I’m new to arch-based systems but have been using mostly Debian and to a lesser extent *buntu for 20 years, the last 10+ using luks-encrypted file systems. I’ve been kind of intimidated by arch because I’ve gathered that it is, shall we say, user-perhaps-less-than-friendly, being a rolling release that moves fast and breaks things. This impression was buttressed by my frequently encountering arch pages while looking for answers to technical issues, and perhaps, by seeing how good a lot of the arch-related documentation is. I figured both of these things were evidence of a bit of breakage.
Anywho, I wanted to play around with BTRFS and arch and installed Manjaro on a spare 120 GB SSD I had lying around.
Everything looked fine, but that computer lay in a corner for about 7 months, so when I finally booted Manjaro, there were gobs of updates, that is to be expected. At some point during the update the KDE interface froze pretty hard, but I was able to drop to a shell using Ctrl+Alt+Fx and restart the GUI using ‘systemctl stop sddm’ and starting it again. I did a “sudo pacman -Syu” but it seemed like the program finished normally and there wasn’t anything to do.
But when I rebooted grub wouldn’t load the kernel. I could boot an older snapshot, but didn’t want to upgrade again, fearing I would just get the same result (plus it took a big download and a fair dollop of time). So I tried to chroot into the system from the Debian install on the system, but things didn’t go smoothly. I decrypted the Manjaro partition with:
sudo cryptsetup luksOpen UUID=WhAtEver luks-WhAtEver
And mounted what I figured the partition was with:
mount /dev/mapper/luks-WhAtEver /mountpoint
But I was confronted by several @ sub-volumes at /mountpoint. So I mounted the efi partition at /mountpoint/@/boot/efi and did a:
for i in /dev /dev/pts /proc /sys /sys/firmware/efi/efivars /run; do mount -B $i /mountpoint/@/$i; done
When I chrooted to the system I did a sudo pacman -Syu but was informed that the system was fully updated. But looking around for people who had similar issues I decided to update/reinstall the kernel, but since the system was BTRFS I had issues.
# pacman -Syu linux
core is up to date
extra is up to date
multilib is up to date
warning: linux66-6.6.103-3 is up to date -- reinstalling
resolving dependencies...
Packages (1) linux66-6.6.103-3
Total Download Size: 129.86 MiB
Total Installed Size: 134.95 MiB
Net Upgrade Size: 0.00 MiB
:: Proceed with installation? [Y/n] y
error: could not determine cachedir mount point /var/cache/pacman/pkg/download-ufPZIf
error: failed to commit transaction
I continued nosing through the net and found some pages that sort of pointed me in the right direction, but didn’t quite work for me. (The forum won’t allow me to include links for some reason).
Here is what did:
I booted from a Manjaro live image thinking I could use a special script I’d read about called arch-chroot but it didn’t seem to be on the image.
I persevered. I decrypted the partition.
Then I mounted the decrypted partition and subvolumes.
mount /dev/mapper/luks-WhAtEver /mnt/
I issued the following command to list the btrfs subvolumes:
btrfs subvolume list /mnt -t
ID gen top level path
256 934 5 @
257 931 5 @home
258 925 5 @cache
259 925 5 @log
260 801 5 @swap
270 923 5 timeshift-btrfs/snapshots/2025-09-12_14-01-23/@
271 862 5 timeshift-btrfs/snapshots/2025-09-12_14-10-10/@
272 864 5 timeshift-btrfs/snapshots/2025-09-12_14-11-12/@
I made a subdirectory in the /mnt directory to mount the root partition and the subvolumes.
mkdir /mnt/mountpoint
Then I mounted the necessary subvolumes thusly:
mount -t btrfs -o subvolid=256 /dev/mapper/luks-WhAtVer /mnt/mountpoint/
mount -t btrfs -o subvolid=258 /dev/mapper/luks-WhAtVer /mnt/mountpoint/var/cache/pacman/pkg
mount -t btrfs -o subvolid=259 /dev/mapper/luks-WhAtVer /mnt/mountpoint/var/log
mount -t btrfs -o subvolid=257 /dev/mapper/luks-WhAtVer /mnt/mountpoint/home
Then I mounted the UFI partition.
mount UUID=SomeUuIdNumber /mnt/mountpoint/boot/efi
I prepped the mountpoints for chroot:
for i in /dev /dev/pts /proc /sys /sys/firmware/efi/efivars /run; do mount -B $i /mnt/mountpoint/$i; done
Did the chroot:
chroot /mnt/mountpoint
From there I was able to issue the necessary command, and when I rebooted I was able to boot my Manjaro system, Victory over the forces of evil!
[manjaro /]# sudo pacman -Syu linux
core is up to date
extra is up to date
:: Retrieving packages...
linux66-6.6.103-3-x86_64 129.9 MiB 108 MiB/s 00:01 [####################################] 100%
(1/1) checking keys in keyring [####################################] 100%
(1/1) checking package integrity [####################################] 100%
(1/1) loading package files [####################################] 100%
(1/1) checking for file conflicts [####################################] 100%
(1/1) checking available disk space [####################################] 100%
(1/1) Creating Timeshift snapshot before upgrade...
First run mode (config file not found)
Selected default snapshot type: BTRFS
Using system disk as snapshot device for creating snapshots in BTRFS mode
Mounted '/dev/dm-2 (sdb2)' (subvolid=0) at '/run/timeshift/8065/backup'
btrfs: Quotas are not enabled
Creating new backup...(BTRFS)
Saving to device: /dev/dm-2, mounted at path: /run/timeshift/8065/backup
Created directory: /run/timeshift/8065/backup/timeshift-btrfs/snapshots/2025-09-14_13-27-05
Created subvolume snapshot: /run/timeshift/8065/backup/timeshift-btrfs/snapshots/2025-09-14_13-27-05/@
Created control file: /run/timeshift/8065/backup/timeshift-btrfs/snapshots/2025-09-14_13-27-05/info.json
BTRFS Snapshot saved successfully (0s)
Tagged snapshot '2025-09-14_13-27-05': ondemand
Mounted '/dev/dm-2 (sdb2)' (subvolid=0) at '/run/timeshift/8192/backup'
Selected default snapshot device: /dev/dm-2
Removing snapshot: 2025-09-12_14-10-10
Deleting subvolume: @ (Id:271)
Deleted subvolume: @ (Id:271)
Deleted directory: /run/timeshift/8192/backup/timeshift-btrfs/snapshots/2025-09-12_14-10-10
Removed snapshot: 2025-09-12_14-10-10
Kind of a pain in the posterior but it worked, maybe someone else will find my experience useful
