I need to install sysprof-capture
so I can update mutter-rounded
, but I don’t know where to install this program. I’ve installed sysprof
but now it asks me to install sysprof-capture
, and I can’t find it in repos searching through terminal, is there any other way to install sysprof-capture
~ yay -Syu ✔
core is up to date
extra is up to date
community is up to date
multilib is up to date
there is nothing to do
:: Searching databases for updates...
:: Searching AUR for updates...
:: 1 Packages to upgrade.
1 aur/mutter-rounded 41.2-1 -> 41.3-1.3
==> Packages to exclude: (eg: "1 2 3", "1-3", "^4" or repo name)
-> Could not find all required packages:
libsysprof-capture (Wanted by: mutter-rounded)
~ inxi -Fxz ✔
Kernel: 5.15.12-1-MANJARO x86_64 bits: 64 compiler: gcc v: 11.1.0
Desktop: GNOME 41.2 Distro: Manjaro Linux base: Arch Linux
Type: Desktop Mobo: ASUSTeK model: PRIME B450M-GAMING/BR v: Rev X.0x
serial: <superuser required> UEFI: American Megatrends v: 2006
date: 11/13/2019
Info: 6-core model: AMD Ryzen 5 2600 bits: 64 type: MT MCP arch: Zen+
rev: 2 cache: L1: 576 KiB L2: 3 MiB L3: 16 MiB
Speed (MHz): avg: 2717 high: 3789 min/max: 1550/3400 boost: enabled
cores: 1: 1327 2: 3181 3: 2568 4: 3787 5: 1517 6: 3776 7: 1429 8: 3425
9: 2506 10: 3789 11: 1528 12: 3779 bogomips: 81466
Device-1: AMD Ellesmere [Radeon RX 470/480/570/570X/580/580X/590]
vendor: XFX Pine driver: amdgpu v: kernel bus-ID: 08:00.0
Device-2: A4Tech REDRAGON Live Camera type: USB driver: uvcvideo
bus-ID: 3-2:2
Display: x11 server: X.Org 1.21.1.2 driver: loaded: amdgpu,ati
unloaded: modesetting,radeon resolution: 1920x1080~70Hz
Device-1: AMD Ellesmere HDMI Audio [Radeon RX 470/480 / 570/580/590]
vendor: XFX Pine driver: snd_hda_intel v: kernel bus-ID: 08:00.1
Device-2: AMD Family 17h HD Audio vendor: ASUSTeK driver: snd_hda_intel
v: kernel bus-ID: 0a:00.3
Device-3: A4Tech REDRAGON Live Camera type: USB driver: uvcvideo
bus-ID: 3-2:2
Sound Server-1: ALSA v: k5.15.12-1-MANJARO running: yes
Sound Server-4: PipeWire v: 0.3.42 running: no
vendor: ASUSTeK PRIME B450M-A driver: r8169 v: kernel port: f000
bus-ID: 07:00.0
IF: enp7s0 state: up speed: 1000 Mbps duplex: full mac: <filter>
Local Storage: total: 447.13 GiB used: 72.92 GiB (16.3%)
ID-1: /dev/sda vendor: Kingston model: SA400S37480G size: 447.13 GiB
ID-1: / size: 58.76 GiB used: 23.15 GiB (39.4%) fs: ext4 dev: /dev/sda2
ID-2: /boot/efi size: 196.9 MiB used: 274 KiB (0.1%) fs: vfat
dev: /dev/sda1
ID-3: /home size: 344.23 GiB used: 49.77 GiB (14.5%) fs: ext4
dev: /dev/sda3
ID-1: swap-1 type: file size: 1024 MiB used: 0 KiB (0.0%) file: /swapfile1
System Temperatures: cpu: N/A mobo: N/A gpu: amdgpu temp: 50.0 C
Fan Speeds (RPM): N/A gpu: amdgpu fan: 1120
Processes: 332 Uptime: 4h 38m Memory: 15.62 GiB used: 3.89 GiB (24.9%)
Init: systemd Compilers: gcc: 11.1.0 clang: 13.0.0 Packages: 1293
Shell: Zsh v: 5.8 inxi: 3.3.11
