I have two audio streams running. How do I play one on my HDMI connected TV and how do I play one on my laptop’s built-in speakers?
Thanks in advance.
Thanks in advance.
For KDE you can install pavucontrol-qt
for PulseAudio Volume Control for PulseAudio or PipeWire
The Playback tab ( pavucontrol -t1
) allows audio streams to be assigned to different playback devices.
That’s not what appears on my screen:
However on Windows (I have dualboot) I could do it.
What should I set my configuration to?
The drop-down menu is not shown if only one audio device is active and available
Check devices in the Configuration tab. One of the devices may have Profile set to Off
With jack or pipewire-jack, you can route sound source to separate outputs.
But probably can’t separate two firefox’s youtube streams to different outputs.
OP was asking for simple thing that should be achievable without a 2nd pro-audio server
(but might require some reconfiguration to get devices visible in pavucontrol)
You posted a similar suggestion to the same user 2 days ago, when OP was seeking help with an ALSA related problem
Audio output not working despite speakers being detected - #2 by aki42
I also notice another comment 2 days ago about use of pavucontrol, follows a suggestion to use pipewire and qjackctl
USB Webcam microphone detected, but there is no sound - #2 by aki42
I have deleted your screenshot so other users can see the context of this discussion without distraction
If you post a similar suggestion in other discussions with new users I will delete it as spam
The only device there was my built-in audio, no other device.
It works when I set the profile to HDMI, but then anything else I play will play on the TV.
I think it should work because as I said previously, in my Windows dualboot I can do this.
I’m not quite sure what to do, I have no clue how to use more advanced tools.
What happens if you unplug the HDMI connection to the TV?
Can you see audio playing in Playback and Output Devices level meters even if you cannot hear it?
Please post response to this command to show audio playback subdevices
aplay -l
and this to show ALSA settings
amixer -c0
and also this to show information about audio Profiles and Ports
pacmd list-cards
Okay, so right now I have my TV connected. Here is my “configuration” on pavucontrol:
If the profile is changed to something that doesn’t have HTML in it, it plays over my speakers. But either everything is on the TV, or everything on the computer. My TV is not appearing in this list, but it appeared on my Windows dualboot.
Again, I have my TV connected via HTML.
aplay -l
**** List of PLAYBACK Hardware Devices ****
card 0: PCH [HDA Intel PCH], device 0: ALC295 Analog [ALC295 Analog]
Subdevices: 1/1
Subdevice #0: subdevice #0
card 0: PCH [HDA Intel PCH], device 3: HDMI 0 [HDMI 0]
Subdevices: 0/1
card 0: PCH [HDA Intel PCH], device 7: HDMI 1 [HDMI 1]
Subdevices: 1/1
card 0: PCH [HDA Intel PCH], device 8: HDMI 2 [HDMI 2]
Subdevices: 1/1
card 0: PCH [HDA Intel PCH], device 9: HDMI 3 [HDMI 3]
Subdevices: 1/1
card 0: PCH [HDA Intel PCH], device 10: HDMI 4 [HDMI 4]
Subdevices: 1/1
amixer -c0 INT ✘
Simple mixer control 'Master',0
Capabilities: pvolume pvolume-joined pswitch pswitch-joined
Playback channels: Mono
Limits: Playback 0 - 87
Mono: Playback 87 [100%] [0.00dB] [on]
Simple mixer control 'Headphone',0
Capabilities: pvolume pswitch
Mono:
Front Left: Playback 0 [0%] [-65.25dB] [off]
Front Right: Playback 0 [0%] [-65.25dB] [off]
Simple mixer control 'Speaker',0
Mono:
Front Left: Playback 87 [100%] [0.00dB] [on]
Front Right: Playback 87 [100%] [0.00dB] [on]
Simple mixer control 'PCM',0
Limits: Playback 0 - 255
Mono:
Front Left: Playback 255 [100%] [0.00dB]
Front Right: Playback 255 [100%] [0.00dB]
Simple mixer control 'Mic Boost',0
Capabilities: volume
Limits: 0 - 3
Front Left: 0 [0%] [0.00dB]
Front Right: 0 [0%] [0.00dB]
Simple mixer control 'IEC958',0
Capabilities: pswitch pswitch-joined
Mono: Playback [on]
Simple mixer control 'IEC958',1
Mono: Playback [on]
Simple mixer control 'IEC958',2
Mono: Playback [on]
Simple mixer control 'IEC958',3
Mono: Playback [on]
Simple mixer control 'IEC958',4
Mono: Playback [on]
Simple mixer control 'Capture',0
Capabilities: cvolume cswitch
Limits: Capture 0 - 63
Front Left: Capture 46 [73%] [17.25dB] [on]
Front Right: Capture 46 [73%] [17.25dB] [on]
Simple mixer control 'Auto-Mute Mode',0
Capabilities: enum
Items: 'Disabled' 'Enabled'
Item0: 'Disabled'
Simple mixer control 'Internal Mic Boost',0
Limits: 0 - 3
pacmd list-cards INT ✘
1 card(s) available.
