Hi,
I have 256GB ECC REG DDR4 on my workstation. I am confused when it comes to swap partition for huge amount of ECC REG. i have looked at the table and it says the following:
Amount of RAM 256GB
No hibernation 16GB
With Hibernation 272GB
Maximum 512GB
Which type of swap would be more benificial for my CAD Workstation? should i chose No hibernation or Hibernation?
P/S Swap Partition must be created on the same SDD device along with the Manjaro OS? or can i put the swap and other partition such as / , home, boot separately on other SDD?
