Thanks @bedna & @dmt for further assistance. Getting out of my depth here, also out for most of today, so all I’ve done so far is delete /etc/shadow.pacnew.
I need to learn up on the other stuff. I’m reasonably familiar with nano, less so with vim and not at all with meld.
Another thought I had, as a temporary workaround till I have more time, is to use the chroot environment to launch applications from my normal system. So I tried opening firefox, but immediately ran into authourisation problems:
[manjaro-gnome /]# su nick
[nick@manjaro-gnome /]$ sudo rm /etc/shadow.pacnew
[sudo] password for nick:
[nick@manjaro-gnome /]$ firefox
Authorization required, but no authorization protocol specified
Error: cannot open display: :0
So two questions:
Could this work?
If yes, how can I set the correct authorisation for the GUI to work?
No, but I have copied it on to an external drive and all my most valuable data - Documaents, Pictures, Videos, Downloads etc - is on a separate drive.
Not fully comfortable, but familiar with Gparted, for example.
Yes, using it on the live usb i’m running from now.
Out for the rest of the day now. Will check back this evening for any further suggestions. I can see how a fresh install is probably the way to go. Why is the timing of these things always so damned inconvenient?!
There’s one last thing I want to try before giving up.
I read this morning that there can be issues with auto-login in Gnome. I had my login set to auto and it occurs to me that that could be at the root of the problem. Presumably there is a setting somewhere in a config file where I could chroot into the unstable system and disable auto-login. Seems worth a shot. Could someone please tell me where to find the relevant file(s)?
This file and it’s location may differ depending on the DE used, but for Gnome and GDM, that’s probably a good place to start looking. Obviously, if the file doesn’t exist, then look elsewhere.
Thanks @soundofthunder and @Mirdarthos for that very helpful info. Sadly disabling auto-login hasn’t made any difference.
I think I’ve run out of road. Thanks for all the help along the way - really good support and much appreciated.
I’ve set myself up as a user on my partner’s machine so I can continue with immediate essential work without too much inconvenience, then when I have more time I shall rejig my drives, adding a new one, and do a fresh installation.
When you have that time, consider having /home on a separate partition. This will allow you to reinstall with less complication in future. It would require that you perform manual partitioning during Manjaro installation; which only takes common sense, really, which you seem to have. Cheers.
You have gotten a lot of great help even if it hasn’t produced the results you were looking for, so, this is going to sound a bit pedantic, but getting a small external drive like a Wd-Passprt and using TimeShift maybe a real help in the future. This is what I do, and it might work for you, too.
Thanks, and yes, I’ll definitely do that. I’d thought that by having key folders on a separate drive, I would not be too bothered to overwrite everything else in home folder, but after a few years of lax housekeeping, how wrong I was!
