How do I blacklist certain mirror providing updates?
Hi, community!
How do I blacklist certain mirror providing updates to get rid of it until its manual removal from blacklist?
Exact current use case
I want to use certain country mirrors only.
I just moved from unstable branch to testing.
❯ sudo pacman-mirrors -a -c Netherlands -P https -B testing
::INFO Branch in config is changed
::INFO Protocols in config is changed
::INFO => Mirror status: https://repo.manjaro.org/status.json
::INFO User generated mirror list
::INFO Custom mirror file saved: /var/lib/pacman-mirrors/custom-mirrors.json
::INFO Using custom mirror file
::INFO Querying mirrors - This may take some time
  0.397 Netherlands    : https://manjaro.mirror.wearetriple.com/
  ..... Netherlands    : https://manjaro.mirrors.lavatech.top/
::ERROR Connection: HTTPSConnectionPool(host='manjaro.mirrors.lavatech.top', port=443): Read timed out.
  0.429 Netherlands    : https://ftp.nluug.nl/pub/os/Linux/distr/manjaro/
  0.417 Netherlands    : https://ftp.snt.utwente.nl/pub/linux/manjaro/
  0.336 Netherlands    : https://mirror.koddos.net/manjaro/
::INFO Writing mirror list
::Netherlands     : https://mirror.koddos.net/manjaro/testing/$repo/$arch
::Netherlands     : https://manjaro.mirror.wearetriple.com/testing/$repo/$arch
::Netherlands     : https://ftp.snt.utwente.nl/pub/linux/manjaro/testing/$repo/$arch
::Netherlands     : https://ftp.nluug.nl/pub/os/Linux/distr/manjaro/testing/$repo/$arch
::INFO Mirror list generated and saved to: /etc/pacman.d/mirrorlist
::INFO To reset custom mirrorlist 'sudo pacman-mirrors -id'
::INFO To remove custom config run  'sudo pacman-mirrors -c all'
I got the
❯ cat /etc/pacman.d/mirrorlist
## Manjaro Linux custom mirrorlist
## Generated on 2026-08-08 21:57
## Please use 'pacman-mirrors -id' To reset custom mirrorlist
## Please use 'pacman-mirrors -c all' To reset custom mirrorlist
## To remove custom config run  'pacman-mirrors -c all'
## Country : Netherlands
Server = https://mirror.koddos.net/manjaro/testing/$repo/$arch
Server = https://manjaro.mirror.wearetriple.com/testing/$repo/$arch
Server = https://ftp.snt.utwente.nl/pub/linux/manjaro/testing/$repo/$arch
Server = https://ftp.nluug.nl/pub/os/Linux/distr/manjaro/testing/$repo/$arch
I start to use it:
❯ sudo pacman -Syyu
:: Synchronising package databases...
 core        150.5 KiB   390 KiB/s 00:00 [############################################################################] 100%
 extra        8.7 MiB  1091 KiB/s 00:08 [############################################################################] 100%
 chaotic-aur        662.9 KiB  1116 KiB/s 00:01 [############################################################################] 100%
warning: 7zip: local (26.02-1) is newer than extra (26.00-1)
warning: a52dec: local (0.8.0-3) is newer than extra (0.8.0-2)
warning: abseil-cpp: local (20260526.0-2) is newer than extra (20250814.1-1)
warning: accountsservice: local (26.27.3-1) is newer than extra (25.34.76-2)
warning: acl: local (2.4.0-1) is newer than core (2.3.2-1)
warning: ada: local (3.4.4-1) is newer than extra (3.4.3-1)
warning: adwaita-cursors: local (50.0-1) is newer than extra (49.0-1)
warning: adwaita-icon-theme: local (50.0-1) is newer than extra (49.0-1)
warning: alsa-card-profiles: local (1:1.6.8-1) is newer than extra (1:1.6.2-1)
warning: alsa-lib: local (1.2.16.1-1) is newer than extra (1.2.15.3-2)
warning: alsa-ucm-conf: local (1.2.16.1-1) is newer than extra (1.2.15.3-1)
warning: alsa-utils: local (1.2.16-1) is newer than extra (1.2.15.2-2)
warning: amd-ucode: local (20260622-1) is newer than core (20260309-1)
warning: amdgpu_top: local (0.11.5-1) is newer than extra (0.11.2-1)
warning: aom: local (3.14.1-1) is newer than extra (3.13.1-2)
warning: appstream: local (1.1.5-1) is newer than extra (1.1.2-1)
warning: appstream-qt: local (1.1.5-1) is newer than extra (1.1.2-1)
warning: archlinux-appstream-data: local (20260722-1) is newer than extra (20260107-1)
warning: archlinux-keyring: local (20260727-1) is newer than core (20260301-1)
warning: ark: local (26.04.3-1) is newer than extra (25.12.3-1)
warning: at-spi2-core: local (2.60.6-1) is newer than extra (2.58.4-1)
warning: atkmm: local (2.28.5-2) is newer than extra (2.28.4-1)
warning: attica: local (6.28.0-1) is newer than extra (6.24.0-1)
warning: attr: local (2.6.0-1) is newer than core (2.5.2-1)
warning: audacity: local (1:3.7.8-2) is newer than extra (1:3.7.7-1)
warning: audit: local (4.2.1-1) is newer than core (4.1.3-1)
warning: aurorae: local (6.7.4-1) is newer than extra (6.5.6-1)
warning: autoconf: local (2.73-1) is newer than core (2.72-1)
warning: avahi: local (1:0.9rc5-1) is newer than extra (1:0.9rc3-1)
warning: b43-fwcutter: local (020-1) is newer than core (019-6)
warning: baloo: local (6.28.0-1) is newer than extra (6.24.0-1)
warning: baloo-widgets: local (26.04.3-1) is newer than extra (25.12.3-1)
warning: base: local (3-5) is newer than core (3-3)
warning: bash: local (5.3.15-1) is newer than core (5.3.9-1)
warning: binutils: local (2.47-1) is newer than core (2.46-1)
warning: bluedevil: local (1:6.7.4-1) is newer than extra (1:6.5.6-1)
warning: bluez: local (5.87-2) is newer than extra (5.86-4)
warning: bluez-libs: local (5.87-2) is newer than extra (5.86-4)
warning: bluez-qt: local (6.28.0-1) is newer than extra (6.24.0-1)
warning: bolt: local (0.9.11-1) is newer than extra (0.9.10-1)
warning: boost-libs: local (1.91.0-2) is newer than extra (1.89.0-4)
warning: brave-browser: local (1.92.144-1) is newer than extra (1.88.132-1)
warning: breeze: local (6.7.4-1) is newer than extra (6.5.6-1)
warning: breeze-cursors: local (6.7.4-1) is newer than extra (6.6.2-1)
warning: breeze-gtk: local (6.7.4-1) is newer than extra (6.5.6-1)
warning: breeze-icons: local (6.28.0-1) is newer than extra (6.24.0-1)
warning: breeze5: local (6.7.4-1) is newer than extra (6.5.6-1)
warning: btrfs-progs: local (7.1-1) is newer than core (6.19-1)
warning: bubblewrap: local (0.11.2-1) is newer than extra (0.11.0-2)
warning: bun: local (1.3.14-1) is newer than extra (1.3.10-1)
warning: c-ares: local (1.34.8-1) is newer than extra (1.34.6-1)
warning: ca-certificates-mozilla: local (3.126-1) is newer than core (3.121-1)
warning: cairomm: local (1.14.6-1) is newer than extra (1.14.5-2)
warning: cdparanoia: local (10.2-10) is newer than extra (10.2-9)
warning: cfitsio: local (1:4.6.4-1) is newer than extra (1:4.6.3-1)
warning: chromium: local (151.0.7922.108-1) is newer than extra (146.0.7680.153-1)
warning: clinfo: local (3.0.25.02.14-1) is newer than extra (3.0.23.01.25-1)
warning: cmark-gfm: local (0.29.0.gfm.13-2) is newer than extra (0.29.0.gfm.13-1)
warning: confuse: local (3.3-5) is newer than extra (3.3-4)
warning: coreutils: local (9.11-2) is newer than core (9.10-1)
warning: cpu-x: local (5.4.0-3) is newer than extra (5.4.0-1)
warning: cpupower: local (7.1.7-1) is newer than extra (6.19.7-1)
warning: cryptsetup: local (2.8.7-1) is newer than core (2.8.4-1)
warning: cups: local (2:2.4.19-1) is newer than extra (2:2.4.16-2)
warning: cups-pdf: local (3.0.3-1) is newer than extra (3.0.2-1)
warning: curl: local (8.21.0-1) is newer than core (8.19.0-1)
warning: dav1d: local (1.5.4-1) is newer than extra (1.5.3-1)
warning: ddcutil: local (2.2.7-1) is newer than extra (2.2.6-1)
warning: debugedit: local (5.3-1) is newer than core (5.2-1)
warning: device-mapper: local (2.03.41-1) is newer than core (2.03.38-1)
warning: ding-libs: local (0.7.0-1) is newer than core (0.6.2-2)
warning: discount: local (3.0.1.3-1) is newer than extra (3.0.1.2-1)
warning: djvulibre: local (3.5.30.1-1) is newer than extra (3.5.29-1)
