PopOS has released its beta for 21.10. As far as i can tell most things, besides application overview are working for gnome 40. Hope they soon iron out those few issues. Would love to use that desktop on my Manjaro system
Once this issue is resolved, COSMIC might be ready to port over:
opened 07:48AM - 13 Oct 21 UTC
closed 02:28PM - 15 Oct 21 UTC
**How did you upgrade to 21.10? (Fresh install / Upgrade)**
Upgrade from 21.04
**Related Application and/or Package Version (run `apt policy $PACKAGE NAME`):**
Package: pop-cosmic
Version: 0.1.0~1631905924~21.10~df7e39a
Priority: optional
Section: gnome
Maintainer: Jeremy Soller <jeremy@system76.com>
Installed-Size: 70,7 kB
Depends: gnome-shell (>= 3.38), dconf-gsettings-backend | gsettings-backend
Homepage: https://github.com/pop-os/cosmic
Download-Size: 13,2 kB
APT-Manual-Installed: no
APT-Sources: http://apt.pop-os.org/release impish/main amd64 Packages
Description: Computer Operating System Main Interface Components
**Issue/Bug Description:**
Pop Cosmic not working
**Steps to reproduce (if you know):**
**Expected behavior:**
Not getting this error
**Other Notes:**
TypeError: box.add is not a function
Stack trace:
buildPrefsWidget@/usr/share/gnome-shell/extensions/pop-cosmic@system76.com/prefs.js:32:9
_init@resource:///org/gnome/Shell/Extensions/js/extensionsService.js:209:40
OpenExtensionPrefsAsync/<@resource:///org/gnome/Shell/Extensions/js/extensionsService.js:122:28
asyncCallback@resource:///org/gnome/gjs/modules/core/overrides/Gio.js:115:22
run@resource:///org/gnome/Shell/Extensions/js/dbusService.js:177:20
main@resource:///org/gnome/Shell/Extensions/js/main.js:19:13
run@resource:///org/gnome/gjs/modules/script/package.js:206:19
start@resource:///org/gnome/gjs/modules/script/package.js:190:8
@/usr/share/gnome-shell/org.gnome.Shell.Extensions:1:17
I tried to update all packages
EDIT: It’s been fixed and turned it it didn’t matter too much.
It was amazing to use but cant beat the experience of using manjaro with aur.
Would you believe the biggest show stopper porting this over was a symlink I forgot to create?
COSMIC is coming soon™…
EDIT: Screenshots are now in the post linked below.
system
Closed
20 October 2021 09:55
28
