Oups ! I forgot these things.
inxi -Fazy :
Kernel: 5.17.6-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 11.2.0
parameters: BOOT_IMAGE=/boot/vmlinuz-5.17-x86_64
root=UUID=0a8a33aa-e804-41f2-9764-18f2e949fcb3 rw quiet
cryptdevice=UUID=f9d67c76-4011-46a6-a4a8-6a8833da6852:luks-f9d67c76-4011-46a6-a4a8-6a8833da6852
root=/dev/mapper/luks-f9d67c76-4011-46a6-a4a8-6a8833da6852 splash
Desktop: GNOME v: 42.1 tk: GTK v: 3.24.33 wm: gnome-shell dm: GDM v: 42.0
Type: Laptop System: Notebook product: NJ5x_NJ7xLU v: N/A
serial: <superuser required> Chassis: No Enclosure type: 10
Mobo: Notebook model: NJ5x_NJ7xLU serial: <superuser required>
UEFI: INSYDE v: 1.07.06 date: 11/06/2020
ID-1: BAT0 charge: 37.7 Wh (100.0%) condition: 37.7/40.1 Wh (94.0%)
volts: 16.7 min: 14.6 model: Notebook BAT type: Li-ion serial: <filter>
status: full
Info: model: Intel Core i3-1005G1 bits: 64 type: MT MCP arch: Ice Lake
family: 6 model-id: 0x7E (126) stepping: 5 microcode: 0xA8
L1: 160 KiB desc: d-2x48 KiB; i-2x32 KiB L2: 1024 KiB desc: 2x512 KiB
L3: 4 MiB desc: 1x4 MiB
Speed (MHz): avg: 2310 high: 3339 min/max: 400/3400 scaling:
driver: intel_pstate governor: powersave cores: 1: 1467 2: 2135 3: 2300
4: 3339 bogomips: 9524
Device-1: Intel Iris Plus Graphics G1 vendor: CLEVO/KAPOK driver: i915
v: kernel ports: active: eDP-1 empty: DP-1,HDMI-A-1,HDMI-A-2 bus-ID: 00:02.0
chip-ID: 8086:8a56 class-ID: 0300
Device-2: Chicony USB2.0 Camera type: USB driver: uvcvideo bus-ID: 3-1:2
chip-ID: 04f2:b685 class-ID: 0e02
Display: wayland server: X.org v: 1.21.1.3 with: Xwayland v: 22.1.1
compositor: gnome-shell driver: X: loaded: modesetting alternate: fbdev,vesa
gpu: i915 display-ID: 0
Monitor-1: eDP-1 model: BOE Display 0x0812 built: 2018 res: 1920x1080
dpi: 142 gamma: 1.2 size: 344x194mm (13.54x7.64") diag: 395mm (15.5")
ratio: 16:9 modes: 1920x1080
Message: Wayland GBM/EGL data currently not available.
Device-1: Intel Ice Lake-LP Smart Sound Audio vendor: CLEVO/KAPOK
driver: snd_hda_intel v: kernel alternate: snd_sof_pci_intel_icl
bus-ID: 00:1f.3 chip-ID: 8086:34c8 class-ID: 0403
Device-2: C-Media Audio Adapter (Unitek Y-247A) type: USB
driver: cmedia_hs100b,snd-usb-audio,usbhid bus-ID: 3-2.1:5
chip-ID: 0d8c:0014 class-ID: 0300
Device-3: C-Media CM108 Audio Controller type: USB
driver: hid-generic,snd-usb-audio,usbhid bus-ID: 3-2.4:7 chip-ID: 0d8c:013c
class-ID: 0300
Sound Server-1: ALSA v: k5.17.6-1-MANJARO running: yes
Sound Server-4: PipeWire v: 0.3.51 running: no
Device-1: Intel Ice Lake-LP PCH CNVi WiFi driver: iwlwifi v: kernel
bus-ID: 00:14.3 chip-ID: 8086:34f0 class-ID: 0280
vendor: CLEVO/KAPOK driver: r8169 v: kernel pcie: gen: 1 speed: 2.5 GT/s
lanes: 1 port: 3000 bus-ID: 01:00.1 chip-ID: 10ec:8168 class-ID: 0200
IF: enp1s0f1 state: down mac: <filter>
IF-ID-1: br-b43956e5c02b state: down mac: <filter>
IF-ID-2: docker0 state: down mac: <filter>
IF-ID-3: wg0 state: unknown speed: N/A duplex: N/A mac: N/A
bus-ID: 3-10:8 chip-ID: 8087:0026 class-ID: e001
Local Storage: total: 894.25 GiB used: 612.59 GiB (68.5%)
ID-1: /dev/sda maj-min: 8:0 vendor: LDLC
model: SSD F6 PLUS M.2 2280 3D NAND 960GB size: 894.25 GiB block-size:
physical: 512 B logical: 512 B speed: 6.0 Gb/s type: SSD serial: <filter>
rev: 4A0 scheme: GPT
ID-1: / raw-size: 893.95 GiB size: 878.85 GiB (98.31%)
used: 612.59 GiB (69.7%) fs: ext4 dev: /dev/dm-0 maj-min: 254:0
mapped: luks-f9d67c76-4011-46a6-a4a8-6a8833da6852
used: 448 KiB (0.1%) fs: vfat dev: /dev/sda1 maj-min: 8:1
System Temperatures: cpu: 46.0 C mobo: N/A
Processes: 286 Uptime: 2m wakeups: 1 Memory: 31.13 GiB
used: 4.21 GiB (13.5%) Init: systemd v: 250 tool: systemctl Compilers:
gcc: 11.2.0 clang: 13.0.1 Packages: 2319 pacman: 2309 lib: 514 flatpak: 0
snap: 10 Shell: Zsh v: 5.8.1 running-in: gnome-terminal inxi: 3.3.15
journalctl --boot=0 --priority=4 --no-pager
mai 18 21:20:37 LDLC-MANJARO kernel: ENERGY_PERF_BIAS: Set to 'normal', was 'performance'
mai 18 21:20:37 LDLC-MANJARO kernel: pnp 00:00: disabling [io 0x3322-0x3323] because it overlaps 0000:00:1d.0 BAR 13 [io 0x3000-0x3fff]
mai 18 21:20:37 LDLC-MANJARO kernel: hpet_acpi_add: no address or irqs in _CRS
mai 18 21:20:37 LDLC-MANJARO kernel: SPI driver ili9163 has no spi_device_id for newhaven,1.8-128160EF
mai 18 21:20:37 LDLC-MANJARO kernel: usb: port power management may be unreliable
mai 18 21:20:38 LDLC-MANJARO kernel: vboxdrv: loading out-of-tree module taints kernel.
mai 18 21:20:38 LDLC-MANJARO kernel: VBoxNetAdp: Successfully started.
mai 18 21:20:38 LDLC-MANJARO kernel: VBoxNetFlt: Successfully started.
mai 18 21:20:38 LDLC-MANJARO systemd-udevd[346]: /usr/lib/udev/rules.d/69-mixxx-usb-uaccess.rules:57 Unknown group 'uaccess', ignoring
mai 18 21:20:38 LDLC-MANJARO kernel: iwlwifi 0000:00:14.3: Direct firmware load for iwlwifi-Qu-c0-hr-b0-69.ucode failed with error -2
mai 18 21:20:38 LDLC-MANJARO kernel: iwlwifi 0000:00:14.3: api flags index 2 larger than supported by driver
mai 18 21:20:39 LDLC-MANJARO kernel: intel-spi 0000:00:1f.5: invalid resource
mai 18 21:20:39 LDLC-MANJARO kernel: intel-spi: probe of 0000:00:1f.5 failed with error -22
mai 18 21:20:39 LDLC-MANJARO kernel: thermal thermal_zone1: failed to read out thermal zone (-61)
mai 18 21:20:39 LDLC-MANJARO systemd-binfmt[607]: /usr/lib/binfmt.d/qemu-static.conf:2: Failed to add binary format 'qemu-alpha': No such file or directory
mai 18 21:20:39 LDLC-MANJARO systemd-binfmt[607]: /usr/lib/binfmt.d/qemu-static.conf:5: Failed to add binary format 'qemu-cris': No such file or directory
mai 18 21:20:39 LDLC-MANJARO systemd-binfmt[607]: /usr/lib/binfmt.d/qemu-static.conf:6: Failed to add binary format 'qemu-m68k': No such file or directory
mai 18 21:20:39 LDLC-MANJARO systemd-binfmt[607]: /usr/lib/binfmt.d/qemu-static.conf:7: Failed to add binary format 'qemu-microblaze': No such file or directory
mai 18 21:20:39 LDLC-MANJARO systemd-binfmt[607]: /usr/lib/binfmt.d/qemu-static.conf:8: Failed to add binary format 'qemu-mips': No such file or directory
mai 18 21:20:39 LDLC-MANJARO systemd-binfmt[607]: /usr/lib/binfmt.d/qemu-static.conf:9: Failed to add binary format 'qemu-mipsel': No such file or directory
mai 18 21:20:39 LDLC-MANJARO systemd-binfmt[607]: /usr/lib/binfmt.d/qemu-static.conf:10: Failed to add binary format 'qemu-ppc': No such file or directory
mai 18 21:20:39 LDLC-MANJARO systemd-binfmt[607]: /usr/lib/binfmt.d/qemu-static.conf:11: Failed to add binary format 'qemu-ppc64': No such file or directory
mai 18 21:20:39 LDLC-MANJARO systemd-binfmt[607]: /usr/lib/binfmt.d/qemu-static.conf:12: Failed to add binary format 'qemu-s390x': No such file or directory
mai 18 21:20:39 LDLC-MANJARO systemd-binfmt[607]: /usr/lib/binfmt.d/qemu-static.conf:13: Failed to add binary format 'qemu-sh4': No such file or directory
mai 18 21:20:39 LDLC-MANJARO systemd-binfmt[607]: /usr/lib/binfmt.d/qemu-static.conf:14: Failed to add binary format 'qemu-sh4eb': No such file or directory
mai 18 21:20:39 LDLC-MANJARO systemd-binfmt[607]: /usr/lib/binfmt.d/qemu-static.conf:15: Failed to add binary format 'qemu-sparc': No such file or directory
mai 18 21:20:39 LDLC-MANJARO systemd-binfmt[607]: /usr/lib/binfmt.d/qemu-static.conf:16: Failed to add binary format 'qemu-sparc32plus': No such file or directory
mai 18 21:20:39 LDLC-MANJARO systemd-binfmt[607]: /usr/lib/binfmt.d/qemu-static.conf:17: Failed to add binary format 'qemu-sparc64': No such file or directory
mai 18 21:20:39 LDLC-MANJARO systemd-binfmt[607]: /usr/lib/binfmt.d/qemu-static.conf:18: Failed to add binary format 'qemu-riscv64': No such file or directory
mai 18 21:20:39 LDLC-MANJARO systemd[1]: systemd-binfmt.service: Failed with result 'exit-code'.