warning: dnsmasq: local (2.93-1) is newer than extra (2.92-1)
warning: dolphin: local (26.04.3-1) is newer than extra (25.12.3-1)
warning: dolphin-plugins: local (26.04.3-1) is newer than extra (25.12.3-1)
warning: editorconfig-core-c: local (0.12.11-1) is newer than extra (0.12.10-1)
warning: efibootmgr: local (18-4) is newer than core (18-3)
warning: efivar: local (39-2) is newer than core (39-1)
warning: elfutils: local (0.195-1) is newer than core (0.194-2)
warning: enchant: local (2.8.15-2) is newer than extra (2.8.15-1)
warning: exfatprogs: local (1.4.2-1) is newer than extra (1.3.2-1)
warning: exiv2: local (0.28.8-2) is newer than extra (0.28.7-1)
warning: expat: local (2.8.2-1) is newer than core (2.7.4-1)
warning: fakeroot: local (1:1.37.2-3) is newer than core (1.37.2-1)
warning: fastfetch: local (2.66.0-1) is newer than extra (2.60.0-1)
warning: ffmpeg: local (2:8.1.2-11) is newer than extra (2:8.0.1-7)
warning: ffmpegthumbs: local (26.04.3-1) is newer than extra (25.12.3-1)
warning: fftw: local (3.3.11-1) is newer than extra (3.3.10-8)
warning: file: local (5.48-1) is newer than core (5.47-1)
warning: findutils: local (4.11.0-1) is newer than core (4.10.0-3)
warning: fio: local (3.42-1) is newer than extra (3.41-1)
warning: firefox: local (153.0.3-1) is newer than extra (148.0.2-1)
warning: firefox-i18n-en-gb: local (153.0.3-1) is newer than extra (148.0.2-1)
warning: firefox-i18n-en-us: local (153.0.3-1) is newer than extra (148.0.2-1)
warning: flameshot: local (14.0.0-1) is newer than extra (13.3.0-2)
warning: flex: local (2.6.4-6) is newer than core (2.6.4-5)
warning: fmt: local (12.2.0-1) is newer than extra (12.1.0-2)
warning: fontconfig: local (2:2.18.2-1) is newer than extra (2:2.17.1-1)
warning: frameworkintegration: local (6.28.0-1) is newer than extra (6.24.0-1)
warning: frameworkintegration5: local (5.116.0-3) is newer than extra (5.116.0-2)
warning: freetype2: local (2.14.3-1) is newer than extra (2.14.2-1)
warning: fuse-common: local (3.18.2-1) is newer than extra (3.18.1-1)
warning: fuse3: local (3.18.2-1) is newer than extra (3.18.1-1)
warning: fwupd: local (2.1.7-1) is newer than extra (2.1.1-1)
warning: fwupd-efi: local (1.8-2) is newer than extra (1.8-1)
warning: gawk: local (5.4.1-1) is newer than core (5.4.0-1)
warning: gcc: local (16.1.1+r595+g171d15ac6959-1) is newer than core (15.2.1+r604+g0b99615a8aef-1)
warning: gcc-libs: local (16.1.1+r595+g171d15ac6959-1) is newer than core (15.2.1+r604+g0b99615a8aef-1)
warning: gdb: local (17.2-1) is newer than extra (17.1-2)
warning: gdb-common: local (17.2-1) is newer than extra (17.1-2)
warning: gdk-pixbuf2: local (2.44.7-1) is newer than extra (2.44.4-1)
warning: ghostscript: local (10.07.1-1) is newer than extra (10.06.0-1)
warning: giflib: local (6.1.3-2) is newer than extra (5.2.2-2)
warning: git: local (2.55.0-1) is newer than extra (2.53.0-1)
warning: glib2: local (2.88.3-1) is newer than core (2.86.4-1)
warning: glibc: local (2.44+r5+g7cba77790f32-1) is newer than core (2.43+r5+g856c426a7534-1)
warning: glibc-locales: local (2.44+r5+g7cba77790f32-1) is newer than core (2.43+r5+g856c426a7534-1)
warning: glibmm: local (2.66.9-1) is newer than extra (2.66.8-1)
warning: glslang: local (1:1.4.357.0-1) is newer than extra (1:1.4.341.0-2)
warning: glycin: local (2.1.5-2) is newer than extra (2.0.8-1)
warning: gnupg: local (2.4.9-2) is newer than core (2.4.9-1)
warning: gnustep-base: local (1.31.1-3) is newer than extra (1.31.1-2)
warning: gnutls: local (3.8.13-2) is newer than core (3.8.12-2)
warning: gperftools: local (2.18.1-1) is newer than extra (2.17.2-1)
warning: gpgme: local (2.1.2-1) is newer than core (2.0.1-3)
warning: gpgmepp: local (2.1.0-1) is newer than extra (2.0.0-2)
warning: graphite: local (1:1.3.15-1) is newer than extra (1:1.3.14-6)
warning: gsettings-desktop-schemas: local (50.1-1) is newer than extra (49.1-1)
warning: gsettings-system-schemas: local (50.1-1) is newer than extra (49.1-1)
warning: gssdp: local (1.6.6-1) is newer than extra (1.6.4-1)
warning: gssproxy: local (0.9.2-3) is newer than core (0.9.2-2)
warning: gst-libav: local (1.28.5-4) is newer than extra (1.28.1-1)
warning: gst-plugin-pipewire: local (1:1.6.8-1) is newer than extra (1:1.6.2-1)
warning: gst-plugins-bad-libs: local (1.28.5-4) is newer than extra (1.28.1-1)
warning: gst-plugins-base: local (1.28.5-4) is newer than extra (1.28.1-1)
warning: gst-plugins-base-libs: local (1.28.5-4) is newer than extra (1.28.1-1)
warning: gst-plugins-good: local (1.28.5-4) is newer than extra (1.28.1-1)
warning: gst-plugins-ugly: local (1.28.5-4) is newer than extra (1.28.1-1)
warning: gstreamer: local (1.28.5-4) is newer than extra (1.28.1-1)
warning: gtk-update-icon-cache: local (1:4.22.4-1) is newer than extra (1:4.20.3-1)
warning: gtk3: local (1:3.24.52-1) is newer than extra (1:3.24.51-1)
warning: gtk4: local (1:4.22.4-1) is newer than extra (1:4.20.3-1)
warning: gtkmm3: local (3.24.11-1) is newer than extra (3.24.10-1)
warning: gupnp: local (1:1.6.10-1) is newer than extra (1:1.6.9-1)
warning: gwenview: local (26.04.3-1) is newer than extra (25.12.3-1)
warning: harfbuzz: local (14.3.0-1) is newer than extra (13.1.1-2)
warning: harfbuzz-icu: local (14.3.0-1) is newer than extra (13.1.1-2)
warning: highway: local (1.4.0-1) is newer than extra (1.3.0-2)
warning: htop: local (3.5.2-1) is newer than extra (3.4.1-1)
warning: hunspell: local (1.7.3-1) is newer than extra (1.7.2-3)
warning: hwdata: local (0.410-1) is newer than core (0.405-1)
warning: hwinfo: local (25.5-1) is newer than extra (25.2-1)
warning: hwloc: local (2.14.0-1) is newer than extra (2.13.0-1)
warning: hyphen: local (2.8.9-1) is newer than extra (2.8.8-6)
warning: hyphen-en: local (2.8.9-1) is newer than extra (2.8.8-6)
warning: i2pd: local (2.61.0-1) is newer than extra (2.59.0-2)
warning: iana-etc: local (20260530-1) is newer than core (20260306-1)
warning: icu: local (78.3-1) is newer than core (78.2-2)
warning: ijs: local (0.35-7) is newer than extra (0.35-6)
warning: imagemagick: local (7.1.2.29-1) is newer than extra (7.1.2.17-1)
warning: imath: local (3.2.2-6) is newer than extra (3.2.2-3)
warning: imlib2: local (1.12.6-2) is newer than extra (1.12.6-1)
warning: inetutils: local (2.8-1) is newer than core (2.7-2)
warning: intel-ucode: local (20260512-1) is newer than extra (20260227-1)
warning: inxi: local (3.3.41.1-2) is newer than extra (3.3.40.1-1)
warning: iproute2: local (7.1.0-1) is newer than core (6.19.0-2)
warning: iptables: local (1:1.8.13-1) is newer than core (1:1.8.11-2)
warning: jasper: local (4.2.9-1) is newer than extra (4.2.8-1)
warning: jbig2dec: local (0.20-2) is newer than extra (0.20-1)
warning: json-c: local (0.19-1) is newer than core (0.18-2)
warning: kaccounts-integration: local (26.04.3-1) is newer than extra (25.12.3-1)
warning: kaccounts-providers: local (26.04.3-1) is newer than extra (25.12.3-1)
warning: kactivitymanagerd: local (6.7.4-1) is newer than extra (6.5.6-1)
warning: kamera: local (26.04.3-1) is newer than extra (25.12.3-1)
warning: karchive: local (6.28.0-1) is newer than extra (6.24.0-1)
warning: karchive5: local (5.116.0-3) is newer than extra (5.116.0-2)
warning: kate: local (26.04.3-1) is newer than extra (25.12.3-1)
warning: kauth: local (6.28.0-1) is newer than extra (6.24.0-1)
warning: kbd: local (2.10.0-1) is newer than core (2.9.0-1)
warning: kbookmarks: local (6.28.0-1) is newer than extra (6.24.0-1)
warning: kcalc: local (26.04.3-1) is newer than extra (25.12.3-1)
warning: kcmutils: local (6.28.0-1) is newer than extra (6.24.0-1)
warning: kcodecs: local (6.28.0-1) is newer than extra (6.24.0-1)
warning: kcolorpicker: local (0.3.1-6) is newer than extra (0.3.1-5)
