[finn@finn-p71207c minecraft-launcher]$ sudo makepkg -si
[sudo] password for finn:
==> ERROR: Running makepkg as root is not allowed as it can cause permanent,
catastrophic damage to your system.
the problem is exactly as the errors say. Use either makepkg -si
or pamac build minecraft-launcher
to utilize pamac.
Wrong
Correct
makepkg -si
No need to use sudo
when it is not needed.
Classic XY Problem. Please tell us what problem you were having before you incorrectly tried to use sudo
with makepkg
