i want to create a 3 gb swap partition. how to chroot through live session to do that??
To create a partition, you need free (unused) disk space.
If you don’t have any free space, you need to shrink a partition - to create that space that will then become the swap partition.
Much easier is:
create a swap file.
You don’t need chroot for any of this.
You do not need to chroot
in order to create a partition, provided that you have enough free space on your drive to do so.
thanks a lot. after lot of research i think i should go with swap file only as it has lesser risk and is easier too.
during installation (if selected) does manjaro create a swap file or partition??
That is left to the choice of the user.
it would be rather pointless to offer a selection when what you (s)elect to happen … doesn’t happen
title edited to reflect the question as this is no tutorial