warning: kcolorscheme: local (6.28.0-1) is newer than extra (6.24.0-1)
warning: kcompletion: local (6.28.0-1) is newer than extra (6.24.0-1)
warning: kconfig: local (6.28.0-1) is newer than extra (6.24.0-1)
warning: kconfigwidgets: local (6.28.0-1) is newer than extra (6.24.0-1)
warning: kcoreaddons: local (6.28.0-1) is newer than extra (6.24.0-1)
warning: kcrash: local (6.28.0-1) is newer than extra (6.24.0-1)
warning: kdbusaddons: local (6.28.0-1) is newer than extra (6.24.0-1)
warning: kde-cli-tools: local (6.7.4-1) is newer than extra (6.5.6-1)
warning: kde-gtk-config: local (6.7.4-1) is newer than extra (6.5.6-1)
warning: kdeclarative: local (6.28.0-1) is newer than extra (6.24.0-1)
warning: kdecoration: local (6.7.4-1) is newer than extra (6.5.6-1)
warning: kded: local (6.28.0-1) is newer than extra (6.24.0-1)
warning: kdegraphics-mobipocket: local (26.04.3-1) is newer than extra (25.12.3-1)
warning: kdegraphics-thumbnailers: local (26.04.3-1) is newer than extra (25.12.3-1)
warning: kdeplasma-addons: local (6.7.4-1) is newer than extra (6.5.6-1)
warning: kdesu: local (6.28.0-1) is newer than extra (6.24.0-1)
warning: kdiff3: local (1.12.6-1) is newer than extra (1.12.4-1)
warning: kdiskmark: local (3.3.0-1) is newer than extra (3.2.0-2)
warning: kdnssd: local (6.28.0-1) is newer than extra (6.24.0-1)
warning: kdoctools: local (6.28.0-1) is newer than extra (6.24.0-1)
warning: keditbookmarks: local (26.04.3-1) is newer than extra (25.12.3-1)
warning: keyutils: local (1.6.3-4) is newer than core (1.6.3-3)
warning: kfilemetadata: local (6.28.0-1) is newer than extra (6.24.0-1)
warning: kfind: local (26.04.3-1) is newer than extra (25.12.3-1)
warning: kgamma: local (6.7.4-1) is newer than extra (6.5.6-1)
warning: kglobalaccel: local (6.28.0-1) is newer than extra (6.24.0-1)
warning: kglobalacceld: local (6.7.4-1) is newer than extra (6.5.6-1)
warning: kguiaddons: local (6.28.0-1) is newer than extra (6.24.0-1)
warning: khelpcenter: local (26.04.3-1) is newer than extra (25.12.3-1)
warning: kholidays: local (1:6.28.0-1) is newer than extra (1:6.24.0-1)
warning: ki18n: local (6.28.0-1) is newer than extra (6.24.0-1)
warning: kiconthemes: local (6.28.0-1) is newer than extra (6.24.0-1)
warning: kidletime: local (6.28.0-1) is newer than extra (6.24.0-1)
warning: kimageannotator: local (0.7.2-2) is newer than extra (0.7.2-1)
warning: kimageformats: local (6.28.1-1) is newer than extra (6.24.0-1)
warning: kinfocenter: local (6.7.4-1) is newer than extra (6.5.6-1)
warning: kio: local (6.28.0-1) is newer than extra (6.24.0-1)
warning: kio-extras: local (26.04.3-1) is newer than extra (25.12.3-1)
warning: kio-fuse: local (5.1.1-2) is newer than extra (5.1.1-1)
warning: kio5: local (5.116.0-6) is newer than extra (5.116.0-5)
warning: kirigami: local (6.28.0-1) is newer than extra (6.24.0-1)
warning: kirigami-addons: local (1.13.1-1) is newer than extra (1.12.0-1)
warning: kitemmodels: local (6.28.0-1) is newer than extra (6.24.0-1)
warning: kitemmodels5: local (5.116.0-3) is newer than extra (5.116.0-2)
warning: kitemviews: local (6.28.0-1) is newer than extra (6.24.0-1)
warning: kjobwidgets: local (6.28.0-1) is newer than extra (6.24.0-1)
warning: kmenuedit: local (6.7.4-1) is newer than extra (6.5.6-1)
warning: knewstuff: local (6.28.0-1) is newer than extra (6.24.0-1)
warning: knighttime: local (6.7.4-1) is newer than extra (6.5.6-1)
warning: knotifications: local (6.28.0-1) is newer than extra (6.24.0-1)
warning: knotifyconfig: local (6.28.0-1) is newer than extra (6.24.0-1)
warning: kolourpaint: local (26.04.3-1) is newer than extra (25.12.3-1)
warning: konsole: local (26.04.3-1) is newer than extra (25.12.3-1)
warning: kpackage: local (6.28.0-1) is newer than extra (6.24.0-1)
warning: kparts: local (6.28.0-1) is newer than extra (6.24.0-1)
warning: kpipewire: local (6.7.4-3) is newer than extra (6.5.6-1)
warning: kpmcore: local (26.04.3-1) is newer than extra (25.12.3-1)
warning: kpty: local (6.28.0-1) is newer than extra (6.24.0-1)
warning: kquickcharts: local (6.28.0-1) is newer than extra (6.24.0-1)
warning: kquickimageeditor: local (0.6.2.1-2) is newer than extra (0.6.0-2)
warning: krb5: local (1.22.2-1) is newer than core (1.21.3-2)
warning: krename: local (5.0.2-13) is newer than extra (5.0.2-10)
warning: krunner: local (6.28.0-1) is newer than extra (6.24.0-1)
warning: krusader: local (2.9.0-2) is newer than extra (2.9.0-1)
warning: ksanecore: local (26.04.3-1) is newer than extra (25.12.3-1)
warning: kscreen: local (6.7.4-1) is newer than extra (6.5.6-1)
warning: kscreenlocker: local (6.7.4-1) is newer than extra (6.5.6-1)
warning: kservice: local (6.28.0-1) is newer than extra (6.24.0-1)
warning: ksshaskpass: local (6.7.4-1) is newer than extra (6.5.6-1)
warning: kstatusnotifieritem: local (6.28.0-1) is newer than extra (6.24.0-1)
warning: ksvg: local (6.28.0-1) is newer than extra (6.24.0-1)
warning: ksystemlog: local (26.04.3-1) is newer than extra (25.12.3-1)
warning: ksystemstats: local (6.7.4-1) is newer than extra (6.5.6-1)
warning: ktexteditor: local (6.28.0-1) is newer than extra (6.24.0-1)
warning: ktexttemplate: local (6.28.0-1) is newer than extra (6.24.0-1)
warning: ktextwidgets: local (6.28.0-1) is newer than extra (6.24.0-1)
warning: kunitconversion: local (6.28.0-1) is newer than extra (6.24.0-1)
warning: kuserfeedback: local (6.28.0-1) is newer than extra (6.24.0-1)
warning: kwallet: local (6.28.0-1) is newer than extra (6.24.0-1)
warning: kwallet-pam: local (6.7.4-1) is newer than extra (6.5.6-1)
warning: kwallet5: local (5.116.0-6) is newer than extra (5.116.0-5)
warning: kwalletmanager: local (26.04.3-1) is newer than extra (25.12.3-1)
warning: kwayland: local (6.7.4-1) is newer than extra (6.5.6-1)
warning: kwayland-integration: local (6.7.4-1) is newer than extra (6.5.6-1)
warning: kwidgetsaddons: local (6.28.0-1) is newer than extra (6.24.0-1)
warning: kwin: local (6.7.4-1) is newer than extra (6.5.6-1)
warning: kwindowsystem: local (6.28.0-1) is newer than extra (6.24.0-1)
warning: kwrited: local (6.7.4-1) is newer than extra (6.5.6-1)
warning: kxmlgui: local (6.28.0-1) is newer than extra (6.24.0-1)
warning: lame: local (4.0-1) is newer than extra (3.101.r6531-1)
warning: layer-shell-qt: local (6.7.4-1) is newer than extra (6.5.6-1)
warning: lcms2: local (2.19.1-1) is newer than extra (2.18-1)
warning: ldb: local (2:4.24.5-1) is newer than extra (2:4.23.6-1)
warning: leancrypto: local (1.8.0-1) is newer than core (1.6.0-1)
warning: less: local (1:704-1) is newer than core (1:692-1)
warning: libabw: local (0.1.4-1) is newer than extra (0.1.3-6)
warning: libaccounts-qt: local (1.17-2) is newer than extra (1.17-1)
warning: libaio: local (0.3.113-4) is newer than core (0.3.113-3)
warning: libarchive: local (3.8.9-1) is newer than core (3.8.6-1)
warning: libasan: local (16.1.1+r595+g171d15ac6959-1) is newer than core (15.2.1+r604+g0b99615a8aef-1)
warning: libass: local (0.17.5-1) is newer than extra (0.17.4-1)
warning: libatasmart: local (0.19-8) is newer than extra (0.19-7)
warning: libatomic: local (16.1.1+r595+g171d15ac6959-1) is newer than core (15.2.1+r604+g0b99615a8aef-1)
warning: libavif: local (1.4.2-1) is newer than extra (1.4.0-1)
warning: libblake3: local (1.8.4-1) is newer than extra (1.8.3-1)
warning: libblockdev: local (3.5.0-2) is newer than extra (3.4.0-2)
warning: libblockdev-crypto: local (3.5.0-2) is newer than extra (3.4.0-2)
warning: libblockdev-fs: local (3.5.0-2) is newer than extra (3.4.0-2)
warning: libblockdev-loop: local (3.5.0-2) is newer than extra (3.4.0-2)
warning: libblockdev-mdraid: local (3.5.0-2) is newer than extra (3.4.0-2)
