Hello, I need help getting a Ryzen 7 system with a Geforce 1650 to run with the proprietary drivers
My Desktop PC has these relevant specs:
Manjaro iso: manjaro-kde-22.1.3-230529-linux61, fully updated
PSU : Nox 500W
Motherboard: Asus Prime II B450 (latest bios - no Overclocking)
Cpu: AMD Ryzen 7 5700G with Integrated Radeon Graphics
Ram: 32GB (4 x 8GB) Crucial DDR4 2666Mhz
Graphics card: Asus Geforce GTX1650 4GB Dual
The card is connected to the lcd via DVI connetor (lcd does not have hdmi)
System runs cool, thermal readings Ok
This system was rock-stable using the iGPU Radeon integrated graphics, but since I installed the GTX1650 all hell broke loose and I cant seem to get the graphics to run properly with the proprietary drivers.
I installed a new Asus geforce GTX1650 expecting improve game performance and Blender 3D rendering and use CUDA to speed up some AI programming python tasks. I know this is a Low-Budget option, but its what I could afford.
The card shows correctly detected in the boot after being plugged in the PCI slot, and the proprietary drivers were installed from the official repository, but:
Can’t start Wayland session (it goes back to login screen), so only X session can be started.
After suspension, about 50% of times the system either dose not resume from suspension (black screen) or resume with blurry screen requiring reboot.
Blender (installed from official repository) crashes with a screen full of coloured square pattern - sound stays on, mouse and keyboard are irresponsive
Linux games installed via flatpak such as Dynablaster or Flightgear crash after a few seconds (coloured squares screen shows up as above)
Windows 3D apps running in Wine such as Daz3d also crash often while rendering with exact same simpthoms as above (In this case I see RAM being taken as if there is a leak)
Otherwise the system shows graphics correctly
What I have tried by searching the web and this forum:
Fresh install Manjaro from iso and choosing proprietary drivers: No changes
disable amd occache option in bios: No changes
installed previous proprietary drivers version from repositories: No changes
Apply open-source nouveau driver and unnistall proprietary driver in the hardware config gui: It works and does not crash, but performance obviously does not meet the cards full potential
Could someone provide me some guidance/clues on how to diagnose or solve this issue so I can make full use of this card potential using the proprietary drivers?
Sorry about the long post
Regards
In order for us, or anyone for that matter, to be able to provide assistance, more information is necessary. To that end, please see:
Please also note and heed: Forum Rules - Manjaro
Hope you manage!
Tip:
To provide terminal output, copy the text you wish to share, and paste it here, surrounded by three (3) backticks, a.k.a grave accents. Like this:
pasted text
Or three (3) tilde signs, like this:
pasted text
Portaest sed
elementum
cursus nisl nisi
hendrerit ac quis
sit
adipiscing
tortor sit leo commodo.
Instead of like this:
Portaest sed elementum cursus nisl nisi hendrerit ac quis sit adipiscing tortor sit leo commodo.
Alternatively , paste the text you wish to format as terminal output, select all pasted text, and click the </> button on the taskbar. This will indent the whole pasted section with one TAB , causing it to render the same way as described above.
Thereby improving legibility and making it much easier for those trying to be of assistance.
Additionally
If your language isn’t English, please prepend any and all terminal commands with LC_ALL=C
. For example:
LC_ALL=C bluetoothctl
cscs
25 July 2023 18:04
3
mhwd -l -li
And … please tell us if PRIME is working.
Maybe this is a case similar to the following thread:
Please do not install packages this way.
It will lead to partial-upgrade state … which is bad.
This shows PRIME working well.
You can use the nvidia card when you call it with prime-run.
Please advise if you were aware of this and truly wish to switch to nvidia-only.
I suppose I can say already - in many cases that is not preferred.
Intel is more compatible with many things and your iGPU will consume less resources, less power, and it is generally a performance betterment to have, for ex…
cscs:
mhwd -l -li
Thank you cscs for your anwser, output bellow:
mhwd -l -li ✔
> Installed PCI configs:
NAME VERSION FREEDRIVER TYPE
video-nvidia 2023.03.23 false PCI
> 0000:01:00.0 (0300:10de:1f82) Display controller nVidia Corporation:
video-nvidia-470xx 2023.03.23 false PCI
video-modesetting 2020.01.13 true PCI
video-vesa 2017.03.12 true PCI
> 0000:04:00.0 (0200:10ec:8168) Network controller Realtek Semiconductor Co., Ltd.:
network-r8168 2016.04.20 true PCI
cscs, I did not install Prime. I saw it mentioned in this forum, but in the context of laptop computers with intel integrated graphics.
cscs
25 July 2023 18:42
6
Ah, so it is not a dual-gpu setup.
Then PRIME does not matter and does not need to be installed.
…or is it ?
You could show us system info:
inxi -Fazy
cscs output is
inxi -Fazy 127|2 ✘
Kernel: 6.1.38-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 13.1.1
parameters: BOOT_IMAGE=/@/boot/vmlinuz-6.1-x86_64
root=UUID=4a77d806-e503-4a05-9fd0-3fc093a56fc5 rw rootflags=subvol=@ quiet
splash udev.log_priority=3
Desktop: KDE Plasma v: 5.27.6 tk: Qt v: 5.15.10 wm: kwin_x11 vt: 2 dm: SDDM
Type: Desktop Mobo: ASUSTeK model: PRIME B450-PLUS v: Rev X.0x
serial: <superuser required> UEFI: American Megatrends v: 4003
date: 03/13/2023
Info: model: AMD Ryzen 7 5700G with Radeon Graphics bits: 64 type: MT MCP
arch: Zen 3 gen: 4 level: v3 note: check built: 2021-22
microcode: 0xA50000D
Topology: cpus: 1x cores: 8 tpc: 2 threads: 16 smt: enabled cache:
L1: 512 KiB desc: d-8x32 KiB; i-8x32 KiB L2: 4 MiB desc: 8x512 KiB L3: 16 MiB
desc: 1x16 MiB
Speed (MHz): avg: 2290 high: 3800 min/max: 1400/4672 boost: enabled
scaling: driver: acpi-cpufreq governor: schedutil cores: 1: 2989 2: 1400
3: 1400 4: 1400 5: 3800 6: 1400 7: 1400 8: 1400 9: 3800 10: 2413 11: 1400
12: 3250 13: 1400 14: 3000 15: 2400 16: 3800 bogomips: 121421
STIBP: always-on, RSB filling, PBRSB-eIBRS: Not affected
Device-1: NVIDIA TU117 [GeForce GTX 1650] vendor: ASUSTeK driver: nvidia
v: 535.54.03 alternate: nouveau,nvidia_drm non-free: 535.xx+
status: current (as of 2023-07) arch: Turing code: TUxxx
process: TSMC 12nm FF built: 2018-22 pcie: gen: 3 speed: 8 GT/s lanes: 16
bus-ID: 01:00.0 chip-ID: 10de:1f82 class-ID: 0300
Display: x11 server: X.Org v: 21.1.8 with: Xwayland v: 23.1.2
compositor: kwin_x11 driver: X: loaded: nvidia gpu: nvidia display-ID: :0
screens: 1
Screen-1: 0 s-res: 1920x1080 s-dpi: 93 s-size: 524x292mm (20.63x11.50")
s-diag: 600mm (23.62")
Monitor-1: DVI-D-0 res: 1920x1080 hz: 60 dpi: 94
size: 521x293mm (20.51x11.54") diag: 598mm (23.53") modes: N/A
API: OpenGL v: 4.6.0 NVIDIA 535.54.03 renderer: NVIDIA GeForce GTX
1650/PCIe/SSE2 direct-render: Yes
Device-1: NVIDIA vendor: ASUSTeK driver: snd_hda_intel v: kernel pcie: gen: 3
speed: 8 GT/s lanes: 16 bus-ID: 01:00.1 chip-ID: 10de:10fa class-ID: 0403
Device-2: AMD Renoir Radeon High Definition Audio vendor: ASUSTeK
link-max: gen: 4 speed: 16 GT/s bus-ID: 09:00.1 chip-ID: 1002:1637
class-ID: 0403
Device-3: AMD Family 17h/19h HD Audio vendor: ASUSTeK PRIME B450M-A
link-max: gen: 4 speed: 16 GT/s bus-ID: 09:00.6 chip-ID: 1022:15e3
class-ID: 0403
API: ALSA v: k6.1.38-1-MANJARO status: kernel-api with: aoss
Server-2: PipeWire v: 0.3.74 status: off with: wireplumber status: active
tools: pw-cli,wpctl
vendor: ASUSTeK PRIME B450M-A driver: r8169 v: kernel pcie: gen: 1
speed: 2.5 GT/s lanes: 1 port: e000 bus-ID: 04:00.0 chip-ID: 10ec:8168
class-ID: 0200
IF: enp4s0 state: down mac: <filter>
Device-2: Realtek RTL8192EE PCIe Wireless Network Adapter driver: rtl8192ee
v: kernel pcie: gen: 1 speed: 2.5 GT/s lanes: 1 port: d000 bus-ID: 08:00.0
chip-ID: 10ec:818b class-ID: 0280
IF: wlp8s0 state: up mac: <filter>
Device-1: TP-Link UB500 Adapter driver: btusb v: 0.8 type: USB rev: 1.1
speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 1-9:4 chip-ID: 2357:0604
Local Storage: total: 10.66 TiB used: 108.89 GiB (1.0%)
ID-1: /dev/sda maj-min: 8:0 vendor: S3Plus model: S3SSDC480
size: 447.13 GiB block-size: physical: 512 B logical: 512 B speed: 6.0 Gb/s
tech: SSD serial: <filter> fw-rev: 916a scheme: GPT
ID-2: /dev/sdb maj-min: 8:16 vendor: Kingston model: SA400S37240G
size: 223.57 GiB block-size: physical: 512 B logical: 512 B speed: 6.0 Gb/s
tech: SSD serial: <filter> fw-rev: 0107 scheme: MBR
ID-3: /dev/sdc maj-min: 8:32 vendor: Western Digital
model: WD40EZAZ-00SF3B0 size: 3.64 TiB block-size: physical: 4096 B
logical: 512 B speed: 6.0 Gb/s tech: HDD rpm: 5400 serial: <filter>
fw-rev: 0A80 scheme: GPT
ID-4: /dev/sdd maj-min: 8:48 vendor: Toshiba model: EXTERNAL USB
size: 3.64 TiB block-size: physical: 4096 B logical: 512 B type: USB rev: 3.0
spd: 5 Gb/s lanes: 1 mode: 3.2 gen-1x1 tech: N/A serial: <filter>
fw-rev: 5438 scheme: GPT
ID-5: /dev/sde maj-min: 8:64 vendor: Western Digital
model: WD30EZRZ-00Z5HB0 size: 2.73 TiB block-size: physical: 4096 B
logical: 512 B type: USB rev: 3.0 spd: 5 Gb/s lanes: 1 mode: 3.2 gen-1x1
tech: HDD rpm: 5400 serial: <filter> fw-rev: 1019 scheme: GPT
ID-1: / raw-size: 446.83 GiB size: 446.83 GiB (100.00%)
used: 108.89 GiB (24.4%) fs: btrfs dev: /dev/sda2 maj-min: 8:2
used: 576 KiB (0.2%) fs: vfat dev: /dev/sda1 maj-min: 8:1
ID-3: /home raw-size: 446.83 GiB size: 446.83 GiB (100.00%)
ID-4: /var/log raw-size: 446.83 GiB size: 446.83 GiB (100.00%)
ID-1: swap-1 type: file size: 512 MiB used: 284.5 MiB (55.6%) priority: -2
file: /swap/swapfile
System Temperatures: cpu: 43.1 C mobo: N/A gpu: nvidia temp: 34 C
Fan Speeds (RPM): N/A gpu: nvidia fan: 26%
Processes: 349 Uptime: 17m wakeups: 0 Memory: total: 32 GiB note: est.