mai 18 21:20:39 LDLC-MANJARO systemd[1]: Failed to start Set Up Additional Binary Formats.
mai 18 21:20:39 LDLC-MANJARO kernel: snd_hda_intel 0000:00:1f.3: spurious response 0x0:0x0, last cmd=0x000000
mai 18 21:20:39 LDLC-MANJARO kernel: hdaudio hdaudioC0D0: no AFG or MFG node found
mai 18 21:20:40 LDLC-MANJARO systemd-udevd[367]: hiddev0: /usr/lib/udev/rules.d/69-mixxx-usb-uaccess.rules:57 Only network interfaces can be renamed, ignoring NAME="usb/%k".
mai 18 21:20:40 LDLC-MANJARO systemd-binfmt[957]: /usr/lib/binfmt.d/qemu-static.conf:2: Failed to add binary format 'qemu-alpha': No such file or directory
mai 18 21:20:40 LDLC-MANJARO systemd-binfmt[957]: /usr/lib/binfmt.d/qemu-static.conf:5: Failed to add binary format 'qemu-cris': No such file or directory
mai 18 21:20:40 LDLC-MANJARO systemd-binfmt[957]: /usr/lib/binfmt.d/qemu-static.conf:6: Failed to add binary format 'qemu-m68k': No such file or directory
mai 18 21:20:40 LDLC-MANJARO systemd-binfmt[957]: /usr/lib/binfmt.d/qemu-static.conf:7: Failed to add binary format 'qemu-microblaze': No such file or directory
mai 18 21:20:40 LDLC-MANJARO systemd-binfmt[957]: /usr/lib/binfmt.d/qemu-static.conf:8: Failed to add binary format 'qemu-mips': No such file or directory
mai 18 21:20:40 LDLC-MANJARO systemd-binfmt[957]: /usr/lib/binfmt.d/qemu-static.conf:9: Failed to add binary format 'qemu-mipsel': No such file or directory
mai 18 21:20:40 LDLC-MANJARO systemd-binfmt[957]: /usr/lib/binfmt.d/qemu-static.conf:10: Failed to add binary format 'qemu-ppc': No such file or directory
mai 18 21:20:40 LDLC-MANJARO systemd-binfmt[957]: /usr/lib/binfmt.d/qemu-static.conf:11: Failed to add binary format 'qemu-ppc64': No such file or directory
mai 18 21:20:40 LDLC-MANJARO systemd-binfmt[957]: /usr/lib/binfmt.d/qemu-static.conf:12: Failed to add binary format 'qemu-s390x': No such file or directory
mai 18 21:20:40 LDLC-MANJARO systemd-binfmt[957]: /usr/lib/binfmt.d/qemu-static.conf:13: Failed to add binary format 'qemu-sh4': No such file or directory
mai 18 21:20:40 LDLC-MANJARO systemd-binfmt[957]: /usr/lib/binfmt.d/qemu-static.conf:14: Failed to add binary format 'qemu-sh4eb': No such file or directory
mai 18 21:20:40 LDLC-MANJARO systemd-binfmt[957]: /usr/lib/binfmt.d/qemu-static.conf:15: Failed to add binary format 'qemu-sparc': No such file or directory
mai 18 21:20:40 LDLC-MANJARO systemd-binfmt[957]: /usr/lib/binfmt.d/qemu-static.conf:16: Failed to add binary format 'qemu-sparc32plus': No such file or directory
mai 18 21:20:40 LDLC-MANJARO systemd-binfmt[957]: /usr/lib/binfmt.d/qemu-static.conf:17: Failed to add binary format 'qemu-sparc64': No such file or directory
mai 18 21:20:40 LDLC-MANJARO systemd-binfmt[957]: /usr/lib/binfmt.d/qemu-static.conf:18: Failed to add binary format 'qemu-riscv64': No such file or directory
mai 18 21:20:40 LDLC-MANJARO systemd[1]: systemd-binfmt.service: Failed with result 'exit-code'.
mai 18 21:20:40 LDLC-MANJARO systemd[1]: Failed to start Set Up Additional Binary Formats.
mai 18 21:20:40 LDLC-MANJARO systemd-binfmt[959]: /usr/lib/binfmt.d/qemu-static.conf:2: Failed to add binary format 'qemu-alpha': No such file or directory
mai 18 21:20:40 LDLC-MANJARO systemd-binfmt[959]: /usr/lib/binfmt.d/qemu-static.conf:5: Failed to add binary format 'qemu-cris': No such file or directory
mai 18 21:20:40 LDLC-MANJARO systemd-binfmt[959]: /usr/lib/binfmt.d/qemu-static.conf:6: Failed to add binary format 'qemu-m68k': No such file or directory
mai 18 21:20:40 LDLC-MANJARO systemd-binfmt[959]: /usr/lib/binfmt.d/qemu-static.conf:7: Failed to add binary format 'qemu-microblaze': No such file or directory
mai 18 21:20:40 LDLC-MANJARO systemd-binfmt[959]: /usr/lib/binfmt.d/qemu-static.conf:8: Failed to add binary format 'qemu-mips': No such file or directory
mai 18 21:20:40 LDLC-MANJARO systemd-binfmt[959]: /usr/lib/binfmt.d/qemu-static.conf:9: Failed to add binary format 'qemu-mipsel': No such file or directory
mai 18 21:20:40 LDLC-MANJARO systemd-binfmt[959]: /usr/lib/binfmt.d/qemu-static.conf:10: Failed to add binary format 'qemu-ppc': No such file or directory
mai 18 21:20:40 LDLC-MANJARO systemd-binfmt[959]: /usr/lib/binfmt.d/qemu-static.conf:11: Failed to add binary format 'qemu-ppc64': No such file or directory
mai 18 21:20:40 LDLC-MANJARO systemd-binfmt[959]: /usr/lib/binfmt.d/qemu-static.conf:12: Failed to add binary format 'qemu-s390x': No such file or directory
mai 18 21:20:40 LDLC-MANJARO systemd-binfmt[959]: /usr/lib/binfmt.d/qemu-static.conf:13: Failed to add binary format 'qemu-sh4': No such file or directory
mai 18 21:20:40 LDLC-MANJARO systemd-binfmt[959]: /usr/lib/binfmt.d/qemu-static.conf:14: Failed to add binary format 'qemu-sh4eb': No such file or directory
mai 18 21:20:40 LDLC-MANJARO systemd-binfmt[959]: /usr/lib/binfmt.d/qemu-static.conf:15: Failed to add binary format 'qemu-sparc': No such file or directory
mai 18 21:20:40 LDLC-MANJARO systemd-binfmt[959]: /usr/lib/binfmt.d/qemu-static.conf:16: Failed to add binary format 'qemu-sparc32plus': No such file or directory
mai 18 21:20:40 LDLC-MANJARO systemd-binfmt[959]: /usr/lib/binfmt.d/qemu-static.conf:17: Failed to add binary format 'qemu-sparc64': No such file or directory
mai 18 21:20:40 LDLC-MANJARO systemd-binfmt[959]: /usr/lib/binfmt.d/qemu-static.conf:18: Failed to add binary format 'qemu-riscv64': No such file or directory
mai 18 21:20:40 LDLC-MANJARO systemd-binfmt[989]: /usr/lib/binfmt.d/qemu-static.conf:2: Failed to add binary format 'qemu-alpha': No such file or directory
mai 18 21:20:40 LDLC-MANJARO systemd-binfmt[989]: /usr/lib/binfmt.d/qemu-static.conf:5: Failed to add binary format 'qemu-cris': No such file or directory
mai 18 21:20:40 LDLC-MANJARO systemd-binfmt[989]: /usr/lib/binfmt.d/qemu-static.conf:6: Failed to add binary format 'qemu-m68k': No such file or directory
mai 18 21:20:40 LDLC-MANJARO systemd-binfmt[989]: /usr/lib/binfmt.d/qemu-static.conf:7: Failed to add binary format 'qemu-microblaze': No such file or directory
mai 18 21:20:40 LDLC-MANJARO systemd-binfmt[989]: /usr/lib/binfmt.d/qemu-static.conf:8: Failed to add binary format 'qemu-mips': No such file or directory
