Hi, I installed Manjaro on a partition occupied by an old linux distro alongside win7 on same ssd.
At reboot grub/bootloader disappears.
Only “Reboot and Select proper Boot device or Insert Boot Media in selected Boot device and press a key” showed.
What can I do?
Boot from an live manjaro to proceed
then:
Welcome to Manjaro!
- Please read the information behind this link. It will help you to post necessary information. [HowTo] Provide System Information
- Please press the three dots … below your post and then press the
- If you give us information about your system, we can see what we’re talking about and make better suggestions.
- You can do this by using
inxi
in a terminal or in console.
- Personally identifiable information such as serial numbers and MAC addresses are filtered out by this command
- Presenting the information in this way allows everyone to be familiar with the format and quickly find the items they need without missing anything.
- Copy the output from inxi (including the command) and paste it into your post.
- To make it more readable, add 3 backticks ``` on an extra line before and after the pasted text.
Thank you andreas85, here the info you required:
Kernel: 5.15.28-1-MANJARO x86_64 bits: 64 compiler: gcc v: 11.2.0
parameters: BOOT_IMAGE=/boot/vmlinuz-x86_64 lang=en_US keytable=us tz=UTC
misobasedir=manjaro misolabel=MANJARO_KDE_2125 quiet systemd.show_status=1
apparmor=1 security=apparmor driver=free nouveau.modeset=1 i915.modeset=1
radeon.modeset=1
Desktop: KDE Plasma 5.24.3 tk: Qt 5.15.3 wm: kwin_x11 vt: 1 dm: SDDM
Type: Desktop Mobo: ASUSTeK model: P6T v: Rev 1.xx
serial: <superuser required> BIOS: American Megatrends v: 1408
date: 09/21/2010
RAM: total: 5.78 GiB used: 2.44 GiB (42.1%)
RAM Report:
Info: model: Intel Core i7 920 bits: 64 type: MT MCP arch: Nehalem family: 6
model-id: 0x1A (26) stepping: 5 microcode: 0x1D
L3: 8 MiB desc: 1x8 MiB
Speed (MHz): avg: 1603 high: 1604 min/max: 1600/2668 boost: enabled
scaling: driver: acpi-cpufreq governor: schedutil cores: 1: 1604 2: 1604
3: 1604 4: 1604 5: 1604 6: 1603 7: 1604 8: 1604 bogomips: 42776
Flags: acpi aperfmperf apic arch_perfmon bts clflush cmov constant_tsc
cpuid cx16 cx8 de ds_cpl dtes64 dtherm dts ept est flexpriority flush_l1d
fpu fxsr ht ibpb ibrs ida lahf_lm lm mca mce mmx monitor msr mtrr
nonstop_tsc nopl nx pae pat pbe pdcm pebs pge pni popcnt pse pse36 pti
rdtscp rep_good sep ssbd sse sse2 sse4_1 sse4_2 ssse3 stibp syscall tm tm2
tpr_shadow tsc vme vmx vnmi vpid xtopology xtpr
Type: l1tf
Type: mds
status: Vulnerable: Clear CPU buffers attempted, no microcode; SMT vulnerable
Device-1: AMD Cypress XT [Radeon HD 5870] vendor: XFX Pine driver: radeon
v: kernel pcie: gen: 2 speed: 5 GT/s lanes: 16 ports: active: HDMI-A-1
empty: DP-1,DVI-I-1,DVI-I-2 bus-ID: 02:00.0 chip-ID: 1002:6898
class-ID: 0300
Display: x11 server: X.Org v: 1.21.1.3 compositor: kwin_x11 driver: X:
loaded: ati,radeon unloaded: modesetting alternate: fbdev,vesa gpu: radeon
display-ID: :0 screens: 1
s-diag: 582mm (22.9")
Monitor-1: HDMI-0 mapped: HDMI-A-1 model: Asus VX238 serial: <filter>
built: 2015 res: 1920x1080 hz: 60 dpi: 96 gamma: 1.2
size: 510x290mm (20.1x11.4") diag: 587mm (23.1") ratio: 16:9 modes:
max: 1920x1080 min: 720x400
OpenGL: renderer: AMD CYPRESS (DRM 2.50.0 / 5.15.28-1-MANJARO LLVM 13.0.1)
v: 4.3 Mesa 21.3.7 compat-v: 3.1 direct render: Yes
Device-1: Intel 82801JI HD Audio vendor: ASUSTeK driver: snd_hda_intel
v: kernel bus-ID: 00:1b.0 chip-ID: 8086:3a3e class-ID: 0403
Device-2: AMD Cypress HDMI Audio [Radeon HD 5830/5850/5870 / 6850/6870
Rebrand]
vendor: XFX Pine driver: snd_hda_intel v: kernel pcie: gen: 2 speed: 5 GT/s
lanes: 16 bus-ID: 02:00.1 chip-ID: 1002:aa50 class-ID: 0403
Sound Server-1: ALSA v: k5.15.28-1-MANJARO running: yes
Sound Server-4: PipeWire v: 0.3.48 running: yes
vendor: ASUSTeK M3A78 Series driver: r8169 v: kernel pcie: gen: 1
speed: 2.5 GT/s lanes: 1 port: e800 bus-ID: 06:00.0 chip-ID: 10ec:8168
class-ID: 0200
IF: enp6s0 state: up speed: 1000 Mbps duplex: full mac: <filter>
Local Storage: total: 247.44 GiB used: 0 KiB (0.0%)
ID-1: /dev/sda maj-min: 8:0 vendor: Samsung model: SSD 850 EVO 250GB
size: 232.89 GiB block-size: physical: 512 B logical: 512 B speed: 3.0 Gb/s
type: SSD serial: <filter> rev: 2B6Q scheme: MBR
ID-2: /dev/sdb maj-min: 8:16 type: USB vendor: Verbatim model: STORE N GO
size: 14.55 GiB block-size: physical: 512 B logical: 512 B speed: 3.0 Gb/s
type: N/A serial: <filter> rev: 1100 scheme: MBR
Floppy-1: /dev/fd0
Message: No partition data found.
