If you still have the video-nvidia-450xx
installed, what does xrandr
print?
I see thanks for catching that…I changed my config but the results were the same (blank screen on my laptop & no output on the monitor)
Section "ServerLayout"
Identifier "layout"
Screen 0 "intel"
Inactive "nvidia"
Option "AllowNVIDIAGPUScreens"
EndSection
Section "Device"
Identifier "nvidia"
Driver "nvidia"
BusID "PCI:1:0:0"
EndSection
Section "Screen"
Identifier "nvidia"
Device "nvidia"
EndSection
Section "Device"
Identifier "intel"
Driver "modesetting"
BusID "PCI:2:0:0"
EndSection
Section "Screen"
Identifier "intel"
Device "intel"
EndSection
I got the bus-id from inxi --full -verbosity=7
(hope that is right)
Device-1: Intel HD Graphics 630 vendor: Dell driver: i915 v: kernel bus ID: 00:02.0 chip ID: 8086:591b
Device-2: NVIDIA GP107M [GeForce GTX 1050 Mobile] vendor: Dell driver: nvidia v: 450.66 bus ID: 01:00.0
chip ID: 10de:1c8d
Device-3: Sunplus Innovation Integrated_Webcam_HD type: USB driver: uvcvideo bus ID: 1-12:5 chip ID: 1bcf:2b95
Display: x11 server: X.Org 1.20.8 compositor: kwin_x11 driver: modesetting,nvidia
alternate: fbdev,intel,nouveau,nv,vesa s-res: 3840x2160 s-dpi: 96
OpenGL: renderer: Mesa Intel HD Graphics 630 (KBL GT2) v: 4.6 Mesa 20.1.6 direct render: Yes
Sorry I switched to prime so I don’t have video-nvidia-450xx installed. I also don’t seem to have xrandr installed…
This should be BusID "PCI:0:2:0"
Then install it: sudo pacman -Syu xorg-xrandr
I see, thank you for correcting the busID
But this gave me the same result (blank screen)
Identifier "layout"
Screen 0 "intel"
Inactive "nvidia"
EndSection
Section "Device"
Identifier "nvidia"
Driver "nvidia"
BusID "PCI:1:0:0"
EndSection
Section "Screen"
Identifier "nvidia"
Device "nvidia"
EndSection
Section "Device"
Identifier "intel"
BusID "PCI:0:2:0"
EndSection
Section "Screen"
Identifier "intel"
Device "intel"
EndSection
So you didn’t get any signal anywhere? Neither on monitor nor on laptop screen?
(Also: the 450 series is pretty new and still has some issues and why I asked you to install the 440 series as your GTX 1050 is supported by that one)
Can you get the Xorg logs? Log into a tty, and then run startx -- -logverbose 10
, and if it fails, check the files in ~/.local/share/xorg/
I am starting to think that something is wrong at a basic level…because when I boot into windows 10, I can’t even mirror my display there…
Sure I will try that today after work, and update you guys - thank you for the follow up.
Smells like a hardware error…
Hello, I’ve tried several possible solutions for this same problem, that’s how I got here, reverse prime didn’t work out, nor going full nvidia. The only solution that worked for me, was to install optimus-manager, Guide: Install and configure optimus-manager for hybrid GPU setups (Intel/NVIDIA) - Tutorials - Manjaro Linux Forum. (itś kinda outdated, stiil worked though)because i have a hybrid amd-nvidia, I decided to install it from source. It’s been a couple of days and so far it’s working ok, you can leave it full nvidia, full integrated, or hybrid and switch between them just login out , in hybrid running programs with prime-run works as well. Hope this helps,
