May 18 19:09:27 dylan-optiplex3010 kernel: RAX: 9092b60f0fe28304 RBX: ffffa034835d7a48 RCX: 0000000000000000
May 18 19:09:27 dylan-optiplex3010 kernel: RDX: 000000000000000c RSI: ffffa034835d7a48 RDI: ffffffffc057e440
May 18 19:09:27 dylan-optiplex3010 kernel: RBP: ffff8b7c00135000 R08: 0000000000000000 R09: 0000000000000008
May 18 19:09:27 dylan-optiplex3010 kernel: FS:  00007f3ec79176c0(0000) GS:ffff8b7f0ed80000(0000) knlGS:0000000000000000
May 18 19:09:27 dylan-optiplex3010 kernel: CR2: 00000000b9ced000 CR3: 00000002367cc004 CR4: 00000000001706e0
May 18 19:09:27 dylan-optiplex3010 kernel:  ? lru_gen_add_folio+0x2c0/0x2c0
May 18 19:09:27 dylan-optiplex3010 kernel: general protection fault, probably for non-canonical address 0x9092b60f0fe28304: 0000 [#5] PREEMPT SMP PTI
May 18 19:09:27 dylan-optiplex3010 kernel: CPU: 1 PID: 6342 Comm: Worker-Main-1 Tainted: G      D W  OE      6.1.26-1-MANJARO #1 e1c38db939b1e3efe75f91662b55a6291cec7a5e
May 18 19:09:27 dylan-optiplex3010 kernel: RSP: 0000:ffffa034881179b8 EFLAGS: 00010282
May 18 19:09:27 dylan-optiplex3010 kernel: RAX: 9092b60f0fe28304 RBX: ffffa03488117a48 RCX: 0000000000000000
May 18 19:09:27 dylan-optiplex3010 kernel: RDX: 000000000000000c RSI: ffffa03488117a48 RDI: ffffffffc057e440
May 18 19:09:27 dylan-optiplex3010 kernel: R10: 0000000000000002 R11: 0000000000000003 R12: 92b60f0fe2830c51
May 18 19:09:27 dylan-optiplex3010 kernel: FS:  00007f3e17cff6c0(0000) GS:ffff8b7f0ec80000(0000) knlGS:0000000000000000
May 18 19:09:27 dylan-optiplex3010 kernel: CR2: 00000000b99fe000 CR3: 00000002367cc001 CR4: 00000000001706e0
May 18 19:09:27 dylan-optiplex3010 kernel:  ? reweight_entity+0x14d/0x160
May 18 19:09:27 dylan-optiplex3010 kernel:  ? check_preempt_curr+0x61/0x70
May 18 19:09:27 dylan-optiplex3010 kernel:  ? sched_clock_cpu+0xd/0xb0
May 18 19:09:27 dylan-optiplex3010 kernel: general protection fault, probably for non-canonical address 0x9092b60f0fe28304: 0000 [#6] PREEMPT SMP PTI
May 18 19:09:27 dylan-optiplex3010 kernel: CPU: 0 PID: 856 Comm: plasmashell Tainted: G      D W  OE      6.1.26-1-MANJARO #1 e1c38db939b1e3efe75f91662b55a6291cec7a5e
May 18 19:09:27 dylan-optiplex3010 kernel: RSP: 0018:ffffa03481e0f658 EFLAGS: 00010282
May 18 19:09:27 dylan-optiplex3010 kernel: RAX: 9092b60f0fe28304 RBX: ffffa03481e0f6e8 RCX: 0000000000000000
May 18 19:09:27 dylan-optiplex3010 kernel: RDX: 000000000000000c RSI: ffffa03481e0f6e8 RDI: ffffffffc057e440
May 18 19:09:27 dylan-optiplex3010 kernel: FS:  00007f736a940f80(0000) GS:ffff8b7f0ec00000(0000) knlGS:0000000000000000
May 18 19:09:27 dylan-optiplex3010 kernel: CR2: 00007f14e42103e8 CR3: 00000001041ee006 CR4: 00000000001706f0
May 18 19:09:27 dylan-optiplex3010 kernel:  ? __get_free_pages+0x11/0x40
May 18 19:09:27 dylan-optiplex3010 kernel:  ? __pollwait+0x8d/0xe0
May 18 19:09:27 dylan-optiplex3010 kernel:  ? pipe_poll+0xa1/0x150
May 18 19:09:27 dylan-optiplex3010 kernel:  ? do_sys_poll+0x2e4/0x610
May 18 19:09:27 dylan-optiplex3010 kernel:  ? poll_initwait+0x40/0x40
May 18 19:09:27 dylan-optiplex3010 kernel:  ? __pollwait+0xe0/0xe0
May 18 19:09:27 dylan-optiplex3010 kernel:  ? __x64_sys_poll+0xbb/0x150
May 18 19:09:27 dylan-optiplex3010 kernel:  ? do_syscall_64+0x5f/0x90
May 18 19:09:27 dylan-optiplex3010 kernel:  ? switch_fpu_return+0x50/0xe0
May 18 19:09:27 dylan-optiplex3010 kernel:  ? exit_to_user_mode_prepare+0x132/0x1e0
May 18 19:09:27 dylan-optiplex3010 kernel:  ? entry_SYSCALL_64_after_hwframe+0x63/0xcd
May 18 19:09:27 dylan-optiplex3010 kernel: general protection fault, probably for non-canonical address 0x9092b60f0fe28304: 0000 [#7] PREEMPT SMP PTI
May 18 19:09:27 dylan-optiplex3010 kernel: CPU: 0 PID: 1075 Comm: pulseaudio Tainted: G      D W  OE      6.1.26-1-MANJARO #1 e1c38db939b1e3efe75f91662b55a6291cec7a5e
May 18 19:09:27 dylan-optiplex3010 kernel: RSP: 0018:ffffa0348247f618 EFLAGS: 00010282
May 18 19:09:27 dylan-optiplex3010 kernel: RAX: 9092b60f0fe28304 RBX: ffffa0348247f6a8 RCX: 0000000000000000
May 18 19:09:27 dylan-optiplex3010 kernel: RDX: 000000000000000c RSI: ffffa0348247f6a8 RDI: ffffffffc057e440
May 18 19:09:27 dylan-optiplex3010 kernel: FS:  00007f9e9b944840(0000) GS:ffff8b7f0ec00000(0000) knlGS:0000000000000000
May 18 19:09:27 dylan-optiplex3010 kernel: CR2: 00007f14e42103e8 CR3: 000000010c60c004 CR4: 00000000001706f0
May 18 19:09:27 dylan-optiplex3010 kernel:  ? __schedule+0x378/0x12a0
May 18 19:09:27 dylan-optiplex3010 kernel:  ? unix_poll+0x27/0x100
May 18 19:09:27 dylan-optiplex3010 kernel:  ? sock_poll+0x55/0xf0
May 18 19:09:27 dylan-optiplex3010 kernel:  ? __x64_sys_ppoll+0xe2/0x170
May 18 19:09:27 dylan-optiplex3010 kernel:  ? syscall_exit_to_user_mode+0x1b/0x40
May 18 19:09:27 dylan-optiplex3010 kernel:  ? do_syscall_64+0x6b/0x90
May 18 19:09:27 dylan-optiplex3010 kernel: BUG: unable to handle page fault for address: 0000000000032e40
May 18 19:09:27 dylan-optiplex3010 kernel: #PF: supervisor instruction fetch in kernel mode
May 18 19:09:27 dylan-optiplex3010 kernel: #PF: error_code(0x0010) - not-present page
May 18 19:09:27 dylan-optiplex3010 kernel: Oops: 0010 [#8] PREEMPT SMP PTI
May 18 19:09:27 dylan-optiplex3010 kernel: CPU: 2 PID: 862 Comm: QDBusConnection Tainted: G      D W  OE      6.1.26-1-MANJARO #1 e1c38db939b1e3efe75f91662b55a6291cec7a5e
May 18 19:09:27 dylan-optiplex3010 kernel: RIP: 0010:0x32e40
May 18 19:09:27 dylan-optiplex3010 kernel: Code: Unable to access opcode bytes at 0x32e16.
May 18 19:09:27 dylan-optiplex3010 kernel: RSP: 0018:ffffa03481e1fd60 EFLAGS: 00010046
May 18 19:09:27 dylan-optiplex3010 kernel: RAX: 0000000000032e40 RBX: ffff8b7c3ca940d0 RCX: 0000000000000001
May 18 19:09:27 dylan-optiplex3010 kernel: RDX: 0000000000000000 RSI: 0000000000000003 RDI: ffffa03481e0fc00
May 18 19:09:27 dylan-optiplex3010 kernel: RBP: 0000000000000000 R08: ffffa03481e0fc00 R09: 0000000000000000
May 18 19:09:27 dylan-optiplex3010 kernel: R10: 0000000000000000 R11: 0000000000000001 R12: 0000000000000000
May 18 19:09:27 dylan-optiplex3010 kernel: R13: 00000000962ea52a R14: ffff8b7f0ec32e28 R15: 0000000000000001
May 18 19:09:27 dylan-optiplex3010 kernel: FS:  00007f736a4436c0(0000) GS:ffff8b7f0ed00000(0000) knlGS:0000000000000000
May 18 19:09:27 dylan-optiplex3010 kernel: CR2: 0000000000032e40 CR3: 00000001041ee004 CR4: 00000000001706e0
May 18 19:09:27 dylan-optiplex3010 kernel:  ? __wake_up_common+0x76/0x180
May 18 19:09:27 dylan-optiplex3010 kernel:  ? eventfd_write+0x21e/0x320
May 18 19:09:27 dylan-optiplex3010 kernel:  ? wake_up_q+0x90/0x90
May 18 19:09:27 dylan-optiplex3010 kernel:  ? vfs_write+0xcb/0x3f0
May 18 19:09:27 dylan-optiplex3010 kernel:  ? __fget_light+0x9d/0x100
May 18 19:09:27 dylan-optiplex3010 kernel:  ? ksys_write+0x6f/0xf0
May 18 19:09:27 dylan-optiplex3010 kernel:  ? __irq_exit_rcu+0x4b/0xe0
May 18 19:09:27 dylan-optiplex3010 kernel: BUG: unable to handle page fault for address: ffffa03481e0fd18
May 18 19:09:27 dylan-optiplex3010 kernel: #PF: supervisor read access in kernel mode
May 18 19:09:27 dylan-optiplex3010 kernel: #PF: error_code(0x0000) - not-present page
May 18 19:09:27 dylan-optiplex3010 kernel: Oops: 0000 [#9] PREEMPT SMP PTI
May 18 19:09:27 dylan-optiplex3010 kernel: CPU: 2 PID: 818 Comm: kded5 Tainted: G      D W  OE      6.1.26-1-MANJARO #1 e1c38db939b1e3efe75f91662b55a6291cec7a5e
May 18 19:09:27 dylan-optiplex3010 kernel: RIP: 0010:__list_del_entry_valid+0x33/0xe0
May 18 19:09:27 dylan-optiplex3010 kernel: Code: 4f 08 48 85 d2 74 3e 48 85 c9 74 51 48 b8 00 01 00 00 00 00 ad de 48 39 c2 74 55 48 b8 22 01 00 00 00 00 ad de 48 39 c1 74 59 <48> 8b 01 48 39 f8 75 67 48 8b 72 08 48 39 c6 75 74 b8 01 00 00 00
May 18 19:09:27 dylan-optiplex3010 kernel: RSP: 0018:ffffa0348139b9d8 EFLAGS: 00010006
May 18 19:09:27 dylan-optiplex3010 kernel: RAX: dead000000000122 RBX: ffff8b7b36b9e020 RCX: ffffa03481e0fd18
May 18 19:09:27 dylan-optiplex3010 kernel: RDX: ffffa03483f57d78 RSI: ffff8b7b36b9e020 RDI: ffff8b7b36b9e038
