Hi. I’m new to Linux and I’m currently using Manjaro. I installed xfce4-terminal using pacman : pacman -S xfce4-terminal
The installation worked fine but when I try to launch the xfce4 terminal, the cursor shows that it is loading the terminal but it doesn’t open. The gnome-terminal is working fine, but I wanted to use xfce4 terminal for its customizability.
OS: Manjaro Linux x86_64
Kernel: 5.9.16-1-MANJARO
Shell: zsh 5.8
DE: GNOME 3.38.3
Terminal: gnome-terminal
is there anything i can do to make this work or should i just stick to gnome-terminal ? tyia.
Yes Sir, it is up to date. :: Synchronizing package databases... core 167.2 KiB 808 KiB/s 00:00 [###################################] 100% extra 1983.7 KiB 8.31 MiB/s 00:00 [###################################] 100% community 6.5 MiB 7.07 MiB/s 00:01 [###################################] 100% multilib 181.3 KiB 3.28 MiB/s 00:00 [###################################] 100% :: Starting full system upgrade... there is nothing to do
That is a very strange error then, because:
that library which is not found in your system, according to the error message,
is present in my fully updated system
My DE is Xfce - maybe that makes a difference - but it shouldn’t.
pacman -Qo /usr/lib/libxfconf-0.so.3
shows, that this is in “xfconf”: /usr/lib/libxfconf-0.so.3 is owned by xfconf 4.16.0-1
which, strangely, probably didn’t get installed for you when you installed xfce4-terminal, because it isn’t a dependency of xfce4-terminal, even though it should be
Installing xfconf should help - at least it provides that library and the terminal should then work
