How I can speed up booting time and loading userspace on Manjaro KDE
Hi!
I have a Manjaro Kde Plasma 5.21.3 installed dual boot with windows 10
I would like to use manjaro as my primary system but while I working on it and after installing some Tools(VS Code Gimp FreeOffice Composer MySQL PHP apache…) I have now a slow booting time
the first time, I measure the boot time:
  • ~ 1:45 for manjaro
  • ~ 0:50 ~ 1:00 for windows 10(a lot of software installed on it)
now the booting time up to 2:30 for manjaro
Please how I can improve the boot time I am new in manjaro but I love using Linux & I want to make the system performance better for development and blogging.
systemd-analyze
   Startup finished in 5.960s (kernel) + 39.511s (userspace) = 45.472s
graphical.target reached after 37.572s in userspace
systemd-analyze blame
16.710s snapd.service
 9.947s udisks2.service
 9.728s polkit.service
 8.078s dev-loop7.device
 7.979s dev-loop4.device
 7.760s dev-loop8.device
 7.633s dev-loop6.device
 7.121s dev-loop3.device
 7.032s dev-loop5.device
 7.032s upower.service
 6.304s avahi-daemon.service
 6.294s NetworkManager.service
 6.215s systemd-logind.service
 6.067s dev-loop2.device
 5.975s dev-sda8.device
 5.680s dev-loop0.device
 5.661s dev-loop1.device
 5.559s snapd.apparmor.service
 4.657s systemd-fsck@dev-disk-by\x2duuid-0f3f3a97\x2d9d67\x2d4f05\x2d94ba\x2dc82438d8a048.service
 3.469s ModemManager.service
 3.196s apparmor.service
 3.167s cups.service
 2.109s systemd-fsck@dev-disk-by\x2duuid-dd95a45d\x2d013e\x2d4ae3\x2d8b39\x2da188875d79d2.service
 1.929s tlp.service
 1.775s systemd-udevd.service
 1.418s systemd-fsck-root.service
 1.234s user@1000.service
 1.000s wpa_supplicant.service
  954ms dev-disk-by\x2duuid-83b11a9a\x2d09e7\x2d4aea\x2d8e79\x2ddd8e1b052992.swap
  947ms systemd-tmpfiles-setup.service
  939ms var-lib-snapd-snap-android\x2dfile\x2dtransfer\x2dlinux-199.mount
  851ms systemd-tmpfiles-setup-dev.service
  816ms modprobe@drm.service
  800ms var-lib-snapd-snap-chromium-1523.mount
  778ms systemd-tmpfiles-clean.service
  773ms systemd-modules-load.service
  682ms systemd-udev-trigger.service
  605ms var-lib-snapd-snap-code-59.mount
  556ms home.mount
  500ms var-lib-snapd-snap-core18-1988.mount
  453ms var-lib-snapd-snap-core-10908.mount
  450ms var-lib-snapd-snap-gnome\x2d3\x2d28\x2d1804-145.mount
  401ms systemd-journald.service
  396ms systemd-backlight@backlight:acpi_video0.service
  372ms var-lib-snapd-snap-gtk\x2dcommon\x2dthemes-1514.mount
  338ms systemd-random-seed.service
  328ms modprobe@fuse.service
  326ms linux-module-cleanup.service
  227ms systemd-sysctl.service
  225ms var-lib-snapd-snap-snapd-11402.mount
  218ms boot.mount
  208ms dev-hugepages.mount
  206ms dev-mqueue.mount
  204ms sys-kernel-debug.mount
  202ms sys-kernel-tracing.mount
  198ms kmod-static-nodes.service
  197ms modprobe@configfs.service
  181ms var-lib-snapd-snap-notable-3.mount
  178ms systemd-binfmt.service
  142ms rtkit-daemon.service
  106ms systemd-remount-fs.service
   80ms systemd-update-utmp.service
   75ms systemd-journal-flush.service
   37ms user-runtime-dir@1000.service
   32ms systemd-user-sessions.service
   13ms systemd-backlight@backlight:radeon_bl0.service
   10ms tmp.mount
    6ms sys-kernel-config.mount
    4ms snapd.socket
    4ms proc-sys-fs-binfmt_misc.mount
    3ms sys-fs-fuse-connections.mount
systemd-analyze critical-chain
graphical.target @37.572s
└─multi-user.target @37.570s
  └─snapd.service @20.859s +16.710s
    └─basic.target @20.773s
      └─sockets.target @20.773s
        └─snapd.socket @20.768s +4ms
          └─sysinit.target @20.720s
            └─systemd-update-utmp.service @20.639s +80ms
              └─systemd-tmpfiles-setup.service @19.687s +947ms
                └─local-fs.target @19.683s
                  └─boot.mount @19.464s +218ms
                    └─systemd-fsck@dev-disk-by\x2duuid-dd95a45d\x2d013e\x2d4ae3\x2d8b39\x2da188875d79d2.service @17.321s +2.109s
                      └─dev-disk-by\x2duuid-dd95a45d\x2d013e\x2d4ae3\x2d8b39\x2da188875d79d2.device @17.317s
Hi, do you use snaps? Because it really slows down boot time.
If not you can disable snap service with sudo systemctl disable snapd.service and sudo systemctl disable snapd.apparmor.service
But if you won’t ever use snaps, you can uninstall snapd and pamac-snap-plugin packages.
There, you should have an enhanced boot time after reboot.
Thanks, now I disable them.
I have tried using hibernate & it makes the booting time faster.
but with some problems (I am trying to fix them at this moment).
