I am trying to use shim-signed but it appears that my current grub installation doesn’t use a SBAT file, is there a way to set grub to use an SBAT file automatically after kernel updates and the image is regenerated?
Extra info: im on 5.15
A internet search found this [SOLVED] How to add .Sbat for Shim/Grub - Secure Boot / Newbie Corner / Arch Linux Forums which should be of help. I really don’t know tho, as I was just curious as to what a SBAT csv file was