warning: libblockdev-nvme: local (3.5.0-2) is newer than extra (3.4.0-2)
warning: libblockdev-part: local (3.5.0-2) is newer than extra (3.4.0-2)
warning: libblockdev-smart: local (3.5.0-2) is newer than extra (3.4.0-2)
warning: libblockdev-swap: local (3.5.0-2) is newer than extra (3.4.0-2)
warning: libbpf: local (1.7.0-1) is newer than core (1.6.2-1)
warning: libcaca: local (0.99.beta20-7) is newer than extra (0.99.beta20-6)
warning: libcap: local (2.78-1) is newer than core (2.77-1)
warning: libcap-ng: local (0.9.3-1) is newer than core (0.9.1-1)
warning: libcbor: local (0.14.0-1) is newer than extra (0.12.0-1)
warning: libcdio-paranoia: local (10.2+2.0.2-2) is newer than extra (10.2+2.0.2-1)
warning: libcdr: local (0.1.9-1) is newer than extra (0.1.8-4)
warning: libcmis: local (0.6.3-1) is newer than extra (0.6.2-7)
warning: libcups: local (2:2.4.19-1) is newer than extra (2:2.4.16-2)
warning: libdbusmenu-qt5: local (0.9.3+16.04.20160218-8) is newer than extra (0.9.3+16.04.20160218-7)
warning: libdc1394: local (2.2.7-2) is newer than extra (2.2.7-1)
warning: libde265: local (1.1.1-1) is newer than extra (1.0.16-2)
warning: libdovi: local (3.4.0-1) is newer than extra (3.3.2-1)
warning: libdrm: local (2.4.134-1) is newer than extra (2.4.131-1)
warning: libdv: local (1.0.0-12) is newer than extra (1.0.0-11)
warning: libdvdcss: local (1.6.0-1) is newer than extra (1.5.0-1)
warning: libdvdread: local (7.1.1-1) is newer than extra (7.0.1-1)
warning: libe-book: local (0.1.4-1) is newer than extra (0.1.3-20)
warning: libebml: local (1.4.5-3) is newer than extra (1.4.5-1)
warning: libedit: local (20260512_3.1-1) is newer than core (20251016_3.1-1)
warning: libei: local (1.6.0-1) is newer than extra (1.5.0-1)
warning: libelf: local (0.195-1) is newer than core (0.194-2)
warning: libevent: local (2.1.13-2) is newer than core (2.1.12-5)
warning: libexif: local (0.6.26-1) is newer than extra (0.6.25-1)
warning: libexttextcat: local (3.4.8-1) is newer than extra (3.4.7-1)
warning: libfdk-aac: local (2.0.3-2) is newer than extra (2.0.3-1)
warning: libffi: local (3.7.1-1) is newer than core (3.5.2-1)
warning: libfido2: local (1.17.0-1) is newer than extra (1.16.0-2)
warning: libfreehand: local (0.1.3-1) is newer than extra (0.1.2-6)
warning: libfyaml: local (0.9.6-3) is newer than extra (0.9.6-1)
warning: libgcc: local (16.1.1+r595+g171d15ac6959-1) is newer than core (15.2.1+r604+g0b99615a8aef-1)
warning: libgcrypt: local (1.12.2-1) is newer than core (1.12.1-1)
warning: libgfortran: local (16.1.1+r595+g171d15ac6959-1) is newer than core (15.2.1+r604+g0b99615a8aef-1)
warning: libgomp: local (16.1.1+r595+g171d15ac6959-1) is newer than core (15.2.1+r604+g0b99615a8aef-1)
warning: libgpg-error: local (1.61-1) is newer than core (1.59-1)
warning: libgphoto2: local (2.5.34-1) is newer than extra (2.5.33-1)
warning: libheif: local (1.23.1-1) is newer than extra (1.21.2-2)
warning: libidn: local (1.44-1) is newer than extra (1.43-1)
warning: libimagequant: local (4.4.1-2) is newer than extra (4.4.1-1)
warning: libinput: local (1.31.3-1) is newer than extra (1.30.1-1)
warning: libisl: local (0.28-1) is newer than core (0.27-1)
warning: libixion: local (0.20.0-7) is newer than extra (0.20.0-5)
warning: libjcat: local (0.2.6-1) is newer than extra (0.2.5-1)
warning: libjpeg-turbo: local (3.2.0-2) is newer than extra (3.1.3-1)
warning: libjxl: local (0.12.0-1) is newer than extra (0.11.2-2)
warning: libkdcraw: local (26.04.3-1) is newer than extra (25.12.3-1)
warning: libkexiv2: local (26.04.3-1) is newer than extra (25.12.3-1)
warning: libksane: local (26.04.3-1) is newer than extra (25.12.3-1)
warning: libksba: local (1.8.0-1) is newer than core (1.6.8-1)
warning: libkscreen: local (6.7.4-1) is newer than extra (6.5.6-1)
warning: libksysguard: local (6.7.4-1) is newer than extra (6.5.6-1)
warning: libldac: local (2.0.2.6-1) is newer than extra (2.0.2.3-3)
warning: liblsan: local (16.1.1+r595+g171d15ac6959-1) is newer than core (15.2.1+r604+g0b99615a8aef-1)
warning: libmanette: local (0.2.13-2) is newer than extra (0.2.13-1)
warning: libmatroska: local (1.7.2-2) is newer than extra (1.7.1-2)
warning: libmd: local (1.2.0-1) is newer than extra (1.1.0-2)
warning: libmicrohttpd: local (1.0.9-1) is newer than core (1.0.2-1)
warning: libmodplug: local (0.8.9.0-7) is newer than extra (0.8.9.0-6)
warning: libmpc: local (1.4.1-1) is newer than core (1.3.1-2)
warning: libmspack: local (1:1.11-2) is newer than extra (1:1.11-1)
warning: libmspub: local (0.1.5-1) is newer than extra (0.1.4-19)
warning: libmwaw: local (0.3.23-1) is newer than extra (0.3.22-4)
warning: libmysofa: local (1.3.4-1) is newer than extra (1.3.3-1)
warning: libnetfilter_conntrack: local (1.1.1-1) is newer than core (1.0.9-2)
warning: libnghttp2: local (1.70.0-1) is newer than core (1.68.0-1)
warning: libnghttp3: local (1.18.0-1) is newer than core (1.15.0-1)
warning: libngtcp2: local (1.25.0-1) is newer than core (1.21.0-1)
warning: libnm: local (1.58.0-1) is newer than extra (1.56.0-1)
warning: libnsl: local (2.0.1-2) is newer than core (2.0.1-1)
warning: libnvme: local (1.16.2-1) is newer than extra (1.16.1-3)
warning: libobjc: local (16.1.1+r595+g171d15ac6959-1) is newer than core (15.2.1+r604+g0b99615a8aef-1)
warning: libopenmpt: local (0.8.7-1) is newer than extra (0.8.4-1)
warning: liborcus: local (0.21.0-6) is newer than extra (0.21.0-4)
warning: libp11-kit: local (0.26.4-1) is newer than core (0.26.2-1)
warning: libpaper: local (2.2.8-1) is newer than extra (2.2.7-1)
warning: libpciaccess: local (0.19-1) is newer than extra (0.18.1-2)
warning: libpgm: local (5.3.128-4) is newer than extra (5.3.128-3)
warning: libpipewire: local (1:1.6.8-1) is newer than extra (1:1.6.2-1)
warning: libplacebo: local (7.360.1-6) is newer than extra (7.360.1-1)
warning: libplasma: local (6.7.4-1) is newer than extra (6.5.6-1)
warning: libpng: local (1.6.58-2) is newer than extra (1.6.55-1)
warning: libqaccessibilityclient-qt6: local (0.6.0-4) is newer than extra (0.6.0-1)
warning: libqalculate: local (5.12.0-1) is newer than extra (5.9.0-1)
warning: libquadmath: local (16.1.1+r595+g171d15ac6959-1) is newer than core (15.2.1+r604+g0b99615a8aef-1)
warning: libqxp: local (0.0.3-1) is newer than extra (0.0.2-15)
warning: libraqm: local (0.11.0-1) is newer than extra (0.10.4-1)
warning: libraw: local (0.22.2-1) is newer than extra (0.22.0-2)
warning: libreoffice-fresh: local (26.2.5-1) is newer than extra (26.2.1-2)
warning: libreoffice-fresh-en-gb: local (26.2.5-1) is newer than extra (26.2.1-1)
warning: librevenge: local (0.0.6-1) is newer than extra (0.0.5-4)
warning: librsvg: local (2:2.62.3-1) is newer than extra (2:2.61.4-1)
warning: libsbsms: local (2.3.0-6) is newer than extra (2.3.0-5)
warning: libsigc++: local (2.12.2-1) is newer than extra (2.12.1-2)
warning: libsodium: local (1.0.22-1) is newer than extra (1.0.21-1)
warning: libsoxr: local (0.1.3-5) is newer than extra (0.1.3-4)
warning: libssc: local (0.4.4-1) is newer than extra (0.4.1-1)
warning: libssh: local (0.12.2-1) is newer than extra (0.12.0-1)
warning: libssh2: local (1.11.1-7) is newer than core (1.11.1-1)
warning: libstaroffice: local (0.0.8-1) is newer than extra (0.0.7-5)
warning: libstdc++: local (16.1.1+r595+g171d15ac6959-1) is newer than core (15.2.1+r604+g0b99615a8aef-1)
warning: libstemmer: local (3.1.1-1) is newer than extra (3.0.1-1)
warning: libsysprof-capture: local (50.0-4) is newer than extra (49.0-2)
warning: libtiff: local (4.7.2-1) is newer than extra (4.7.1-1)
warning: libtool: local (2.6.2-3) is newer than core (2.6.0-4)
warning: libtorrent-rasterbar: local (1:2.1.0-3) is newer than extra (1:2.0.11-8)
