How do you get LG Gram 13.3 Fingerprinter working?
deepin
#1
Need help with setting up the fingerprinter reader for my laptop. I ran lsusb but nothing is coming up?
Bus 002 Device 001: ID 1d6b:0003 Linux Foundation 3.0 root hub
Bus 001 Device 004: ID 10a5:0007
Bus 001 Device 003: ID 0bda:562e Realtek Semiconductor Corp.
Bus 001 Device 002: ID 8087:0a2b Intel Corp.
Can anyone help?
#2
Some information about that some models will be supported in the 4.20 kernel
https://www.phoronix.com/scan.php?page=news_item&px=LG-Gram-Laptop-Linux-Driver
The arch wiki on using the Fingerprint GUI
https://wiki.archlinux.org/index.php/Fingerprint_GUI
A link to the AUR package is in the wiki. If you want to install it on Manjaro you will need to:
  • Install the 4.20 kernel using the Manjaro Settings Manager > Kernel
  • Then from terminal run
    sudo pacman -S trizen base-devel --needed
    trizen -S fingerprint-gui --noconfirm
#3
thanks, I think I have the 4.20 running on my lg gram I will give it a go
#4
please advice how to run the command in the right order. if enter at once, getting “error only one command can be used at time”. The finger-gui most be installed first i take it?
#5
Each line separately, after the first finished run the second.
#6
thanks, all installed now. Do i then just run fingerprint-gui in the command line?
#7
No :slight_smile: You have to follow the entire wiki i provided about it, check each step and do what they suggest there.
#8
thanks, just ran the first step listed on the wiki and reached a wall. No finger print device found. I guess the drivers and hardware from LG is not fully implemented on in the new kernel.
#9
you may wish to ask philm nicely to take a look at this. the person compiling the kernel has to enable the new LG Gram hardware support according to the phoronix article. it is only available if a flag is toggled during the kernel build.
toggled at build time via LG_LAPTOP Kconfig switch
#10
thanks, is he on part of the forum or if so how do I get in touch with him?
#11
shove a @ symbol in front of his name
#12
thanks for the response
#13
just ran the first step listed on the wiki and reached a wall. No finger print device found. I guess the drivers and hardware from LG is not fully implemented on in the new kernel. @philm can you help?
#14
Let’s see the xinput --list if is listed there, then it should work …
#15
is this a command line list, how do I use it.
#16
Open terminal an run it from there, then share that list it displays.
#17
getting this error “bash: Xinput: command not found”
#18
is xinput not Xinput but maybe is unrelated to case-sensitive and you need to install it:
sudo pacman -S xorg-xinput
then
xinput --list
#19
Virtual core pointer id=2 [master pointer (3)]
⎜ ↳ Virtual core XTEST pointer id=4 [slave pointer (2)]
⎜ ↳ 04CA00A0:00 04CA:00A0 Touchpad id=9 [slave pointer (2)]
⎜ ↳ MELF0411:00 1FD2:7011 id=10 [slave pointer (2)]
⎣ Virtual core keyboard id=3 [master keyboard (2)]
↳ Virtual core XTEST keyboard id=5 [slave keyboard (3)]
↳ Video Bus id=6 [slave keyboard (3)]
↳ Power Button id=7 [slave keyboard (3)]
↳ Sleep Button id=8 [slave keyboard (3)]
↳ AT Translated Set 2 keyboard id=11 [slave keyboard (3)]
↳ LG Camera: LG Camera id=12 [slave keyboard (3)]
#20
I think this is it, but i can’t find any references about it. You will have to wait that someone with more knowledge comes along, as i can’t help you out.