May 18 19:09:27 dylan-optiplex3010 kernel: RBP: ffff8b7c001247d0 R08: 0000000000000001 R09: 0000000000000002
May 18 19:09:27 dylan-optiplex3010 kernel: R10: 0000000000000002 R11: 0000000000000002 R12: 0000000000000282
May 18 19:09:27 dylan-optiplex3010 kernel: R13: ffffa0348139bbc0 R14: 0000000000000009 R15: ffff8b7c73d04500
May 18 19:09:27 dylan-optiplex3010 kernel: FS:  00007f1d0443a840(0000) GS:ffff8b7f0ed00000(0000) knlGS:0000000000000000
May 18 19:09:27 dylan-optiplex3010 kernel: CR2: ffffa03481e0fd18 CR3: 000000010c60e006 CR4: 00000000001706e0
May 18 19:09:27 dylan-optiplex3010 kernel:  remove_wait_queue+0x24/0x60
May 18 19:09:27 dylan-optiplex3010 kernel:  poll_freewait+0x6f/0xb0
May 18 19:09:27 dylan-optiplex3010 kernel:  do_sys_poll+0x394/0x610
May 18 19:09:27 dylan-optiplex3010 kernel:  ? ktime_get_ts64+0x4a/0xe0
May 18 19:09:27 dylan-optiplex3010 kernel:  __x64_sys_poll+0xbb/0x150
May 18 19:09:27 dylan-optiplex3010 kernel:  do_syscall_64+0x5f/0x90
May 18 19:09:27 dylan-optiplex3010 kernel:  entry_SYSCALL_64_after_hwframe+0x63/0xcd
May 18 19:09:27 dylan-optiplex3010 kernel: RIP: 0033:0x7f1d041139df
May 18 19:09:27 dylan-optiplex3010 kernel: Code: 54 24 1c 48 89 74 24 10 48 89 7c 24 08 e8 49 76 f8 ff 8b 54 24 1c 48 8b 74 24 10 41 89 c0 48 8b 7c 24 08 b8 07 00 00 00 0f 05 <48> 3d 00 f0 ff ff 77 31 44 89 c7 89 44 24 08 e8 9d 76 f8 ff 8b 44
May 18 19:09:27 dylan-optiplex3010 kernel: RSP: 002b:00007ffc61599780 EFLAGS: 00000293 ORIG_RAX: 0000000000000007
May 18 19:09:27 dylan-optiplex3010 kernel: RAX: ffffffffffffffda RBX: 00007f1cfc000ee0 RCX: 00007f1d041139df
May 18 19:09:27 dylan-optiplex3010 kernel: RDX: 000000000000581a RSI: 000000000000000c RDI: 000055f8f4060b50
May 18 19:09:27 dylan-optiplex3010 kernel: RBP: 000055f8f4060b50 R08: 0000000000000000 R09: 00007ffc61599600
May 18 19:09:27 dylan-optiplex3010 kernel: R10: 00007ffc615a7080 R11: 0000000000000293 R12: 000000000000581a
May 18 19:09:27 dylan-optiplex3010 kernel: R13: 0000000000000001 R14: 000000000000000c R15: 00007f1d037700be
May 18 19:09:28 dylan-optiplex3010 kernel: BUG: unable to handle page fault for address: ffffa0348247fc78
May 18 19:09:28 dylan-optiplex3010 kernel: #PF: supervisor read access in kernel mode
May 18 19:09:28 dylan-optiplex3010 kernel: #PF: error_code(0x0000) - not-present page
  1. Was playing Minecraft and this happened. I’ve noticed that all of these lockups have something to do with a general protection fault, any ideas?