mai 18 21:20:40 LDLC-MANJARO systemd-binfmt[989]: /usr/lib/binfmt.d/qemu-static.conf:9: Failed to add binary format 'qemu-mipsel': No such file or directory
mai 18 21:20:40 LDLC-MANJARO systemd-binfmt[989]: /usr/lib/binfmt.d/qemu-static.conf:10: Failed to add binary format 'qemu-ppc': No such file or directory
mai 18 21:20:40 LDLC-MANJARO systemd-binfmt[989]: /usr/lib/binfmt.d/qemu-static.conf:11: Failed to add binary format 'qemu-ppc64': No such file or directory
mai 18 21:20:40 LDLC-MANJARO systemd-binfmt[989]: /usr/lib/binfmt.d/qemu-static.conf:12: Failed to add binary format 'qemu-s390x': No such file or directory
mai 18 21:20:40 LDLC-MANJARO systemd-binfmt[989]: /usr/lib/binfmt.d/qemu-static.conf:13: Failed to add binary format 'qemu-sh4': No such file or directory
mai 18 21:20:40 LDLC-MANJARO systemd-binfmt[989]: /usr/lib/binfmt.d/qemu-static.conf:14: Failed to add binary format 'qemu-sh4eb': No such file or directory
mai 18 21:20:40 LDLC-MANJARO systemd-binfmt[989]: /usr/lib/binfmt.d/qemu-static.conf:15: Failed to add binary format 'qemu-sparc': No such file or directory
mai 18 21:20:40 LDLC-MANJARO systemd-binfmt[989]: /usr/lib/binfmt.d/qemu-static.conf:16: Failed to add binary format 'qemu-sparc32plus': No such file or directory
mai 18 21:20:40 LDLC-MANJARO systemd-binfmt[989]: /usr/lib/binfmt.d/qemu-static.conf:17: Failed to add binary format 'qemu-sparc64': No such file or directory
mai 18 21:20:40 LDLC-MANJARO systemd-binfmt[989]: /usr/lib/binfmt.d/qemu-static.conf:18: Failed to add binary format 'qemu-riscv64': No such file or directory
mai 18 21:20:41 LDLC-MANJARO systemd[1]: postgresql.service: Failed with result 'exit-code'.
mai 18 21:20:41 LDLC-MANJARO systemd[1]: Failed to start PostgreSQL database server.
mai 18 21:20:42 LDLC-MANJARO gnome-session-binary[1135]: GLib-GIO-CRITICAL: g_bus_get_sync: assertion 'error == NULL || *error == NULL' failed
mai 18 21:20:42 LDLC-MANJARO gnome-session-binary[1135]: WARNING: Could not parse desktop file orca-autostart.desktop or it references a not found TryExec binary
mai 18 21:20:43 LDLC-MANJARO /usr/lib/gdm-wayland-session[1134]: dbus-daemon[1134]: [session uid=120 pid=1134] Activating service name='org.a11y.Bus' requested by ':1.4' (uid=120 pid=1166 comm="/usr/bin/gnome-shell")
mai 18 21:20:43 LDLC-MANJARO /usr/lib/gdm-wayland-session[1134]: dbus-daemon[1134]: [session uid=120 pid=1134] Successfully activated service 'org.a11y.Bus'
mai 18 21:20:44 LDLC-MANJARO kernel: kauditd_printk_skb: 202 callbacks suppressed
mai 18 21:20:44 LDLC-MANJARO /usr/lib/gdm-wayland-session[1134]: dbus-daemon[1134]: [session uid=120 pid=1134] Activating service name='org.freedesktop.impl.portal.PermissionStore' requested by ':1.3' (uid=120 pid=1166 comm="/usr/bin/gnome-shell")
mai 18 21:20:44 LDLC-MANJARO /usr/lib/gdm-wayland-session[1134]: dbus-daemon[1134]: [session uid=120 pid=1134] Successfully activated service 'org.freedesktop.impl.portal.PermissionStore'
mai 18 21:20:44 LDLC-MANJARO geoclue[1230]: Failed to connect to avahi service: Daemon not running
mai 18 21:20:44 LDLC-MANJARO gnome-shell[1166]: JS ERROR: Could not load extension material-shell@papyelgringo: Error: Missing metadata.json
createExtensionObject@resource:///org/gnome/shell/ui/extensionSystem.js:297:19
_loadExtensions/<@resource:///org/gnome/shell/ui/extensionSystem.js:624:34
collectFromDatadirs@resource:///org/gnome/shell/misc/fileUtils.js:27:28
_loadExtensions@resource:///org/gnome/shell/ui/extensionSystem.js:608:19
_enableAllExtensions@resource:///org/gnome/shell/ui/extensionSystem.js:635:18
_sessionUpdated@resource:///org/gnome/shell/ui/extensionSystem.js:655:14
init@resource:///org/gnome/shell/ui/extensionSystem.js:55:14
_initializeUI@resource:///org/gnome/shell/ui/main.js:289:22
start@resource:///org/gnome/shell/ui/main.js:166:5
@resource:///org/gnome/shell/ui/init.js:6:17
mai 18 21:20:44 LDLC-MANJARO /usr/lib/gdm-wayland-session[1134]: dbus-daemon[1134]: [session uid=120 pid=1134] Activating service name='org.gnome.Shell.Notifications' requested by ':1.3' (uid=120 pid=1166 comm="/usr/bin/gnome-shell")
mai 18 21:20:44 LDLC-MANJARO /usr/lib/gdm-wayland-session[1201]: dbus-daemon[1201]: Activating service name='org.a11y.atspi.Registry' requested by ':1.0' (uid=120 pid=1166 comm="/usr/bin/gnome-shell")
mai 18 21:20:44 LDLC-MANJARO /usr/lib/gdm-wayland-session[1201]: dbus-daemon[1201]: Successfully activated service 'org.a11y.atspi.Registry'
mai 18 21:20:44 LDLC-MANJARO org.gnome.Shell.desktop[1166]: Window manager warning: Failed to parse saved session file: L’ouverture du fichier « /var/lib/gdm/.config/mutter/sessions/105447e40e38ce2da7165290164245809600000011350000.ms » a échoué : Aucun fichier ou dossier de ce type
mai 18 21:20:44 LDLC-MANJARO /usr/lib/gdm-wayland-session[1134]: dbus-daemon[1134]: [session uid=120 pid=1134] Successfully activated service 'org.gnome.Shell.Notifications'
mai 18 21:20:44 LDLC-MANJARO /usr/lib/gdm-wayland-session[1134]: dbus-daemon[1134]: [session uid=120 pid=1134] Activating service name='org.gnome.ScreenSaver' requested by ':1.10' (uid=120 pid=1250 comm="/usr/lib/gsd-usb-protection")
mai 18 21:20:44 LDLC-MANJARO /usr/lib/gdm-wayland-session[1134]: dbus-daemon[1134]: [session uid=120 pid=1134] Activating service name='org.freedesktop.systemd1' requested by ':1.11' (uid=120 pid=1248 comm="/usr/lib/gsd-sharing")
mai 18 21:20:44 LDLC-MANJARO /usr/lib/gdm-wayland-session[1134]: dbus-daemon[1134]: [session uid=120 pid=1134] Activated service 'org.freedesktop.systemd1' failed: Process org.freedesktop.systemd1 exited with status 1
mai 18 21:20:44 LDLC-MANJARO gsd-sharing[1248]: Failed to StopUnit service: GDBus.Error:org.freedesktop.DBus.Error.Spawn.ChildExited: Process org.freedesktop.systemd1 exited with status 1
mai 18 21:20:44 LDLC-MANJARO /usr/lib/gdm-wayland-session[1134]: dbus-daemon[1134]: [session uid=120 pid=1134] Successfully activated service 'org.gnome.ScreenSaver'
mai 18 21:20:44 LDLC-MANJARO gsd-usb-protect[1250]: Failed to fetch USBGuard parameters: GDBus.Error:org.freedesktop.DBus.Error.ServiceUnknown: The name org.usbguard1 was not provided by any .service files
mai 18 21:20:44 LDLC-MANJARO org.gnome.Shell.desktop[1166]: Window manager warning: Overwriting existing binding of keysym 38 with keysym 38 (keycode 11).
mai 18 21:20:44 LDLC-MANJARO org.gnome.Shell.desktop[1166]: Window manager warning: Overwriting existing binding of keysym 37 with keysym 37 (keycode 10).
mai 18 21:20:44 LDLC-MANJARO org.gnome.Shell.desktop[1166]: Window manager warning: Overwriting existing binding of keysym 33 with keysym 33 (keycode c).
mai 18 21:20:44 LDLC-MANJARO org.gnome.Shell.desktop[1166]: Window manager warning: Overwriting existing binding of keysym 34 with keysym 34 (keycode d).
mai 18 21:20:44 LDLC-MANJARO org.gnome.Shell.desktop[1166]: Window manager warning: Overwriting existing binding of keysym 32 with keysym 32 (keycode b).
mai 18 21:20:44 LDLC-MANJARO org.gnome.Shell.desktop[1166]: Window manager warning: Overwriting existing binding of keysym 39 with keysym 39 (keycode 12).
mai 18 21:20:44 LDLC-MANJARO org.gnome.Shell.desktop[1166]: Window manager warning: Overwriting existing binding of keysym 31 with keysym 31 (keycode a).
mai 18 21:20:44 LDLC-MANJARO org.gnome.Shell.desktop[1166]: Window manager warning: Overwriting existing binding of keysym 35 with keysym 35 (keycode e).
mai 18 21:20:44 LDLC-MANJARO org.gnome.Shell.desktop[1166]: Window manager warning: Overwriting existing binding of keysym 36 with keysym 36 (keycode f).
mai 18 21:20:45 LDLC-MANJARO gsd-media-keys[1271]: Failed to grab accelerator for keybinding settings:playback-repeat
mai 18 21:20:45 LDLC-MANJARO gsd-media-keys[1271]: Failed to grab accelerator for keybinding settings:hibernate
mai 18 21:20:45 LDLC-MANJARO gnome-shell[1166]: ATK Bridge is disabled but a11y has already been enabled.
mai 18 21:20:45 LDLC-MANJARO xbrlapi.desktop[1392]: openConnection: connect: Aucun fichier ou dossier de ce type
mai 18 21:20:45 LDLC-MANJARO xbrlapi.desktop[1392]: Ne peut pas se connecter au démon des périphériques braille de brltty sur :0
mai 18 21:20:45 LDLC-MANJARO org.gnome.Shell.desktop[1397]: The XKEYBOARD keymap compiler (xkbcomp) reports:
mai 18 21:20:45 LDLC-MANJARO org.gnome.Shell.desktop[1397]: > Warning: Unsupported maximum keycode 708, clipping.
mai 18 21:20:45 LDLC-MANJARO org.gnome.Shell.desktop[1397]: > X11 cannot support keycodes above 255.
mai 18 21:20:45 LDLC-MANJARO org.gnome.Shell.desktop[1397]: Errors from xkbcomp are not fatal to the X server
mai 18 21:20:46 LDLC-MANJARO kernel: snd_hda_intel 0000:00:1f.3: azx_get_response timeout, switching to polling mode: last cmd=0x202f8100
mai 18 21:20:46 LDLC-MANJARO kernel: snd_hdac_bus_update_rirb: 70911 callbacks suppressed
mai 18 21:20:46 LDLC-MANJARO kernel: snd_hda_intel 0000:00:1f.3: spurious response 0x0:0x0, last cmd=0x0f0004
mai 18 21:20:46 LDLC-MANJARO /usr/lib/gdm-wayland-session[1134]: dbus-daemon[1134]: [session uid=120 pid=1134] Activating service name='org.freedesktop.systemd1' requested by ':1.11' (uid=120 pid=1248 comm="/usr/lib/gsd-sharing")
mai 18 21:20:46 LDLC-MANJARO /usr/lib/gdm-wayland-session[1134]: dbus-daemon[1134]: [session uid=120 pid=1134] Activated service 'org.freedesktop.systemd1' failed: Process org.freedesktop.systemd1 exited with status 1
mai 18 21:20:46 LDLC-MANJARO gsd-sharing[1248]: Failed to StopUnit service: GDBus.Error:org.freedesktop.DBus.Error.Spawn.ChildExited: Process org.freedesktop.systemd1 exited with status 1
mai 18 21:20:47 LDLC-MANJARO kernel: snd_hda_intel 0000:00:1f.3: No response from codec, disabling MSI: last cmd=0x202f8100
mai 18 21:20:48 LDLC-MANJARO kernel: snd_hda_intel 0000:00:1f.3: azx_get_response timeout, switching to single_cmd mode: last cmd=0x202f8100
mai 18 21:20:48 LDLC-MANJARO ibus-x11[1445]: Can not connect to ibus daemon
mai 18 21:20:51 LDLC-MANJARO kernel: kauditd_printk_skb: 158 callbacks suppressed
mai 18 21:20:58 LDLC-MANJARO gdm-password][1612]: gkr-pam: unable to locate daemon control file
mai 18 21:20:59 LDLC-MANJARO systemd-xdg-autostart-generator[1629]: /home/antoinetrin/.config/autostart/appimagekit_6e69e139b75cfa0296c1a656cf7a1257-Tutanota_Desktop.desktop:17: Unknown key name 'Actions' in section 'Desktop Entry', ignoring.
mai 18 21:20:59 LDLC-MANJARO systemd-xdg-autostart-generator[1629]: /home/antoinetrin/.config/autostart/appimagekit_6e69e139b75cfa0296c1a656cf7a1257-Tutanota_Desktop.desktop:20: Unknown section 'Desktop Action Remove'. Ignoring.
mai 18 21:20:59 LDLC-MANJARO systemd-xdg-autostart-generator[1629]: /home/antoinetrin/.config/autostart/appimagekit_9113654770b1176dd9496e1c372a48bc-Tutanota_Desktop.desktop:17: Unknown key name 'Actions' in section 'Desktop Entry', ignoring.
mai 18 21:20:59 LDLC-MANJARO systemd-xdg-autostart-generator[1629]: /home/antoinetrin/.config/autostart/appimagekit_9113654770b1176dd9496e1c372a48bc-Tutanota_Desktop.desktop:20: Unknown section 'Desktop Action Remove'. Ignoring.
mai 18 21:20:59 LDLC-MANJARO systemd-xdg-autostart-generator[1629]: /home/antoinetrin/.config/autostart/thunderbird.desktop:65: Unknown key name 'Actions' in section 'Desktop Entry', ignoring.
mai 18 21:20:59 LDLC-MANJARO systemd-xdg-autostart-generator[1629]: /home/antoinetrin/.config/autostart/thunderbird.desktop:67: Unknown section 'Desktop Action ComposeMessage'. Ignoring.
mai 18 21:20:59 LDLC-MANJARO systemd-xdg-autostart-generator[1629]: /home/antoinetrin/.config/autostart/thunderbird.desktop:121: Unknown section 'Desktop Action OpenAddressBook'. Ignoring.
mai 18 21:20:59 LDLC-MANJARO systemd-xdg-autostart-generator[1629]: /home/antoinetrin/.config/autostart/org.flameshot.Flameshot.desktop:47: Unknown key name 'Actions' in section 'Desktop Entry', ignoring.
mai 18 21:20:59 LDLC-MANJARO systemd-xdg-autostart-generator[1629]: /home/antoinetrin/.config/autostart/org.flameshot.Flameshot.desktop:52: Unknown section 'Desktop Action Configure'. Ignoring.
mai 18 21:20:59 LDLC-MANJARO systemd-xdg-autostart-generator[1629]: /home/antoinetrin/.config/autostart/org.flameshot.Flameshot.desktop:69: Unknown section 'Desktop Action Capture'. Ignoring.
mai 18 21:20:59 LDLC-MANJARO systemd-xdg-autostart-generator[1629]: /home/antoinetrin/.config/autostart/org.flameshot.Flameshot.desktop:86: Unknown section 'Desktop Action Launcher'. Ignoring.
mai 18 21:20:59 LDLC-MANJARO systemd-xdg-autostart-generator[1629]: Not generating service for XDG autostart app-protonvpn@autostart.service, error parsing Exec= line: No such file or directory
mai 18 21:20:59 LDLC-MANJARO systemd-xdg-autostart-generator[1629]: Not generating service for XDG autostart app-syncthing\x2dgtk@autostart.service, error parsing Exec= line: No such file or directory
mai 18 21:20:59 LDLC-MANJARO systemd-xdg-autostart-generator[1629]: Not generating service for XDG autostart app-kMeet.bin@autostart.service, error parsing Exec= line: No such file or directory
mai 18 21:20:59 LDLC-MANJARO gnome-session-binary[1670]: WARNING: Could not parse desktop file appimagekit_9113654770b1176dd9496e1c372a48bc-Tutanota_Desktop.desktop or it references a not found TryExec binary
mai 18 21:20:59 LDLC-MANJARO gnome-session-binary[1670]: WARNING: Could not parse desktop file kMeet.bin.desktop or it references a not found TryExec binary
mai 18 21:20:59 LDLC-MANJARO gnome-session-binary[1670]: WARNING: Could not parse desktop file com.github.rssguard.desktop or it references a not found TryExec binary
mai 18 21:20:59 LDLC-MANJARO gnome-session-binary[1670]: WARNING: Could not parse desktop file syncthing-gtk.desktop or it references a not found TryExec binary
mai 18 21:20:59 LDLC-MANJARO gnome-session-binary[1670]: WARNING: Could not parse desktop file protonvpn.desktop or it references a not found TryExec binary
mai 18 21:20:59 LDLC-MANJARO systemd[1623]: org.gnome.Shell@x11.service: Start request repeated too quickly.
mai 18 21:21:00 LDLC-MANJARO kernel: snd_hdac_bus_update_rirb: 71913 callbacks suppressed
mai 18 21:21:00 LDLC-MANJARO kernel: snd_hda_intel 0000:00:1f.3: spurious response 0x0:0x0, last cmd=0x0f0004
mai 18 21:21:01 LDLC-MANJARO gnome-shell[1686]: JS ERROR: Could not load extension gsconnect@andyholmes.github.io: Error: Failed to parse metadata.json: SyntaxError: JSON.parse: unexpected end of data at line 1 column 1 of the JSON data
createExtensionObject@resource:///org/gnome/shell/ui/extensionSystem.js:310:19
mai 18 21:21:01 LDLC-MANJARO gnome-shell[1686]: JS ERROR: Could not load extension nightthemeswitcher@romainvigier.fr: Error: Failed to parse metadata.json: SyntaxError: JSON.parse: unexpected end of data at line 1 column 1 of the JSON data
mai 18 21:21:01 LDLC-MANJARO gnome-shell[1686]: JS ERROR: Error: GDesktopAppInfo does not implement Gio.AppInfo, add Gio.AppInfo to your implements array
_create@/home/antoinetrin/.local/share/gnome-shell/extensions/dash-to-dock@micxgx.gmail.com/utils.js:267:43
addWithLabel@/home/antoinetrin/.local/share/gnome-shell/extensions/dash-to-dock@micxgx.gmail.com/utils.js:67:32
_ensureLocations@/home/antoinetrin/.local/share/gnome-shell/extensions/dash-to-dock@micxgx.gmail.com/docking.js:1656:35
DashToDock_DockManager@/home/antoinetrin/.local/share/gnome-shell/extensions/dash-to-dock@micxgx.gmail.com/docking.js:1562:14
enable@/home/antoinetrin/.local/share/gnome-shell/extensions/dash-to-dock@micxgx.gmail.com/extension.js:16:5
_callExtensionEnable@resource:///org/gnome/shell/ui/extensionSystem.js:181:32
loadExtension@resource:///org/gnome/shell/ui/extensionSystem.js:381:26
_loadExtensions/<@resource:///org/gnome/shell/ui/extensionSystem.js:629:18
mai 18 21:21:01 LDLC-MANJARO gnome-shell[1686]: JS ERROR: TypeError: GObject_Object.prototype.[__GObject__hook_up_vfunc] called on incompatible Object
_prepareMainDash@/home/antoinetrin/.local/share/gnome-shell/extensions/dash-to-dock@micxgx.gmail.com/docking.js:1972:31
_createDocks@/home/antoinetrin/.local/share/gnome-shell/extensions/dash-to-dock@micxgx.gmail.com/docking.js:1814:14
DashToDock_DockManager@/home/antoinetrin/.local/share/gnome-shell/extensions/dash-to-dock@micxgx.gmail.com/docking.js:1566:14
_prepareMainDash@/home/antoinetrin/.local/share/gnome-shell/extensions/dash-to-dock@micxgx.gmail.com/docking.js:2038:31
mai 18 21:21:01 LDLC-MANJARO gnome-shell[1686]: JS ERROR: Extension dash-to-dock@micxgx.gmail.com: TypeError: Main.panel._leftCorner is undefined
_revertPanelCorners@/home/antoinetrin/.local/share/gnome-shell/extensions/dash-to-dock@micxgx.gmail.com/docking.js:2258:9
_adjustPanelCorners@/home/antoinetrin/.local/share/gnome-shell/extensions/dash-to-dock@micxgx.gmail.com/docking.js:2254:18
_createDocks@/home/antoinetrin/.local/share/gnome-shell/extensions/dash-to-dock@micxgx.gmail.com/docking.js:1817:14
mai 18 21:21:01 LDLC-MANJARO gnome-shell[1686]: JS ERROR: Could not load extension IP-Finder@linxgem33.com: Error: Failed to parse metadata.json: SyntaxError: JSON.parse: unexpected end of data at line 1 column 1 of the JSON data
mai 18 21:21:01 LDLC-MANJARO gnome-shell[1686]: JS ERROR: Could not load extension places-menu@gnome-shell-extensions.gcampax.github.com: Error: Failed to parse metadata.json: SyntaxError: JSON.parse: unexpected end of data at line 1 column 1 of the JSON data
mai 18 21:21:01 LDLC-MANJARO gnome-shell[1686]: JS ERROR: Could not load extension drive-menu@gnome-shell-extensions.gcampax.github.com: Error: Failed to parse metadata.json: SyntaxError: JSON.parse: unexpected end of data at line 1 column 1 of the JSON data
mai 18 21:21:01 LDLC-MANJARO gnome-shell[1686]: JS ERROR: Could not load extension user-theme@gnome-shell-extensions.gcampax.github.com: Error: Failed to parse metadata.json: SyntaxError: JSON.parse: unexpected end of data at line 1 column 1 of the JSON data
mai 18 21:21:01 LDLC-MANJARO gnome-shell[1686]: JS ERROR: Could not load extension apps-menu@gnome-shell-extensions.gcampax.github.com: Error: Failed to parse metadata.json: SyntaxError: JSON.parse: unexpected end of data at line 1 column 1 of the JSON data
mai 18 21:21:01 LDLC-MANJARO pulseaudio[1741]: stat('/etc/pulse/default.pa.d'): Aucun fichier ou dossier de ce type
mai 18 21:21:01 LDLC-MANJARO systemd[1623]: Dependency failed for GNOME XSettings service.
mai 18 21:21:02 LDLC-MANJARO gnome-session-binary[1670]: GnomeDesktop-WARNING: Could not create transient scope for PID 2000: GDBus.Error:org.freedesktop.DBus.Error.UnixProcessIdUnknown: Process with ID 2000 does not exist.
mai 18 21:21:02 LDLC-MANJARO gnome-session-binary[1670]: GnomeDesktop-WARNING: Could not create transient scope for PID 2003: GDBus.Error:org.freedesktop.DBus.Error.UnixProcessIdUnknown: Process with ID 2003 does not exist.
mai 18 21:21:02 LDLC-MANJARO gsd-usb-protect[1892]: Failed to fetch USBGuard parameters: GDBus.Error:org.freedesktop.DBus.Error.ServiceUnknown: The name org.usbguard1 was not provided by any .service files
mai 18 21:21:02 LDLC-MANJARO gnome-session-binary[1670]: GnomeDesktop-WARNING: Could not create transient scope for PID 2011: GDBus.Error:org.freedesktop.DBus.Error.UnixProcessIdUnknown: Process with ID 2011 does not exist.
mai 18 21:21:02 LDLC-MANJARO gnome-session-binary[1670]: GnomeDesktop-WARNING: Could not create transient scope for PID 2013: GDBus.Error:org.freedesktop.DBus.Error.UnixProcessIdUnknown: Process with ID 2013 does not exist.
mai 18 21:21:02 LDLC-MANJARO gnome-session-binary[1670]: GnomeDesktop-WARNING: Could not create transient scope for PID 2027: GDBus.Error:org.freedesktop.DBus.Error.UnixProcessIdUnknown: Process with ID 2027 does not exist.
mai 18 21:21:02 LDLC-MANJARO gnome-session-binary[1670]: GnomeDesktop-WARNING: Could not create transient scope for PID 2034: GDBus.Error:org.freedesktop.DBus.Error.UnixProcessIdUnknown: Process with ID 2034 does not exist.
mai 18 21:21:02 LDLC-MANJARO kdeconnectd[2047]: QSocketNotifier: Can only be used with threads started with QThread
mai 18 21:21:02 LDLC-MANJARO libinput-gestures.desktop[2043]: Warning: must install wmctrl to use _internal command.
mai 18 21:21:03 LDLC-MANJARO nemo[1836]: Current gtk theme is not known to have nemo support (Adwaita-maia-dark) - checking...
