Its probably not too hard, but i dont get it. So Fawkes is a tool for cloaking images and with the command fawkes -d ./imgs --mode low
i should be able to do that. But then this is popping up:
Identify 0 files in the directory
Identify 0 images in the directory
No images in the directory
So how do I get images in the directory
if i do which fawkes
its in /usr/bin/fawkes but yeah.
Thanks in advance
Yes i do, thank you. I already read that.
So, side question, which of the two accounts on the forum you want to keep?
The one with the one s, sry i didnt even know i had two accounts. I accidently logged into my “old” account that i didnt know existed. So it would be in my favor, please delete that one if possible.
Regarding the topic, do you have any other ideas?
you told him to both keep and delete the account. While it might be possible to assume what you mean, maybe try to word your answer correctly?
