I want to automatically login after waking up from suspend. Security isn’t an issue because this is just a media center. I do have a password though.
I am using the default SDDM as my display manager and have already checked Login in immediately after logging off in the advanced tab.
I think there should be some option to disable screen-lock, most likely in power manager settings or screensaver. (I use XFCE, so can’t pin-point you to the respective section)
Thank you, it was in the Workspace Behavior.
