I apologize if i3 is unrelated to this issue, but I read that the desktop environment can affect keyboard layouts and I suspect i3 may be part of the issue.
I like to use the numpad home/end + shift to select entire lines, but in most applications, pressing numpad home/end + shift will just put in a number since shift switches back to entering numbers.
From what I’ve read, the numpad:microsoft X11 option should make things work the way I’m used to.
Here’s the output of setxkbmap -query:
rules: evdev
layout: us
options: numpad:microsoft
Here’s the output of localectl -status:
System Locale: LANG=en_US.UTF-8
VC Keymap: us
X11 Layout: us
X11 Variant: ,
X11 Options: numpad:microsoft
Any clue why the numpad:microsoft option doesn’t appear to do anything?
Thanks!
