Dxd1
28 October 2020 05:23
1
All of a sudden my home wifi is not recognised by Manjaro. I didn’t change anything on my machine and on the wifi router either. It worked before.
Moving closer to the router does not help
Trying to connect to the network as if it was hidden doesn’t resolve the issue
I can see other wifi networks (which I don’t have access to)
The wifi works on all other devices
The RJ45 port works
I’ve tried changing kernels, but that didn’t resolve either
I’m using a BCM43142 wifi device
iw dev wlp6s0 scan also doesn’t show the SSID
rebooting doesn’t resolve the issue either
cscs
28 October 2020 05:38
2
Do other devices see the network?
Dxd1
28 October 2020 06:09
3
Yes, wifi works on all other devices.
pobrn
28 October 2020 13:37
4
Have you tried changing the channel on your wifi access point?
Pippin
28 October 2020 14:46
5
Switch off WiFi,
go to Configure Network Connections,
remove the affected connection,
make sure it is not in here:
sudo ls /etc/NetworkManager/system-connections
switch on WiFi,
maybe it’s back now…
Dxd1
29 October 2020 08:41
6
Before I could try any of the suggestions, it started working again. I didn’t change anything. So, thanks the help. I hope it never happens again.
system
Closed
13 November 2020 08:41
7
