How do I install customtkinter
So i was able to get tkinter installed after a few minutes of research. But i’m also needing custom-tkinter, i tried doing stuff like
sudo pacman -S customtk
sudo pacman -S customtkinter
I even messed around and did
sudo pacman -S ctk
and none of that seems to work. I can download the git repo, but im not sure how i would go about installing it from the repo
It isn’t in the repo. It is an AUR package. So using pacman won’t work.
TL:DR
DISCLAIMER: AUR packages are user produced content. Any use of the provided files is at your own risk
sudo pacman-mirrors -aS unstable
sudo pacman -Syu base-devel git --needed
git clone https://aur.archlinux.org/customtkinter
cd customtkinter
pamac build
Additional:
  • Manjaro AUR for important prerequisites and related information.
  • The customtkinter AUR page - Note this package is flagged out-of-date by some 3-4 months. I’d suggest caution.
