Without triggering a discussion about the purpose of cronie: What is the most effective way to remove cronie from a freshly installed Manjaro?
Is sudo systemctl disable cronie.service
followed by sudo pacman -R cronie
enough or is there something else to do?
sayan
2
If you want to remove the dependencies also then you should run sudo pacman -Rns cronie
This is the recommended procedure:
systemctl disable --now cronie.service
systemctl mask cronie.service
Be aware that this could affect timeshift. If you are using timeshift better skip the pacman command.
system
Closed
5
