Hello Manjaro Community. I am very new to Linux and have been facing a very exhausting issue for the past two days since installing Manjaro. Every answer I could find so far only worked half the way until something wasn’t reproducible anymore.
My issue is, I can’t write on any (except 1) of my mounted partitions. (Curiously it’s a random NTFS Drive I use for Windows programs). I can also write in /home/user/ but nowhere else.
Also important to know is, that I run Manjaro in Dual Boot with Windows 10. (I disabled Fast Startup)
I don’t really know what I am doing, but I have tried things like sudo chgrp adm
and sudo chmod g+w
or chown -R user /mnt/point
(I tried different mounting points and only got error messages) or remounting with read/write permission or other things that I don’t remember.
Oftentimes I don’t get an error but it also doesn’t do anything.
Of course I also tried reinstalling multiple times.
It could be that some of these approaches are the right solution and they just don’t work bacause I am doing something wrong.
I am very grateful for any help on this matter.
/etc/fstab
# <file system> <mount point> <type> <options> <dump> <pass>
UUID=04CB-9640 /boot/efi vfat umask=0077 0 2
UUID=45c891a1-90bf-484c-8b11-c12985cad0a5 swap swap defaults,noatime 0 2
UUID=79f82edf-9642-445b-a4d0-140b06d78eb1 / ext4 defaults,noatime 0 1
tmpfs /tmp tmpfs defaults,noatime,mode=1777 0 0
fdisk
Disk /dev/sda: 931,51 GiB, 1000204886016 bytes, 1953525168 sectors
Disk model: ST1000DM003-1ER1
Sector size (logical/physical): 512 bytes / 4096 bytes
I/O size (minimum/optimal): 4096 bytes / 4096 bytes
Disklabel type: gpt
Disk identifier: BDA688F4-6EC3-43C4-8BD4-B0804EAF1DEF
Device Start End Sectors Size Type
/dev/sda1 2048 1953523711 1953521664 931,5G Linux filesystem
Disk /dev/sdb: 119,24 GiB, 128032974848 bytes, 250064404 sectors
Disk model: INTENSO SSD 128G
Disklabel type: gpt
Disk identifier: 84934A9F-7F2C-4031-94AE-3519188AE8D3
/dev/sdb1 2048 1085439 1083392 529M Windows recovery environment
/dev/sdb2 163824029 169969663 6145635 2,9G Linux swap
/dev/sdb3 169969664 250064370 80094707 38,2G Linux filesystem
/dev/sdb4 1323008 163824028 162501021 77,5G Microsoft basic data
/dev/sdb6 1085440 1323007 237568 116M EFI System
Partition table entries are not in disk order.
Disk /dev/sdc: 1,82 TiB, 2000398934016 bytes, 3907029168 sectors
Disk model: ST2000DM008-2FR1
Disklabel type: gpt
Disk identifier: 9052A64D-9104-4A4E-9E0A-5805E4BE74F6
/dev/sdc1 34 32767 32734 16M Microsoft reserved
/dev/sdc2 32768 3907026943 3906994176 1,8T Microsoft basic data
Partition 1 does not start on physical sector boundary.
Disk /dev/sdd: 931,51 GiB, 1000204886016 bytes, 1953525168 sectors
Disk model: WDC WD10EZEX-08W
Disklabel type: dos
Disk identifier: 0x3706d653
Device Boot Start End Sectors Size Id Type
/dev/sdd1 2048 1953519615 1953517568 931,5G 83 Linux
System Information
System: Kernel: 5.7.15-1-MANJARO x86_64 bits: 64 compiler: gcc v: 10.1.0
parameters: BOOT_IMAGE=/boot/vmlinuz-5.7-x86_64 root=UUID=79f82edf-9642-445b-a4d0-140b06d78eb1 rw quiet
apparmor=1 security=apparmor resume=UUID=45c891a1-90bf-484c-8b11-c12985cad0a5 udev.log_priority=3
Desktop: KDE Plasma 5.19.4 tk: Qt 5.15.0 wm: kwin_x11 dm: SDDM Distro: Manjaro Linux
Machine: Type: Desktop System: Micro-Star product: MS-7A34 v: 2.0 serial: <filter>
Mobo: Micro-Star model: B350 PC MATE (MS-7A34) v: 2.0 serial: <filter> UEFI: American Megatrends v: A.H0
