Hello community,
I can’t figure out and find similar existing topics. Neither her nor on the web.
I installed Manjaro via manjaro-xfce-20.2.1-210103-linux59.iso and used the architect regarding to this how to: How to install Manjaro Linux using Architect installer with full disk encryption and btrfs. from Sheridan Computers starting at 9:13
The only difference I made was that I created four partitions instead of two:
boot 1G
root 49G
home 180G
swap 8G
After that I mounted them:
BOOT /dev/mapper/vg0-boot–lv
ROOT /dev/mapper/vg0-root–lv
HOME /dev/mapper/vg0-home–lv
SWAP /dev/mapper/vg0-swap–lv
But I noticed that there are no folders in my /dev/mapper/vg0-home–lv
Instead the folders Desk, Documents, etc. are in e.g. /home/upn/documents
Probably on the /root partition.
I also took some screenshots but unfortunately I can’t attach them here to my post.
df -l
Filesystem Size Used Avai. Used% Mounted on
dev 7,8G 0 7,8G 0% /dev
run 7,8G 1,8M 7,8G 1% /run
/dev/mapper/vg0-root--lv 49G 15G 34G 31% /
tmpfs 7,8G 135M 7,7G 2% /dev/shm
/dev/mapper/vg0-root--lv 49G 15G 34G 31% /home
tmpfs 7,8G 67M 7,7G 1% /tmp
/dev/mapper/vg0-boot--lv 976M 160M 750M 18% /boot
/dev/nvme0n1p1 511M 488K 511M 1% /boot/efi
tmpfs 1,6G 92K 1,6G 1% /run/user/1000
/dev/mapper/vg0-home--lv 177G 72M 168G 1% /run/media/upn/616f****-****-****-****-********9d95
lsblk
NAME MAJ:MIN RM SIZE RO TYPE MOUNTPOINTS
nvme0n1 259:0 0 238,5G 0 disk
├─nvme0n1p1 259:1 0 512M 0 part /boot/efi
└─nvme0n1p2 259:2 0 238G 0 part
└─cryptroot 254:0 0 238G 0 crypt
├─vg0-boot--lv 254:1 0 1G 0 lvm /boot
├─vg0-root--lv 254:2 0 49G 0 lvm /home
├─vg0-home--lv 254:3 0 180G 0 lvm /run/media/jns/616f****-****-****-****-********9d95
└─vg0-swap--lv 254:4 0 8G 0 lvm [SWAP]
nano /etc/fstab
GNU nano 5.9 /etc/fstab
# /dev/mapper/vg0-root--lv
UUID=5809****-****-****-****-****4356 / btrfs rw,noatime,compress=lzo,ssd,space_c>
# /dev/mapper/vg0-boot--lv
UUID=21a8****-****-****-****-****5223 /boot ext4 rw,noatime 0 0
# /dev/nvme0n1p1
UUID=06**-**74 /boot/efi vfat rw,relatime,fmask=0022,dmask=0022,codepage=437,iocharset=is>
UUID=5809****-****-****-****-********4356 /home btrfs rw,noatime,compress=lzo,ssd,space_c>
# /dev/mapper/vg0-home--lv
UUID=616f****-****-****-****-********9d95 /home ext4 rw,noatime 0 0
# /dev/mapper/vg0-swap--lv
UUID=477f****-****-****-****-********30fe none swap defaults,pri=-2 0 0
Am I correct that /home is not on the partition starting with the UID 616f
How may I change it? Because I already had to reinstall Manjaro once because I ran out of space on /root
Thank you very much already
Best regards
px