warning: libtsan: local (16.1.1+r595+g171d15ac6959-1) is newer than core (15.2.1+r604+g0b99615a8aef-1)
warning: libubsan: local (16.1.1+r595+g171d15ac6959-1) is newer than core (15.2.1+r604+g0b99615a8aef-1)
warning: libunibreak: local (7.0-1) is newer than extra (6.1-1)
warning: libunistring: local (1.4.2-1) is newer than core (1.4.1-1)
warning: liburing: local (2.15-1) is newer than extra (2.14-1)
warning: libusb: local (1.0.30-1) is newer than core (1.0.29-1)
warning: libva: local (2.24.1-1) is newer than extra (2.23.0-1)
warning: libva-utils: local (2.24.0-1) is newer than extra (2.22.0-1)
warning: libvdpau-va-gl: local (0.4.2-5) is newer than extra (0.4.2-4)
warning: libverto: local (0.3.2-6) is newer than core (0.3.2-5)
warning: libvisio: local (0.1.11-1) is newer than extra (0.1.10-3)
warning: libvpl: local (2.17.0-1) is newer than extra (2.16.0-2)
warning: libvpx: local (1.16.0-3) is newer than extra (1.15.2-3)
warning: libwacom: local (2.19.1-1) is newer than extra (2.18.0-2)
warning: libwbclient: local (2:4.24.5-1) is newer than extra (2:4.23.6-1)
warning: libwireplumber: local (0.5.15-1) is newer than extra (0.5.13-1)
warning: libxaw: local (1.0.16-2) is newer than extra (1.0.16-1)
warning: libxdmcp: local (1.1.5-2) is newer than extra (1.1.5-1)
warning: libxfont2: local (2.0.9-1) is newer than extra (2.0.7-1)
warning: libxi: local (1.8.3-1) is newer than extra (1.8.2-1)
warning: libxkbcommon: local (1.13.2-1) is newer than extra (1.13.1-1)
warning: libxkbcommon-x11: local (1.13.2-1) is newer than extra (1.13.1-1)
warning: libxml2: local (2.15.3-1) is newer than core (2.15.2-1)
warning: libxmlb: local (0.3.29-1) is newer than extra (0.3.25-1)
warning: libxnvctrl: local (610.57.04-1) is newer than extra (590.48.01-1)
warning: libxpm: local (3.5.19-1) is newer than extra (3.5.18-1)
warning: lilv: local (0.28.0-1) is newer than extra (0.26.4-1)
warning: linux-api-headers: local (7.1-1) is newer than core (6.19-1)
:: Replace linux-firmware with core/linux-firmware-meta? [Y/n] n
warning: linux-firmware-amdgpu: local (20260622-1) is newer than core (20260309-1)
warning: linux-firmware-atheros: local (20260622-1) is newer than core (20260309-1)
warning: linux-firmware-broadcom: local (20260622-1) is newer than core (20260309-1)
warning: linux-firmware-cirrus: local (20260622-1) is newer than core (20260309-1)
warning: linux-firmware-intel: local (20260622-1) is newer than core (20260309-1)
warning: linux-firmware-liquidio: local (20260622-1) is newer than core (20260309-1)
warning: linux-firmware-marvell: local (20260622-1) is newer than core (20260309-1)
warning: linux-firmware-mediatek: local (20260622-1) is newer than core (20260309-1)
warning: linux-firmware-mellanox: local (20260622-1) is newer than core (20260309-1)
warning: linux-firmware-nfp: local (20260622-1) is newer than core (20260309-1)
warning: linux-firmware-nvidia: local (20260622-1) is newer than core (20260309-1)
warning: linux-firmware-other: local (20260622-1) is newer than core (20260309-1)
warning: linux-firmware-qcom: local (20260622-1) is newer than core (20260309-1)
warning: linux-firmware-qlogic: local (20260622-1) is newer than core (20260309-1)
warning: linux-firmware-radeon: local (20260622-1) is newer than core (20260309-1)
warning: linux-firmware-realtek: local (20260622-1) is newer than core (20260309-1)
warning: linux-firmware-whence: local (20260622-1) is newer than core (20260309-1)
warning: litehtml: local (0.10-1) is newer than extra (0.9-2)
warning: llvm-libs: local (22.1.8-2) is newer than extra (22.1.1-1)
warning: lsof: local (4.99.7-1) is newer than extra (4.99.6-1)
warning: lua: local (5.5.1-1) is newer than extra (5.4.8-2)
warning: luajit: local (2.1.1785763465+1edc3e5-1) is newer than extra (2.1.1772619647+659a616-1)
warning: lvm2: local (2.03.41-1) is newer than core (2.03.38-1)
warning: m4: local (1.4.21-2) is newer than core (1.4.21-1)
warning: make: local (4.4.1-3) is newer than core (4.4.1-2)
warning: man-db: local (2.13.1-2) is newer than core (2.13.1-1)
warning: man-pages: local (6.18-1) is newer than core (6.17-1)
warning: manjaro-browser-settings: local (20231111-2) is newer than extra (20231111-1)
warning: manjaro-hello: local (0.8.1-7) is newer than extra (0.8.1-4)
warning: manjaro-release: local (26.1.0-1) is newer than core (26.0.4-1)
warning: manjaro-settings-manager: local (0.5.8-9) is newer than extra (0.5.8-8)
warning: manjaro-settings-manager-knotifier: local (0.5.8-9) is newer than extra (0.5.8-8)
warning: manjaro-zsh-config: local (0.26-4) is newer than extra (0.26-2)
warning: md4c: local (0.5.3-1) is newer than extra (0.5.2-1)
warning: mdadm: local (4.6-2) is newer than core (4.5-2)
warning: meld: local (3.24.0-1) is newer than extra (3.22.3-2)
warning: mesa: local (1:26.1.6-1) is newer than extra (1:26.0.2-1)
warning: mhwd-db: local (20260305-1) is newer than extra (20260107-1)
warning: mhwd-nvidia: local (610.57.04-1) is newer than extra (590.48.01-3)
warning: mhwd-nvidia-390xx: local (390.157-28) is newer than extra (390.157-23)
warning: mhwd-nvidia-470xx: local (470.256.02-19) is newer than extra (470.256.02-17)
warning: mhwd-nvidia-580xx: local (580.178.04-1) is newer than extra (580.142-1)
warning: micro: local (2.0.15-3) is newer than extra (2.0.15-2)
warning: milou: local (6.7.4-1) is newer than extra (6.5.6-1)
warning: mkinitcpio: local (41-2) is newer than core (40-4)
warning: mkvtoolnix-cli: local (100.0-1) is newer than extra (97.0-1)
warning: mkvtoolnix-gui: local (100.0-1) is newer than extra (97.0-1)
warning: modemmanager-qt: local (6.28.0-1) is newer than extra (6.24.0-1)
warning: mpdecimal: local (4.0.1-3) is newer than core (4.0.1-1)
warning: mpg123: local (1.33.5-1) is newer than extra (1.33.4-1)
warning: nano: local (9.1-1) is newer than core (8.7.1-1)
warning: ncurses: local (6.6-2) is newer than core (6.6-1)
warning: neon: local (0.37.1-1) is newer than extra (0.36.0-1)
warning: nettle: local (4.0-1) is newer than core (3.10.2-1)
warning: networkmanager: local (1.58.0-1) is newer than extra (1.56.0-1)
warning: networkmanager-l2tp: local (1.52.2-2) is newer than extra (1.52.0-1)
warning: networkmanager-qt: local (6.28.0-1) is newer than extra (6.24.0-1)
warning: networkmanager-vpn-plugin-l2tp: local (1.52.2-2) is newer than extra (1.52.0-1)
warning: nfs-utils: local (2.9.2-1) is newer than core (2.8.7-1)
warning: nfsidmap: local (2.9.2-1) is newer than core (2.8.7-1)
warning: nodejs: local (26.7.0-1) is newer than extra (25.8.1-1)
warning: noto-fonts: local (1:2026.08.01-1) is newer than extra (1:2026.03.01-1)
warning: nspr: local (4.39-1) is newer than core (4.38.2-1)
warning: nss: local (3.126-1) is newer than core (3.121-1)
warning: ntfs-3g: local (2026.7.7-1) is newer than extra (2022.10.3-2)
:: Replace ntfsprogs with extra/ntfs-3g? [Y/n] n
warning: nvidia-driver-assistant: local (0.23.48.01-7) is newer than extra (0.23.48.01-6)
warning: oath-toolkit: local (2.6.14-4) is newer than extra (2.6.14-1)
warning: ocean-sound-theme: local (6.7.4-1) is newer than extra (6.5.6-1)
warning: ocl-icd: local (2.3.5-1) is newer than extra (2.3.4-1)
warning: okular: local (26.04.3-1) is newer than extra (25.12.3-1)
warning: onetbb: local (2023.1.0-1) is newer than extra (2022.3.0-4)
warning: openal: local (1.25.2-1) is newer than extra (1.25.1-1)
warning: openconnect: local (1:9.21-1) is newer than extra (1:9.12-4)
warning: opencv: local (5.0.0-7) is newer than extra (4.13.0-2)
warning: openexr: local (3.4.13-3) is newer than extra (3.4.7-1)
warning: openjph: local (0.31.0-1) is newer than extra (0.26.3-3)
warning: openssh: local (10.4p1-3) is newer than core (10.2p1-2)
warning: openssl: local (3.6.3-1) is newer than core (3.6.1-1)
warning: openvpn: local (2.7.6-1) is newer than extra (2.7.0-1)
warning: openxr: local (1.1.60-1) is newer than extra (1.1.57-1)
warning: p11-kit: local (0.26.4-1) is newer than core (0.26.2-1)
warning: pacman: local (7.1.0.r9.g54d9411-2) is newer than core (7.1.0.r9.g54d9411-1)
warning: pambase: local (20260616-1) is newer than core (20250719-1)
warning: pango: local (1:1.58.2-1) is newer than extra (1:1.57.0-2)
warning: pangomm: local (2.46.5-1) is newer than extra (2.46.4-1)
warning: papirus-icon-theme: local (20260801-1) is newer than extra (20250501-1)
warning: parallel: local (20260722-1) is newer than extra (20260222-1)
warning: parted: local (3.7-1) is newer than extra (3.6-2)
warning: partitionmanager: local (26.04.3-1) is newer than extra (25.12.3-1)
warning: passim: local (0.1.12-1) is newer than extra (0.1.10-1)
warning: pciutils: local (3.15.0-1) is newer than core (3.14.0-1)
warning: pcsclite: local (2.5.1-1) is newer than extra (2.4.1-1)
warning: perl: local (5.42.2-1) is newer than core (5.42.0-1)
warning: perl-alien-build: local (2.84-5) is newer than extra (2.84-4)
warning: perl-clone: local (0.50-1) is newer than extra (0.48-1)
warning: perl-dbi: local (1.651-1) is newer than extra (1.647-2)
warning: perl-file-mimeinfo: local (0.37-1) is newer than extra (0.36-1)
warning: perl-html-parser: local (3.85-1) is newer than extra (3.83-2)
warning: perl-http-cookies: local (6.12-1) is newer than extra (6.11-4)
warning: perl-http-daemon: local (6.17-1) is newer than extra (6.16-6)
warning: perl-http-date: local (6.08-1) is newer than extra (6.06-5)
warning: perl-http-message: local (7.04-1) is newer than extra (7.01-2)
warning: perl-libwww: local (6.83-1) is newer than extra (6.81-2)
warning: perl-timedate: local (2.35-1) is newer than extra (2.34-1)
warning: perl-uri: local (5.35-1) is newer than extra (5.34-2)
warning: perl-www-robotrules: local (6.03-1) is newer than extra (6.02-16)
warning: perl-xml-libxml: local (2.0213-1) is newer than extra (2.0210-4)
warning: perl-xml-parser: local (2.59-1) is newer than extra (2.47-3)
warning: phonon-qt6: local (4.12.0-6) is newer than extra (4.12.0-5)
warning: pinentry: local (1.3.3-1) is newer than core (1.3.2-2)
warning: pipewire: local (1:1.6.8-1) is newer than extra (1:1.6.2-1)
warning: pipewire-alsa: local (1:1.6.8-1) is newer than extra (1:1.6.2-1)
warning: pipewire-audio: local (1:1.6.8-1) is newer than extra (1:1.6.2-1)
warning: pipewire-pulse: local (1:1.6.8-1) is newer than extra (1:1.6.2-1)
warning: pipewire-session-manager: local (1:1.6.8-1) is newer than extra (1:1.6.2-1)
warning: pkgconf: local (3.0.5-1) is newer than core (2.5.1-1)
warning: plasma-activities: local (6.7.4-1) is newer than extra (6.5.6-1)
warning: plasma-activities-stats: local (6.7.4-1) is newer than extra (6.5.6-1)
warning: plasma-browser-integration: local (6.7.4-1) is newer than extra (6.5.6-1)
warning: plasma-desktop: local (6.7.4-1) is newer than extra (6.5.6-1)
warning: plasma-integration: local (6.7.4-1) is newer than extra (6.5.6-1)
warning: plasma-login-manager: local (6.7.4-1) is newer than extra (6.5.91-2)
warning: plasma-nm: local (6.7.4-1) is newer than extra (6.5.6-1)
warning: plasma-pa: local (6.7.4-1) is newer than extra (6.5.6-1)
warning: plasma-systemmonitor: local (6.7.4-1) is newer than extra (6.5.6-1)
warning: plasma-thunderbolt: local (6.7.4-1) is newer than extra (6.5.6-1)
warning: plasma-workspace: local (6.7.4-1) is newer than extra (6.5.6-1)
warning: plasma5support: local (6.7.4-1) is newer than extra (6.5.6-1)
warning: podofo: local (0.10.6-1) is newer than extra (0.10.4-2)
warning: polkit-kde-agent: local (6.7.4-1) is newer than extra (6.5.6-1)
warning: polkit-qt5: local (0.201.1-1) is newer than extra (0.200.0-1)
warning: polkit-qt6: local (0.201.1-1) is newer than extra (0.200.0-1)
warning: poppler: local (26.07.0-1) is newer than extra (26.03.0-1)
warning: poppler-glib: local (26.07.0-1) is newer than extra (26.03.0-1)
warning: poppler-qt6: local (26.07.0-1) is newer than extra (26.03.0-1)
warning: portaudio: local (1:19.7.0-4) is newer than extra (1:19.7.0-3)
warning: powerdevil: local (6.7.4-1) is newer than extra (6.5.6-1)
warning: ppp: local (2.5.3-1) is newer than core (2.5.2-1)
warning: print-manager: local (1:6.7.4-1) is newer than extra (1:6.5.6-1)
warning: prison: local (6.28.0-1) is newer than extra (6.24.0-1)
warning: procps-ng: local (4.0.6-3) is newer than core (4.0.6-1)
warning: protobuf: local (35.1-1) is newer than extra (33.1-4)
warning: protobuf-c: local (1.5.2-12) is newer than extra (1.5.2-8)
warning: psmisc: local (23.7-2) is newer than core (23.7-1)
warning: pugixml: local (1.16-1) is newer than extra (1.15-3)
warning: purpose: local (6.28.0-1) is newer than extra (6.24.0-1)
warning: python: local (3.14.6-1) is newer than core (3.14.3-1)
warning: python-attrs: local (26.1.0-1) is newer than extra (25.4.0-3)
warning: python-cairo: local (1.29.1-1) is newer than extra (1.29.0-2)
warning: python-certifi: local (2026.07.22-1) is newer than extra (2026.02.25-1)
warning: python-cffi: local (2.1.1-1) is newer than extra (2.0.0-2)
warning: python-charset-normalizer: local (3.4.7-1) is newer than extra (3.4.6-1)
warning: python-cryptography: local (49.0.0-1) is newer than extra (46.0.5-2)
warning: python-filelock: local (3.29.3-1) is newer than extra (3.24.0-1)
warning: python-gobject: local (3.56.3-1) is newer than extra (3.54.5-2)
warning: python-idna: local (3.18-1) is newer than extra (3.11-2)
warning: python-npyscreen: local (5.0.4-1) is newer than extra (5.0.2-2)
warning: python-packaging: local (26.2-1) is newer than extra (26.0-1)
warning: python-pillow: local (12.3.0-1) is newer than extra (12.1.1-1)
warning: python-pip: local (26.2.1-1) is newer than extra (26.0.1-1)
warning: python-pycparser: local (3.00-1) is newer than extra (2.23-2)
warning: python-pyqt5: local (5.15.11-7) is newer than extra (5.15.11-5)
warning: python-pyqt5-sip: local (12.19.0-1) is newer than extra (12.18.0-1)
warning: python-pytz: local (2026.1-1) is newer than extra (2025.2-2)
warning: python-reportlab: local (5.0.0-1) is newer than extra (4.2.2-6)
warning: python-requests: local (2.34.2-1) is newer than extra (2.32.5-4)
warning: python-typing_extensions: local (4.16.0-1) is newer than extra (4.15.0-3)
warning: python-urllib3: local (2.7.0-1) is newer than extra (2.6.3-1)
warning: python-urwid: local (4.0.8-2) is newer than extra (3.0.5-1)
warning: python-wcwidth: local (0.8.2-1) is newer than extra (0.6.0-1)
warning: python-wheel: local (0.47.0-1) is newer than extra (0.46.3-1)
warning: qbittorrent: local (5.2.3-3) is newer than extra (5.1.4-1)
warning: qca-qt6: local (2.3.10-7) is newer than extra (2.3.10-5)
warning: qcoro: local (0.13.0-2) is newer than extra (0.13.0-1)
warning: qqc2-breeze-style: local (6.7.4-1) is newer than extra (6.5.6-1)
warning: qqc2-desktop-style: local (6.28.0-1) is newer than extra (6.24.0-1)
warning: qt5-base: local (5.15.19+kde+r96-1) is newer than extra (5.15.18+kde+r109-2)
warning: qt5-declarative: local (5.15.19+kde+r23-1) is newer than extra (5.15.18+kde+r23-1)
warning: qt5-graphicaleffects: local (5.15.19-1) is newer than extra (5.15.18-1)
warning: qt5-multimedia: local (5.15.19+kde+r2-1) is newer than extra (5.15.18+kde+r2-1)
warning: qt5-quickcontrols: local (5.15.19-1) is newer than extra (5.15.18-1)
warning: qt5-quickcontrols2: local (5.15.19+kde+r5-1) is newer than extra (5.15.18+kde+r5-1)
warning: qt5-speech: local (5.15.19+kde+r1-1) is newer than extra (5.15.18+kde+r1-1)
warning: qt5-svg: local (5.15.19+kde+r5-1) is newer than extra (5.15.18+kde+r5-1)