mai 18 21:21:04 LDLC-MANJARO pulseaudio[1226]: X11 I/O error handler called
mai 18 21:21:04 LDLC-MANJARO pulseaudio[1226]: X11 I/O error exit handler called, preparing to tear down X11 modules
mai 18 21:21:04 LDLC-MANJARO gnome-shell[1166]: Connection to xwayland lost
mai 18 21:21:04 LDLC-MANJARO /usr/lib/gdm-wayland-session[1134]: dbus-daemon[1134]: [session uid=120 pid=1134] Activating service name='org.freedesktop.systemd1' requested by ':1.11' (uid=120 pid=1248 comm="/usr/lib/gsd-sharing")
mai 18 21:21:04 LDLC-MANJARO gdm-launch-environment][1103]: GLib-GObject: g_object_unref: assertion 'G_IS_OBJECT (object)' failed
mai 18 21:21:04 LDLC-MANJARO kernel: kauditd_printk_skb: 168 callbacks suppressed
mai 18 21:21:04 LDLC-MANJARO gsd-media-keys[1880]: Failed to grab accelerator for keybinding settings:playback-repeat
mai 18 21:21:04 LDLC-MANJARO gsd-media-keys[1880]: Failed to grab accelerator for keybinding settings:hibernate
mai 18 21:21:04 LDLC-MANJARO gsd-color[1874]: could not find device: property match 'XRANDR_name'='eDP-1' does not exist
mai 18 21:21:04 LDLC-MANJARO gnome-shell[1686]: ATK Bridge is disabled but a11y has already been enabled.
mai 18 21:21:05 LDLC-MANJARO io.element.Element.desktop[2422]: libva error: vaGetDriverNameByIndex() failed with unknown libva error, driver_name = (null)
mai 18 21:21:05 LDLC-MANJARO io.element.Element.desktop[2422]: [2422:0518/212105.244127:ERROR:sandbox_linux.cc(377)] InitializeSandbox() called with multiple threads in process gpu-process.
mai 18 21:21:05 LDLC-MANJARO systemd-xdg-autostart-generator[2510]: /home/antoinetrin/.config/autostart/appimagekit_6e69e139b75cfa0296c1a656cf7a1257-Tutanota_Desktop.desktop:17: Unknown key name 'Actions' in section 'Desktop Entry', ignoring.
mai 18 21:21:05 LDLC-MANJARO systemd-xdg-autostart-generator[2510]: /home/antoinetrin/.config/autostart/appimagekit_6e69e139b75cfa0296c1a656cf7a1257-Tutanota_Desktop.desktop:20: Unknown section 'Desktop Action Remove'. Ignoring.
mai 18 21:21:05 LDLC-MANJARO systemd-xdg-autostart-generator[2510]: /home/antoinetrin/.config/autostart/appimagekit_9113654770b1176dd9496e1c372a48bc-Tutanota_Desktop.desktop:17: Unknown key name 'Actions' in section 'Desktop Entry', ignoring.
mai 18 21:21:05 LDLC-MANJARO systemd-xdg-autostart-generator[2510]: /home/antoinetrin/.config/autostart/appimagekit_9113654770b1176dd9496e1c372a48bc-Tutanota_Desktop.desktop:20: Unknown section 'Desktop Action Remove'. Ignoring.
mai 18 21:21:05 LDLC-MANJARO systemd-xdg-autostart-generator[2510]: /home/antoinetrin/.config/autostart/thunderbird.desktop:65: Unknown key name 'Actions' in section 'Desktop Entry', ignoring.
mai 18 21:21:05 LDLC-MANJARO systemd-xdg-autostart-generator[2510]: /home/antoinetrin/.config/autostart/thunderbird.desktop:67: Unknown section 'Desktop Action ComposeMessage'. Ignoring.
mai 18 21:21:05 LDLC-MANJARO systemd-xdg-autostart-generator[2510]: /home/antoinetrin/.config/autostart/thunderbird.desktop:121: Unknown section 'Desktop Action OpenAddressBook'. Ignoring.
mai 18 21:21:05 LDLC-MANJARO systemd-xdg-autostart-generator[2510]: /home/antoinetrin/.config/autostart/org.flameshot.Flameshot.desktop:47: Unknown key name 'Actions' in section 'Desktop Entry', ignoring.
mai 18 21:21:05 LDLC-MANJARO systemd-xdg-autostart-generator[2510]: /home/antoinetrin/.config/autostart/org.flameshot.Flameshot.desktop:52: Unknown section 'Desktop Action Configure'. Ignoring.
mai 18 21:21:05 LDLC-MANJARO systemd-xdg-autostart-generator[2510]: /home/antoinetrin/.config/autostart/org.flameshot.Flameshot.desktop:69: Unknown section 'Desktop Action Capture'. Ignoring.
mai 18 21:21:05 LDLC-MANJARO systemd-xdg-autostart-generator[2510]: /home/antoinetrin/.config/autostart/org.flameshot.Flameshot.desktop:86: Unknown section 'Desktop Action Launcher'. Ignoring.
mai 18 21:21:05 LDLC-MANJARO systemd-xdg-autostart-generator[2510]: Not generating service for XDG autostart app-kMeet.bin@autostart.service, error parsing Exec= line: No such file or directory
mai 18 21:21:05 LDLC-MANJARO systemd-xdg-autostart-generator[2510]: Not generating service for XDG autostart app-syncthing\x2dgtk@autostart.service, error parsing Exec= line: No such file or directory
mai 18 21:21:05 LDLC-MANJARO systemd-xdg-autostart-generator[2510]: Not generating service for XDG autostart app-protonvpn@autostart.service, error parsing Exec= line: No such file or directory
mai 18 21:21:05 LDLC-MANJARO appindicatorsupport@rgcjonas.gmail.com[1686]: unable to update icon for Element1
mai 18 21:21:06 LDLC-MANJARO appindicatorsupport@rgcjonas.gmail.com[1686]: unable to update icon for flameshot
mai 18 21:21:06 LDLC-MANJARO riseup-vpn[2005]: qrc:/qml/main.qml:41:9: QML QQuickItem: Detected anchors on an item that is managed by a layout. This is undefined behavior; use Layout.alignment instead.
mai 18 21:21:06 LDLC-MANJARO riseup-vpn[2005]: qrc:/qml/main.qml:108:9: QML QQuickItem: Detected anchors on an item that is managed by a layout. This is undefined behavior; use Layout.alignment instead.
mai 18 21:21:06 LDLC-MANJARO riseup-vpn[2005]: qrc:/qml/main.qml:177:9: QML BridgesItem: Detected anchors on an item that is managed by a layout. This is undefined behavior; use Layout.alignment instead.
mai 18 21:21:06 LDLC-MANJARO riseup-vpn[2009]: qrc:/qml/main.qml:41:9: QML QQuickItem: Detected anchors on an item that is managed by a layout. This is undefined behavior; use Layout.alignment instead.
mai 18 21:21:06 LDLC-MANJARO riseup-vpn[2009]: qrc:/qml/main.qml:108:9: QML QQuickItem: Detected anchors on an item that is managed by a layout. This is undefined behavior; use Layout.alignment instead.
mai 18 21:21:06 LDLC-MANJARO riseup-vpn[2009]: qrc:/qml/main.qml:177:9: QML BridgesItem: Detected anchors on an item that is managed by a layout. This is undefined behavior; use Layout.alignment instead.
mai 18 21:21:06 LDLC-MANJARO systemd-xdg-autostart-generator[2555]: /home/antoinetrin/.config/autostart/appimagekit_6e69e139b75cfa0296c1a656cf7a1257-Tutanota_Desktop.desktop:17: Unknown key name 'Actions' in section 'Desktop Entry', ignoring.
mai 18 21:21:06 LDLC-MANJARO systemd-xdg-autostart-generator[2555]: /home/antoinetrin/.config/autostart/appimagekit_6e69e139b75cfa0296c1a656cf7a1257-Tutanota_Desktop.desktop:20: Unknown section 'Desktop Action Remove'. Ignoring.
mai 18 21:21:06 LDLC-MANJARO systemd-xdg-autostart-generator[2555]: /home/antoinetrin/.config/autostart/appimagekit_9113654770b1176dd9496e1c372a48bc-Tutanota_Desktop.desktop:17: Unknown key name 'Actions' in section 'Desktop Entry', ignoring.
mai 18 21:21:06 LDLC-MANJARO systemd-xdg-autostart-generator[2555]: /home/antoinetrin/.config/autostart/appimagekit_9113654770b1176dd9496e1c372a48bc-Tutanota_Desktop.desktop:20: Unknown section 'Desktop Action Remove'. Ignoring.
mai 18 21:21:06 LDLC-MANJARO systemd-xdg-autostart-generator[2555]: /home/antoinetrin/.config/autostart/thunderbird.desktop:65: Unknown key name 'Actions' in section 'Desktop Entry', ignoring.
mai 18 21:21:06 LDLC-MANJARO systemd-xdg-autostart-generator[2555]: /home/antoinetrin/.config/autostart/thunderbird.desktop:67: Unknown section 'Desktop Action ComposeMessage'. Ignoring.
mai 18 21:21:06 LDLC-MANJARO systemd-xdg-autostart-generator[2555]: /home/antoinetrin/.config/autostart/thunderbird.desktop:121: Unknown section 'Desktop Action OpenAddressBook'. Ignoring.
mai 18 21:21:06 LDLC-MANJARO systemd-xdg-autostart-generator[2555]: /home/antoinetrin/.config/autostart/org.flameshot.Flameshot.desktop:47: Unknown key name 'Actions' in section 'Desktop Entry', ignoring.
mai 18 21:21:06 LDLC-MANJARO systemd-xdg-autostart-generator[2555]: /home/antoinetrin/.config/autostart/org.flameshot.Flameshot.desktop:52: Unknown section 'Desktop Action Configure'. Ignoring.