available: 31.14 GiB used: 3.9 GiB (12.5%) Init: systemd v: 253
default: graphical tool: systemctl Compilers: gcc: 13.1.1 alt: 12
clang: 15.0.7 Packages: 1389 pm: pacman pkgs: 1368 libs: 391 tools: pamac
pm: flatpak pkgs: 21 Shell: Zsh v: 5.9 default: Bash v: 5.1.16
running-in: konsole inxi: 3.3.28
cscs
25 July 2023 18:46
8
pedrovalv000:
According to this you only have the one GPU.
But this could be a consequence of installing the nvidia drivers.
Please remove and run again
sudo mhwd -r pci video-nvidia
output after removing video-nvidia:
Successfully removed video-nvidia
~ inxi -Fazy ✔ 17s
date: 03/13/2023
desc: 1x16 MiB
Speed (MHz): avg: 2497 high: 4640 min/max: 1400/4672 boost: enabled
scaling: driver: acpi-cpufreq governor: schedutil cores: 1: 2901 2: 1400
3: 1400 4: 3800 5: 1400 6: 4640 7: 2393 8: 1400 9: 1400 10: 1400 11: 3709
12: 3800 13: 1400 14: 1400 15: 3710 16: 3800 bogomips: 121421
v: 535.54.03 alternate: nouveau non-free: 535.xx+
process: TSMC 12nm FF built: 2018-22 pcie: gen: 1 speed: 2.5 GT/s lanes: 16
link-max: gen: 3 speed: 8 GT/s bus-ID: 01:00.0 chip-ID: 10de:1f82
class-ID: 0300
screens: 1
API: OpenGL v: 4.5 Mesa 23.0.4 renderer: llvmpipe (LLVM 15.0.7 256 bits)
direct-render: Yes
Device-1: NVIDIA vendor: ASUSTeK driver: snd_hda_intel v: kernel pcie: gen: 1
speed: 2.5 GT/s lanes: 16 link-max: gen: 3 speed: 8 GT/s bus-ID: 01:00.1
class-ID: 0403
class-ID: 0403
tools: pw-cli,wpctl
class-ID: 0200
Local Storage: total: 10.66 TiB used: 108.9 GiB (1.0%)
used: 108.9 GiB (24.4%) fs: btrfs dev: /dev/sda2 maj-min: 8:2
ID-1: swap-1 type: file size: 512 MiB used: 420.6 MiB (82.1%) priority: -2
System Temperatures: cpu: 47.2 C mobo: N/A
Processes: 349 Uptime: 20m wakeups: 0 Memory: total: 32 GiB note: est.
available: 31.14 GiB used: 4.01 GiB (12.9%) Init: systemd v: 253
clang: 15.0.7 Packages: 1382 pm: pacman pkgs: 1361 libs: 389 tools: pamac
cscs
25 July 2023 18:49
10
I think you need to restart (it still shows using the nvidia driver).
