Home Studio with RecBox
music
openbox
#1
Honestly I don’t know how to start and describe “What I’ve done” (screenshots down below) :smile:
Long story short.
I’ve started project on 1.60 Ghz HP 356 and XFCE was too much for this brave laptop when recording session had more than fifteen tracks and tons of plugins (compressors, equalizers etc). PC always was on last place because all money I invested in music equipment and related things. So I don’t had many options (meanwhile I discovered OpenBox and i3) and I started to think…
Back to the subject.
Basically it’s redesigned OpenBox (regular) made by fhdk with Obsuite from William (alfalfa) and “jgmenu trick” from Piotrek (nwg). So credits go to gentlemen :slight_smile:
My copycat work is “Studio and Daily” mode, few pdfs with plugins description, system configuration, Ardour configuration, tips for beginners, install scripts, Frankenstein obmenu and few things I don’t remember now.
Main goals is to have one system for daily and studio work and ergonomic graphical environment. What i mean is guitar on leg and keyboard they don’t like each other.
For now I can’t say that RecBox is done in 100% I think it will never be. It’s always something that can be done better and cool plugin worth to be mentioned. Btw last days I’ve added enable and disable cpu power and RTC services item to obmenu, so manjaro behave almost like a normal system. I need to do something with disabling threadirqs when is not needed but it’s matter of time. Probably shell script do the job.
Edit:
Now Increasing RTC, enabling cpupower service, and threadirqs are managed by WorkFlow > Studio and Daily options. No need do this manually :slight_smile:
Edit:
I always forget to mention it. If in RecBox is something you like but you don’t want to drop your desktop environment I’ll be happy to help you with “transplantation” :slight_smile:
I’ll be appreciated for all suggestions and happy christmas :slight_smile:
Edit:
I’ve made Matcha color scheme based theme for Ardour.
If you enjoy it you can grab theme from separated repo or AUR if you don’t want whole RecBox Stuff.
Excited, then disapointed
#2
Looks nice, I like to try it :slight_smile:
#3
Thanks, sometimes I think that it’s look better than it works :joy:
#4
We almost always our own hardest judges. Great work :+1:
#5
Thanks I’m trying my best :slight_smile:
For few last days I thought about maintaining package for Manjaro as a next step in RecBox developing (It is still missing something but I’m not sure what). I don’t want to provide extra work for you guys so package will be pretty safe for as all at the moment. I guess :smile: So if RecBox will be ready who I need to ask and how whole procedure looks, what are the criteria and so on? And is this will be possible at all?
#6
get in touch with me :slight_smile:
#7
Cool :slight_smile: Thank You @fhdk :kissing_heart: :heart_eyes: xoxo lol
#8
If someone is interested about Ardour theme, AUR package can be found here.
#9
I’ve made separate repository for RecBox docs so if you interested check it out.
Repo contains:
  • List and description of Pro Audio plugins and extra form AUR
  • System setup
  • Ardour configuration and tips for beginners
  • list of youtube channels with tutorials and articles (at the moment only one)
In this week I’ll be focused on documenting stuff so expect frequent updates.
Happy Sunday :slight_smile:
#10
just checking out the Ardour theme, v cool
not seen openbox look so nice before
been happy with XFCE for ages, but this would be good on my older backup system
good to see a different take on an audio setup to keep it simple with just one DAW
look forward to seeing updates
#11
Thank you @nikgnomic :smiling_face_with_three_hearts:
I think you should feel like home. Open Box regular is working with xfce under hood and Rec Box is set to use xfce settings on Daily Mode and openbox settings on Studio.
If you want to make your custom color theme it’s relatively easy but time consuming. Just choose one of themes in Colors and change one color or more, then open my-theme-you-changing-ardour.colors in text editor (/.config/ardour5/) to find what you changing. This should be helpful too.
Once again Thank You :slight_smile:
#12
I know that isn’t most epic thing in the world but I customized
XFCE settings manager to be more useful with openbox.
