Hi Guys,
i bought a new Lenovo V15 (Gen4) with an AMD Ryzen 5 and freshly installed Manjaro XFCE.
The keyboard and touchpad worked fine wile in UEFI and Grub but stopped doing so in the moment Manjaro boots, the external keyboard/mouse are working fine. I tried kernel 6.3.5 and 6.1.131, kernel 5.15.114 wont even boot.
And when i am tryind to poste the inxi output the forum software say:
An error occurred: Sorry, you can’t include links in your posts.
Any idea?
Posting links and images is not allowed until you get some reputation.
Images is frowned upon - it is generally useless and a waste of resources
Terminal output like inxi, logs etc must be code-fenced
~~~text
how to format your inxi output
please use the code fence from the comment toolbar </>
Select the output and click the code fence button.
johndoebyom:
Any idea?
there is an issue while installation if external keyboards are connected. in this case the detection of keyboards can fire up problems afterwards because keyboards won’t get detected in the way they should. it’s a good advice to use only the laptop keyboard during installation and connect external devices after full installation.
Thanks for the advice. Here is my inxi output:
Kernel: 6.3.5-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 12.2.1
parameters: BOOT_IMAGE=/boot/vmlinuz-6.3-x86_64
root=UUID=80345748-e340-433f-b7ee-a4a4ea3e44ba rw quiet splash apparmor=1
security=apparmor resume=UUID=4f242560-8060-4515-845e-636bb58105e4
udev.log_priority=3
Desktop: Xfce v: 4.18.1 tk: Gtk v: 3.24.36 info: xfce4-panel wm: xfwm
v: 4.18.0 vt: 7 dm: LightDM v: 1.32.0 Distro: Manjaro Linux base: Arch Linux
Type: Laptop System: LENOVO product: 82YU v: Lenovo V15 G4 AMN
serial: <superuser required> Chassis: type: 10 v: Lenovo V15 G4 AMN
Mobo: LENOVO model: LNVNB161216 v: NO DPK serial: <superuser required>
UEFI: LENOVO v: L1CN26WW date: 02/09/2023
ID-1: BAT0 charge: 38.8 Wh (100.0%) condition: 38.8/38.0 Wh (102.1%)
volts: 8.7 min: 7.7 model: Sunwoda L22D2PG2 type: Li-poly serial: <filter>
status: full cycles: 3
Device-1: hidpp_battery_0 model: Logitech Wireless KeyboarWir
status: discharging
System RAM: available: 5.62 GiB used: 1.89 GiB (33.7%)
Info: model: AMD Ryzen 5 7520U with Radeon Graphics bits: 64 type: MT MCP
arch: Zen 2 gen: 3 level: v3 note: check built: 2020-22
process: TSMC n7 (7nm) family: 0x17 (23) model-id: 0xA0 (160) stepping: 0
microcode: 0x8A00006
L1: 256 KiB desc: d-4x32 KiB; i-4x32 KiB L2: 2 MiB desc: 4x512 KiB L3: 4 MiB
desc: 1x4 MiB
Speed (MHz): avg: 1850 high: 2800 min/max: 900/6735 boost: enabled scaling:
driver: acpi-cpufreq governor: schedutil cores: 1: 2800 2: 2800 3: 900
4: 2800 5: 900 6: 900 7: 900 8: 2800 bogomips: 44730
f16c flushbyasid fma fpu fsgsbase fxsr fxsr_opt ht hw_pstate ibpb ibrs ibs
pfthreshold pge pni popcnt pse pse36 rapl rdpid rdpru rdrand rdseed rdt_a
rdtscp rep_good sep sev sev_es sha_ni skinit smap smca smep ssbd sse sse2
sse4_1 sse4_2 sse4a ssse3 stibp succor svm svm_lock syscall tce topoext
tsc tsc_scale umip v_spec_ctrl v_vmsave_vmload vgif vmcb_clean vme vmmcall
wbnoinvd wdt x2apic xgetbv1 xsave xsavec xsaveerptr xsaveopt
Type: retbleed mitigation: untrained return thunk; SMT enabled with STIBP
protection
Type: spectre_v2 mitigation: Retpolines, IBPB: conditional, STIBP:
always-on, RSB filling, PBRSB-eIBRS: Not affected
Device-1: AMD Mendocino vendor: Lenovo driver: amdgpu v: kernel arch: RDNA-2
code: Navi-2x process: TSMC n7 (7nm) built: 2020-22 pcie: gen: 4
speed: 16 GT/s lanes: 16 ports: active: eDP-1 empty: DP-1,DP-2,HDMI-A-1
bus-ID: 04:00.0 chip-ID: 1002:1506 class-ID: 0300 temp: 42.0 C
Device-2: Chicony Integrated Camera driver: uvcvideo type: USB rev: 2.0
speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 5-1:2 chip-ID: 04f2:b7ba
Display: x11 server: X.Org v: 21.1.8 compositor: xfwm v: 4.18.0 driver: X:
loaded: amdgpu unloaded: modesetting alternate: fbdev,vesa dri: radeonsi
gpu: amdgpu display-ID: :0.0 screens: 1
s-diag: 582mm (22.93") monitors: <missing: xrandr>
Monitor-1: eDP-1 model: BOE Display 0x08d5 built: 2019 res: 1920x1080
dpi: 142 gamma: 1.2 size: 344x194mm (13.54x7.64") diag: 395mm (15.5")
ratio: 16:9 modes: max: 1920x1080 min: 640x480
API: OpenGL Message: Unable to show GL data. Required tool glxinfo missing.
Device-1: AMD Rembrandt Radeon High Definition Audio vendor: Lenovo
bus-ID: 04:00.1 chip-ID: 1002:1640 class-ID: 0403
Device-2: AMD ACP/ACP3X/ACP6x Audio Coprocessor vendor: Lenovo
driver: snd_pci_acp6x v: kernel alternate: snd_pci_acp3x, snd_rn_pci_acp3x,
snd_pci_acp5x, snd_acp_pci, snd_rpl_pci_acp6x, snd_pci_ps,
snd_sof_amd_renoir, snd_sof_amd_rembrandt pcie: gen: 4 speed: 16 GT/s
lanes: 16 bus-ID: 04:00.5 chip-ID: 1022:15e2 class-ID: 0480
Device-3: AMD Family 17h/19h HD Audio vendor: Lenovo driver: snd_hda_intel
v: kernel pcie: gen: 4 speed: 16 GT/s lanes: 16 bus-ID: 04:00.6
chip-ID: 1022:15e3 class-ID: 0403
API: ALSA v: k6.3.5-1-MANJARO status: kernel-api with: aoss
Server-2: PipeWire v: 0.3.70 status: off tools: pw-cli
type: plugin tools: pacat,pactl,pavucontrol
Device-1: Realtek RTL8822CE 802.11ac PCIe Wireless Network Adapter
vendor: Lenovo driver: rtw_8822ce v: N/A modules: rtw88_8822ce pcie: gen: 1
speed: 2.5 GT/s lanes: 1 port: 3000 bus-ID: 02:00.0 chip-ID: 10ec:c822
class-ID: 0280
vendor: Lenovo driver: r8169 v: kernel pcie: gen: 1 speed: 2.5 GT/s lanes: 1
port: 2000 bus-ID: 03:00.0 chip-ID: 10ec:8168 class-ID: 0200
Device-1: Realtek Bluetooth Radio driver: btusb v: 0.8 type: USB rev: 1.0
speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 1-2:2 chip-ID: 0bda:c123
Report: rfkill ID: hci0 rfk-id: 3 state: down bt-service: enabled,running
Local Storage: total: 931.51 GiB used: 9.26 GiB (1.0%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Samsung model: SSD 980 1TB
lanes: 4 tech: SSD serial: <filter> fw-rev: 3B4QFXO7 temp: 31.9 C
scheme: GPT
ID-1: / raw-size: 29 GiB size: 28.38 GiB (97.85%) used: 9.26 GiB (32.6%)
fs: ext4 dev: /dev/nvme0n1p1 maj-min: 259:1 label: manjaro
uuid: 80345748-e340-433f-b7ee-a4a4ea3e44ba
used: 288 KiB (0.1%) fs: vfat dev: /dev/nvme0n1p2 maj-min: 259:2
label: BOOT-EFI uuid: 273A-0C9E
ID-3: /data raw-size: 898.31 GiB size: 883.13 GiB (98.31%)
used: 2 MiB (0.0%) fs: ext4 dev: /dev/nvme0n1p4 maj-min: 259:4 label: data
uuid: 4746c89b-2eaa-4e38-94c9-a368ac1bf238
ID-1: swap-1 type: partition size: 3.91 GiB used: 0 KiB (0.0%) priority: -2
dev: /dev/nvme0n1p3 maj-min: 259:3 label: swap
uuid: 4f242560-8060-4515-845e-636bb58105e4
Hub-1: 1-0:1 info: hi-speed hub with single TT ports: 2 rev: 2.0
Device-1: 1-2:2 info: Realtek Bluetooth Radio type: bluetooth driver: btusb
interfaces: 2 rev: 1.0 speed: 12 Mb/s (1.4 MiB/s) lanes: 1 mode: 1.1
power: 500mA chip-ID: 0bda:c123 class-ID: e001 serial: <filter>
Hub-2: 2-0:1 info: super-speed hub ports: 1 rev: 3.1
Hub-3: 3-0:1 info: hi-speed hub with single TT ports: 3 rev: 2.0
Device-1: 3-2:2 info: Logitech Unifying Receiver type: keyboard,mouse
driver: logitech-djreceiver,usbhid interfaces: 2 rev: 2.0
chip-ID: 046d:c534 class-ID: 0301
Hub-5: 5-0:1 info: hi-speed hub with single TT ports: 1 rev: 2.0
Device-1: 5-1:2 info: Chicony Integrated Camera type: video
driver: uvcvideo interfaces: 2 rev: 2.0 speed: 480 Mb/s (57.2 MiB/s) lanes: 1
mode: 2.0 power: 500mA chip-ID: 04f2:b7ba class-ID: 0e02 serial: <filter>
Hub-6: 6-0:1 info: Linux Foundation 3.0 root hub ports: N/A rev: 3.0
System Temperatures: cpu: 45.8 C mobo: N/A gpu: amdgpu temp: 43.0 C
Processes: 264 Uptime: 3m wakeups: 4 Init: systemd v: 252 default: graphical
tool: systemctl Compilers: gcc: 12.2.1 clang: 15.0.7 Packages: pm: pacman
pkgs: 1090 libs: 348 tools: pamac pm: flatpak pkgs: 0 Shell: Bash v: 5.1.16
running-in: xfce4-terminal inxi: 3.3.27
I cant see any sign of the touchpad. Xinput is the same:
xinput
⎡ Virtual core pointer id=2 [master pointer (3)]
⎜ ↳ Virtual core XTEST pointer id=4 [slave pointer (2)]
⎜ ↳ Logitech Wireless Mouse id=9 [slave pointer (2)]
⎜ ↳ Logitech Wireless Keyboard PID:4023 id=10 [slave pointer (2)]
⎣ Virtual core keyboard id=3 [master keyboard (2)]
↳ Virtual core XTEST keyboard id=5 [slave keyboard (3)]
↳ Video Bus id=6 [slave keyboard (3)]
↳ Power Button id=7 [slave keyboard (3)]
↳ Ideapad extra buttons id=8 [slave keyboard (3)]
↳ Logitech Wireless Keyboard PID:4023 id=11 [slave keyboard (3)]
I booted from the Manjaro live medium and there was no keyboard. So I had to plug in the external one and hoped the problem will fix itself with updates and the newest kernel. funnily some function keys are working. i tried to play with the settings for function keys and the Amd security chip, but no change.
I played a bit around… I assume that the keyboard is controlled by the i8042 controller.
dmesg| grep i8042 shows me the following
[ 0.552101] i8042: PNP: PS/2 Controller [PNP0303:KBC0] at 0x60,0x64 irq 1
[ 0.552107] i8042: PNP: PS/2 appears to have AUX port disabled, if this is incorrect please boot with i8042.nopnp
[ 0.553236] serio: i8042 KBD port at 0x60,0x64 irq 1
After i put i8042.nopnp in GRUB_CMDLINE_LINUX_DEFAULT the output of dmesg| grep i8042 changed to
[ 0.000000] Command line: BOOT_IMAGE=/boot/vmlinuz-6.1-x86_64 root=UUID=80345748-e340-433f-b7ee-a4a4ea3e44ba rw i8042.nopnp quiet splash apparmor=1 security=apparmor resume=UUID=4f242560-8060-4515-845e-636bb58105e4 udev.log_priority=3
[ 0.021494] Kernel command line: BOOT_IMAGE=/boot/vmlinuz-6.1-x86_64 root=UUID=80345748-e340-433f-b7ee-a4a4ea3e44ba rw i8042.nopnp quiet splash apparmor=1 security=apparmor resume=UUID=4f242560-8060-4515-845e-636bb58105e4 udev.log_priority=3
[ 0.616789] i8042: PNP detection disabled
[ 0.889057] serio: i8042 KBD port at 0x60,0x64 irq 1
[ 1.302432] input: AT Translated Set 2 keyboard as /devices/platform/i8042/serio0/input/input2
But still no keyboard/touchpad. Is there someway to push the hardware detection?
banjo
5 June 2023 02:24
6
Not the same devices, but all lenovo…
Thanks a lot for your help.
I tried all kind of i8042 Kernel parameters in GRUB_CMDLINE_LINUX_DEFAULTbut - no success.
And then i followed your 2nd link leading me to your 3rd link and installed the patch before i saw your advice not to do it… but nothing changed so far.