warning: qt5-translations: local (5.15.19-1) is newer than extra (5.15.18-1)
warning: qt5-wayland: local (5.15.19+kde+r55-1) is newer than extra (5.15.18+kde+r55-1)
warning: qt5-x11extras: local (5.15.19-1) is newer than extra (5.15.18-1)
warning: qt6-5compat: local (6.11.1-1) is newer than extra (6.10.2-1)
warning: qt6-base: local (6.11.1-1) is newer than extra (6.10.2-1)
warning: qt6-declarative: local (6.11.1-3) is newer than extra (6.10.2-1)
warning: qt6-imageformats: local (6.11.1-1) is newer than extra (6.10.2-1)
warning: qt6-location: local (6.11.1-1) is newer than extra (6.10.2-1)
warning: qt6-multimedia: local (6.11.1-1) is newer than extra (6.10.2-1)
warning: qt6-multimedia-ffmpeg: local (6.11.1-1) is newer than extra (6.10.2-1)
warning: qt6-positioning: local (6.11.1-1) is newer than extra (6.10.2-1)
warning: qt6-quick3d: local (6.11.1-1) is newer than extra (6.10.2-1)
warning: qt6-quicktimeline: local (6.11.1-1) is newer than extra (6.10.2-1)
warning: qt6-shadertools: local (6.11.1-1) is newer than extra (6.10.2-1)
warning: qt6-speech: local (6.11.1-1) is newer than extra (6.10.2-1)
warning: qt6-svg: local (6.11.1-1) is newer than extra (6.10.2-1)
warning: qt6-tools: local (6.11.1-4) is newer than extra (6.10.2-3)
warning: qt6-translations: local (6.11.1-1) is newer than extra (6.10.2-1)
warning: qt6-virtualkeyboard: local (6.11.1-1) is newer than extra (6.10.2-1)
warning: qt6-wayland: local (6.11.1-1) is newer than extra (6.10.2-1)
warning: qt6-webchannel: local (6.11.1-1) is newer than extra (6.10.2-1)
warning: qt6-webengine: local (6.11.1-4) is newer than extra (6.10.2-1)
warning: qt6-websockets: local (6.11.1-1) is newer than extra (6.10.2-1)
warning: qtkeychain-qt6: local (0.17.0-1) is newer than extra (0.15.0-3)
warning: rasqal: local (1:0.9.33-9) is newer than extra (1:0.9.33-7)
warning: rav1e: local (0.8.1-3) is newer than extra (0.8.1-2)
warning: re2: local (2:2025.11.05-5) is newer than extra (2:2025.11.05-1)
warning: redland: local (1:1.0.17-10) is newer than extra (1:1.0.17-9)
warning: ripgrep: local (15.2.0-1) is newer than extra (15.1.0-2)
warning: rpcbind: local (1.2.9-1) is newer than core (1.2.8-1)
warning: rsync: local (3.4.4-1) is newer than extra (3.4.1-2)
warning: rubberband: local (4.0.0-2) is newer than extra (4.0.0-1)
warning: s-tui: local (1.4.0-1) is newer than extra (1.3.0-1)
warning: sdl2-compat: local (2.32.70-1) is newer than extra (2.32.64-1)
warning: sdl3: local (3.4.14-1) is newer than extra (3.4.2-1)
warning: sed: local (4.10-1) is newer than core (4.9-3)
warning: serd: local (0.32.10-1) is newer than extra (0.32.8-1)
warning: shaderc: local (2026.3-1) is newer than extra (2026.1-2)
warning: shadow: local (4.20.0.arch1-1) is newer than core (4.18.0-1)
warning: shared-mime-info: local (2.5.1-2) is newer than extra (2.4-3)
warning: signon-kwallet-extension: local (26.04.3-1) is newer than extra (25.12.3-1)
warning: signon-plugin-oauth2: local (0.25-4) is newer than extra (0.25-3)
warning: signon-ui: local (0.17+20231016-4) is newer than extra (0.17+20231016-3)
warning: signond: local (8.61-4) is newer than extra (8.61-3)
warning: simdjson: local (1:4.6.6-1) is newer than extra (1:4.4.0-1)
warning: skanlite: local (26.04.3-1) is newer than extra (25.12.3-1)
warning: smbclient: local (2:4.24.5-1) is newer than extra (2:4.23.6-1)
warning: socat: local (1.8.1.3-1) is newer than extra (1.8.1.1-1)
warning: solid: local (6.28.0-1) is newer than extra (6.24.0-1)
warning: sonnet: local (6.28.0-1) is newer than extra (6.24.0-1)
warning: soundtouch: local (2.4.1-1) is newer than extra (2.4.0-1)
warning: source-highlight: local (3.1.9-18) is newer than extra (3.1.9-16)
warning: spectacle: local (1:6.7.4-1) is newer than extra (1:6.5.6-1)
warning: spirv-tools: local (1:1.4.357.0-1) is newer than extra (1:1.4.341.0-2)
warning: sqlite: local (3.53.4-1) is newer than core (3.52.0-1)
warning: srt: local (1.5.6-1) is newer than extra (1.5.4-1)
warning: sshfs: local (3.7.6-1) is newer than extra (3.7.5-1)
warning: stoken: local (0.92-6) is newer than extra (0.92-5)
warning: sudo: local (1.9.17.p2-6) is newer than core (1.9.17.p2-2)
warning: sudo-rs: local (0.2.14-1) is newer than extra (0.2.13-1)
warning: svt-av1: local (4.2.0-1) is newer than extra (4.0.1-1)
warning: syndication: local (6.28.0-1) is newer than extra (6.24.0-1)
warning: syntax-highlighting: local (6.28.1-1) is newer than extra (6.24.0-1)
warning: systemd: local (261.2-1) is newer than core (259.5-1)
warning: systemd-libs: local (261.2-1) is newer than core (259.5-1)
warning: systemd-sysvcompat: local (261.2-1) is newer than core (259.5-1)
warning: systemsettings: local (6.7.4-1) is newer than extra (6.5.6-1)
warning: taglib: local (2.3.1-1) is newer than extra (2.2.1-1)
warning: talloc: local (2.5.0-1) is newer than extra (2.4.4-1)
warning: telegram-desktop: local (7.0.8-2) is newer than extra (6.6.3-1)
warning: tesseract: local (5.5.3-1) is newer than extra (5.5.2-1)
warning: tesseract-data-eng: local (2:4.1.0-5) is newer than extra (2:4.1.0-4)
warning: tesseract-data-osd: local (2:4.1.0-5) is newer than extra (2:4.1.0-4)
warning: tevent: local (1:0.17.2-1) is newer than extra (1:0.17.1-2)
warning: texinfo: local (7.3-1) is newer than core (7.2-1)
warning: thin-provisioning-tools: local (1.3.3-1) is newer than core (1.3.1-1)
warning: threadweaver: local (6.28.0-1) is newer than extra (6.24.0-1)
warning: tinysparql: local (3.11.1-1) is newer than extra (3.10.1-2)
warning: ttf-dejavu: local (2.37+18+g9b5d1b2f-8) is newer than extra (2.37+18+g9b5d1b2f-7)
warning: ttf-hack-nerd: local (3.5.0-1) is newer than extra (3.4.0-2)
warning: tzdata: local (2026c-1) is newer than core (2026a-1)
warning: uchardet: local (0.0.8-4) is newer than extra (0.0.8-3)
warning: udev-usb-sync: local (1.1-1) is newer than extra (1.0-1)
warning: udiskie: local (2.7.0-1) is newer than extra (2.6.1-1)
warning: udisks2: local (2.11.2-1) is newer than extra (2.11.1-2)
warning: upower: local (1.91.3-1) is newer than extra (1.91.1-1)
warning: util-linux: local (2.42.2-1) is newer than core (2.41.3-2)
warning: util-linux-libs: local (2.42.2-1) is newer than core (2.41.3-2)
warning: vapoursynth: local (77-2) is newer than extra (73-2)
warning: ventoy: local (1.1.17-1) is newer than extra (1.1.10-2)
warning: verdict: local (1.4.5-2) is newer than extra (1.4.4-1)
warning: vid.stab: local (1.1.1-3) is newer than extra (1.1.1-2)
warning: vivaldi: local (8.1.4087.61-1) is newer than extra (7.9.3970.39-1)
warning: vmaf: local (3.2.0-1) is newer than extra (3.0.0-2)
warning: vpnc: local (1:0.5.3.r557.r241-1) is newer than extra (1:0.5.3.r539.r239-1)
warning: vulkan-icd-loader: local (1.4.357.0-1) is newer than extra (1.4.341.0-1)
warning: vulkan-intel: local (1:26.1.6-1) is newer than extra (1:26.0.2-1)
warning: vulkan-mesa-implicit-layers: local (1:26.1.6-1) is newer than extra (1:26.0.2-1)
warning: vulkan-nouveau: local (1:26.1.6-1) is newer than extra (1:26.0.2-1)
warning: vulkan-radeon: local (1:26.1.6-1) is newer than extra (1:26.0.2-1)
warning: vulkan-tools: local (1.4.357.0-1) is newer than extra (1.4.341.0-2)
warning: wayland: local (1.25.0-1) is newer than extra (1.24.0-1)
warning: webkit2gtk-4.1: local (2.52.5-2) is newer than extra (2.50.6-1)
warning: webkitgtk-6.0: local (2.52.5-2) is newer than extra (2.50.6-1)
warning: wget: local (1.25.0-6) is newer than extra (1.25.0-3)
warning: which: local (2.25-1) is newer than core (2.23-1)
warning: wireless-regdb: local (2026.05.30-1) is newer than core (2026.02.04-1)
warning: wireplumber: local (0.5.15-1) is newer than extra (0.5.13-1)