Also I made scripts for system suspend and one for studio session backups :slight_smile:
Suspend is provided by betterlockscreen ( -s option) so we have locked screen by the way.
If you want to update RecBox please use Configure RecBox option from recbox-install.sh (touchpad script will be written so you need to configure it).
Regards :slight_smile:
#13
Really nice work :+1:
#14
I pushed my laziness to a higher level today :smile: Now in Tools menu we have magic button called Update RecBox so we have repo package equivalent for now. Should be good enough before RecBox turn in to package.
Also no need to spam gitlab there is Show Updates option in Tools menu.
#15
I made Zenity calendar script with notes, snippet here
and GUI installer for extra plugins. Looks nice and have short plugins description. If somebody want I can make snippet for this too or you can grab it from here :slight_smile:
Script is using st terminal (st -e pamac build) so you need to modify it a little bit or install st-manjaro.
PS
Screenshots are updated.
Have a good day ladies and gents.
#16
Hi guys I have something that potentially can interest you. Yesterday I’d some exploration in rc.xml file and I learned that window tiling can be improved pretty much (I’m not a fan of random window positioning). Before I set everything to center
    <application type="normal">
      <position>
        <x>center</x>
        <y>center</y>
      </position>
    </application>
but it doesn’t satisfy my needs so I started to mess around with force positioning and setting up apps to corners. Some of apps need more work but in general it’s done the job. Don’t know why Firefox won’t cooperate maybe I figure out this later. For example browsers like Opera, Vivaldi and Yandex behave well with tilling to corner.
    <application name="vivaldi-stable">
      <position force="yes">
        <x>-0</x>
        <y>0</y>
      </position>
    </application>
For apps like Gimp or LibreOffice basic settings don’t work well. For example if you set tilling to left, welcome window will be also moved to left. Same behavior is with confirmation dialog windows. Don’t try yet but I think that openbox wm can do the same thing as KDE with widgets. What I mean is to setting apps in specific place on screen with determinate size and number of desktop. You only need to remember that file is read from top to bottom so for example centering for all apps need to be on top of the list and everything else under. This should be helpful. Here is my config file.
Second thing is Dexed . I found that synthesizer yesterday night and sounds promising. “Dexed is a multi platform, multi format plugin synth that is closely modeled on the Yamaha DX7.”
Dexxed (OSC74) | Hexed (OSC74)
In most cases you’ll probably choose Chelm and ZynAddSubFX like unfa but I think it’s worth to check it out.
Description and installation from Extra Plugins installer is available with new update.
Recbox-config | RecBox-docs | Extra Plugins
#17
From last post I made some cosmetic work like changing rodiolists to normal lists. They are less frustrating and have keyboard support. Few icomoons and dunst notification here and there :smiley: Pretty much boring stuff in general. What is worth to mention is extra plugins list reach 40 items.
adlplug-git;;
opnplug-git;;
bitrot-git;;
creox-git;;
dexed;;
digitsvst-git;;
distrho-lv2-git;;
distrho-vst-git;;
distrho-extra-lv2-git;;
dpf-plugins-git;;
luftikus;;
tal-plugins;;
drmr-falktx-git;;
openav-fabla2-git;;
fluidplug-git;;
foo-yc20;;
ghostess;;
gxplugins-lv2;;
hexter;;
hybridreverb2-git;;
ingen-git;;
jackass-git;;
jackman-git;;
mustang-plug;;
ob-xd;;
oxefmsynth;;
rakarrack;;
rkr-lv2-git;;
rt_pvc;;
tunefish4;;
vcvrack;;
vcvrack-fundamental;;
vcvrack-audible-instruments;;
vcvrack-befaco;;
vcvrack-eseries;;
vlevel-git;;
vocoder-jack;;
vocoder-ladspa;;
whysynth;;
xsynth-dssi;;
Some plugins like DragonFly reverb and eq10q now are in M-repo (Pamac > Groups > pro-audio) (they are now in recbox-install script > Install Pro Audio Plugins) which is very cool. If you guys reading this thank you :blush:
PDF with Pro Audio and extra plugins are up to date and I wrote how to make twin pedal effect with AVL Drums. I write soon few more tutorials about AVL Drums and something about mixing and mastering. I need some time to Compress my thoughts.
