So, basically I was trying to change my monitor’s refresh rate from 60Hz to 75Hz using this tutorial, however it gets to the point where it says: “create the file ~/.xprofile” how to create this file? And how to delete it once created?
inxi -Fxz
Kernel: 5.10.15-1-MANJARO x86_64 bits: 64 compiler: gcc v: 10.2.1
Desktop: GNOME 3.38.3 Distro: Manjaro Linux
Type: Desktop Mobo: ASUSTeK model: PRIME B450M-GAMING/BR v: Rev X.0x
serial: <filter> UEFI: American Megatrends v: 2006 date: 11/13/2019
Info: 6-Core model: AMD Ryzen 5 2600 bits: 64 type: MT MCP arch: Zen+
rev: 2 L2 cache: 3 MiB
bogomips: 81470
Speed: 1388 MHz min/max: 1550/3400 MHz boost: enabled Core speeds (MHz):
1: 1388 2: 1376 3: 1478 4: 1545 5: 1376 6: 1378 7: 1376 8: 1550 9: 1504
10: 1479 11: 1480 12: 1404
Device-1: AMD Ellesmere [Radeon RX 470/480/570/570X/580/580X/590]
vendor: XFX Pine driver: amdgpu v: kernel bus ID: 08:00.0
Display: x11 server: X.org 1.20.10 driver: loaded: amdgpu
OpenGL: renderer: Radeon RX 570 Series (POLARIS10 DRM 3.40.0
5.10.15-1-MANJARO LLVM 11.0.1)
v: 4.6 Mesa 20.3.4 direct render: Yes
Device-1: AMD Ellesmere HDMI Audio [Radeon RX 470/480 / 570/580/590]
vendor: XFX Pine driver: snd_hda_intel v: kernel bus ID: 08:00.1
Device-2: AMD Family 17h HD Audio vendor: ASUSTeK driver: snd_hda_intel
v: kernel bus ID: 0a:00.3
Sound Server: ALSA v: k5.10.15-1-MANJARO
vendor: ASUSTeK driver: r8169 v: kernel port: f000 bus ID: 07:00.0
IF: enp7s0 state: up speed: 100 Mbps duplex: full mac: <filter>
Local Storage: total: 447.13 GiB used: 213.49 GiB (47.7%)
ID-1: /dev/sda vendor: Kingston model: SA400S37480G size: 447.13 GiB
ID-1: / size: 48.97 GiB used: 35.17 GiB (71.8%) fs: ext4 dev: /dev/sda2
ID-2: /boot/efi size: 269.5 MiB used: 312 KiB (0.1%) fs: vfat
dev: /dev/sda1
ID-3: /home size: 389.64 GiB used: 178.32 GiB (45.8%) fs: ext4
dev: /dev/sda3
ID-1: swap-1 type: file size: 1024 MiB used: 0 KiB (0.0%) file: /swapfile1
System Temperatures: cpu: 46.1 C mobo: N/A gpu: amdgpu temp: 44.0 C
Fan Speeds (RPM): N/A gpu: amdgpu fan: 1117
Processes: 303 Uptime: 14m Memory: 15.62 GiB used: 2.54 GiB (16.3%)
Init: systemd Compilers: gcc: 10.2.0 clang: 11.0.1 Packages: 1256
Shell: Zsh v: 5.8 inxi: 3.3.01
