Trying to schedule a oneshot event with systemd timer. But the result is actually twoshot. Starting the timer runs the service, and then elapsing the timer runs the service again.
How would I adjust the following to prevent the initial run, and only fire off the service exactly once, after the timer has elapsed?
~/.config/systemd/user/relax.service
[Unit]
Description=Reminder to relax
[Service]
Type=oneshot
ExecStart=echo Relax
~/.config/systemd/user/relax.timer
[Unit]
Description=Future reminder to relax
Requires=relax.service
[Timer]
Unit=relax.service
OnActiveSec=10s
# Accuracy for fast and predictable debugging
# First run will be perceptually immediate,
# and second-run appears to be exactly 10s later.
AccuracySec=1us
RemainAfterElapse=false
[Install]
WantedBy=timers.target
This option means the timer is started with the systemctl start command, 10 seconds later it is started again. So the first run is need to start the 10 seconds for OnActiveSec.
Thanks for the suggestion. But this is no longer contained inside a unit. Kind of defeats the purpose in choosing systemd for the timer, don’t you think?
Also, from my brief research, stopping/cancelling/removing a transient timer looks to require hacky solutions.
I don’t really know, since I don’t know what your use case is, it works for the test case you’ve shown. I was just pointing it out in the unlikely case it was enough, or maybe helped with troubleshooting.
