It is a problem when restoring
Selection
boot
boot/efi
For me, Manjaro is installed in luks ext4 mode, everything is located in the root partition, except for the boot efi partition, which is in the path
boot/efi/ mounted
Now restore through timeshift
When I select the boot path on root, it does not accept
I have to select choose “boot” and “boot/efi” separate efi partitions, this causes problems in grub.
Where is the problem?
Do you use 3 separate partitions?
- The root LUKS partition Ext4 “/”
- The boot partition Ext4 “/boot”
- The EFI partition “Fat32 /boot/efi”
Both are in the Root Partition
I didn’t make a separate for the boot.
I had mistakenly copied the boot files to the boot/efi path, which caused this problem. I formatted the boot/efi partition, reinstalled Grub, and it was solved.