index: 0
driver: <module-alsa-card.c>
owner module: 6
properties:
alsa.card = "0"
alsa.long_card_name = "HDA Intel PCH at 0xb1228000 irq 131"
sysfs.path = "/devices/pci0000:00/0000:00:1f.3/sound/card0"
device.bus = "pci"
device.vendor.id = "8086"
device.product.id = "9d71"
device.product.name = "Sunrise Point-LP HD Audio"
device.string = "0"
device.description = "Built-in Audio"
module-udev-detect.discovered = "1"
device.icon_name = "audio-card-pci"
profiles:
input:analog-stereo: Analog Stereo Input (priority 32833, available: unknown)
output:analog-stereo: Analog Stereo Output (priority 39268, available: unknown)
output:analog-stereo+input:analog-stereo: Analog Stereo Duplex (priority 39333, available: unknown)
output:hdmi-stereo: Digital Stereo (HDMI) Output (priority 38668, available: unknown)
output:hdmi-stereo+input:analog-stereo: Digital Stereo (HDMI) Output + Analog Stereo Input (priority 38733, available: unknown)
output:hdmi-surround: Digital Surround 5.1 (HDMI) Output (priority 33568, available: unknown)
output:hdmi-surround+input:analog-stereo: Digital Surround 5.1 (HDMI) Output + Analog Stereo Input (priority 33633, available: unknown)
output:hdmi-surround71: Digital Surround 7.1 (HDMI) Output (priority 33568, available: unknown)
output:hdmi-surround71+input:analog-stereo: Digital Surround 7.1 (HDMI) Output + Analog Stereo Input (priority 33633, available: unknown)
output:hdmi-stereo-extra1: Digital Stereo (HDMI 2) Output (priority 5700, available: no)
output:hdmi-stereo-extra1+input:analog-stereo: Digital Stereo (HDMI 2) Output + Analog Stereo Input (priority 5765, available: unknown)
output:hdmi-surround-extra1: Digital Surround 5.1 (HDMI 2) Output (priority 600, available: no)
output:hdmi-surround-extra1+input:analog-stereo: Digital Surround 5.1 (HDMI 2) Output + Analog Stereo Input (priority 665, available: unknown)
output:hdmi-surround71-extra1: Digital Surround 7.1 (HDMI 2) Output (priority 600, available: no)
output:hdmi-surround71-extra1+input:analog-stereo: Digital Surround 7.1 (HDMI 2) Output + Analog Stereo Input (priority 665, available: unknown)
output:hdmi-stereo-extra2: Digital Stereo (HDMI 3) Output (priority 5700, available: no)
output:hdmi-stereo-extra2+input:analog-stereo: Digital Stereo (HDMI 3) Output + Analog Stereo Input (priority 5765, available: unknown)
output:hdmi-surround-extra2: Digital Surround 5.1 (HDMI 3) Output (priority 600, available: no)
output:hdmi-surround-extra2+input:analog-stereo: Digital Surround 5.1 (HDMI 3) Output + Analog Stereo Input (priority 665, available: unknown)
output:hdmi-surround71-extra2: Digital Surround 7.1 (HDMI 3) Output (priority 600, available: no)
output:hdmi-surround71-extra2+input:analog-stereo: Digital Surround 7.1 (HDMI 3) Output + Analog Stereo Input (priority 665, available: unknown)
output:hdmi-stereo-extra3: Digital Stereo (HDMI 4) Output (priority 5700, available: no)
output:hdmi-stereo-extra3+input:analog-stereo: Digital Stereo (HDMI 4) Output + Analog Stereo Input (priority 5765, available: unknown)
output:hdmi-surround-extra3: Digital Surround 5.1 (HDMI 4) Output (priority 600, available: no)
