Could not probe OpenGL. This program requires OpenGL 2.0 or higher. Please check your video card drivers.
I’m getting this error with Cura 5.0.0 appimage. Cura 4.13.1 is working fine though.
KDE Plasma Version: 5.24.5
KDE Frameworks Version: 5.94.0
Qt Version: 5.15.4
Kernel Version: 5.15.41-1-MANJARO (64-bit)
Graphics Platform: X11
Processors: 16 × AMD Ryzen 7 2700X Eight-Core Processor
Memory: 31.4 GiB of RAM
Graphics Processor: AMD Radeon RX 580 Series
$ inxi --admin --verbosity=7 --filter --width ✔ 01:10:36 AM
Kernel: 5.15.41-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 12.1.0
root=UUID=2bb84221-8736-478d-8f20-6c17ab04e608 rw quiet apparmor=1
Desktop: KDE Plasma v: 5.24.5 tk: Qt v: 5.15.4 info: latte-dock
wm: kwin_x11 vt: 1 dm: SDDM Distro: Manjaro Linux base: Arch Linux
Type: Desktop Mobo: Micro-Star model: B450M GAMING PLUS (MS-7B87) v: 1.0
serial: <superuser required> UEFI: American Megatrends v: 1.C0
date: 06/11/2020
RAM: total: 31.36 GiB used: 18.74 GiB (59.8%)
RAM Report:
Info: model: AMD Ryzen 7 2700X bits: 64 type: MT MCP arch: Zen+ gen: 2
built: 2018-21 process: GF 12nm family: 0x17 (23) model-id: 8 stepping: 2
microcode: 0x800820D
Topology: cpus: 1x cores: 8 tpc: 2 threads: 16 smt: enabled cache:
L1: 768 KiB desc: d-8x32 KiB; i-8x64 KiB L2: 4 MiB desc: 8x512 KiB
L3: 16 MiB desc: 2x8 MiB
Speed (MHz): avg: 4099 high: 4100 min/max: N/A cores: 1: 4100 2: 4100
3: 4100 4: 4100 5: 4100 6: 4100 7: 4100 8: 4087 9: 4100 10: 4100 11: 4100
12: 4100 13: 4100 14: 4100 15: 4100 16: 4100 bogomips: 131260
bmi2 bpext clflush clflushopt clzero cmov cmp_legacy constant_tsc cpb cpuid
fma fpu fsgsbase fxsr fxsr_opt ht hw_pstate ibpb irperf lahf_lm lbrv lm
mca mce misalignsse mmx mmxext monitor movbe msr mtrr mwaitx nonstop_tsc
nopl npt nrip_save nx osvw overflow_recov pae pat pausefilter pclmulqdq
pdpe1gb perfctr_core perfctr_llc perfctr_nb pfthreshold pge pni popcnt pse
pse36 rapl rdrand rdseed rdtscp rep_good sep sev sev_es sha_ni skinit smap
smca sme smep ssbd sse sse2 sse4_1 sse4_2 sse4a ssse3 succor svm svm_lock
syscall tce topoext tsc tsc_scale v_vmsave_vmload vgif vmcb_clean vme
vmmcall wdt xgetbv1 xsave xsavec xsaveerptr xsaveopt xsaves
Type: spectre_v2
mitigation: Retpolines, IBPB: conditional, STIBP: disabled, RSB filling
Device-1: AMD Ellesmere [Radeon RX 470/480/570/570X/580/580X/590]
vendor: Sapphire Nitro+ driver: amdgpu v: kernel arch: GCN 4
process: GF 14nm built: 2016-20 pcie: gen: 3 speed: 8 GT/s lanes: 16
ports: active: DP-1, DP-2, HDMI-A-1, HDMI-A-2 empty: DVI-D-1
bus-ID: 29:00.0 chip-ID: 1002:67df class-ID: 0300
Device-2: Logitech C920 HD Pro Webcam type: USB
driver: snd-usb-audio,uvcvideo bus-ID: 1-6:2 chip-ID: 046d:0892
class-ID: 0102 serial: <filter>
Display: x11 server: X.Org v: 21.1.3 with: Xwayland v: 22.1.2
compositor: kwin_x11 driver: X: loaded: amdgpu unloaded: modesetting
alternate: fbdev,vesa gpu: amdgpu display-ID: :0 screens: 1
Screen-1: 0 s-res: 5760x2160 s-dpi: 96 s-size: 1520x570mm (59.84x22.44")
s-diag: 1623mm (63.91")
Monitor-1: DP-1 mapped: DisplayPort-0 pos: 1-3 model: Acer VG220Q
serial: <filter> built: 2018 res: 1920x1080 dpi: 102 gamma: 1.2
size: 476x268mm (18.74x10.55") diag: 546mm (21.5") ratio: 16:9 modes:
max: 1920x1080 min: 720x400
Monitor-2: DP-2 mapped: DisplayPort-1 pos: 2-1 model: Samsung built: 2009
res: 1920x1080 hz: 60 dpi: 305 gamma: 1.2 size: 160x90mm (6.3x3.54")
diag: 184mm (7.2") ratio: 16:9 modes: max: 1280x720 min: 640x480
Monitor-3: HDMI-A-1 mapped: HDMI-A-0 pos: primary,2-4 model: VG245
serial: <filter> built: 2021 res: 1920x1080 dpi: 92 gamma: 1.2
size: 531x299mm (20.91x11.77") diag: 609mm (24") ratio: 16:9 modes:
Monitor-4: HDMI-A-2 mapped: HDMI-A-1 pos: 2-2 model: ASUS VA24E
serial: <filter> built: 2020 res: 1920x1080 dpi: 93 gamma: 1.2
size: 527x296mm (20.75x11.65") diag: 604mm (23.8") ratio: 16:9 modes:
OpenGL: renderer: AMD Radeon RX 580 Series (polaris10 LLVM 13.0.1 DRM 3.42
5.15.41-1-MANJARO)
v: 4.6 Mesa 22.1.1 direct render: Yes
Device-1: AMD Ellesmere HDMI Audio [Radeon RX 470/480 / 570/580/590]
vendor: Sapphire driver: snd_hda_intel v: kernel bus-ID: 1-6:2
chip-ID: 046d:0892 pcie: class-ID: 0102 gen: 3 speed: 8 GT/s
serial: <filter> lanes: 16 bus-ID: 29:00.1 chip-ID: 1002:aaf0
class-ID: 0403
Device-2: AMD Family 17h HD Audio vendor: Micro-Star MSI
bus-ID: 2b:00.3 chip-ID: 1022:1457 class-ID: 0403
Device-3: Logitech C920 HD Pro Webcam type: USB
Sound Server-1: ALSA v: k5.15.41-1-MANJARO running: yes
Sound Server-3: PulseAudio v: 16.0 running: yes
Sound Server-4: PipeWire v: 0.3.52 running: yes
vendor: Micro-Star MSI driver: r8169 v: kernel pcie: gen: 1 speed: 2.5 GT/s
lanes: 1 port: f000 bus-ID: 25:00.0 chip-ID: 10ec:8168 class-ID: 0200
IF: enp37s0 state: up speed: 1000 Mbps duplex: full mac: <filter>
IP v6: <filter> scope: link
IF-ID-1: br-c79169e0a407 state: up speed: 10000 Mbps duplex: unknown
mac: <filter>
IF-ID-2: docker0 state: down mac: <filter>
IF-ID-3: veth367f01f state: up speed: 10000 Mbps duplex: full
mac: <filter>
Device-1: Realtek Bluetooth 5.1 Radio type: USB driver: btusb v: 0.8
bus-ID: 3-1.3:7 chip-ID: 0bda:a725 class-ID: e001 serial: <filter>
Report: hciconfig ID: hci0 rfk-id: 3 state: up address: <filter> bt-v: 3.0
lmp-v: 5.1 sub-v: 8a6b hci-v: 5.1 rev: 9a9
Info: acl-mtu: 1021:6 sco-mtu: 255:12 link-policy: rswitch hold sniff park
link-mode: peripheral accept
Local Storage: total: 2.18 TiB used: 1.62 TiB (74.4%)
ID-1: /dev/sda maj-min: 8:0 vendor: Seagate model: ST1000DM010-2EP102
type: HDD rpm: 7200 serial: <filter> rev: CC43 scheme: GPT
SMART Message: Unknown smartctl error. Unable to generate data.