ID-1: /dev/sda1 maj-min: 8:1 size: 100 MiB fs: ntfs label: System Reserved
uuid: CED2333CD233285B
ID-2: /dev/sda2 maj-min: 8:2 size: 211.93 GiB fs: ntfs label: N/A
uuid: 223E347E3E344D53
ID-3: /dev/sda3 maj-min: 8:3 size: 1 KiB fs: <superuser required>
label: N/A uuid: N/A
ID-4: /dev/sda5 maj-min: 8:5 size: 20.86 GiB fs: ext4 label: N/A
uuid: 0b9e232b-cafd-4f39-b0da-9ddf22172089
ID-5: /dev/sdb1 maj-min: 8:17 size: 3.54 GiB fs: iso9660
ID-6: /dev/sdb2 maj-min: 8:18 size: 4 MiB fs: vfat label: MISO_EFI
uuid: EAE6-38D6
Hub-1: 1-0:1 info: Full speed or root hub ports: 6 rev: 2.0 speed: 480 Mb/s
Hub-2: 2-0:1 info: Full speed or root hub ports: 6 rev: 2.0
Hub-3: 2-5:2 info: Genesys Logic Hub ports: 4 rev: 2.0 speed: 480 Mb/s
Device-1: 2-5.1:4 info: MosArt 2.4G Keyboard Mouse type: Keyboard,Mouse
driver: hid-generic,usbhid interfaces: 2 rev: 1.1 speed: 12 Mb/s
power: 100mA chip-ID: 062a:5918 class-ID: 0301
Hub-4: 2-5.3:5 info: Genesys Logic Hub ports: 4 rev: 2.0 speed: 480 Mb/s
Device-1: 2-5.3.1:8 info: Holtek Keyboard LKS02 type: Keyboard,HID
power: 100mA chip-ID: 04d9:1702 class-ID: 0300
Device-2: 2-5.3.2:9 info: Microsoft Xbox360 Controller
type: <vendor specific> driver: xpad interfaces: 4 rev: 2.0 speed: 12 Mb/s
power: 500mA chip-ID: 045e:028e class-ID: ff00 serial: <filter>
Device-3: 2-6:3 info: Verbatim Flash Drive type: Mass Storage
driver: usb-storage interfaces: 1 rev: 2.0 speed: 480 Mb/s power: 500mA
chip-ID: 18a5:0302 class-ID: 0806 serial: <filter>
Hub-5: 3-0:1 info: Full speed or root hub ports: 2 rev: 1.1 speed: 12 Mb/s
chip-ID: 1d6b:0001 class-ID: 0900
Hub-6: 4-0:1 info: Full speed or root hub ports: 2 rev: 1.1 speed: 12 Mb/s
Hub-7: 5-0:1 info: Full speed or root hub ports: 2 rev: 1.1 speed: 12 Mb/s
Hub-8: 6-0:1 info: Full speed or root hub ports: 2 rev: 1.1 speed: 12 Mb/s
Hub-9: 7-0:1 info: Full speed or root hub ports: 2 rev: 1.1 speed: 12 Mb/s
Hub-10: 8-0:1 info: Full speed or root hub ports: 2 rev: 1.1
speed: 12 Mb/s chip-ID: 1d6b:0001 class-ID: 0900
System Temperatures: cpu: 35.0 C mobo: 37.0 C gpu: radeon temp: 41.5 C
Fan Speeds (RPM): cpu: 1962 psu: 0 case-1: 0 case-2: 0
Power: 12v: 12.14 5v: N/A 3.3v: 3.28 vbat: N/A
Processes: 241 Uptime: 34m wakeups: 0 Init: systemd v: 250 tool: systemctl
Compilers: gcc: 11.2.0 clang: 13.0.1 Packages: pacman: 1241 lib: 334
flatpak: 0 Shell: Zsh v: 5.8.1 default: Bash v: 5.1.16 running-in: konsole
inxi: 3.3.13
This is a bios / mbr install.
This is out of my comfort zone
Thank you anyway. I’ll wait for someone.
