This is basically first time that I decide to create new question, I went through wast amount of pages and “solutions” without getting even closer to find the problem, so here it is:
When triggering suspend by low level interface
echo mem > /sys/power/state
wol is working as a dream without much issues. -
When I try suspend system by high lvl command like
systemclt suspend
, I can’t wake up system by magic package anymore (power button is still working to wakeup system), also Wake-on flag in ethtool is getting lost in the process.
My question is:
How to find root cause or event better haw to fix it
Here are some random configs that my or may not help
$inxi -Fazy
Kernel: 5.9.16-1-MANJARO x86_64 bits: 64 compiler: gcc v: 10.2.1
parameters: BOOT_IMAGE=/boot/vmlinuz-5.9-x86_64
root=UUID=038ccb7e-bcec-44b3-9bda-9f7b25b6170f ro quiet
resume=UUID=93c0a0a8-385a-42c6-bd52-9765f8e8e4de udev.log_priority=3
Desktop: Xfce info: polybar wm: Openbox 3.6.1 dm: LXDM Distro: Manjaro Linux
Type: Desktop Mobo: ASRock model: E350M1 serial: <filter>
BIOS: American Megatrends v: P2.10 date: 03/06/2014
Info: Dual Core model: AMD E-350 bits: 64 type: MCP arch: Bobcat
family: 14 (20) model-id: 1 stepping: N/A microcode: 5000029
L2 cache: 512 KiB
flags: lm nx pae sse sse2 sse3 sse4a ssse3 svm bogomips: 6402
Speed: 1048 MHz min/max: 800/1600 MHz Core speeds (MHz): 1: 1048 2: 801
Type: spectre_v2
mitigation: Full AMD retpoline, STIBP: disabled, RSB filling
Device-1: AMD Wrestler [Radeon HD 6310] vendor: ASRock driver: radeon
v: kernel bus ID: 00:01.0 chip ID: 1002:9802 class ID: 0300
Display: x11 server: X.Org 1.20.10 driver: loaded: ati,radeon
unloaded: fbdev,modesetting,vesa display ID: :0 screens: 1
s-diag: 582mm (22.9")
Monitor-1: HDMI-0 res: 1920x1080 hz: 60 dpi: 30
size: 1600x900mm (63.0x35.4") diag: 1836mm (72.3")
Device-1: AMD Wrestler HDMI Audio vendor: ASRock driver: snd_hda_intel
v: kernel bus ID: 00:01.1 chip ID: 1002:1314 class ID: 0403
Device-2: AMD SBx00 Azalia vendor: ASRock driver: snd_hda_intel v: kernel
bus ID: 00:14.2 chip ID: 1002:4383 class ID: 0403
Sound Server: ALSA v: k5.9.16-1-MANJARO
vendor: ASRock driver: r8169 v: kernel port: e000 bus ID: 04:00.0
chip ID: 10ec:8168 class ID: 0200
IF: enp4s0 state: up speed: 1000 Mbps duplex: full mac: <filter>
IF-ID-1: br-55bdd5b06c04 state: up speed: 10000 Mbps duplex: unknown
mac: <filter>
IF-ID-2: docker0 state: down mac: <filter>
IF-ID-3: veth2f50612 state: up speed: 10000 Mbps duplex: full mac: <filter>
Local Storage: total: 2.84 TiB used: 46.43 GiB (1.6%)
ID-1: /dev/sda maj-min: 8:0 vendor: Silicon Power
model: SPCC Solid State Disk size: 111.79 GiB block size: physical: 512 B
logical: 512 B speed: 6.0 Gb/s rotation: SSD serial: <filter> rev: 71.1
scheme: MBR
ID-2: /dev/sdb maj-min: 8:16 vendor: Western Digital model: WD20EARX-008FB0
size: 1.82 TiB block size: physical: 4096 B logical: 512 B speed: 6.0 Gb/s
serial: <filter> rev: AB51 scheme: GPT
ID-3: /dev/sdc maj-min: 8:32 vendor: Samsung model: HD103SI size: 931.51 GiB
block size: physical: 512 B logical: 512 B speed: 3.0 Gb/s serial: <filter>
rev: 1118 scheme: MBR
ID-1: / raw size: 104.49 GiB size: 102.35 GiB (97.95%) used: 6.51 GiB (6.4%)
fs: ext4 block size: 4096 B dev: /dev/sda1 maj-min: 8:1
ID-1: swap-1 type: partition size: 7.3 GiB used: 0 KiB (0.0%) priority: -2
dev: /dev/sda2 maj-min: 8:2
System Temperatures: cpu: 66.1 C mobo: N/A gpu: radeon temp: 67.0 C
Processes: 161 Uptime: 1h 18m wakeups: 6 Memory: 3.32 GiB
used: 1.06 GiB (32.0%) Init: systemd v: 247 Compilers: gcc: 10.2.0 Packages:
pacman: 665 lib: 134 Shell: Zsh v: 5.8 running in: terminator inxi: 3.3.01
$cat /sys/power/state
freeze mem disk
$cat /etc/systemd/sleep.conf
[Sleep]
AllowSuspend=yes
AllowHibernation=no
AllowSuspendThenHibernate=no
AllowHybridSleep=no
SuspendState=mem
$cat /etc/systemd/network/50-wired.link
[Match]
MACAddress=aa:aa:aa:aa:aa
[Link]
NamePolicy=kernel database onboard slot path
MACAddressPolicy=persistent
WakeOnLan=magic
$journalctl -p3 -b-0 | cat
-- Journal begins at Fri 2021-02-12 19:17:03 CET, ends at Sat 2021-02-20 12:55:01 CET. --
lut 20 11:43:16 serverus-mediapc systemd[1]: connman.service: Two services allocated for the same bus name net.connman, refusing operation.
lut 20 11:43:16 serverus-mediapc systemd[1]: Failed to start Wait for network to be configured by ConnMan.
lut 20 11:43:18 serverus-mediapc connman-vpnd[291]: Can't load /usr/lib/connman/plugins-vpn/wireguard.so: /usr/lib/connman/plugins-vpn/wireguard.so: undefined symbol: __vpn_ipconfig_foreach
lut 20 11:43:28 serverus-mediapc smbd[773]: [2021/02/20 11:43:28.864525, 0] ../../lib/util/become_daemon.c:135(daemon_ready)
lut 20 11:43:28 serverus-mediapc smbd[773]: daemon_ready: daemon 'smbd' finished starting up and ready to serve connections