ID-2: /dev/sdb maj-min: 8:16 vendor: Western Digital model: WDS500G2B0A
type: SSD serial: <filter> rev: 90WD scheme: GPT
ID-3: /dev/sdc maj-min: 8:32 vendor: Kingston model: SA400S37120G
size: 111.79 GiB block-size: physical: 512 B logical: 512 B speed: 6.0 Gb/s
type: SSD serial: <filter> rev: 0002 scheme: MBR
ID-4: /dev/sdd maj-min: 8:48 vendor: Crucial model: CT275MX300SSD1
size: 256.17 GiB block-size: physical: 512 B logical: 512 B speed: 6.0 Gb/s
type: SSD serial: <filter> rev: R070 scheme: GPT
ID-5: /dev/sde maj-min: 8:64 vendor: Western Digital
model: WDS500G2B0B-00YS70 size: 465.76 GiB block-size: physical: 512 B
logical: 512 B speed: 6.0 Gb/s type: SSD serial: <filter> rev: 90WD
scheme: GPT
ID-1: / raw-size: 465.27 GiB size: 456.9 GiB (98.20%)
used: 367.38 GiB (80.4%) fs: ext4 block-size: 4096 B dev: /dev/sdb2
maj-min: 8:18 label: N/A uuid: 2bb84221-8736-478d-8f20-6c17ab04e608
ID-2: /boot/efi raw-size: 500 MiB size: 499 MiB (99.80%)
used: 304 KiB (0.1%) fs: vfat block-size: 512 B dev: /dev/sdb1 maj-min: 8:17
label: N/A uuid: 3C6A-0BA3
ID-3: /media/crucial275 raw-size: 256.17 GiB size: 256.17 GiB (100.00%)
used: 154.5 GiB (60.3%) fs: btrfs block-size: 4096 B dev: /dev/sdd1
maj-min: 8:49 label: crucial275 uuid: 91b24d59-0eeb-4601-98db-1ec74349f15d
ID-4: /media/kingston128 raw-size: 111.79 GiB size: 109.47 GiB (97.93%)
used: 67.69 GiB (61.8%) fs: ext4 block-size: 4096 B dev: /dev/sdc1
maj-min: 8:33 label: kingston128GB
uuid: ff1800f1-d3e2-427e-bd0a-0616f1336b99
ID-5: /media/wd1tb raw-size: 931.51 GiB size: 931.51 GiB (100.00%)
used: 700.52 GiB (75.2%) fs: ntfs block-size: 4096 B dev: /dev/sda1
maj-min: 8:1 label: WD1TBstorage uuid: 66B100327273B3A7
ID-6: /media/win10disk raw-size: 465.13 GiB size: 465.13 GiB (100.00%)
used: 369.09 GiB (79.4%) fs: ntfs block-size: 4096 B dev: /dev/sde4
maj-min: 8:68 label: N/A uuid: 34E8AB19E8AAD87E
ID-7: /mnt/wdred raw-size: N/A size: 3.58 TiB used: 1.76 TiB (49.2%)
fs: nfs4 remote: 192.168.1.100:/media/wdred
ID-8: /mnt/wdred2 raw-size: N/A size: 3.58 TiB used: 1.43 TiB (39.9%)
fs: nfs4 remote: 192.168.1.100:/media/wdred2
Kernel: swappiness: 10 (default 60) cache-pressure: 100 (default)
ID-1: swap-1 type: file size: 16 GiB used: 476.9 MiB (2.9%) priority: -2
file: /media/kingston128/swapfile