What else I can say :thinking: No fancy images this time :smile:
Have a good day and Regards :slight_smile:
#18
I think I managed everything related to window tiling :slight_smile:
What I don’t thought before is plugins are treated as utilities and if you want to set them with “title” method it will be work only when it’s added first time. After next Ardour start they loose position.
    <!-- tile application window to center -->
      <position>
        <x>center</x>
        <y>center</y>
      </position>
    </application>
    <!-- Ardour Plugins and other utilitis -->
    <application type="utility">
        <x>-0</x>
        <y>0</y>
      </position>
    </application>
    <!-- Dialogs -->
    <application type="dialog">
      <position>
        <x>center</x>
        <y>center</y>
      </position>
    </application>
    <!-- Splash (Gimp, LibreOffice etc) -->
    <application type="splash">
      <position>
        <x>center</x>
        <y>center</y>
      </position>
    </application>
  <!-- applications tile to right top corner -->
    <application name="termite">
        <x>-10</x>
        <y>10</y>
      </position>
    </application>
    <application title="*st">
        <x>-10</x>
        <y>10</y>
      </position>
    </application>
    <application title="*micro">
        <x>-10</x>
        <y>10</y>
      </position>
    </application>
        <x>-0</x>
        <y>0</y>
      </position>
    </application>
    <application name="chromium-browser">
        <x>-0</x>
        <y>0</y>
      </position>
    </application>
    <application name="cantata">
        <x>-0</x>
        <y>0</y>
      </position>
    </application>
    <application name="deadbeef">
        <x>-10</x>
        <y>10</y>
      </position>
    </application>
    <application name="smplayer">
        <x>-10</x>
        <y>10</y>
      </position>
    </application>
    <application name="qpdfview">
      <decor>no</decor>
        <x>-0</x>
        <y>0</y>
      </position>
    </application>
    <application name="thunar">
        <x>-10</x>
        <y>10</y>
      </position>
    </application>
    <application name="nitrogen">
        <x>-10</x>
        <y>10</y>
      </position>
    </application>
    <application name="arandr">
        <x>-10</x>
        <y>10</y>
      </position>
    </application>
    <application name="xfce4-display-settings">
        <x>-10</x>
        <y>10</y>
      </position>
    </application>
    <application name="viewnior">
        <x>-10</x>
        <y>10</y>
      </position>
    </application>
    <application name="transmission-gtk">
        <x>-10</x>
        <y>10</y>
      </position>
    </application>
    <application name="syncthing-gtk">
        <x>-10</x>
        <y>10</y>
      </position>
    </application>
    <application name="obkey">
        <x>-10</x>
        <y>10</y>
      </position>
    </application>
    <application name="xfce4-settings-manager">
        <x>-10</x>
        <y>10</y>
      </position>
    </application>
    <application name="xfce4-settings-editor">
        <x>-10</x>
        <y>10</y>
      </position>
    </application>
    <application name="thunar-volman-settings">
        <x>-10</x>
        <y>10</y>
      </position>
    </application>
  <!-- applications tile to left top corner -->
    <application name="keepassxc">
        <x>0</x>
        <y>0</y>
      </position>
    </application>
    <application name="xfce4-keyboard-settings">
        <x>60</x>
        <y>10</y>
      </position>
    </application>
    <application name="xfce4-mime-settings">
        <x>60</x>
        <y>10</y>
      </position>
    </application>
  <!--  maximized applications without decoration -->
    <application title="Mozilla Firefox">
      <decor>no</decor>
      <maximized>yes</maximized>
    </application>
    <application name="libreoffice">
      <decor>no</decor>
    </application>
    <application title="GNU Image Manipulation Program">
      <decor>no</decor>
    </application>
    <application title="Open Image"> <!--  Gimp -->
      <decor>no</decor>
    </application>
    <application title="Open Image as Layers"> <!--  Gimp -->