mai 18 21:21:06 LDLC-MANJARO systemd-xdg-autostart-generator[2555]: /home/antoinetrin/.config/autostart/org.flameshot.Flameshot.desktop:69: Unknown section 'Desktop Action Capture'. Ignoring.
mai 18 21:21:06 LDLC-MANJARO systemd-xdg-autostart-generator[2555]: /home/antoinetrin/.config/autostart/org.flameshot.Flameshot.desktop:86: Unknown section 'Desktop Action Launcher'. Ignoring.
mai 18 21:21:06 LDLC-MANJARO systemd-xdg-autostart-generator[2555]: Not generating service for XDG autostart app-protonvpn@autostart.service, error parsing Exec= line: No such file or directory
mai 18 21:21:06 LDLC-MANJARO systemd-xdg-autostart-generator[2555]: Not generating service for XDG autostart app-syncthing\x2dgtk@autostart.service, error parsing Exec= line: No such file or directory
mai 18 21:21:06 LDLC-MANJARO systemd-xdg-autostart-generator[2555]: Not generating service for XDG autostart app-kMeet.bin@autostart.service, error parsing Exec= line: No such file or directory
mai 18 21:21:06 LDLC-MANJARO riseup-vpn_launcher.desktop[2005]: 2022/05/18 21:21:06 Client expects anon auth
mai 18 21:21:06 LDLC-MANJARO riseup-vpn_launcher.desktop[2005]: 2022/05/18 21:21:06 firewall stop
mai 18 21:21:06 LDLC-MANJARO RiseupVPN.desktop[2009]: 2022/05/18 21:21:06 There is a running process with the pid 2005 and executable: riseup-vpn
mai 18 21:21:06 LDLC-MANJARO RiseupVPN.desktop[2009]: 2022/05/18 21:21:06 Error acquiring PID: Another systray is running with pid: 2005
mai 18 21:21:06 LDLC-MANJARO RiseupVPN.desktop[2009]: 2022/05/18 21:21:06 Another systray is running with pid: 2005
mai 18 21:21:06 LDLC-MANJARO kernel: [UFW BLOCK] IN=wlp0s20f3 OUT= MAC=04:6c:59:72:0c:31:7c:16:89:d1:57:7c:08:00 SRC=192.168.1.254 DST=192.168.1.70 LEN=492 TOS=0x00 PREC=0x00 TTL=64 ID=5984 DF PROTO=UDP SPT=1900 DPT=48982 LEN=472
mai 18 21:21:06 LDLC-MANJARO kernel: [UFW BLOCK] IN=wlp0s20f3 OUT= MAC=04:6c:59:72:0c:31:7c:16:89:d1:57:7c:08:00 SRC=192.168.1.254 DST=192.168.1.70 LEN=492 TOS=0x00 PREC=0x00 TTL=64 ID=6012 DF PROTO=UDP SPT=1900 DPT=50388 LEN=472
mai 18 21:21:07 LDLC-MANJARO riseup-vpn_launcher.desktop[2005]: 2022/05/18 21:21:07 Fetching gateways...
mai 18 21:21:07 LDLC-MANJARO gnome-shell[1686]: Unhandled promise rejection. To suppress this warning, add an error handler to your promise chain with .catch() or a try-catch block around your await expression. Stack trace of the failed promise:
_checkNeededProperties@/home/antoinetrin/.local/share/gnome-shell/extensions/appindicatorsupport@rgcjonas.gmail.com/appIndicator.js:133:33
_setupProxy@/home/antoinetrin/.local/share/gnome-shell/extensions/appindicatorsupport@rgcjonas.gmail.com/appIndicator.js:103:18
async*AppIndicatorsAppIndicator@/home/antoinetrin/.local/share/gnome-shell/extensions/appindicatorsupport@rgcjonas.gmail.com/appIndicator.js:87:14
_registerItem@/home/antoinetrin/.local/share/gnome-shell/extensions/appindicatorsupport@rgcjonas.gmail.com/statusNotifierWatcher.js:93:31
_ensureItemRegistered@/home/antoinetrin/.local/share/gnome-shell/extensions/appindicatorsupport@rgcjonas.gmail.com/statusNotifierWatcher.js:132:14
RegisterStatusNotifierItemAsync@/home/antoinetrin/.local/share/gnome-shell/extensions/appindicatorsupport@rgcjonas.gmail.com/statusNotifierWatcher.js:191:14
async*_handleMethodCall@resource:///org/gnome/gjs/modules/core/overrides/Gio.js:354:35
_wrapJSObject/<@resource:///org/gnome/gjs/modules/core/overrides/Gio.js:387:34
mai 18 21:21:07 LDLC-MANJARO xdg-desktop-por[2228]: Failed connect to PipeWire: Couldn't connect to PipeWire
mai 18 21:21:07 LDLC-MANJARO python3[2172]: libpng warning: iCCP: known incorrect sRGB profile
mai 18 21:21:08 LDLC-MANJARO python3[2172]: libpng warning: iCCP: known incorrect sRGB profile
mai 18 21:21:09 LDLC-MANJARO io.element.Element.desktop[2422]: [2422:0518/212109.543019:ERROR:gl_surface_presentation_helper.cc(260)] GetVSyncParametersIfAvailable() failed for 1 times!
mai 18 21:21:09 LDLC-MANJARO tutanota-desktop.desktop[2631]: (node:2631) [DEP0005] DeprecationWarning: Buffer() is deprecated due to security and usability issues. Please use the Buffer.alloc(), Buffer.allocUnsafe(), or Buffer.from() methods instead.
mai 18 21:21:09 LDLC-MANJARO tutanota-desktop.desktop[2631]: (Use `tutanota-desktop --trace-deprecation ...` to show where the warning was created)
mai 18 21:21:09 LDLC-MANJARO appimagekit_6e69e139b75cfa0296c1a656cf7a1257-Tutanota_Desktop.desktop[2645]: (node:2645) [DEP0005] DeprecationWarning: Buffer() is deprecated due to security and usability issues. Please use the Buffer.alloc(), Buffer.allocUnsafe(), or Buffer.from() methods instead.
mai 18 21:21:09 LDLC-MANJARO appimagekit_6e69e139b75cfa0296c1a656cf7a1257-Tutanota_Desktop.desktop[2645]: (Use `tutanota-desktop --trace-deprecation ...` to show where the warning was created)
mai 18 21:21:09 LDLC-MANJARO python3[2172]: libpng warning: iCCP: known incorrect sRGB profile
mai 18 21:21:10 LDLC-MANJARO python3[2172]: libpng warning: iCCP: known incorrect sRGB profile
mai 18 21:21:10 LDLC-MANJARO thunderbird.desktop[2026]: Unsupported modifier, resource creation failed.
mai 18 21:21:10 LDLC-MANJARO thunderbird.desktop[2026]: XXX: resource creation failed
mai 18 21:21:10 LDLC-MANJARO tutanota-desktop.desktop[2841]: libva error: vaGetDriverNameByIndex() failed with unknown libva error, driver_name = (null)
mai 18 21:21:10 LDLC-MANJARO appimagekit_6e69e139b75cfa0296c1a656cf7a1257-Tutanota_Desktop.desktop[2853]: libva error: vaGetDriverNameByIndex() failed with unknown libva error, driver_name = (null)
mai 18 21:21:10 LDLC-MANJARO tutanota-desktop.desktop[2841]: [2841:0518/212110.982203:ERROR:sandbox_linux.cc(377)] InitializeSandbox() called with multiple threads in process gpu-process.
mai 18 21:21:11 LDLC-MANJARO appimagekit_6e69e139b75cfa0296c1a656cf7a1257-Tutanota_Desktop.desktop[2853]: [2853:0518/212111.011386:ERROR:sandbox_linux.cc(377)] InitializeSandbox() called with multiple threads in process gpu-process.
mai 18 21:21:11 LDLC-MANJARO python3[2172]: libpng warning: iCCP: known incorrect sRGB profile
mai 18 21:21:11 LDLC-MANJARO python3[2172]: libpng warning: known incorrect sRGB profile
mai 18 21:21:11 LDLC-MANJARO python3[2172]: libpng warning: profile matches sRGB but writing iCCP instead
mai 18 21:21:11 LDLC-MANJARO appindicatorsupport@rgcjonas.gmail.com[1686]: unable to update icon for tutanota-desktop1
mai 18 21:21:11 LDLC-MANJARO appindicatorsupport@rgcjonas.gmail.com[1686]: unable to update icon for calibre
mai 18 21:21:11 LDLC-MANJARO tutanota-desktop.desktop[2631]: [2631:0518/212111.883933:ERROR:browser_main_loop.cc(267)] Gtk: gtk_widget_add_accelerator: assertion 'GTK_IS_ACCEL_GROUP (accel_group)' failed
mai 18 21:21:11 LDLC-MANJARO tutanota-desktop.desktop[2631]: [2631:0518/212111.902415:ERROR:browser_main_loop.cc(267)] Gtk: gtk_widget_add_accelerator: assertion 'GTK_IS_ACCEL_GROUP (accel_group)' failed
mai 18 21:21:12 LDLC-MANJARO tutanota-desktop.desktop[2631]: [2631:0518/212112.168048:ERROR:browser_main_loop.cc(267)] Gtk: gtk_widget_add_accelerator: assertion 'GTK_IS_ACCEL_GROUP (accel_group)' failed
mai 18 21:21:12 LDLC-MANJARO thunderbird.desktop[2026]: Unsupported modifier, resource creation failed.
mai 18 21:21:12 LDLC-MANJARO thunderbird.desktop[2026]: XXX: resource creation failed
mai 18 21:21:13 LDLC-MANJARO gnome-shell[1686]: Unhandled promise rejection. To suppress this warning, add an error handler to your promise chain with .catch() or a try-catch block around your await expression. Stack trace of the failed promise:
refreshPropertyOnProxy@/home/antoinetrin/.local/share/gnome-shell/extensions/appindicatorsupport@rgcjonas.gmail.com/util.js:41:38
_translateNewSignals/<@/home/antoinetrin/.local/share/gnome-shell/extensions/appindicatorsupport@rgcjonas.gmail.com/appIndicator.js:206:18
_translateNewSignals@/home/antoinetrin/.local/share/gnome-shell/extensions/appindicatorsupport@rgcjonas.gmail.com/appIndicator.js:205:50
_onProxySignal/<@/home/antoinetrin/.local/share/gnome-shell/extensions/appindicatorsupport@rgcjonas.gmail.com/appIndicator.js:222:56
_onProxySignal@/home/antoinetrin/.local/share/gnome-shell/extensions/appindicatorsupport@rgcjonas.gmail.com/appIndicator.js:222:38
mai 18 21:21:13 LDLC-MANJARO io.element.Element.desktop[2422]: [2422:0518/212113.124492:ERROR:gl_surface_presentation_helper.cc(260)] GetVSyncParametersIfAvailable() failed for 2 times!
mai 18 21:21:13 LDLC-MANJARO io.element.Element.desktop[2422]: [2422:0518/212113.140954:ERROR:gl_surface_presentation_helper.cc(260)] GetVSyncParametersIfAvailable() failed for 3 times!
mai 18 21:21:15 LDLC-MANJARO thunderbird.desktop[2026]: Unsupported modifier, resource creation failed.
mai 18 21:21:15 LDLC-MANJARO thunderbird.desktop[2026]: XXX: resource creation failed
mai 18 21:21:18 LDLC-MANJARO tutanota-desktop.desktop[2631]: [2631:0518/212118.291050:ERROR:browser_main_loop.cc(267)] Gtk: gtk_widget_add_accelerator: assertion 'GTK_IS_ACCEL_GROUP (accel_group)' failed
mai 18 21:21:18 LDLC-MANJARO riseup-vpn_launcher.desktop[2005]: 2022/05/18 21:21:18 Got sorted gateways: [zarapito.riseup.net mouette.riseup.net fournier.riseup.net hirondelle.riseup.net hoatzin.riseup.net pie.riseup.net redshank.riseup.net hornero.riseup.net mockingjay.riseup.net shag.riseup.net starling.riseup.net yal.riseup.net gaei.riseup.net crane.riseup.net limpkin.riseup.net garza.riseup.net]
mai 18 21:21:35 LDLC-MANJARO kernel: [UFW BLOCK] IN=wlp0s20f3 OUT= MAC= SRC=fe80:0000:0000:0000:9168:574c:8c9a:85f1 DST=ff12:0000:0000:0000:0000:0000:0000:8384 LEN=357 TC=0 HOPLIMIT=1 FLOWLBL=965707 PROTO=UDP SPT=45895 DPT=21027 LEN=317
mai 18 21:22:05 LDLC-MANJARO kernel: [UFW BLOCK] IN=wlp0s20f3 OUT= MAC= SRC=fe80:0000:0000:0000:9168:574c:8c9a:85f1 DST=ff12:0000:0000:0000:0000:0000:0000:8384 LEN=573 TC=0 HOPLIMIT=1 FLOWLBL=965707 PROTO=UDP SPT=45895 DPT=21027 LEN=533
mai 18 21:22:32 LDLC-MANJARO kernel: [UFW BLOCK] IN=wlp0s20f3 OUT= MAC=01:00:5e:00:00:01:7c:16:89:d1:57:7c:08:00 SRC=192.168.1.254 DST=224.0.0.1 LEN=32 TOS=0x00 PREC=0xA0 TTL=1 ID=58715 DF PROTO=2
mai 18 21:22:35 LDLC-MANJARO kernel: [UFW BLOCK] IN=wlp0s20f3 OUT= MAC= SRC=fe80:0000:0000:0000:9168:574c:8c9a:85f1 DST=ff12:0000:0000:0000:0000:0000:0000:8384 LEN=573 TC=0 HOPLIMIT=1 FLOWLBL=965707 PROTO=UDP SPT=45895 DPT=21027 LEN=533
mai 18 21:23:05 LDLC-MANJARO kernel: [UFW BLOCK] IN=wlp0s20f3 OUT= MAC= SRC=fe80:0000:0000:0000:9168:574c:8c9a:85f1 DST=ff12:0000:0000:0000:0000:0000:0000:8384 LEN=573 TC=0 HOPLIMIT=1 FLOWLBL=965707 PROTO=UDP SPT=45895 DPT=21027 LEN=533
mai 18 21:23:06 LDLC-MANJARO org.gnome.Nautilus[4009]: ModuleNotFoundError: No module named 'syncthing-plugin-nautilus'
mai 18 21:23:08 LDLC-MANJARO appindicatorsupport@rgcjonas.gmail.com[1686]: unable to update icon for Nextcloud
mai 18 21:23:11 LDLC-MANJARO gedit[4102]: Error loading plugin: libvoikko.so.1: Ne peut ouvrir le fichier d'objet partagé: Aucun fichier ou dossier de ce type
mai 18 21:23:11 LDLC-MANJARO gedit[4102]: Error loading plugin: libnuspell.so.5: Ne peut ouvrir le fichier d'objet partagé: Aucun fichier ou dossier de ce type
mai 18 21:23:11 LDLC-MANJARO gedit[4102]: Error loading plugin: libhspell.so.0: Ne peut ouvrir le fichier d'objet partagé: Aucun fichier ou dossier de ce type
mai 18 21:23:12 LDLC-MANJARO gnome-shell[1686]: meta_window_set_stack_position_no_sync: assertion 'window->stack_position >= 0' failed
mai 18 21:23:35 LDLC-MANJARO kernel: [UFW BLOCK] IN=wlp0s20f3 OUT= MAC= SRC=fe80:0000:0000:0000:9168:574c:8c9a:85f1 DST=ff12:0000:0000:0000:0000:0000:0000:8384 LEN=573 TC=0 HOPLIMIT=1 FLOWLBL=965707 PROTO=UDP SPT=45895 DPT=21027 LEN=533
mai 18 21:24:05 LDLC-MANJARO kernel: [UFW BLOCK] IN=wlp0s20f3 OUT= MAC= SRC=fe80:0000:0000:0000:9168:574c:8c9a:85f1 DST=ff12:0000:0000:0000:0000:0000:0000:8384 LEN=573 TC=0 HOPLIMIT=1 FLOWLBL=965707 PROTO=UDP SPT=45895 DPT=21027 LEN=533
mai 18 21:24:35 LDLC-MANJARO kernel: [UFW BLOCK] IN=wlp0s20f3 OUT= MAC= SRC=fe80:0000:0000:0000:9168:574c:8c9a:85f1 DST=ff12:0000:0000:0000:0000:0000:0000:8384 LEN=573 TC=0 HOPLIMIT=1 FLOWLBL=965707 PROTO=UDP SPT=45895 DPT=21027 LEN=533
mai 18 21:25:05 LDLC-MANJARO kernel: [UFW BLOCK] IN=wlp0s20f3 OUT= MAC= SRC=fe80:0000:0000:0000:9168:574c:8c9a:85f1 DST=ff12:0000:0000:0000:0000:0000:0000:8384 LEN=573 TC=0 HOPLIMIT=1 FLOWLBL=965707 PROTO=UDP SPT=45895 DPT=21027 LEN=533
mai 18 21:25:35 LDLC-MANJARO kernel: [UFW BLOCK] IN=wlp0s20f3 OUT= MAC= SRC=fe80:0000:0000:0000:9168:574c:8c9a:85f1 DST=ff12:0000:0000:0000:0000:0000:0000:8384 LEN=573 TC=0 HOPLIMIT=1 FLOWLBL=965707 PROTO=UDP SPT=45895 DPT=21027 LEN=533
mai 18 21:26:05 LDLC-MANJARO kernel: [UFW BLOCK] IN=wlp0s20f3 OUT= MAC= SRC=fe80:0000:0000:0000:9168:574c:8c9a:85f1 DST=ff12:0000:0000:0000:0000:0000:0000:8384 LEN=573 TC=0 HOPLIMIT=1 FLOWLBL=965707 PROTO=UDP SPT=45895 DPT=21027 LEN=533
Thanks !
