how execute script python
how to run one python script when turning on computer? (I am a beginner in the manjaro and I am using google translator)
Assume that you want this script keep running in the background like a service-daemon.
Since Manjaro uses systemd (like Arch), one way to do this is to write an unit file (ArchWiki) for your script and let it be managed by systemd (as a service.)
Add:
#!/usr/bin/env python
To the top of the script.
Make the script executable:
chmod +x yourscript.py
Add it to your start up programs. It is a bit more complicated if running gnome.
How do I put in startup programs? I'm using XFCE
search function go to
I really should have an XFCE install to refer to.
Seems to cover it.
