I don’t use Gnome but are you using a custom theme? Did you try to change some theme settings for colors?
tryed but none of them works does anyone can tell what is default manjaro gnome theme?
found it on forum with same problem. needed to plaay with settings of Kvantum. sorry.
Can u give me da link plz!?
sure dude!