output:hdmi-surround-extra3+input:analog-stereo: Digital Surround 5.1 (HDMI 4) Output + Analog Stereo Input (priority 665, available: unknown)
output:hdmi-surround71-extra3: Digital Surround 7.1 (HDMI 4) Output (priority 600, available: no)
output:hdmi-surround71-extra3+input:analog-stereo: Digital Surround 7.1 (HDMI 4) Output + Analog Stereo Input (priority 665, available: unknown)
output:hdmi-stereo-extra4: Digital Stereo (HDMI 5) Output (priority 5700, available: no)
output:hdmi-stereo-extra4+input:analog-stereo: Digital Stereo (HDMI 5) Output + Analog Stereo Input (priority 5765, available: unknown)
output:hdmi-surround-extra4: Digital Surround 5.1 (HDMI 5) Output (priority 600, available: no)
output:hdmi-surround-extra4+input:analog-stereo: Digital Surround 5.1 (HDMI 5) Output + Analog Stereo Input (priority 665, available: unknown)
output:hdmi-surround71-extra4: Digital Surround 7.1 (HDMI 5) Output (priority 600, available: no)
output:hdmi-surround71-extra4+input:analog-stereo: Digital Surround 7.1 (HDMI 5) Output + Analog Stereo Input (priority 665, available: unknown)
off: Off (priority 0, available: unknown)
active profile: <output:hdmi-stereo>
sinks:
alsa_output.pci-0000_00_1f.3.hdmi-stereo/#2: Built-in Audio Digital Stereo (HDMI)
sources:
alsa_output.pci-0000_00_1f.3.hdmi-stereo.monitor/#3: Monitor of Built-in Audio Digital Stereo (HDMI)
ports:
analog-input-internal-mic: Internal Microphone (priority 8900, latency offset 0 usec, available: unknown)
properties:
analog-input-mic: Microphone (priority 8700, latency offset 0 usec, available: no)
properties:
analog-output-speaker: Speakers (priority 10000, latency offset 0 usec, available: unknown)
properties:
analog-output-headphones: Headphones (priority 9900, latency offset 0 usec, available: no)
properties:
hdmi-output-0: HDMI / DisplayPort (priority 5900, latency offset 0 usec, available: yes)
properties:
device.product.name = "D39hn-E0"
hdmi-output-1: HDMI / DisplayPort 2 (priority 5800, latency offset 0 usec, available: no)
properties:
hdmi-output-2: HDMI / DisplayPort 3 (priority 5700, latency offset 0 usec, available: no)
properties:
hdmi-output-3: HDMI / DisplayPort 4 (priority 5600, latency offset 0 usec, available: no)
properties:
hdmi-output-4: HDMI / DisplayPort 5 (priority 5500, latency offset 0 usec, available: no)
properties:
ALSA data is showing output for Headphone is set to 0% and muted [off]
This is not unusual for a laptop system as the Headphone output would normally be muted automatically, but Auto-Mute Mode is set to Disabled
I suggest you enable auto-mute so audio can switch between the 2 analog outputs
amixer --set 'Auto-Mute Mode' Enabled
then plug in headphones (or any other 3.5mm jack - auto-mute in ALSA only detects if a jack is plugged in)
and check amixer -c0
to determine if auto-mute has unmuted Headphone output and muted Speaker output as expected
PulseAudio profile for card must be changed from Digital Stereo (HDMI) Output to Analog Stereo Output to access audio outputs
The Output Devices tab in pavucontrol should show a drop-down menu for Headphones and Speakers Ports