y 18 20:49:55 dylan-optiplex3010 kernel: general protection fault, probably for non-canonical address 0xe58948fffff000e6: 0000 [#1] PREEMPT SMP PTI
May 18 20:49:55 dylan-optiplex3010 kernel: CPU: 2 PID: 60 Comm: kswapd0 Tainted: G        W  OE      6.1.26-1-MANJARO #1 e1c38db939b1e3efe75f91662b55a6291cec7a5e
May 18 20:49:55 dylan-optiplex3010 kernel: Hardware name: Dell Inc. OptiPlex 3010/042P49, BIOS A22 11/29/2018
May 18 20:49:55 dylan-optiplex3010 kernel: RIP: 0010:__x86_indirect_thunk_array+0x10/0x20
May 18 20:49:55 dylan-optiplex3010 kernel: Code: b9 cc cc cc cc cc cc cc cc cc cc cc cc cc cc cc cc cc cc cc cc cc cc cc cc cc e8 07 00 00 00 f3 90 0f ae e8 eb f9 48 89 04 24 <c3> cc cc cc cc 66 66 2e 0f 1f 84 00 00 00 00 00 e8 07 00 00 00 f3
May 18 20:49:55 dylan-optiplex3010 kernel: RSP: 0018:ffffaf984032fba0 EFLAGS: 00010206
May 18 20:49:55 dylan-optiplex3010 kernel: RAX: e58948fffff000e6 RBX: ffffaf984032fc30 RCX: 0000000000000000
May 18 20:49:55 dylan-optiplex3010 kernel: RDX: 000000000000000c RSI: ffffaf984032fc30 RDI: ffffffffc082f440
May 18 20:49:55 dylan-optiplex3010 kernel: RBP: ffff89f000133000 R08: 0000000000000000 R09: 0000000000000002
May 18 20:49:55 dylan-optiplex3010 kernel: R10: 0000000000000002 R11: 0000000000000000 R12: 410000000007c748
May 18 20:49:55 dylan-optiplex3010 kernel: R13: 000000000000000c R14: 000000000000000c R15: ffffffffc082f440
May 18 20:49:55 dylan-optiplex3010 kernel: FS:  0000000000000000(0000) GS:ffff89f30ed00000(0000) knlGS:0000000000000000
May 18 20:49:55 dylan-optiplex3010 kernel: CS:  0010 DS: 0000 ES: 0000 CR0: 0000000080050033
May 18 20:49:55 dylan-optiplex3010 kernel: CR2: 00000000d9200000 CR3: 000000030dc10005 CR4: 00000000001706e0
May 18 20:49:55 dylan-optiplex3010 kernel: Call Trace:
May 18 20:49:55 dylan-optiplex3010 kernel:  <TASK>
May 18 20:49:55 dylan-optiplex3010 kernel:  ? do_shrink_slab+0x3a/0x2e0
May 18 20:49:55 dylan-optiplex3010 kernel:  ? VBoxHost_RTR0MemObjAllocPhysExTag+0x30/0xb0 [vboxdrv 68fee84976504c8167f0e5e9c605615892aa6121]
May 18 20:49:55 dylan-optiplex3010 kernel:  ? shrink_slab+0xaa/0x290
May 18 20:49:55 dylan-optiplex3010 kernel:  ? shrink_node+0x21c/0x710
May 18 20:49:55 dylan-optiplex3010 kernel:  ? balance_pgdat+0x309/0xa40
May 18 20:49:55 dylan-optiplex3010 kernel:  ? psi_task_switch+0xd6/0x230
May 18 20:49:55 dylan-optiplex3010 kernel:  ? __switch_to_asm+0x3e/0x60
May 18 20:49:55 dylan-optiplex3010 kernel:  ? kswapd+0x1f8/0x3b0
May 18 20:49:55 dylan-optiplex3010 kernel:  ? sugov_start+0x150/0x150
May 18 20:49:55 dylan-optiplex3010 kernel:  ? balance_pgdat+0xa40/0xa40
