How does one provide value of xxxxxxxxxx
In following post
https://forum.manjaro.org/t/preventing-manjaro-bootloader-from-being-overridden/27805
By telling us more. Where and what value would be a good start.
That’s the uuid of the partition. In that post, it refers to the uuid of the manjaro partition.
search --no-floppy --fs-uuid --set=root xxxxxxxxxxxxxxxxxxxxxxxx
configfile /boot/grub/grub.cfg
So that is the root partition / define at install?
Defined at ‘sudo blkid’
Still. Blkid looking for manjaro root / partition ?
no.
Post must be at least 5 characters
UUID of sda perhaps? Ok once I get to my computer later I will,post values of blkid ok?
ok
Or you can use Thumbs up emoji :+1: on the post you want to respond :sunglasses:
/dev/sda1: UUID="85e9779a-91d5-423e-80ca-a4828496e5a1" TYPE="ext4" PARTUUID="daea0421-01"
/dev/sda2: UUID="98581c7e-ae0b-485b-91b5-bad998185e82" TYPE="swap" PARTUUID="daea0421-02"
/dev/sda3: UUID="1bc6e4b8-9f1f-449b-8d96-c11621148aaa" TYPE="ext4" PARTUUID="daea0421-03"
/dev/sda5: LABEL="DataShare" UUID="309dd93a-cbc2-4604-9401-088dc6a1377d" TYPE="ext4" PARTUUID="daea0421-05"
/dev/sda6: UUID="870b2d61-df4a-46e1-9cb4-c90395537e90" TYPE="ext4" PARTUUID="daea0421-06"
/dev/sda7: UUID="cebf6ab1-8689-4ec6-82f8-00d414b828b0" TYPE="swap" PARTUUID="daea0421-07"
/dev/sda8: UUID="dab9e75c-33d4-4fd7-a529-41d8b9a5292e" TYPE="ext4" PARTUUID="daea0421-08"
/dev/sdb1: LABEL="FreeAgent" UUID="8044F89544F88F62" TYPE="ntfs" PARTUUID="d7e7ccf0-01"
/dev/sdg1: LABEL="MyBook" UUID="F21843B31843759F" TYPE="ntfs" PTTYPE="atari" PARTUUID="00064002-01"
/dev/sdh1: LABEL="FA1T" UUID="4C60612A60611BC8" TYPE="ntfs" PARTUUID="9e878aae-01"
For the record I have
sda1 /  -Mint
sda2 swap
sda3 Home - Mint
sda6 / - manjaro
sda7 swap
sda8 Home - Manjaro
is the uuid you need for --root
Nice! Thanks for that! :grin:
Now in regards to [A fallback alternative] is that good to use in Linux Mint 18?
IN regards to btrfs will need additional tweeks (rootflag=subvolume=@)
This is foreign to me and I kind of like to idea of
Preventing Manjaro bootloader from being overridden
Still I can always fall back to https://forum.manjaro.org/t/using-livecd-v17-0-1-as-grub-to-boot-os-with-broken-bootloader/24916
yes.
Cool!. I will give it a try. Thanks for your support guys! :star_struck:
