I don’t have a discrete graphics card. Currently I’m using Ryzen 5 2400G which have Vega 11 GPU. I tried to run DaVinci Resolve on my system. But failed every time. Kernel version is 5.10.
What I did till now :
installed amdgpu-pro-libgl
installed opencl-mesa
installed opencl-amdgpu-pro-orca
tried to run Resolve using environment variableLD_LIBRARY_PATH="$PACKAGEPATH/opt/amdgpu-pro/lib/x86_64-linux-gnu:${LD_LIBRARY_PATH}" LIBGL_DRIVERS_PATH="$PACKAGEPATH/usr/lib/x86_64-linux-gnu/dri/" dri_driver="amdgpu" /opt/resolve/bin/resolve
But nothing worked for me. When I run Resolve it shows this :
ActCCMessage Already in Table: Code= c005, Mode= 13, Level= 1, CmdKey= -1, Option= 0
ActCCMessage Already in Table: Code= c006, Mode= 13, Level= 1, CmdKey= -1, Option= 0
ActCCMessage Already in Table: Code= c007, Mode= 13, Level= 1, CmdKey= -1, Option= 0
ActCCMessage Already in Table: Code= 2282, Mode= 0, Level= 0, CmdKey= 8, Option= 0
PnlMsgActionStringAdapter Already in Table: Code= 615e, Mode= 0, Level= 0, CmdKey= -1, Option= 0
log4cxx: No appender could be found for logger (BtCommon).
log4cxx: Please initialize the log4cxx system properly.
16.2.8 (#005) Linux/Clang
Main thread starts: D9D0D5C0
[0x7fefd9d0d5c0] | Undefined | INFO | 2021-02-07 18:29:00,027 | --------------------------------------------------------------------------------
[0x7fefd9d0d5c0] | Undefined | INFO | 2021-02-07 18:29:00,028 | Loaded log config from /home/fahim/.local/share/DaVinciResolve/configs/log-conf.xml
[0x7fefd9d0d5c0] | Undefined | INFO | 2021-02-07 18:29:00,028 | --------------------------------------------------------------------------------
And when I run with variable it shows this :
Main thread starts: 1F6E25C0
[0x7f001f6e25c0] | Undefined | INFO | 2021-02-07 18:48:38,849 | --------------------------------------------------------------------------------
[0x7f001f6e25c0] | Undefined | INFO | 2021-02-07 18:48:38,849 | Loaded log config from /home/fahim/.local/share/DaVinciResolve/configs/log-conf.xml
Discard all samples (playback) or generate zero samples (capture)
Rate Converter Plugin Using Samplerate Library
Rate Converter Plugin Using Speex Resampler
JACK Audio Connection Kit
Open Sound System
PipeWire Sound Server
PulseAudio Sound Server
Plugin using Speex DSP (resample, agc, denoise, echo, dereverb)
Plugin for channel upmix (4,6,8)
Plugin for channel downmix (stereo) with a simple spacialization
Default ALSA Output (currently PulseAudio Sound Server)
HD-Audio Generic, HDMI 0HDMI Audio Output
HD-Audio Generic, HDMI 1HDMI Audio Output
HD-Audio Generic, HDMI 2HDMI Audio Output
HD-Audio GenericUSB Stream Output
HD-Audio Generic, ALC887-VD AnalogDefault Audio Device
HD-Audio Generic, ALC887-VD AnalogFront output / input
HD-Audio Generic, ALC887-VD Analog2.1 Surround output to Front and Subwoofer speakers
HD-Audio Generic, ALC887-VD Analog4.0 Surround output to Front and Rear speakers
HD-Audio Generic, ALC887-VD Analog4.1 Surround output to Front, Rear and Subwoofer speakers
HD-Audio Generic, ALC887-VD Analog5.0 Surround output to Front, Center and Rear speakers
HD-Audio Generic, ALC887-VD Analog5.1 Surround output to Front, Center, Rear and Subwoofer speakers
HD-Audio Generic, ALC887-VD Analog7.1 Surround output to Front, Center, Side, Rear and Woofer speakers
HD-Audio Generic, ALC887-VD DigitalIEC958 (S/PDIF) Digital Audio Output
USB Device 0x46d:0x825USB Stream Output
Open Sound System
Open Sound System
Can someone help to configure this?