ID-1: /dev/sde1 maj-min: 8:65 size: 529 MiB fs: ntfs label: Recovery
uuid: E0069DA0069D786C
ID-2: /dev/sde2 maj-min: 8:66 size: 100 MiB fs: vfat label: N/A
uuid: C29D-F203
ID-3: /dev/sde3 maj-min: 8:67 size: 16 MiB fs: <superuser required>
label: N/A uuid: N/A
Hub-1: 1-0:1 info: Hi-speed hub with single TT ports: 10 rev: 2.0
Device-1: 1-6:2 info: Logitech C920 HD Pro Webcam type: Video,Audio
power: 500mA chip-ID: 046d:0892 class-ID: 0102 serial: <filter>
Hub-2: 2-0:1 info: Super-speed hub ports: 4 rev: 3.1 speed: 10 Gb/s
Hub-3: 3-0:1 info: Hi-speed hub with single TT ports: 4 rev: 2.0
Hub-4: 3-1:2 info: Genesys Logic Hub ports: 4 rev: 2.1 speed: 480 Mb/s
power: 100mA chip-ID: 05e3:0610 class-ID: 0900
Device-1: 3-1.1:4
info: Shenzhen Riitek wireless mini keyboard with touchpad
type: Keyboard,Mouse driver: hid-generic,usbhid interfaces: 2 rev: 1.1
speed: 12 Mb/s power: 100mA chip-ID: 1997:2433 class-ID: 0301
Hub-5: 3-1.2:9 info: Terminus Hub ports: 4 rev: 2.0 speed: 480 Mb/s
power: 100mA chip-ID: 1a40:0101 class-ID: 0900
Device-1: 3-1.2.1:10 info: SHARKOON GmbH Keyboard type: Keyboard,HID
driver: semitek,usbhid interfaces: 3 rev: 1.1 speed: 12 Mb/s power: 100mA
chip-ID: 1ea7:0907 class-ID: 0300 serial: <filter>
Device-2: 3-1.3:7 info: Realtek Bluetooth 5.1 Radio type: Bluetooth
driver: btusb interfaces: 2 rev: 1.1 speed: 12 Mb/s power: 500mA
Device-3: 3-2:3 info: Holtek USB Gaming Mouse type: Mouse,Keyboard,HID
driver: hid-generic,usbhid interfaces: 3 rev: 2.0 speed: 12 Mb/s
power: 100mA chip-ID: 04d9:fc58 class-ID: 0300
Device-4: 3-4:13 info: Cyber Power System CP1500 AVR UPS type: HID
driver: hid-generic,usbhid interfaces: 1 rev: 1.1 speed: 1.5 Mb/s
power: 50mA chip-ID: 0764:0501 class-ID: 0300
Hub-6: 4-0:1 info: Super-speed hub ports: 4 rev: 3.0 speed: 5 Gb/s
Hub-7: 4-1:2 info: Genesys Logic Hub ports: 4 rev: 3.1 speed: 5 Gb/s
chip-ID: 05e3:0626 class-ID: 0900
System Temperatures: cpu: 38.4 C mobo: 43.0 C gpu: amdgpu temp: 46.0 C
Fan Speeds (RPM): fan-1: 0 fan-2: 872 fan-3: 961 fan-4: 910 fan-5: 0
gpu: amdgpu fan: 781
Processes: 596 Uptime: 2d 20h 5m wakeups: 3 Init: systemd v: 251
default: graphical tool: systemctl Compilers: gcc: 12.1.0 alt: 10/11
clang: 13.0.1 Packages: 2386 pacman: 2360 lib: 474 flatpak: 21 snap: 5
Shell: Zsh v: 5.9 running-in: yakuake inxi: 3.3.17
