How best to implement systemd-boot support for Manjaro kernels
systemd
systemd-boot
#22
OK so the clr-boot-manager pkgbuild builds now.
For this to work I think there are more changes needed (and I really want to try them). Sadly I dont really understand anything from the original readme.
  • Do I need to set a specific path for the kernel at compile time of the kernel, and if yes: how?
  • I’m almost clear with, that I need to rename the kernel to a different format, than what manjaro provides right now. but here again: how?
#23
It looks like it requires changing the packaging of the kernel and /boot.
That seems like a pretty extreme solution when a simple pacman hook could generate the systemd-boot entries.