      <decor>no</decor>
    </application>
    <application title="Export Image"> <!--  Gimp -->
      <decor>no</decor>
    </application>
    <application name="inkscape">
      <decor>no</decor>
    </application>
    <application title="*Ardour">
      <decor>no</decor>
    </application>
    <application name="audacity">
      <decor>no</decor>
    </application>
    <application name="lmms">
      <decor>no</decor>
    </application>
    <application title="New comparison"> <!-- Meld -->
      <decor>no</decor>
    </application>
    <application name="gitkraken">
      <decor>no</decor>
    </application>
  <!--  Zenity -->
    <application title="Zenity Backup">
      <decor>no</decor>
        <x>400</x>
        <y>0</y>
      </position>
    </application>
    <application title="Calendar">
      <decor>no</decor>
        <x>400</x>
        <y>0</y>
      </position>
    </application>
    <application title="Notes">
      <decor>no</decor>
        <x>400</x>
        <y>0</y>
      </position>
    </application>
    <application title="Zenity Cleaning">
      <decor>no</decor>
        <x>400</x>
        <y>0</y>
      </position>
    </application>
    <application title="RecBox Updates">
      <decor>no</decor>
        <x>0</x>
        <y>0</y>
      </position>
    </application>
    <application title="Extra Plugins">
      <decor>no</decor>
    </application>
    <application title="Zenity Suspend">
      <decor>no</decor>
        <x>-160</x>
        <y>0</y>
      </position>
    </application>
    <application title="Manjaro Stable Updates Announcements">
      <decor>no</decor>
        <x>0</x>
        <y>0</y>
      </position>
    </application>
Update was pushed to repository :slight_smile:
#19
Good evening ladies and gentlemen :slight_smile:
I’d added Alternative mode to RecBox. Literally it’s a playground separated from Daily and Studio modes using Polybar and Tint2 panel. You can switch from Daily or Studio to Alternative mode without changing system setup. It’s only changing Polybar and Tint2 session cofig files.
We’re one step closer to push RecBox to repository :blush:
Polybar modules here and here I am only using cmus module but there is more cool stuff there like RSS/Atom feed module. Can be useful to don’t miss any Updates Announcements :grin:
Tomorrow I have bass guitar recording session so it’s good opportunity to make notes and later write some useful tips :slight_smile:
Wallpaper here
#20
Hello boys and gals I have few new things today :slight_smile:
I made a little reconnaissance in jgmenu man and found cool option for menu separators:
   sep_markup = string (unset by default)
      If specified, <span $sep_markup>foo</span> will be passed to pango
      for ^sep(foo).  See the following link for pango attributes:
      https://developer.gnome.org/pango/stable/PangoMarkupFormat.html
        Keywords include (but are not limited to):
           font
           size (x-small, small, medium, large, x-large)
           style (normal, oblique, italic)
           weight (ultralight, light, normal, bold, ultrabold, heavy
           foreground (using format #rrggbb or a colour name)
           underline (none, single, double)
        Example:
          sep_markup = font="Sans Italic 12" foreground="blue"
RecBox:
sep_height         = 5
sep_halign         = left
sep_markup         = font="Noto Sans Music 10" foreground="#504e65"
color_sep_fg       = #282733 100  |  Normal separators are in the same color as background because
                                  |  I'm using them as spaces between items. 'height' flag don't work
                                  |  for markups or I'm doing something wrong.
Also change a little bit obmenu separators padding and OSD borders:
menu.separator.padding.width: 50
menu.separator.padding.height: 10
osd.border.width: 5
Tint2 menu now have executor for cmus like polybar I’ve added also icomoons to player-cmus.sh
side-menu now have microfone mute/unmute item
I’ve added key binding also for it under Fn + F4 and Super + c for cmus
and last but not least PDFs now have bookmarks so we can easily jump for interested topics :slight_smile:
