Today, in trying to update Manjaro, I received a “Failed to prepare transaction.” The error message says: target not found: python-referencing
How do I fix this? Anyone?
sudo pacman-mirrors -f 5 && sudo pkgfile -u && sudo pacman -Syyu python-referencing
Hi @Wayne636,
Since the package is in the extra
repository:
$ pamac search python-referencing
python-referencing 0.29.1-1 extra
An implementation-agnostic implementation of JSON reference resolution
…I’d say you need to refresh your mirror(s):
sudo pacman-mirrors --fasttrack 5
Followed by refreshing your package list:
pamac upgrade --force-refresh
Hope this helps!
To be precise, this is likely all that’s needed:
sudo pacman -Syu python-referencing
Rebuilding the mirrorlist should only be needed if you have a problem with your mirrors.
Yes, but the last Stable update included the merge of the Community repository into the Extra repository, so it’s not a bad idea to refresh both the mirror list and the package list.