warning: wxwidgets-common: local (3.2.11-2) is newer than extra (3.2.10-1)
warning: wxwidgets-gtk3: local (3.2.11-2) is newer than extra (3.2.10-1)
warning: x265: local (4.2-2) is newer than extra (4.1-1)
warning: xapian-core: local (1:2.0.0-2) is newer than extra (1:1.4.30-1)
warning: xdg-dbus-proxy: local (0.1.7-1) is newer than extra (0.1.6-1)
warning: xdg-desktop-portal: local (1.22.1-2) is newer than extra (1.20.3-2)
warning: xdg-desktop-portal-kde: local (6.7.4-2) is newer than extra (6.5.6-1)
warning: xdg-user-dirs: local (0.20-1) is newer than extra (0.19-2)
warning: xf86-input-elographics: local (1.4.4-2) is newer than extra (1.4.4-1)
warning: xf86-video-ati: local (1:22.0.0-3) is newer than extra (1:22.0.0-2)
warning: xfsprogs: local (7.1.1-1) is newer than core (6.18.0-1)
warning: xkeyboard-config: local (2.48-1) is newer than extra (2.47-1)
warning: xmlsec: local (1.3.12-1) is newer than extra (1.3.9-1)
warning: xorg-fonts-encodings: local (1.1.0-2) is newer than extra (1.1.0-1)
warning: xorg-mkfontscale: local (1.2.4-2) is newer than extra (1.2.3-1)
warning: xorg-server: local (21.1.24-1) is newer than extra (21.1.21-1)
warning: xorg-server-common: local (21.1.24-1) is newer than extra (21.1.21-1)
warning: xorg-setxkbmap: local (1.3.5-1) is newer than extra (1.3.4-2)
warning: xorg-xmessage: local (1.0.7-2) is newer than extra (1.0.7-1)
warning: xorg-xmodmap: local (1.0.12-1) is newer than extra (1.0.11-2)
warning: xorg-xrdb: local (1.2.3-1) is newer than extra (1.2.2-2)
warning: xorg-xset: local (1.2.6-1) is newer than extra (1.2.5-2)
warning: xorg-xwayland: local (24.1.13-1) is newer than extra (24.1.9-1)
warning: xsettingsd: local (1.0.4-1) is newer than extra (1.0.2-3)
warning: xvidcore: local (1.3.7-4) is newer than extra (1.3.7-3)
warning: xz: local (5.8.3-1) is newer than core (5.8.2-1)
warning: yay: local (13.0.1-1) is newer than extra (12.5.7-1)
warning: zimg: local (3.0.6-2) is newer than extra (3.0.6-1)
warning: zint: local (2.16.0-2) is newer than extra (2.16.0-1)
warning: zix: local (0.8.2-1) is newer than extra (0.8.0-1)
warning: zsh: local (5.9.2-1) is newer than extra (5.9-5)
warning: zsh-syntax-highlighting: local (0.8.0-2) is newer than extra (0.8.0-1)
warning: zsh-theme-powerlevel10k: local (1:1.20.17-1) is newer than extra (1.20.15-1)
warning: zxing-cpp: local (3.1.1-1) is newer than extra (3.0.2-1)
 there is nothing to do
I comment out the suspicious-to-be-dead mirror:
# Server = https://mirror.koddos.net/manjaro/testing/$repo/$arch
I re-check for updates:
❯ sudo pacman -Syyu
 core        150.0 KiB   324 KiB/s 00:00 [############################################################################] 100%
 extra        8.9 MiB   663 KiB/s 00:14 [############################################################################] 100%
 chaotic-aur        662.9 KiB   828 KiB/s 00:01 [############################################################################] 100%
warning: cpupower: local (7.1.7-1) is newer than extra (7.1.6-1)
warning: libxfont2: local (2.0.9-1) is newer than extra (2.0.8-1)
warning: nodejs: local (26.7.0-1) is newer than extra (26.5.1-1)
warning: openvpn: local (2.7.6-1) is newer than extra (2.7.5-1)
warning: pango: local (1:1.58.2-1) is newer than extra (1:1.58.1-1)
warning: python-reportlab: local (5.0.0-1) is newer than extra (4.4.10-2)
warning: python-urwid: local (4.0.8-2) is newer than extra (4.0.8-1)
and got near actual outdated packages.
I went to check mirror status (https://repo.manjaro.org/):
The suspicious mirror is outdated for 1088 hours =
> 1088/24/30
1.5111111111111113
months
We all new, that to edit the /etc/pacman.d/mirrorlist is only temporal solution, cause weekly it’s being re-generated:
❯ systemctl status pamac-mirrorlist.timer
● pamac-mirrorlist.timer - Generate mirrorlist weekly
     Loaded: loaded (/usr/lib/systemd/system/pamac-mirrorlist.timer; enabled; preset: disabled)
     Active: active (waiting) since Sun 2026-08-02 12:16:05 MSK; 6 days ago
 Invocation: 8210fe8911e5464b980a26cdc7d5b455
    Trigger: Thu 2026-08-13 08:02:35 MSK; 4 days left
   Triggers: ● pamac-mirrorlist.service
Aug 02 12:16:05 pc systemd[1]: Started Generate mirrorlist weekly.
and cause of fastest response it could be my main mirror again after a few days. And again after, and again after…
So, how do I black list certain mirror until its manual removal from black list on user will only?
If there is no solid (non-temporal) solution, then how hard is it to add such feature say into /etc/pacman-mirrors.conf configuration?
Thanks!
After switching branches, you must first run… :backhand_index_pointing_down:
sudo pacman-mirrors -f
… to select only the mirrors which have already synced. It then also helps to refresh the files database, given that there may be packages in the Unstable branch which do not exist yet in the Testing or Stable branches… :backhand_index_pointing_down:
sudo pacman -Fyy
Only then should you try updating the system… :backhand_index_pointing_down:
sudo pacman -Syyu
As far as I know, this is not possible, but… :backhand_index_pointing_down:
Actually, this is not such a good idea. I am in Belgium and I do not filter by country. I find that the US-based fcix.net mirrors are generally the ones most often in sync, and they have very fast access times.
You can always tune the list to your liking as you did and then disable the timer for the weekly service that refreshes the list.
But it does not make much sense actually. Periodical refreshing is exactly there to drop dead mirrors. And right now no Dutch mirror is synced, so wait a bit (like a couple of hours) and run sudo pacman-mirrors -f
Me personally i have switched to country Global, which is a CDN and very fastly synced and always online (except that cicku mirror which is wonky).
Mirror #1   OK  00:02   Global  https://mirrors.manjaro.org/repo/
Mirror #2   OK  00:02   Global  https://mirrors2.manjaro.org/
Mirror #3   --  28:50   Global  https://mirrors.cicku.me/manjaro/
Besides, you are switching back a branch so unless you actively want to downgrade you will have to wait some 2-3 weeks for new package versions so it does not matter at all if your country is synced today or the timer runs in a week and prunes the dead mirror. A self solving problem.
If you really really want to disable the automatic refreshing (bad idea)
sudo systemctl disable --now pamac-mirrorlist.timer
The wise approach is to relax the limiting (at least put also Germany as another country with coma after Netherlands or even better switch to country Global)
You cannot deny a specific mirror, using pacman-mirrors.
What you can do has already been suggested and marked as answer. However changes to the hosts file tends to get forgotten.
A connection error is a network specific error which is not directly related to the mirror pool; a connection error is usually a temporary error; a connection error will cause the mirror to be excluded from the final mirror list.
What you can do is that you can create a custom mirror pool.
If you want to select from scratch without consideration for their current status you can create a list from which you can select individual mirrors
sudo pacman-mirrors --interactive --default
This will provide you with a GTK based window where you can design your mirror pool.
If you rather work in console you can achieve a similar list
sudo pacman-mirrors --interactive --default -fc
Your selection will be written to /var/lib/pacman-mirrors/custom-mirrors.json
pacman-mirrors also has an argument similar to the referenced reflector but it requires you to override the default of only selecting up-to-date mirrors.
sudo pacman-mirrors --interval HOURS --no-status
