How do I stop the system from suspending when I close the lid?
Please reply if you know how to do this
Thanks in advance for helping
if you’re using gnome then search tweaks and in general uncheck the second option which says, “suspend when laptop lid is closed”.
Hi @Aspect,
If you’re using KDE, go to System settings → Hardware → Power Management → Energy Saving.
There you should be able to set what happens when the lid is closed. Set and Apply as neccessary. (On my desktop it’s not the lid closing I can customize, but rather what happens when the power button is pressed.)
Hope this helps!