i am back, after restart, output bellow:
inxi -Fazy ✔
date: 03/13/2023
desc: 1x16 MiB
Speed (MHz): avg: 2783 high: 4151 min/max: 1400/4672 boost: enabled
scaling: driver: acpi-cpufreq governor: schedutil cores: 1: 3645 2: 1400
3: 3043 4: 2912 5: 3480 6: 1400 7: 3476 8: 2993 9: 3272 10: 3520 11: 3800
12: 1400 13: 1400 14: 1400 15: 3243 16: 4151 bogomips: 121419
Device-1: NVIDIA TU117 [GeForce GTX 1650] vendor: ASUSTeK driver: nouveau
v: kernel non-free: 535.xx+ status: current (as of 2023-07) arch: Turing
code: TUxxx process: TSMC 12nm FF built: 2018-22 pcie: gen: 1
speed: 2.5 GT/s lanes: 16 link-max: gen: 3 speed: 8 GT/s ports:
active: DVI-D-1 empty: DP-1,HDMI-A-1 bus-ID: 01:00.0 chip-ID: 10de:1f82
class-ID: 0300 temp: 25.0 C
compositor: kwin_x11 driver: X: loaded: modesetting alternate: fbdev,vesa
dri: nouveau gpu: nouveau display-ID: :0 screens: 1
s-diag: 582mm (22.93")
Monitor-1: DVI-D-1 model: Asus VP247 serial: <filter> built: 2017
res: 1920x1080 hz: 60 dpi: 94 gamma: 1.2 size: 521x293mm (20.51x11.54")
diag: 598mm (23.5") ratio: 16:9 modes: max: 1920x1080 min: 720x400
API: OpenGL v: 4.3 Mesa 23.0.4 renderer: NV167 direct-render: Yes
class-ID: 0403
class-ID: 0403
tools: pw-cli,wpctl
class-ID: 0200
Local Storage: total: 10.66 TiB used: 108.92 GiB (1.0%)
used: 108.92 GiB (24.4%) fs: btrfs dev: /dev/sda2 maj-min: 8:2
ID-1: swap-1 type: file size: 512 MiB used: 91.8 MiB (17.9%) priority: -2
System Temperatures: cpu: 52.9 C mobo: N/A gpu: nouveau temp: 25.0 C
Fan Speeds (RPM): N/A gpu: nouveau fan: 960
Processes: 358 Uptime: 0m wakeups: 0 Memory: total: 32 GiB note: est.
available: 31.14 GiB used: 1.81 GiB (5.8%) Init: systemd v: 253
cscs
25 July 2023 18:58
12
I still only see the nvidia card.
… is the amd disabled somehow, such as in BIOS?
Usually an iGPU + dGPU both should be recognized and the iGPU should be used by default … the dGPU called by PRIME. But … your system seems to only recognize the dGPU.
Some folks pull out their hair trying to get it this way … but yours is somehow just like that inexplicably.
in the bios if i remember well I only have a listbox with iGpu and iPci options. When I plugged the card for the first time and rebooted it changed to iPci by itself. The monitor is connected to the geforce dvi output instead of the motherboard dvi. I did not made any manual changes to the bios settings.
cscs
25 July 2023 19:08
14
OK. Well, in that case I suppose the output makes sense.
We can put the nvidia drivers back:
sudo mhwd -i pci video-nvidia
I wonder if maybe it would be helpful to remove the open profile (should be unneeded now):
sudo mhwd -r pci video-linux
You may also try a newer kernel, ex:
sudo mhwd-kernel -i linux64
I will try that. I will get back to you after reboot and testing, Changing to 6.4 kernel would not be my first option since I saw other people having issues with it and geforce drivers… , but since I have already did a backup and fresh install before, I have nothing to loose.
cscs
25 July 2023 19:18
16
You can have multiple kernels installed and select them from grub at boot.
I’m just thinking it might be a good idea to try the newer ones with newish hardware.
I am back . No luck, the behavior is the same , check screenshot of the dynablaster game crash ( just like before the driver and kernel change). It took 20 sec to crash. I had to reboot again to log into the forum.
i took a photo of the screen, because obviously i had irresponsive keyboard. cscs thank you for you time and effort anyway.
I have just tried another KDE arch linux distribution ( the terminal-centric one) with same kernel version (6.1) and same nvidia proprietary drivers (version ) and the card works fine after a fresh OS install and does not crash. So I guess that rules out any hardware issue.
Could someone give me some clues about what I could look for to make it work in Manjaro ?
Please dont get me wrong , I am not trying to criticize anyone , I just want to make it work for me and anyone else with this issue because Manjaro is my favorite distro and its in main machines both at work and home.
Update: In my last previous I mentioned the problem was not present using another arch distro, but after some more testing i found that the computers still freezes in other arch linux with same kernel and driver version, but it takes longer: like a couple of minutes instead than just a few seconds.
I will do a few more tests, but the PSU is now my main suspect. Its a basic 500W Nox branded psu that was sold together with the case. I also have a lot of other periphals drawing power from USB, likely the 1650 under load is taking the PSU to the limit and voltage drops causing the crashes.