date: 11/01/2018
CPU: Topology: 6-Core model: AMD Ryzen 5 1600 bits: 64 type: MT MCP arch: Zen family: 17 (23) model-id: 1
stepping: 1 microcode: 8001137 L2 cache: 3072 KiB
flags: avx avx2 lm nx pae sse sse2 sse3 sse4_1 sse4_2 sse4a ssse3 svm bogomips: 76821
Speed: 1377 MHz min/max: 1550/3200 MHz boost: enabled Core speeds (MHz): 1: 1377 2: 1377 3: 1375 4: 1377
5: 1377 6: 1377 7: 1377 8: 1378 9: 1376 10: 1377 11: 1375 12: 1375
Type: spectre_v2 mitigation: Full AMD retpoline, IBPB: conditional, STIBP: disabled, RSB filling
Graphics: Device-1: Advanced Micro Devices [AMD/ATI] Vega 10 XL/XT [Radeon RX Vega 56/64] vendor: Sapphire Limited
driver: amdgpu v: kernel bus ID: 1e:00.0 chip ID: 1002:687f
Display: x11 server: X.Org 1.20.8 compositor: kwin_x11 driver: amdgpu FAILED: ati unloaded: modesetting
alternate: fbdev,vesa display ID: :0 screens: 1
Screen-1: 0 s-res: 4480x1440 s-dpi: 96 s-size: 1185x381mm (46.7x15.0") s-diag: 1245mm (49")
Monitor-1: DisplayPort-2 res: 2560x1440 dpi: 109 size: 597x336mm (23.5x13.2") diag: 685mm (27")
Monitor-2: HDMI-A-0 res: 1920x1080 hz: 60 dpi: 96 size: 510x290mm (20.1x11.4") diag: 587mm (23.1")
OpenGL: renderer: Radeon RX Vega (VEGA10 DRM 3.37.0 5.7.15-1-MANJARO LLVM 10.0.1) v: 4.6 Mesa 20.1.5
direct render: Yes
Audio: Device-1: Advanced Micro Devices [AMD/ATI] Vega 10 HDMI Audio [Radeon Vega 56/64] driver: snd_hda_intel
v: kernel bus ID: 1e:00.1 chip ID: 1002:aaf8
Device-2: Advanced Micro Devices [AMD] Family 17h HD Audio vendor: Micro-Star MSI driver: snd_hda_intel
v: kernel bus ID: 20:00.3 chip ID: 1022:1457
Device-3: C-Media Anua Mic CM 900 type: USB driver: hid-generic,snd-usb-audio,usbhid bus ID: 3-1:2
chip ID: 0d8c:0134
Sound Server: ALSA v: k5.7.15-1-MANJARO
Network: Device-1: Realtek RTL8111/8168/8411 PCI Express Gigabit Ethernet vendor: Micro-Star MSI driver: r8169
v: kernel port: f000 bus ID: 19:00.0 chip ID: 10ec:8168
IF: enp25s0 state: up speed: 1000 Mbps duplex: full mac: <filter>
Drives: Local Storage: total: 3.76 TiB used: 1.17 TiB (31.2%)
ID-1: /dev/sda vendor: Seagate model: ST1000DM003-1ER162 size: 931.51 GiB block size: physical: 4096 B
logical: 512 B speed: 6.0 Gb/s rotation: 7200 rpm serial: <filter> rev: CC45 scheme: GPT
ID-2: /dev/sdb vendor: Intenso model: SSD 128GB size: 119.24 GiB block size: physical: 512 B logical: 512 B
speed: 6.0 Gb/s serial: <filter> rev: 0A scheme: GPT
ID-3: /dev/sdc vendor: Seagate model: ST2000DM008-2FR102 size: 1.82 TiB block size: physical: 4096 B
logical: 512 B speed: 6.0 Gb/s rotation: 7200 rpm serial: <filter> rev: 0001 scheme: GPT
ID-4: /dev/sdd vendor: Western Digital model: WD10EZEX-08WN4A0 size: 931.51 GiB block size: physical: 4096 B
logical: 512 B speed: 6.0 Gb/s rotation: 7200 rpm serial: <filter> rev: 1A01 scheme: MBR
Partition: ID-1: / raw size: 38.19 GiB size: 37.34 GiB (97.77%) used: 8.26 GiB (22.1%) fs: ext4 dev: /dev/sdb3
Swap: Kernel: swappiness: 60 (default) cache pressure: 100 (default)
ID-1: swap-1 type: partition size: 2.93 GiB used: 0 KiB (0.0%) priority: -2 dev: /dev/sdb2
Sensors: System Temperatures: cpu: 41.5 C mobo: N/A gpu: amdgpu temp: 44 C
Fan Speeds (RPM): N/A gpu: amdgpu fan: 1329
Info: Processes: 298 Uptime: 1h 20m Memory: 15.65 GiB used: 2.24 GiB (14.3%) Init: systemd v: 245 Compilers:
gcc: 10.1.0 Packages: pacman: 1184 lib: 318 flatpak: 0 Shell: Bash v: 5.0.18 running in: konsole
inxi: 3.1.05