May 18 20:49:55 dylan-optiplex3010 kernel:  ? kthread+0xde/0x110
May 18 20:49:55 dylan-optiplex3010 kernel:  ? kthread_complete_and_exit+0x20/0x20
May 18 20:49:55 dylan-optiplex3010 kernel:  ? ret_from_fork+0x22/0x30
May 18 20:49:55 dylan-optiplex3010 kernel:  </TASK>
May 18 20:49:55 dylan-optiplex3010 kernel: Modules linked in: rfcomm vmnet(OE) ppdev parport_pc parport vmw_vsock_vmci_transport vsock vmw_vmci vmmon(OE) qrtr cmac algif_hash algif_skcipher af_alg bnep intel_rapl_msr intel_rapl_common x86_pkg_temp_thermal intel_powerclamp coretemp psmouse serio_raw atkbd raid0 kvm_intel libps2 amdgpu vivaldi_fmap kvm at24 wmi_bmof irqbypass crct10dif_pclmul crc32_pclmul mei_hdcp mei_pxp polyval_clmulni dell_wmi polyval_generic gf128mul ghash_clmulni_intel iTCO_wdt intel_pmc_bxt snd_hda_codec_conexant snd_hda_codec_generic dell_smbios iTCO_vendor_support sha512_ssse3 snd_usb_audio gpu_sched snd_hda_codec_hdmi dell_wmi_descriptor ledtrig_audio aesni_intel sparse_keymap crypto_simd i8042 snd_hda_intel cryptd btusb btrtl r8169 snd_intel_dspcfg snd_usbmidi_lib drm_buddy rapl snd_intel_sdw_acpi btbcm serio snd_rawmidi btintel realtek drm_ttm_helper snd_seq_device snd_hda_codec btmtk ttm intel_cstate mc dcdbas snd_hda_core i2c_i801 mdio_devres drm_display_helper md_mod snd_hwdep
May 18 20:49:55 dylan-optiplex3010 kernel:  intel_uncore i2c_smbus snd_pcm cec bluetooth snd_timer lpc_ich mei_me ecdh_generic snd libphy mei soundcore rfkill joydev video wmi mousedev mac_hid uinput dm_multipath vboxnetflt(OE) vboxnetadp(OE) vboxdrv(OE) sg crypto_user ashmem_linux(OE) fuse dm_mod loop bpf_preload ip_tables x_tables ext4 crc32c_generic crc16 mbcache jbd2 crc32c_intel sr_mod cdrom usbhid
May 18 20:49:55 dylan-optiplex3010 kernel: Unloaded tainted modules: binder_linux(OE):4
May 18 20:49:55 dylan-optiplex3010 kernel: ---[ end trace 0000000000000000 ]---
May 18 20:51:59 dylan-optiplex3010 kmix[1054]: org.kde.kmix: Could not get icon for "audio-card-pci"
May 18 20:51:59 dylan-optiplex3010 kmix[1054]: org.kde.kmix: Could not get icon for "audio-card-usb"
May 18 20:51:59 dylan-optiplex3010 kmix[1054]: org.kde.kmix: Could not get icon for "chromium-browser"
you mean on xorg?
if a crash happens, and you have to force reboot, post logs from the crash:
journalctl -b-1 -p4 --no-pager
Yeah, I mean Xorg. Sorry.
New crash. Check post 15.
It’s happened again.
I ran a memtest (as was suggested when I looked up “linux general protection fault”) and it was a pass. Any other suggestions? Once again, thanks in advance.
